- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-M-LAG configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-QinQ configuration
- 11-VLAN mapping configuration
- 12-Loop detection configuration
- 13-Spanning tree configuration
- 14-LLDP configuration
- 15-L2PT configuration
- 16-Service loopback group configuration
- 17-Cut-through Layer 2 forwarding configuration
16-Service loopback group configuration | 48.02 KB |
Configuring service loopback groups
Restrictions and guidelines: Service loopback group configuration
Configuring a service loopback group
Display and maintenance commands for service loopback groups
About service loopback groups
When you apply service loopback groups to features, follow these restrictions and guidelines:
· You can apply a service loopback group to a feature once the group is created. The service loopback group will process services for the feature.
· Do not delete a service loopback group that is being used by a feature.
1. Enter system view.
2. Create a service loopback group and specify its service type.
service-loopback group group-id type vsi-gateway
You can configure only one service loopback group for a service type.
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ group-id ] |
