- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-QINQV2-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-HH3C-LswMSTP-MIB
- 16-HH3C-LswVLAN-MIB
- 17-IEEE8021-CFM-MIB
- 18-IEEE8021-CFM-V2-MIB
- 19-IEEE8023-LAG-MIB
- 20-LLDP-EXT-MED-MIB
- 21-LLDP-EXT-DOT3-V2-MIB
- 22-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 23-LLDP-EXT-DOT1-MIB
- 24-LLDP-EXT-DOT1-V2-MIB
- 25-LLDP-EXT-DOT3-MIB
- 26-LLDP-MIB
- 27-LLDP-V2-MIB
- 28-MAU-MIB
- 29-P-BRIDGE-MIB
- 30-Q-BRIDGE-MIB
- 31-RBRIDGE-MIB
| 06-HH3C-LswMAM-MIB | 63.48 KB |
HH3C-LswMAM-MIB
About this MIB
Use this MIB to configure unicast MAC address entries.
MIB file name
hh3c-splat-mam.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswMAM(3)
Tabular objects
hh3cdot1qTpFdbSetTable
About this table
Use this table to configure unicast MAC address entries.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cdot1qVlanIndex and hh3cdot1qTpFdbSetAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qTpFdbSetAddress (1.3.6.1.4.1.25506.8.35.3.2.1.1) |
not-accessible |
MacAddress |
Standard MIB values. |
Unicast MAC address entry. |
As per the MIB. |
hh3cdot1qTpFdbSetPort (1.3.6.1.4.1.25506.8.35.3.2.1.2) |
read-write |
InterfaceIndex |
Index of the interface corresponding to the MAC address entry. |
The object value is 0 when the state of the MAC address entry is blackhole. |
hh3cdot1qTpFdbSetStatus (1.3.6.1.4.1.25506.8.35.3.2.1.3) |
read-write |
INTEGER |
other(1), learned(3), static(6), dynamic(7), blackhole(9), security(11) |
MAC address entry state. |
A MAC address entry configured with the dynamic type will be added to the learned MAC address entry list. |
hh3cdot1qTpFdbSetOperate (1.3.6.1.4.1.25506.8.35.3.2.1.4) |
read-write |
INTEGER |
add(1), delete(2) |
Add or delete a MAC address entry. |
The object can only be written. |
