06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
22-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
22-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB 69.62 KB
About this MIB
Use this MIB to obtain information about EVB TLV configuration.
MIB file name
lldp-ext-dot1-evb-extensions.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962).lldpXdot1StandAloneExtensions(7).lldpXDot1EvbExtensions(1)
This MIB is LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information for the EVB extension objects.
Tabular objects
lldpXdot1EvbConfigEvbTable
About this table
This table configures the transmission of EVB TLVs on a set of ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1EvbConfigEvbTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable EVB TLV transmission.
As per the MIB.
lldpXdot1EvbConfigCdcpTable
About this table
This table configures the transmission of CDCP TLVs on a set of ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1EvbConfigCdcpTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable CDCP TLV transmission.
As per the MIB.
lldpV2Xdot1LocEvbTlvTable
About this table
This table contains information about local EVB TLVs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpV2LocPortIfIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.1.1)
read-only
OCTET STRING
OCTET STRING (0..514)
Local EVB TLV information.
As per the MIB.
lldpV2Xdot1LocCdcpTlvTable
About this table
This table contains information about local CDCP TLVs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index islldpV2LocPortIfIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.1.1)
read-only
OCTET STRING
Local CDCP TLV information.
As per the MIB.
lldpV2Xdot1RemEvbTlvTable
About this table
This table contains information about EVB TLVs received from the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.1.1)
read-only
OCTET STRING
Information about EVB TLVs from neighboring devices.
As per the MIB.
lldpV2Xdot1RemCdcpTlvTable
About this table
This table contains information about CDCP TLVs received from the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.1.1)
read-only
OCTET STRING
Information about CDCP TLVs from neighboring devices.
As per the MIB.
