- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-QINQV2-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-HH3C-LswMSTP-MIB
- 16-HH3C-LswVLAN-MIB
- 17-IEEE8021-CFM-MIB
- 18-IEEE8021-CFM-V2-MIB
- 19-IEEE8023-LAG-MIB
- 20-LLDP-EXT-MED-MIB
- 21-LLDP-EXT-DOT3-V2-MIB
- 22-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 23-LLDP-EXT-DOT1-MIB
- 24-LLDP-EXT-DOT1-V2-MIB
- 25-LLDP-EXT-DOT3-MIB
- 26-LLDP-MIB
- 27-LLDP-V2-MIB
- 28-MAU-MIB
- 29-P-BRIDGE-MIB
- 30-Q-BRIDGE-MIB
- 31-RBRIDGE-MIB
| 11-HH3C-QINQV2-MIB | 50.03 KB |
HH3C-QINQV2-MIB
About this MIB
Use this MIB to manage, configure, and obtain 802.1Q in 802.1Q (QinQ) information.
MIB file name
hh3c-qinqv2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQinQv2(137)
Scalar objects
hh3cQinQv2ServiceTPID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2ServiceTPID (1.3.6.1.4.1.25506.2.137.1.1.1) |
read-write |
Integer32 |
Integer32 (1..65535) |
SVLAN TPID |
Implementation varies by product |
hh3cQinQv2CustomerTPID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2CustomerTPID (1.3.6.1.4.1.25506.2.137.1.1.2) |
read-write |
Integer32 |
CVLAN TPID |
Tabular objects
hh3cQinQv2IfCfgTable
About this table
Use this table to enable QinQ, set the CVLAN TPID and SVLAN TPID, and configure VLAN transparent transmission on a port.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cQinQv2IfState (1.3.6.1.4.1.25506.2.137.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
This variable is used to enable or disable QinQ on the port. |
hh3cQinQv2IfServiceTPID (1.3.6.1.4.1.25506.2.137.1.2.1.2) |
read-write |
Integer32 |
SVLAN TPID on the port. |
hh3cQinQv2IfCustomerTPID (1.3.6.1.4.1.25506.2.137.1.2.1.3) |
read-write |
Integer32 |
CVLAN TPID on the port. |
hh3cQinQv2IfTransparentVlanList (1.3.6.1.4.1.25506.2.137.1.2.1.4) |
read-write |
OCTET STRING |
OCTET STRING (512) |
List of transparent VLANs the port. |
