06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
25-LLDP-EXT-DOT3-MIB
25-LLDP-EXT-DOT3-MIB 120.62 KB
LLDP-EXT-DOT3-MIB
About this MIB
LLDP facilitates network management to discover and use network physical topology in a standard way, and enables network management to discover configuration inconsistencies or errors that affect the upper-layer applications. H3C products support LLDP.
LLDP-EXT-DOT3-MIB is a standard public MIB, one of the four MIBs available for LLDP, which also include LLDP-MIB, LLDP-EXT-DOT1-MIB, and LLDP-MED-MIB. This MIB is the IEEE 802.3 organizationally defined neighbor discovery MIB, an extension for LLDP-MIB. This MIB contains IEEE 802.3 organizationally specific LLDP configuration, IEEE 802.3 organizationally specific local LLDP information, and IEEE 802.3 organizationally specific LLDP information received from the neighboring devices.
MIB file name
lldp-ext-dot3.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXdot3MIB(4623)
The root object is the LLDP management information base extension module for discovery information defined by the IEEE 802.3 organization.
Tabular objects
lldpXdot3PortConfigTable
About this table
This table controls selection of LLDP TLVs to be transmitted on individual ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index islldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.5.4623.1.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot3PortConfigTLVsTxEnable (1.0.8802.1.1.2.1.5.4623.1.1.1.1.1)
read-write
BITS
BITS {macPhyConfigStatus(0),
powerViaMDI(1),
linkAggregation(2),
maxFrameSize(3)}
IEEE 802.3 organizationally specific optional TLVs whose transmission is enabled on the ports.
By default, each bit is set to 1, which indicates that all IEEE 802.3 organizationally specific TLVs can be transmitted on a given port.
Link aggregation TLVs are defined as 802.1 organizationally specific TLVs.
lldpXdot3LocPortTable
About this table
This table contains information about 802.3 organizationally specific TLVs on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpLocPortNum.
The table OID is 1.0.8802.1.1.2.1.5.4623.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpXdot3LocPortAutoNegSupported (1.0.8802.1.1.2.1.5.4623.1.2.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given local port supports autonegotiation.
As per the MIB.
lldpXdot3LocPortAutoNegEnabled (1.0.8802.1.1.2.1.5.4623.1.2.1.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether autonegotiation is enabled on the given local port.
As per the MIB.
lldpXdot3LocPortAutoNegAdvertisedCap (1.0.8802.1.1.2.1.5.4623.1.2.1.1.3)
read-only
OCTET STRING
OCTET STRING (2)
Autonegotiation capability on the given local port.
As per the MIB.
lldpXdot3LocPortOperMauType (1.0.8802.1.1.2.1.5.4623.1.2.1.1.4)
read-only
Integer32
Integer32(0..2147483647)
Operational MAU type of the given local port.
As per the MIB.
lldpXdot3LocPowerTable
About this table
This table contains information about power supply capabilities of the local ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.2.2.
Object (OID)
Access
Value range
Implementation
lldpXdot3LocPowerPortClass (1.0.8802.1.1.2.1.5.4623.1.2.2.1.1)
read-only
LldpPowerPortClass
Standard MIB values.
Port class (PSE or PD) of the local port.
As per the MIB.
lldpXdot3LocPowerMDISupported (1.0.8802.1.1.2.1.5.4623.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the MDI power is supported on the given local port.
As per the MIB.
lldpXdot3LocPowerMDIEnabled (1.0.8802.1.1.2.1.5.4623.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the MDI power is enabled on the given local port.
As per the MIB.
lldpXdot3LocPowerPairControlable (1.0.8802.1.1.2.1.5.4623.1.2.2.1.4)
read-only
TruthValue
true(1),
false(2)
Indicates whether the pair selection can be controlled on the given local port.
As per the MIB.
lldpXdot3LocPowerPairs (1.0.8802.1.1.2.1.5.4623.1.2.2.1.5)
read-only
Integer32
Integer32(1|2)
Current pair on the given local port.
As per the MIB.
lldpXdot3LocPowerClass (1.0.8802.1.1.2.1.5.4623.1.2.2.1.6)
read-only
Integer32
Integer32(1|2|3|4|5)
Power supply capability or power consumption on the given local port.
As per the MIB.
lldpXdot3LocLinkAggTable
About this table
This table contains information about link aggregation information on the local ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.2.3.
Object (OID)
Access
Value range
Implementation
lldpXdot3LocLinkAggStatus (1.0.8802.1.1.2.1.5.4623.1.2.3.1.1)
read-only
LldpLinkAggStatusMap
Link aggregation capabilities and current aggregation status of the link.
As per the MIB.
lldpXdot3LocLinkAggPortId (1.0.8802.1.1.2.1.5.4623.1.2.3.1.2)
read-only
Integer32
Integer32(0|1..2147483647)
Aggregate interface ID.
As per the MIB.
lldpXdot3LocMaxFrameSizeTable
About this table
This table contains one row per port of maximum frame size information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.2.4.
Object (OID)
Access
Value range
Implementation
lldpXdot3LocMaxFrameSize (1.0.8802.1.1.2.1.5.4623.1.2.4.1.1)
read-only
Integer32
Integer32(0..65535)
The maximum supported frame size on the given local port.
As per the MIB.
lldpXdot3RemPortTable
About this table
This table contains port information of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.5.4623.1.3.1.
Object (OID)
Access
Value range
Implementation
lldpXdot3RemPortAutoNegSupported (1.0.8802.1.1.2.1.5.4623.1.3.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port of a neighboring device supports autonegotiation.
As per the MIB.
lldpXdot3RemPortAutoNegEnabled (1.0.8802.1.1.2.1.5.4623.1.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether autonegotiation is enabled on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPortAutoNegAdvertisedCap (1.0.8802.1.1.2.1.5.4623.1.3.1.1.3)
read-only
OCTET STRING
SIZE(2)
Autonegotiation capability on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPortOperMauType (1.0.8802.1.1.2.1.5.4623.1.3.1.1.4)
read-only
Integer32
Operational MAU type of the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPowerTable
About this table
This table contains power supply information of the ports on the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.3.2.
Object (OID)
Access
Value range
Implementation
lldpXdot3RemPowerPortClass (1.0.8802.1.1.2.1.5.4623.1.3.2.1.1)
read-only
LldpPowerPortClass
Port class (PSE or PD) of the given port on a neighboring device.
As per the MIB.
lldpXdot3RemPowerMDISupported (1.0.8802.1.1.2.1.5.4623.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port on the neighboring device supports the MDI power.
As per the MIB.
lldpXdot3RemPowerMDIEnabled (1.0.8802.1.1.2.1.5.4623.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the MDI power is enabled on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPowerPairControlable (1.0.8802.1.1.2.1.5.4623.1.3.2.1.4)
read-only
TruthValue
true(1),
false(2)
Indicates whether the pair selection can be controlled on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPowerPairs (1.0.8802.1.1.2.1.5.4623.1.3.2.1.5)
read-only
Integer32
Integer32(1|2)
Current pair on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemPowerClass (1.0.8802.1.1.2.1.5.4623.1.3.2.1.6)
read-only
Integer32
Power supply capability or power consumption on the given port of the neighboring device.
As per the MIB.
lldpXdot3RemLinkAggTable
About this table
This table contains information about link aggregation information on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.3.3.
Object (OID)
Access
Value range
Implementation
lldpXdot3RemLinkAggStatus (1.0.8802.1.1.2.1.5.4623.1.3.3.1.1)
read-only
As per the MIB.
lldpXdot3RemLinkAggPortId (1.0.8802.1.1.2.1.5.4623.1.3.3.1.2)
read-only
Integer32
Aggregate interface ID on the neighboring devices.
As per the MIB.
lldpXdot3RemMaxFrameSizeTable
About this table
This table contains one row per port of maximum frame size information on the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.0.8802.1.1.2.1.5.4623.1.3.4.
Object (OID)
Access
Value range
Implementation
lldpXdot3RemMaxFrameSize (1.0.8802.1.1.2.1.5.4623.1.3.4.1.1)
read-only
Integer32
Integer32(0..65535)
The maximum supported frame size on the given port of the neighboring device.
As per the MIB.
