10-MPLS
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10010-MPLS
04-HH3C-EVC-MIB
04-HH3C-EVC-MIB 78.98 KB
HH3C-EVC-MIB
About this MIB
Use this MIB to configure EVC related settings.
MIB file name
hh3c-evc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEvc(106)
Tabular objects
hh3cEvcScalarGroup
About this table
Use this table to obtain global EVC information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstEncapCapabilities (1.3.6.1.4.1.25506.2.106.1.1.1)
read-only
BITS
encapDefault(0),
encapUntagged(1),
encapTagged(2),
encapSvlanId(3),
encapSvlanIdList(4),
encapSvlanIdOnlyTagged(5),
encapSvlanIdCvlanId(6),
encapSvlanIdCvlanIdList(7),
encapCvlanId(8),
encapCvlanIdList(9)
Capabilities of the EVC service instance.
As per the MIB.
hh3cEvcPortMaxSrvInstNum (1.3.6.1.4.1.25506.2.106.1.1.2)
read-only
Integer32
Integer32 (1..2147483647)
Maximum number of EVC service instances supported on a port.
As per the MIB.
hh3cEvcSrvInstTable
About this table
Use this table to create and delete EVC service instances.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are ifIndex and hh3cEvcSrvInstId.
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstId (1.3.6.1.4.1.25506.2.106.1.2.1.1)
not-accessible
Integer32
Service instance ID.
As per the MIB.
hh3cEvcSrvInstEncap (1.3.6.1.4.1.25506.2.106.1.2.1.2)
read-create
INTEGER
none(0),
default(1),
untagged(2),
tagged(3),
svlanIdList(4),
svlanIdListOnlyTagged(5),
svlanIdCvlanId(6),
svlanIdCvlanIdList(7),
svlanIdCvlanIdAll(8),
cvlanIdList(9)
Encapsulation type of the service instance.
As per the MIB.
hh3cEvcSrvInstSvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.3)
read-create
OCTET STRING
OCTET STRING (0..256)
Low bit of the SVLAN list.
As per the MIB.
hh3cEvcSrvInstSvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.4)
read-create
OCTET STRING
High bit of the SVLAN list.
As per the MIB.
hh3cEvcSrvInstRowStatus (1.3.6.1.4.1.25506.2.106.1.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports active(1), createAndGo(4), and destroy(6).
hh3cEvcSrvInstEnableInStat (1.3.6.1.4.1.25506.2.106.1.2.1.6)
read-create
TruthValue
true(1),
false(2)
Inbound statistics function.
Supports only the read operation.
The set operation will be ignored.
hh3cEvcSrvInstEnableOutStat (1.3.6.1.4.1.25506.2.106.1.2.1.7)
read-create
TruthValue
true(1),
false(2)
Outbound statistics function.
hh3cEvcSrvInstCvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.8)
read-create
OCTET STRING
Low bit of the CVLAN list.
As per the MIB.
hh3cEvcSrvInstCvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.9)
read-create
OCTET STRING
High bit of the CVLAN list.
As per the MIB.
hh3cEvcSrvInstInRewriteType (1.3.6.1.4.1.25506.2.106.1.2.1.10)
read-create
INTEGER
none(0),
nestSvlan(1),
nestCvlan(2),
nestSvlanCvlan(3),
stripSvlan(4,
stripCvlan(5),
stripSvlanCvlan(6),
remark1To1(7),
remark1To2(8),
remark2To1(9),
remark2To2(10),
Rewrite type in inbound direction.
hh3cEvcSrvInstInRewriteSvlanId (1.3.6.1.4.1.25506.2.106.1.2.1.11)
read-create
Integer32
Integer32 (1..4094)
Inbound SVLAN ID to rewrite.
hh3cEvcSrvInstInRewriteCvlanId (1.3.6.1.4.1.25506.2.106.1.2.1.12)
read-create
Integer32
Integer32 (1..4094)
Inbound CVLAN ID to rewrite
hh3cEvcSrvInstInRewriteSymm (1.3.6.1.4.1.25506.2.106.1.2.1.13)
read-create
TruthValue
true(1),
false(2)
Inbound Symmetric parameter setting, indicating whether to perform reverse label operations for outbound packets.
hh3cEvcSrvInstOutRewriteType (1.3.6.1.4.1.25506.2.106.1.2.1.14)
read-create
INTEGER
none(0),
nestSvlan(1),
nestCvlan(2),
nestSvlanCvlan(3),
stripSvlan(4,
stripCvlan(5),
stripSvlanCvlan(6),
remark1To1(7),
remark1To2(8),
remark2To1(9),
remark2To2(10),
Rewrite type in outbound direction.
hh3cEvcSrvInstOutRewriteSvlanId (1.3.6.1.4.1.25506.2.106.1.2.1.15)
read-create
Integer32
Integer32 (1..4094)
Outbound SVLAN ID to rewrite.
hh3cEvcSrvInstOutRewriteCvlanId (1.3.6.1.4.1.25506.2.106.1.2.1.16)
read-create
Integer32
Integer32 (1..4094)
Outbound CVLAN ID to rewrite.
hh3cEvcSrvInstCarTable
About this table
Use this table to configure CAR for EVC service instances.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstInCarIndex (1.3.6.1.4.1.25506.2.106.1.3.1.1)
read-write
Integer32
Global CAR index in the inbound direction.
hh3cEvcSrvInstOutCarIndex (1.3.6.1.4.1.25506.2.106.1.3.1.2)
read-write
Integer32
Global CAR index in the outbound direction.
hh3cEvcSrvInstStatInfoTable
About this table
Use this table to obtain forwarding statistics about an EVC service instance.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cEvcSrvInstInPackets (1.3.6.1.4.1.25506.2.106.1.4.1.1)
read-only
Counter64
Counter64 (0..18446744073709551615)
Number of packets received on this service instance.
As per the MIB.
hh3cEvcSrvInstInBytes (1.3.6.1.4.1.25506.2.106.1.4.1.2)
read-only
Counter64
Number of bytes received on this service instance.
As per the MIB.
hh3cEvcSrvInstOutPackets (1.3.6.1.4.1.25506.2.106.1.4.1.3)
read-only
Counter64
Number of packets transmitted on this service instance.
As per the MIB.
hh3cEvcSrvInstOutBytes (1.3.6.1.4.1.25506.2.106.1.4.1.4)
read-only
Counter64
Number of bytes transmitted on this service instance.
As per the MIB.
