06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
29-P-BRIDGE-MIB
29-P-BRIDGE-MIB 51.19 KB
P-BRIDGE-MIB
About this MIB
Use this table to manage the priorities and multicast filtering defined in IEEE 802.1D-1998.
MIB file name
Rfc4363-pbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2().dod1dBridge(17).pBridgeMIB(6)
Scalar objects
dot1dDeviceCapabilities
Object (OID)
Access
Value range
Implementation
dot1dDeviceCapabilities (1.3.6.1.2.1.17.6.1.1.1)
read-only
BITS
dot1dExtendedFilteringServices(0),
dot1dTrafficClasses(1),
dot1qStaticEntryIndividualPort(2),
dot1qIVLCapable(3),
dot1qSVLCapable(4),
dot1qHybridCapable(5),
dot1qConfigurablePvidTagging(6),
dot1dLocalVlanCapable(7)
Device capabilities.
As per the MIB.
dot1dTrafficClassesEnabled
Object (OID)
Access
Value range
Implementation
dot1dTrafficClassesEnabled (1.3.6.1.2.1.17.6.1.1.2)
read-write
TruthValue
true(1),
false(2)
Whether traffic classification is supported.
Read-only.
dot1dGmrpStatus
Object (OID)
Access
Value range
Implementation
dot1dGmrpStatus (1.3.6.1.2.1.17.6.1.1.3)
read-write
EnabledStatus
enabled(1),
disabled(2)
GMRP enabling state.
Not supported
Tabular objects
dot1dPortCapabilitiesTable
About this table
Use this table to obtain the port capability set parameters on the local device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is dot1dBasePort.
The OID of this table is 1.3.6.1.2.1.17.6.1.1.4.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.17.6.1.1.4.1.1)
read-only
BITS
dot1qDot1qTagging(0) ,
dot1qConfigurableAcceptableFrameTypes(1) ,
dot1qIngressFiltering(2)
Port capabilities.
As per the MIB.
