10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
03-HH3C-MPLSSCRLSP-MIB
03-HH3C-MPLSSCRLSP-MIB 101.62 KB
HH3C-MPLSSCRLSP-MIB
About this MIB
Use this MIB to manage static CRLSP notifications.
MIB file name
hh3c-mplsscrlsp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsScrlsp(231)
Scalar objects
hh3cMplsScrlspBaseInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsScrlspBaseInfo (1.3.6.1.4.1.25506.2.231.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (1..127)
Static CRLSP basic information.
As per the MIB.
hh3cMplsScrlspExtInfo
Object (OID)
Access
Value range
Implementation
hh3cMplsScrlspExtInfo (1.3.6.1.4.1.25506.2.231.1.1.2)
OCTET STRING
Static CRLSP extended information.
As per the MIB.
Notifications
hh3cMplsScrlspDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.231.0.1
A static CRLSP went down.
Error
Major
1.3.6.1.4.1.25506.2.231.0.2 (hh3cMplsScrlspUp)
OFF
Notification triggers
This notification might be generated when the following events occur:
·     MPLS disabled on an interface.
·     MPLS TE disabled on an interface.
·     Route change.
·     Tunnel binding associated with the CR-LSP deleted.
·     Inbound interface Down.
·     Outbound interface Down.
·     Tunnel associated with the static CR-LSP has been shut down.
·     Static CR-LSP configuration update.
·     The bound ring is invalid.
·     Others.
System impact
·     Service interruption will occur on services that use the static CRLSP for traffic forwarding.
·     No negative impact will occur on services that do not use the static CRLSP for traffic forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable te-private scrlsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private scrlsp-up-down command.
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
Standard MIB values.
N/A
OCTET STRING
Recommended action
To resolve this issue:
1.     Execute the display mpls interface command to check interface information.
If the alarm was generated at the ingress of the static CRLSP, check the outgoing interface. If the alarm was generated at the egress of the static CRLSP, check the incoming interface. If the alarm was generated at the transit node of the static CRLSP, check both the incoming interface and outgoing interface. In the command output, verify that the corresponding interface exists and the interface status is Up.
¡     If the interface status is not Up, check and correct the interface configuration.
¡     If the corresponding interface is not displayed in the command output, it indicates that MPLS is not enabled on the interface. Enable MPLS on the interface. If MPLS TE is not enabled on the interface, enable MPLS TE on the interface.
2.     Check whether the alarms have been cleared.
¡     If yes, the issue has been resolved.
¡     If not, go to step 3.
3.     Execute the display current-configuration interface tunnel interface-name command on the ingress to verify that the tunnel configuration is correct.
¡     If the configuration is correct, go to step 4.
¡     If the destination address of the corresponding tunnel is different from the destination address of the static CRLSP, enter tunnel interface view and use the destination command to change the tunnel destination address.
¡     If the signaling type of the tunnel is not static, use the mpls te signaling static command to set the tunnel signaling type to static.
4.     If the bandwidth attribute is configured on the static CRLSP, execute the display current-configuration interface interface-name command to check the maximum bandwidth and maximum reserved bandwidth configuration of the outgoing interface.
¡     If the configuration is correct, go to step 5.
¡     If the available bandwidth of the outgoing interface is smaller than the bandwidth required by the static CRLSP, enter the interface view of the outgoing interface. In the interface view, execute the mpls te bandwidth max-reservable-bandwidth command to increase the bandwidth of the outgoing interface.
5.     Check whether the alarms have been cleared.
¡     If not, go to step 6.
6.     If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
hh3cMplsScrlspUp
Basic information
OID
Event
Severity
Default status
A static CRLSP came up.
Recovery
Major
N/A
OFF
This notification is generated when a static CRLSP comes up.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
No action is required.
hh3cMplsScrlspLabelConflict
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.231.0.3
SR label conflict
Error
Major
(1.3.6.1.4.1.25506.2.231.0.4)
hh3cMplsScrlspLabelDup
OFF
The requested Segment Routing label has been occupied.
System impact
The label request failed.
Status control
ON
CLI: Use the snmp-agent trap enable te-private scrlsp-lab-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable te-private scrlsp-lab-conflict command.
Objects
OID (object name)
Index nodes
Value range
Basic information of the static CRLSP
N/A
OCTET STRING
Extended information of the static CRLSP
N/A
OCTET STRING
Recommended action
1.     Delete the configuration for the occupied label to release the label.
2.     Request an unused label.
3.     If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The incoming label of the static CRLSP is already used by a static PW or static LSP.
Error
Major
N/A
OFF
1.     MPLS is enabled and then a static CRLSP is configured with an incoming label that has been used by an existing static PW or static LSP.
2.     A static CRLSP is configured with an incoming label that has been used by an existing static PW or static LSP, and then MPLS is enabled.
System impact
The incoming label request failed.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
