10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
02-HH3C-MPLSLSPV-MIB
02-HH3C-MPLSLSPV-MIB 52.81 KB
HH3C-MPLSLSPV-MIB
About this MIB
Use this MIB to notify LSPV traps.
MIB file name
hh3c-mplslspv.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsLspv(241)
Scalar objects
hh3cMplsLspvBaseInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsLspvBaseInfo (1.3.6.1.4.1.25506.2.241.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (0..127)
Basic LSPV information
As per the MIB.
Notifications
hh3cMplsLspvPingProbe
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.241.0.1
LSP ping test
Informational
Major
ON
Notification triggers
This notification is generated when the device receives LSP ping packets and the reply mode is no reply.
System impact
No negative impact on the system.
Status control
None
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.241.1.1.1 (hh3cMplsLspvBaseInfo)
N/A
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cMplsLspvTracertProbe
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.241.0.2
LSP tracert test
Informational
Major
ON
This notification is generated when the device receives LSP tracert packets and the reply mode is no reply.
System impact
Status control
None
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
