- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-QINQV2-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-HH3C-LswMSTP-MIB
- 16-HH3C-LswVLAN-MIB
- 17-IEEE8021-CFM-MIB
- 18-IEEE8021-CFM-V2-MIB
- 19-IEEE8023-LAG-MIB
- 20-LLDP-EXT-MED-MIB
- 21-LLDP-EXT-DOT1-MIB
- 22-LLDP-EXT-DOT1-V2-MIB
- 23-LLDP-EXT-DOT3-MIB
- 24-LLDP-EXT-DOT3-V2-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-Q-BRIDGE-MIB
- 29-RBRIDGE-MIB
20-LLDP-EXT-MED-MIB | 170.53 KB |
LLDP-EXT-MED-MIB
About this MIB
Use this MIB to obtain TIA-TR41.4 Media Endpoint Discovery (MED) information.
MIB file name
lldp-ext-med.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXMedMIB(4795)
Scalar objects
lldpXMedLocDeviceClass
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocDeviceClass (1.0.8802.1.1.2.1.5.4795.1.1.1) |
read-only |
LldpXMedDeviceClass |
Standard MIB values. |
MED device class. |
As per the MIB. |
lldpXMedFastStartRepeatCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedFastStartRepeatCount (1.0.8802.1.1.2.1.5.4795.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (1..8) |
Number of times the fast start LLDPDU are being sent. |
As per the MIB. |
lldpXMedLocHardwareRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocHardwareRev (1.0.8802.1.1.2.1.5.4795.1.2.2) |
read-only |
SnmpAdminString |
OCTET STRING (0..32) |
Local hardware revision. |
As per the MIB. |
lldpXMedLocFirmwareRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.2.3) |
read-only |
SnmpAdminString |
Local firmware revision. |
As per the MIB. |
lldpXMedLocSoftwareRev
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.2.4) |
read-only |
SnmpAdminString |
Local software revision. |
As per the MIB. |
lldpXMedLocSerialNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocSerialNum (1.0.8802.1.1.2.1.5.4795.1.2.5) |
read-only |
SnmpAdminString |
Local serial number. |
As per the MIB. |
lldpXMedLocMfgName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocMfgName (1.0.8802.1.1.2.1.5.4795.1.2.6) |
read-only |
SnmpAdminString |
Local manufacturer name. |
As per the MIB. |
lldpXMedLocModelName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocModelName (1.0.8802.1.1.2.1.5.4795.1.2.7) |
read-only |
SnmpAdminString |
Local model name. |
As per the MIB. |
lldpXMedLocAssetID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocAssetID (1.0.8802.1.1.2.1.5.4795.1.2.8) |
read-only |
SnmpAdminString |
Local asset tracking identifier. |
As per the MIB. |
lldpXMedLocXPoEDeviceType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpxMedLocXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.2.10) |
read-only |
INTEGER |
unknown(1) pseDevice(2) pdDevice(3) none(4) |
Local PoE type. |
As per the MIB. |
lldpXMedLocXPoEPSEPowerSource
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.12) |
read-only |
INTEGER |
unknown(1) primary(2) backup(3) |
Local PSE power supply type. |
As per the MIB. |
lldpXMedLocXPoEPDPowerReq
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.2.13) |
read-only |
Gauge32 |
Power required by a PD. |
As per the MIB. |
lldpXMedLocXPoEPDPowerSource
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.14) |
read-only |
INTEGER |
unknown(1) fromPSE(2) local(3) localAndPSE(4) |
Local PD power supply type. |
As per the MIB. |
lldpXMedLocXPoEPDPowerPriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.2.15) |
read-only |
INTEGER |
unknown(1) critical(2) high(3) low(4) |
Local PD power priority. |
As per the MIB. |
Tabular objects
lldpXMedPortConfigTable
About this table
Use this table to configure MED on ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is lldpPortConfigPortNum.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.1.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedPortCapSupported (1.0.8802.1.1.2.1.5.4795.1.1.2.1.1) |
read-only |
LldpXMedCapabilities |
Supported MED TLVs. |
As per the MIB. |
lldpXMedPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.2) |
read-write |
Enabled MED TLVs. |
By default, the networkPolicy bit is set to 0. On a port operating in bridging mode, the networkPolicy bit is set to 1. By default, the location and extendedPD bits are set to 0, and the other bits are set to 1. If the extendedPSE bit is set to 1 but a port does not support a capability, the bridge agents on the port does not send the related TLVs, and this bit is read-only. |
lldpXMedPortConfigNotifEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.3) |
read-write |
TruthValue |
true(1) false(2) |
LLDP-MED trapping status. |
As per the MIB. |
lldpXMedLocMediaPolicyTable
About this table
Use this table to obtain local media policy configuration.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpLocPortNum and lldpXMedLocMediaPolicyAppType.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.2.1.1.1) |
not-accessible |
PolicyAppType |
Media policy type. |
As per the MIB. |
lldpXMedLocMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.2.1.1.2) |
read-only |
Integer32 |
Integer32 (0|1..4094|4095) |
Media VLAN ID. |
As per the MIB. |
lldpXMedLocMediaPolicyPriority(1.0.8802.1.1.2.1.5.4795.1.2.1.1.3) |
read-only |
Integer32 |
Integer32 (0..7) |
Media policy priority. |
As per the MIB. |
lldpXMedLocMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.2.1.1.4) |
read-only |
Dscp |
DSCP value. |
As per the MIB. |
lldpXMedLocMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.2.1.1.5) |
read-only |
TruthValue |
true(1) false(2) |
Whether the media policy type is unknown. |
As per the MIB. |
lldpXMedLocMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.2.1.1.6) |
read-only |
TruthValue |
true(1) false(2) |
Whether packets of the media VLAN are tagged. |
As per the MIB. |
lldpXMedLocLocationTable
About this table
Use this table to configure the local location information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpLocPortNum and lldpXMedLocLocationSubtype.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.9.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocLocationSubtype (1.0.8802.1.1.2.1.5.4795.1.2.9.1.1) |
not-accessible |
LocationSubtype |
Local MED location type. |
Supports only civicAddress(3) and elin(4). |
lldpXMedLocLocationInfo (1.0.8802.1.1.2.1.5.4795.1.2.9.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Local MED location information. |
As per the MIB. |
lldpXMedLocXPoEPSEPortTable
About this table
Use this table to obtain PSE information on ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpLocPortNUm.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.2.11.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedLocXPoEPSEPortPowerAv (1.0.8802.1.1.2.1.5.4795.1.2.11.1.1) |
read-only |
Gauge32 |
Available PoE power on PSE ports. |
As per the MIB. |
lldpXMedLocXPoEPSEPortPDPriority (1.0.8802.1.1.2.1.5.4795.1.2.11.1.2) |
read-only |
INTEGER |
Unknown(1) Critical(2) High(3) Low(4) |
PSE port power priority. |
As per the MIB. |
lldpXMedRemCapabilitiesTable
About this table
Use this table to obtain the LLDP-MED capabilities of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemCapSupported (1.0.8802.1.1.2.1.5.4795.1.3.1.1.1) |
read-only |
As per the MIB. |
lldpXMedRemCapCurrent (1.0.8802.1.1.2.1.5.4795.1.3.1.1.2) |
read-only |
Sent MED TLVs. |
As per the MIB. |
lldpXMedRemDeviceClass (1.0.8802.1.1.2.1.5.4795.1.3.1.1.3) |
read-only |
MED device type. |
As per the MIB. |
lldpXMedRemMediaPolicyTable
About this table
Use this table to obtain the media policy configuration of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXMedRemMediaPolicyAppType.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.3.2.1.1) |
not-accessible |
PolicyAppType |
As per the MIB. |
lldpXMedRemMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.3.2.1.2) |
read-only |
Integer32 |
Media VLAN ID. |
As per the MIB. |
lldpXMedRemMediaPolicyPriority (1.0.8802.1.1.2.1.5.4795.1.3.2.1.3) |
read-only |
Integer32 |
Integer32 (0..7) |
As per the MIB. |
lldpXMedRemMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.3.2.1.4) |
read-only |
Dscp |
DSCP value. |
As per the MIB. |
lldpXMedRemMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.3.2.1.5) |
read-only |
TruthValue |
true(1) false(2) |
As per the MIB. |
lldpXMedRemMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.3.2.1.6) |
read-only |
TruthValue |
true(1) false(2) |
As per the MIB. |
lldpXMedRemInventoryTable
About this table
Use this table to obtain the inventory information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemHardwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.1) |
read-only |
SnmpAdminString |
Hardware revision. |
As per the MIB. |
lldpXMedRemFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.2) |
read-only |
SnmpAdminString |
Firmware revision. |
As per the MIB. |
lldpXMedRemSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.3) |
read-only |
SnmpAdminString |
Software revision. |
As per the MIB. |
lldpXMedRemSerialNum (1.0.8802.1.1.2.1.5.4795.1.3.3.1.4) |
read-only |
SnmpAdminString |
Serial number. |
As per the MIB. |
lldpXMedRemMfgName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.5) |
read-only |
SnmpAdminString |
Manufacturer name. |
As per the MIB. |
lldpXMedRemModelName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.6) |
read-only |
SnmpAdminString |
Model name. |
As per the MIB. |
lldpXMedRemAssetID (1.0.8802.1.1.2.1.5.4795.1.3.3.1.7) |
read-only |
SnmpAdminString |
Asset tracking identifier. |
As per the MIB. |
lldpXMedRemLocationTable
About this table
Use this table to obtain the location information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex ,and lldpXMedRemLocationSubtype.
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemLocationSubtype(1.0.8802.1.1.2.1.5.4795.1.3.4.1.1) |
not-accessible |
LocationSubtype |
As per the MIB. |
lldpXMedRemLocationInfo (1.0.8802.1.1.2.1.5.4795.1.3.4.1.2) |
read-only |
OCTET STRING |
As per the MIB. |
lldpXMedRemXPoETable
About this table
Use this table to obtain the PoE type of a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.5.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.3.5.1.1) |
read-only |
INTEGER |
PoE type. |
As per the MIB. |
lldpXMedRemXPoEPSETable
About this table
Use this table to obtain the PSE information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.6.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEPSEPowerAv (1.0.8802.1.1.2.1.5.4795.1.3.6.1.1) |
read-only |
Gauge32 |
As per the MIB. |
lldpXMedRemXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.6.1.2) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPSEPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.6.1.3) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPDTable
About this table
Use this table to obtain the PD information about a neighbor.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.0.8802.1.1.2.1.5.4795.1.3.7.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXMedRemXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.3.7.1.1) |
read-only |
Gauge32 |
As per the MIB. |
lldpXMedRemXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.7.1.2) |
read-only |
INTEGER |
As per the MIB. |
lldpXMedRemXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.7.1.3) |
read-only |
INTEGER |
As per the MIB. |
Notifications
lldpXMedTopologyChangeDetected
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.0.8802.1.1.2.1.5.4795.0.1 |
MED neighbor topology changes. |
Informational |
Warning |
OFF |
Notification triggers
This notification is generated when the device detects MED neighbor topology changes, such as attaching a peer device to the local device, disconnecting a peer device, or moving a peer device from one port to another port.
System impact
No negative impact on services.
Status control
ON
CLI: Use the lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to true (1).
OFF
CLI: Use the undo lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to false (2).
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.0.8802.1.1.2.1.4.1.1.4 (lldpRemChassisIdSubtype) |
Neighbor chassis ID type. |
lldpRemTimeMark lldpRemLocalPortNum lldpRemIndex |
LldpChassisIdSubtype |
1.0.8802.1.1.2.1.4.1.1.5 (lldpRemChassisId) |
Neighbor chassis ID. |
LldpChassisId |
1.0.8802.1.1.2.1.5.4795.1.3.1.1.3 (lldpXMedRemDeviceClass) |
Neighbor MED device class. |
Recommended action
Verify that the topology changes are as expected.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
