03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-64H Switch Command References-Release 6715-6W10003-Layer 2—LAN Switching Command Reference
11-VLAN mapping commands
11-VLAN mapping commands 73.93 KB
VLAN mapping and Ethernet service instance-to-VSI binding are mutually exclusive on a Layer 2 Ethernet interface or Layer 2 aggregate interface. Do not configure both features on the same interface. Otherwise, the features cannot take effect.
display vlan mapping
Use display vlan mapping to display VLAN mapping information.
display vlan mapping [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays VLAN mapping information on all interfaces.
# Display VLAN mapping information on all interfaces.
<Sysname> display vlan mapping
Interface HundredGigE1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10            N/A           120                      N/A
Interface HundredGigE1/0/2:
  1024-4094     N/A           100                      N/A
Interface HundredGigE1/0/3:
  12            N/A           110                      12
Interface HundredGigE1/0/4:
  11            30            130                      40
Outer VLAN
Original outer VLAN.
This field indicates the original VLAN for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
Inner VLAN
Original inner VLAN.
This field displays N/A for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
Translated outer VLAN.
This field indicates the translated VLAN for one-to-one VLAN mapping, two-to-one VLAN mapping, and many-to-one VLAN mapping.
Translated inner VLAN.
This field displays N/A for one-to-one VLAN mapping, two-to-one VLAN mapping, and many-to-one VLAN mapping.
vlan mapping
vlan mapping
Use vlan mapping to configure VLAN mapping on an interface.
Use undo vlan mapping to cancel the VLAN mapping configuration.
vlan mapping { vlan-id translated-vlan vlan-id | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id }
undo vlan mapping { vlan-id translated-vlan vlan-id | all | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id}
No VLAN mapping is configured on an interface.
vlan-id translated-vlan vlan-id: Specifies the original VLAN and translated VLAN for a one-to-one VLAN mapping. The value range for the vlan-id argument is 1 to 4094. The original VLAN and the translated VLAN cannot be the same.
uni range vlan-range-list translated-vlan vlan-id: Specifies the original VLAN ranges and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-range-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. The value range for the vlan-id argument is 1 to 4094. Different VLAN ranges cannot overlap. Any of the original VLANs cannot be the same as the translated VLAN.
uni single vlan-id-list translated-vlan vlan-id: Specifies the original VLANs and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN IDs, each of which is in the range of 1 to 4094. The value range for the vlan-id argument is 1 to 4094. Any of the original VLANs cannot be the same as the translated VLAN.
nni: Configures the network-side port to use the original VLAN tags of the many-to-one mapping to replace the VLAN tags of the packets destined for the user network.
nest range vlan-range-list nested-vlan vlan-id: Specifies the CVLAN ranges and the SVLAN for a one-to-two VLAN mapping. The vlan-range-list argument specifies a space-separated list of up to 8 CVLAN items. Each item specifies a CVLAN ID or a range of CVLAN IDs in the format of vlan-id1 to vlan-id2. The value range for CVLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. Different CVLAN ranges cannot overlap. The vlan-id argument specifies the SVLAN ID in the range of 1 to 4094.
nest single vlan-id-list nested-vlan vlan-id: Specifies the CVLANs and the SVLAN for a one-to-two VLAN mapping. The vlan-id-list argument specifies a space-separated list of up to 10 CVLAN IDs, each of which is in the range of 1 to 4094. The vlan-id argument specifies the SVLAN ID in the range of 1 to 4094.
tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id: Specifies the original outer VLAN ID, original inner VLAN ID, translated outer VLAN ID, and translated inner VLAN ID for a two-to-two VLAN mapping. The value ranges for the outer-vlan-id argument and the inner-vlan-id argument are both 1 to 4094.
all: Deletes all VLAN mapping configurations from the interface.
VLAN mapping takes effect only on VLAN-tagged packets received on an interface.
The original and translated VLANs in VLAN mappings on an interface must meet the following requirements:
·     Different types of VLAN mapping entries cannot include the same original VLANs or translated VLANs.
·     Different one-to-one or two-to-two VLAN mapping entries cannot include the same translated VLANs. If you configure multiple one-to-one or two-to-two VLAN mapping entries for the same original VLANs, the most recent configuration takes effect.
·     The translated CVLAN and SVLAN of a two-to-two VLAN mapping cannot be the same as the original CVLAN and SVLAN of a two-to-one VLAN mapping.
When using the vlan mapping nest range command to configure a one-to-two VLAN mapping on the same interface, you can only configure up to 8 pairs of CVLAN ranges and the SVLAN for the one-to-two VLAN mapping. To add a one-to-two VLAN mapping, use the vlan mapping nest single command.
When you configure many-to-one VLAN mappings, following these restrictions and guidelines:
·     For many-to-one VLAN mapping to take effect, configure many-to-one VLAN mapping in pairs on both the customer side and the network side.
·     An interface cannot be configured as the customer-side port and network-side port of many-to-one VLAN mapping at the same time.
·     After you configure an interface as the network-side interface of many-to-one VLAN mapping, do not configure the other types of VLAN mapping on the interface.
·     To ensure correct traffic forwarding from the service provider network to the customer network, do not configure many-to-one VLAN mappings together with uRPF. For more information about uRPF, see Security Configuration Guide.
VLAN mapping and the MAC learning limit cannot be configured on the same interface. If you configured both features on an interface, the feature configured later does not take effect.
The configuration restrictions between QinQ and VLAN mappings are as follows:
·     Before you enable or disable QinQ on a port, you must remove all VLAN mappings on the port.
·     You cannot configure two-to-two VLAN mappings on a QinQ-enabled port.
If you use both transparent VLANs and VLAN mappings on an interface, the transparent VLANs cannot be the following VLANs:
·     Original or translated VLANs of one-to-one, many-to-one, and one-to-two VLAN mappings.
·     Original or translated outer VLANs of two-to-two VLAN mappings.
The MTU of an interface is 1500 bytes by default. After a VLAN tag is added to a packet, the packet length is added by 4 bytes. As a best practice, set the MTU to a minimum of 1504 bytes for ports on the forwarding path of the packet on the service provider network.
# Configure a one-to-one VLAN mapping on HundredGigE 1/0/1 to map VLAN 1 to VLAN 101.
[Sysname-HundredGigE1/0/1] vlan mapping 1 translated-vlan 101
# Configure many-to-one VLAN mappings on the customer-side port (HundredGigE 1/0/2) to map VLANs 1 through 50 and VLAN 80 to VLAN 101. Configure the network-side port (HundredGigE 1/0/3) to use the original VLAN tags of the many-to-one mappings to replace the VLAN tags of the packets destined for the user network.
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] vlan mapping uni range 1 to 50 translated-vlan 101
[Sysname-HundredGigE1/0/2] vlan mapping uni single 80 translated-vlan 101
[Sysname-HundredGigE1/0/2] quit
[Sysname] interface hundredgige 1/0/3
[Sysname-HundredGigE1/0/3] vlan mapping nni
# Configure one-to-two VLAN mappings on HundredGigE 1/0/4 to add SVLAN tag 101 to packets carrying VLAN tags 1 through 10 and VLAN tag 80.
[Sysname] interface hundredgige 1/0/4
[Sysname-HundredGigE1/0/4] vlan mapping nest range 1 to 10 nested-vlan 101
[Sysname-HundredGigE1/0/4] vlan mapping nest single 80 nested-vlan 101
# Configure a two-to-two VLAN mapping on HundredGigE 1/0/5 to map SVLAN 101 and CVLAN 1 to SVLAN 201 and CVLAN 10.
[Sysname] interface hundredgige 1/0/5
[Sysname-HundredGigE1/0/5] vlan mapping tunnel 101 1 translated-vlan 201 10
vlan mapping egress
Use vlan mapping egress to configure a two-to-one VLAN mapping on an interface.
Use undo vlan mapping egress to remove the two-to-one VLAN mapping configuration.
vlan mapping egress outer-vlan outer-vlan-id inner-vlan inner-vlan-id translated-vlan vlan-id
undo vlan mapping egress outer-vlan outer-vlan-id inner-vlan inner-vlan-id translated-vlan vlan-id
No two-to-one VLAN mapping is configured on an interface.
outer-vlan outer-vlan-id: Specifies the original SVLAN ID in the range of 1 to 4094.
inner-vlan inner-vlan-id: Specifies the original CVLAN ID in the range of 1 to 4094.
translated-vlan vlan-id: Specifies the translated VLAN ID in the range of 1 to 4094.
After you configure a two-to-one VLAN mapping, the device will replace original SVLAN and CVLAN tags of the matching double-tagged packets with one translated VLAN tag. When the device receives packets with the translated VLAN tag, it does not replace the VLAN tag with the original VLAN tags.
On an interface, the original CVLAN and SVLAN of a two-to-one VLAN mapping cannot be the same as the translated CVLAN and SVLAN of a two-to-two  VLAN mapping.
On an interface, the transparent VLAN cannot be the same as the original or translated VLANs in two-to-one VLAN mappings. For more information about transparent VLANs, see QinQ in Layer 2—LAN Switching Configuration Guide.
You cannot specify multiple translated CVLANs for the same original CVLAN and SVLAN on an interface. To modify an existing two-to-one VLAN mapping on an interface, you must execute the undo vlan mapping egress command to remove it first and then configure a new mapping.
# Configure a two-to-one VLAN mapping on HundredGigE 1/0/1 to replace SVLAN 20 and CVLAN 30 of the double-tagged packets with the translated VLAN 40.
[Sysname-HundredGigE1/0/1] vlan mapping egress outer-vlan 20 inner-vlan 30 translated-vlan 40
