03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-64H Switch Command References-Release 6715-6W10003-Layer 2—LAN Switching Command Reference
16-Service loopback group commands
16-Service loopback group commands 59.30 KB
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5                Service type: Tunnel
  Member                            Status
  HundredGigE1/0/1                  Selected
  HundredGigE1/0/2                  Unselected
Group ID
Service loopback group ID.
Service type
Service type of the service loopback group:
·     Inter-VPN-fwd—Supports inter-VPN forwarding services.
·     Multicast-tunnel—Supports multicast tunnel services.
·     Tunnel—Supports unicast tunnel services.
·     Multiport—Supports multiport ARP services.
·     VSI-gateway—Supports VSI gateway services.
·     Telemetry-stream—Supports Telemetry streaming services.
Member
Member ports of the service loopback group.
Status
Member port state:
·     Unselected—The port is in Unselected state. An unselected port cannot forward traffic of the service type.
·     Selected—The port is in Selected state. A selected port can forward traffic of the service type.
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
CAUTION
CAUTION:
·     When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network.
·     Do not execute this command on an IRF physical interface if that interface is the only member interface of an IRF port. Doing so will split the IRF fabric, because this command also removes the binding of the physical interface and IRF port.
·     For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group. You can assign a maximum of 32 ports to a service loopback group.
# Assign HundredGigE 1/0/1 to service loopback group 5.
[Sysname-HundredGigE1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type { inter-vpn-fwd | { multicast-tunnel | tunnel } * | multiport | telemetry-stream | vsi-gateway }
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
inter-vpn-fwd: Specifies inter-VPN forwarding services.
multicast-tunnel: Specifies multicast tunnel services.
tunnel: Specifies unicast tunnel services.
multiport: Specifies multiport ARP services.
telemetry-stream: Specifies Telemetry streaming services.
vsi-gateway: Specifies VSI gateway services.
Service loopback groups must work with other features. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
You can configure only one service loopback group for a service type. You cannot change the service type of a service loopback group.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify unicast tunnel services for the group.
[Sysname] service-loopback group 5 type tunnel
