06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
04-HH3C-LLDP-EXT-MIB
04-HH3C-LLDP-EXT-MIB 126.22 KB
HH3C-LLDP-EXT-MIB
About this MIB
The Link Layer Discovery Protocol (LLDP) is a Layer 2 industry-standard protocol (IEEE 802.1AB) that allows network devices from different vendors to discover neighbors and exchange system and configuration information.
This MIB defines private MIB objects for the following extended LLDP management features:
·     Global LLDP configuration:
¡     Global status of LLDP.
¡     Global status of CDP compatibility.
·     LLDP port configuration:
¡     Port-specific packet transmission settings of CDP-compatible LLDP.
¡     Protection action taken on ports whose neighbors fail validation.
¡     Protection action taken on ports whose neighbors age out.
·     LLDP neighbor validation criteria:
¡     Chassis ID subtype.
¡     Chassis ID.
¡     Port ID subtype.
¡     Port ID.
·     Feature status on LLDP-enabled ports:
¡     Neighbor validation status.
¡     Neighbor aging status.
·     Trapping configuration on LLDP-enabled ports:
¡     Trapping for neighbor validation status changes.
¡     Trapping for neighbor aging status changes.
MIB file name
hh3c-lldp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).huawei.h3c(10).h3cCommon(2).h3clldp(100)
Scalar objects
hh3clldpAdminStatus
Object (OID)
Access
Value range
Implementation
hh3clldpAdminStatus
(1.3.6.1.4.1.25506.2.100.1.1.1)
read-write
TruthValue
true(1)
false(2)
As per the MIB.
hh3clldpComplianceCDPStatus
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.2)
read-write
TruthValue
true(1)
false(2)
Not supported.
Fixed at 2.
hh3clldpManAddr
Object (OID)
Access
Value range
Implementation
hh3clldpManAddr
(1.3.6.1.4.1.25506.2.100.3.1)
accessible-for-notify
OCTET STRING
OCTET STRING (0..31)
Management address.
As per the MIB.
Tabular objects
hh3clldpPortConfigTable
About this table
Use this table to configure LLDP on ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3clldpPortConfigPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.3.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.3.1.1)
not-accessible
LldpPortNumber
Standard MIB values.
Port index.
As per the MIB.
hh3clldpPortConfigCDPComplianceStatus
(1.3.6.1.4.1.25506.2.100.1.1.3.1.2)
read-write
INTEGER
txAndRx(1)
disabled(2)
Packet transmission capabilities of CDP-compatible LLDP.
As per the MIB.
hh3clldpPortConfigValidationAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.3)
read-write
Integer32
As per the MIB.
hh3clldpPortConfigAgingAction
(1.3.6.1.4.1.25506.2.100.1.1.3.1.4)
read-write
Integer32
As per the MIB.
hh3clldpNbIdentityTable
About this table
Use this table to configure neighbor validation criteria.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3clldpNbIdentityPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.4.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.4.1.1)
not-accessible
LldpPortNumber
Port index.
As per the MIB.
hh3clldpNbIdentityChassisIDSubtype
(1.3.6.1.4.1.25506.2.100.1.1.4.1.2)
read-write
INTEGER
default(0)
chassisComponent(1)
interfaceAlias(2)
portComponent(3)
macAddress(4)
networkAddress(5)
interfaceName(6)
local(7)
Chassis ID subtype.
As per the MIB.
(1.3.6.1.4.1.25506.2.100.1.1.4.1.3)
read-write
OCTET STRING
OCTET STRING (0..255)
Chassis ID.
As per the MIB.
hh3clldpNbIdentityPortIDSubtype
(1.3.6.1.4.1.25506.2.100.1.1.4.1.4)
read-write
INTEGER
default(0)
interfaceAlias(1)
portComponent(2)
macAddress(3)
networkAddress(4)
interfaceName(5)
agentCircuitId(6)
local(7)
Port ID subtype.
As per the MIB.
(1.3.6.1.4.1.25506.2.100.1.1.4.1.5)
read-write
OCTET STRING
Port ID.
As per the MIB.
hh3clldpNbIdentityRowStatus
(1.3.6.1.4.1.25506.2.100.1.1.4.1.6)
read-create
RowStatus
Row status.
As per the MIB.
hh3clldpPortStatusTable
About this table
Use this table to obtain status of features on LLDP-enabled ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3clldpPortStatusPortNum.
The table OID is 1.3.6.1.4.1.25506.2.100.1.1.5.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.100.1.1.5.1.1)
LldpPortNumber
Port index.
As per the MIB.
hh3clldpPortValidationStatus
(1.3.6.1.4.1.25506.2.100.1.1.5.1.2)
read-only
Integer32
As per the MIB.
hh3clldpPortAgingStatus
(1.3.6.1.4.1.25506.2.100.1.1.5.1.3)
read-only
Integer32
As per the MIB.
hh3clldpRemManAddrTable
About this table
Use this table to display neighbor management addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, lldpRemManAddrSubtype, and lldpRemManAddr.
The table OID is 1.3.6.1.4.1.25506.2.100.1.2.1.
Object (OID)
Access
Value range
Implementation
hh3clldpRemManAddrSubtype
(1.3.6.1.4.1.25506.2.100.1.2.1.1.1)
read-only
AddressFamilyNumbers
Encoding format.
As per the MIB.
hh3clldpRemManAddr
(1.3.6.1.4.1.25506.2.100.1.2.1.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
Management address.
As per the MIB.
hh3clldpRemManAddrIfSubtype
(1.3.6.1.4.1.25506.2.100.1.2.1.1.3)
read-only
LldpManAddrIfSubtype
LLDP neighbor port numbers.
As per the MIB.
hh3clldpRemManAddrIfId
(1.3.6.1.4.1.25506.2.100.1.2.1.1.4)
read-only
Integer32
Port number.
As per the MIB.
hh3clldpRemManAddrOID
(1.3.6.1.4.1.25506.2.100.1.2.1.1.5)
read-only
OBJECT IDENTIFIER
OID.
Not supported.
Notifications
hh3clldpValidationStatusChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.100.2.0.1
Neighbor validation status changes.
Informational
Warning
OFF
Notification triggers
LLDP neighbor validation enables a port to validate the identity of the neighbor based on the neighbor validation criteria configured on the port. Each incoming LLDP packet must match all the validation criteria configured on the port. If the neighbor information in a packet does not match the criteria, the system shuts down the data link layer and disables data transmission on the port.
System impact
No negative impact on services.
Status control
ON
CLI: Use the lldp neighbor-protection validation command.
OFF
CLI: Use the undo lldp neighbor-protection validation command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.100.1.1.5.1.1 (hh3clldpPortStatusPortNum)
Port index.
LldpPortNumber
1.3.6.1.4.1.25506.2.100.1.1.5.1.2 (hh3clldpPortValidationStatus)
Integer32
Recommended action
1.     Verify that the neighbor matches all neighbor validation criteria configured on the port.
2.     If the neighbor does not match all neighbor validation criteria configured on the port, notify the administrator of the neighbor to configure LLDP related settings to establish the LLDP neighbor relationship.
3.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3clldpAgingStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.100.2.0.2
Neighbor aging status changes.
Informational
Warning
N/A
OFF
The system blocks or shuts down an LLDP neighbor aging-enabled port if the neighbor on the port ages out.
System impact
Status control
ON
CLI: Use the lldp neighbor-protection aging { block | shutdown } command.
OFF
CLI: Use the undo lldp neighbor-protection aging command.
Objects
OID (object name)
Index nodes
Value range
Port index.
LldpPortNumber
1.3.6.1.4.1.25506.2.100.1.1.5.1.3 (hh3clldpPortAgingStatus)
N/A
Integer32
Recommended action
Identify whether a neighbor has aged out.
hh3clldpGlobalEnableStatus
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.100.2.0.3
Enabling status of LLDP changes globally.
Informational
Warning
ON
This notification is generated when the enabling status of LLDP changes globally.
System impact
No impact on services.
Status control
ON
CLI: Use the lldp global enable command.
OFF
CLI: Use the undo lldp global enable command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.100.1.1.1 (hh3clldpAdminStatus)
Enabling status of LLDP on the device.
N/A
TruthValue
Recommended action
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
hh3clldpgLocManAddrChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.100.2.0.4
Management address advertised by LLDP changes.
Informational
Warning
ON
This notification is generated when the management address advertised by LLDP changes.
System impact
Status control
ON
CLI: Use the lldp tlv-enable basic-tlv management-address-tlv command.
OFF
CLI: Use the undo lldp tlv-enable basic-tlv management-address-tlv command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.100.3.1 (hh3clldpManAddr)
Management address.
N/A
OCTET STRING
Recommended action
If the LLDP management address to be advertised is incorrect, execute the lldp tlv-enable basic-tlv management-address-tlv command on the port to change the LLDP management address to be advertised.
