- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-QINQV2-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-HH3C-LswMSTP-MIB
- 16-HH3C-LswVLAN-MIB
- 17-IEEE8021-CFM-MIB
- 18-IEEE8021-CFM-V2-MIB
- 19-IEEE8023-LAG-MIB
- 20-LLDP-EXT-MED-MIB
- 21-LLDP-EXT-DOT1-MIB
- 22-LLDP-EXT-DOT1-V2-MIB
- 23-LLDP-EXT-DOT3-MIB
- 24-LLDP-EXT-DOT3-V2-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-Q-BRIDGE-MIB
- 29-RBRIDGE-MIB
09-HH3C-MLAG-MIB | 310.70 KB |
Table of Contents
hh3cMLagAutoRecoveryReloadDelay
hh3cMLagRoleLocalConfiguredRole
hh3cMLagRolePeerConfiguredRole
hh3cMLagRoleLocalEffectiveRole
hh3cMLagGlobalCheckConsistency
hh3cMLagGlobalCheckInConsistency
HH3C-MLAG-MIB
About this MIB
Multichassis Link Aggregation Group (M-LAG) virtualizes two physical devices into one system through multichassis link aggregation to provide node redundancy in addition to link redundancy.
HH3C-MLAG-MIB is a private MIB for managing M-LAG from an NMS. This MIB offers following functions: 1. Obtain and modify M-LAG system settings such as the M-LAG system MAC address, priority, and number. 2. Obtain and modify M-LAG keepalive settings. 3. Obtain information about and configure peer-link interfaces and M-LAG interfaces.
MIB file name
hh3c-mlag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cMLag(176)
Scalar objects
hh3cMLagSystemMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemMac (1.3.6.1.4.1.25506.2.176.1.1.1) |
read-write |
MacAddress |
OCTET STRING(6) |
M-LAG system MAC address. |
Default value: 0-0-0-0-0-0. |
hh3cMLagSystemPriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemPriority (1.3.6.1.4.1.25506.2.176.1.1.2) |
read-write |
Integer32 |
Integer32 (0..65535) |
M-LAG system priority. |
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system. |
hh3cMLagSystemNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagSystemNumber (1.3.6.1.4.1.25506.2.176.1.1.3) |
read-write |
Integer32 |
Integer32 (0..2) |
M-LAG system number. |
Default value: 0. |
hh3cMLagRestoreDelay
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRestoreDelay (1.3.6.1.4.1.25506.2.176.1.1.4) |
read-write |
Integer32 |
Integer32 (1..3600) |
Data restoration interval. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagAutoRecoveryReloadDelay (1.3.6.1.4.1.25506.2.176.1.1.5) |
read-write |
Integer32 |
Integer32 (0|240..3600) |
Reload delay for M-LAG system auto-recovery. |
A value of 0 indicates that M-LAG system auto-recovery is disabled. |
hh3cMLagRoleLocalRolePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalRolePriority (1.3.6.1.4.1.25506.2.176.1.2.1) |
read-write |
Integer32 |
The role priority of the local M-LAG member device. |
The smaller the priority value, the higher the priority. |
hh3cMLagRolePeerRolePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerRolePriority (1.3.6.1.4.1.25506.2.176.1.2.2) |
read-only |
Integer32 |
Role priority of the peer M-LAG member device. |
hh3cMLagRoleLocalBridgeMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.3) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC address of the local M-LAG member device. |
Default value: 0-0-0-0-0-0 |
hh3cMLagRolePeerBridgeMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.4) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC address of the peer M-LAG member device. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.5) |
read-only |
INTEGER |
none(0), primary(1), secondary(2) |
Specified role for the local M-LAG member device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.6) |
read-only |
INTEGER |
Specified role for the peer M-LAG member device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleLocalEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.7) |
read-only |
INTEGER |
Effective role for the local M-LAG member device. |
As per the MIB. |
hh3cMLagRolePeerEffectiveRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRolePeerEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.8) |
read-only |
INTEGER |
Effective role for the peer M-LAG member device. |
As per the MIB. |
hh3cMLagKeepaliveDestIpv4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveDestIpv4 (1.3.6.1.4.1.25506.2.176.1.3.1) |
read-write |
InetAddressIPv4 |
OCTET STRING(4) |
Destination IP address of keepalive packets. |
Default value: 0.0.0.0. |
hh3cMLagKeepaliveSourceIpv4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveSourceIpv4 (1.3.6.1.4.1.25506.2.176.1.3.2) |
read-write |
InetAddressIPv4 |
OCTET STRING(4) |
Source IP address of keepalive packets. |
Default value: 0.0.0.0. Configured with the destination IP address of keepalive packets. |
hh3cMLagKeepaliveDestIpv6
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveDestIpv6 (1.3.6.1.4.1.25506.2.176.1.3.3) |
read-write |
InetAddressIPv6 |
OCTET STRING(16) |
Destination IPv6 address of keepalive packets. |
Default value: 0:0::0:0. |
hh3cMLagKeepaliveSourceIpv6
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveSourceIpv6 (1.3.6.1.4.1.25506.2.176.1.3.4) |
read-write |
InetAddressIPv6 |
OCTET STRING(16) |
Source IPv6 address of keepalive packets. |
Default value: 0.0::0.0. Configured with the destination IPv6 address of keepalive packets. |
hh3cMLagKeepaliveUdpPort
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveUdpPort (1.3.6.1.4.1.25506.2.176.1.3.5) |
read-write |
Integer32 |
Integer32 (1..65535) |
Destination UDP port of keepalive packets. |
The destination UDP port is also deleted when the keepalive source and destination IP addresses are deleted. |
hh3cMLagKeepaliveInterval
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveInterval (1.3.6.1.4.1.25506.2.176.1.3.6) |
read-write |
Integer32 |
Integer32 (100..10000) |
M-LAG keepalive interval. |
As per the MIB. |
hh3cMLagKeepaliveTimeout
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveTimeout (1.3.6.1.4.1.25506.2.176.1.3.7) |
read-write |
Integer32 |
Integer32 (3..20) |
M-LAG keepalive timeout timer. |
The local M-LAG keepalive timeout timer must be at least two times the M-LAG keepalive interval of the peer. |
hh3cMLagKeepaliveHoldTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveHoldTime (1.3.6.1.4.1.25506.2.176.1.3.8) |
read-write |
Integer32 |
Integer32 (3..10) |
Keepalive hold timer. |
As per the MIB. |
hh3cMLagKeepaliveLinkStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepaliveLinkStatus (1.3.6.1.4.1.25506.2.176.1.3.9) |
read-only |
INTEGER |
unknown(1), up(2), down(3) |
Keepalive link status. |
As per the MIB. |
hh3cMLagVrf
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagVrf (1.3.6.1.4.1.25506.2.176.1.3.10) |
read-write |
OCTET STRING |
OCTET STRING(0..31) |
VPN instance name. |
If the M-LAG member device exists in a public network, the VPN instance name length is 0. |
hh3cMLagConsistencyType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagConsistencyType (1.3.6.1.4.1.25506.2.176.2.1.1) |
accessible-for-notify |
Integer32 |
type1(1) type2(2) |
Configuration consistency check. |
As per the MIB. |
hh3cMLagGroupIdForNotify
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagGroupIdForNotify(1.3.6.1.4.1.25506.2.176.2.1.2 ) |
Integer32 |
Integer32 (1..1024) |
M-LAG group ID. |
As per the MIB. |
hh3cMLagPortNotSelectedReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagPortNotSelectedReason (1.3.6.1.4.1.25506.2.176.2.1.3) |
OCTET STRING |
OCTET STRING(0..255) |
Reason why no selected member port exists for the M-LAG interface. |
As per the MIB. |
hh3cMLagKeepAliveDownReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagKeepAliveDownReason(1.3.6.1.4.1.25506.2.176.2.1.4 ) |
OCTET STRING |
Reason why the keepalive link goes down. |
As per the MIB. |
hh3cMLagMadDownReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagMadDownReason(1.3.6.1.4.1.25506.2.176.2.1.5 ) |
OCTET STRING |
Reason why the device is placed in M-LAG MAD DOWN state. |
As per the MIB. |
hh3cMLagOldRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagOldRole(1.3.6.1.4.1.25506.2.176.2.1.6 ) |
INTEGER |
Previous role for the device. |
As per the MIB. |
hh3cMLagNewRole
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagNewRole(1.3.6.1.4.1.25506.2.176.2.1.7 ) |
INTEGER |
New role for the device. |
As per the MIB. |
hh3cMLagRoleChangeReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagRoleChangeReason(1.3.6.1.4.1.25506.2.176.2.1.8 ) |
OCTET STRING |
Reason for the device role switching. |
As per the MIB. |
hh3cMLagVmacInEffectiveReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagVmacInEffectiveReason(1.3.6.1.4.1.25506.2.176.2.1.9) |
OCTET STRING |
Failure reason, which can only be insufficient hardware resources in the current software version. |
As per the MIB. |
hh3cMLagVirtualMac
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagVirtualMac(1.3.6.1.4.1.25506.2.176.2.1.10) |
MacAddress |
OCTET STRING(6) |
Virtual MAC address |
As per the MIB. |
Tabular objects
hh3cMLagPeerLinkTable
About this table
Use this table to obtain and configure parameters for peer-link interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMLagPeerLinkNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagPeerLinkNumber (1.3.6.1.4.1.25506.2.176.1.4.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2) |
Peer-link interface number. |
The peer-link interface number can only be 1. |
hh3cMLagPeerLinkIfIndex (1.3.6.1.4.1.25506.2.176.1.4.1.1.2) |
read-write |
InterfaceIndex |
Integer32 (1..2147483647) |
Index of the aggregate interface acting as the peer-link interface. |
As per the MIB. |
hh3cMLagPeerLinkRowStatus (1.3.6.1.4.1.25506.2.176.1.4.1.1.3) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only destroy(6). |
hh3cMLagPortTable
About this table
Use this table to configure and obtain parameters for M-LAG interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cMLagGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagGroupId (1.3.6.1.4.1.25506.2.176.1.4.2.1.1) |
not-accessible |
Integer32 |
M-LAG group ID. |
As per the MIB. |
hh3cMLagPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.2.1.2) |
read-write |
InterfaceIndex |
Index of the aggregate interface acting as the M-LAG interface. |
As per the MIB. |
hh3cMLagPortRowStatus (1.3.6.1.4.1.25506.2.176.1.4.2.1.3) |
read-create |
RowStatus |
Row status. |
hh3cMLagAllPortTable
About this table
Use this table to obtain and configure selected member port information, DRCP state, and the short DRCP timeout timer for peer-link interfaces and M-LAG interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMLagAllPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMLagAllPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.3.1.1) |
not-accessible |
InterfaceIndex |
Interface index |
As per the MIB. |
hh3cMLagPortDrcpIsShortPeriod (1.3.6.1.4.1.25506.2.176.1.4.3.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether the short DRCP timeout timer is enabled. |
As per the MIB. |
hh3cMLagPortPortStatus (1.3.6.1.4.1.25506.2.176.1.4.3.1.3) |
read-only |
INTEGER |
up(1), down(2) |
Interface status |
As per the MIB. |
hh3cMLagPortLocalDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.4) |
read-only |
OCTET STRING |
OCTET STRING(1) |
DRCP status on the local end. |
As per the MIB. |
hh3cMLagPortPeerDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.5) |
read-only |
OCTET STRING |
OCTET STRING(1) |
DRCP status on the peer end. |
As per the MIB. |
hh3cMLagPortLocalMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.6) |
read-only |
PortList |
Member list of the local aggregate interface. |
As per the MIB. |
hh3cMLagPortPeerMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.7) |
read-only |
PortList |
Member list of the peer aggregate interface. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.1 |
No inconsistency is detected during the global consistency check. |
Informational |
Warning |
OFF |
Notification triggers
This notification is generated if the consistency check result for global M-LAG settings is consistent.
System impact
No impact on services.
Status control
This notification cannot be disabled.
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.1 (hh3cMLagConsistencyType) |
Consistency check type. |
N/A |
Integer32 |
type1(1) type2(2) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.2 |
Inconsistency is detected during the global consistency check. |
Informational |
Warning |
OFF |
This notification is generated if the consistency check result for global M-LAG settings is inconsistent.
System impact
The M-LAG member devices have inconsistent type 1 or type 2 configuration. As a result, loops might occur, and traffic loss might persist even through the status of the M-LAG system is normal.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
N/A |
Integer32 |
type1(1) type2(2) |
Recommended action
To resolve the issue:
1. If the global consistency check for the type 1 configuration is inconsistent, use the display m-lag consistency command to view configuration information on the M-LAG member devices, and modify their configuration to ensure consistency.
2. If the global consistency check for the type 2 configuration is inconsistent, modify the configuration on the M-LAG member devices to ensure consistency.
hh3cMLagIfCheckConsistency
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.3 |
Consistency is detected during the consistency check on M-LAG interfaces. |
Informational |
Warning |
OFF |
This notification is generated if the consistency check result for M-LAG interfaces is consistent.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.1 hh3cMLagConsistencyType |
N/A |
Integer32 |
type1(1) type2(2) |
6.1.4.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
ifIndex |
Integer32 |
6.1.4.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
hh3cMLagIfCheckInConsistency
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.4 |
Inconsistency is detected during the consistency check on M-LAG interfaces. |
Informational |
Warning |
OFF |
This notification is generated if the consistency check result for M-LAG interfaces is inconsistent.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
N/A |
Integer32 |
type1(1) type2(2) |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
1. If the consistency check on M-LAG interfaces for the type 1 configuration is inconsistent, use the display m-lag consistency command to view configuration information on the M-LAG member devices, and modify their configuration to ensure consistency.
2. If the consistency check on M-LAG interfaces for the type 2 configuration is inconsistent, modify the configuration on the M-LAG member devices to ensure consistency.
hh3cMLagPortGlobalDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.5 |
M-LAG group goes down. |
Informational |
Warning |
OFF |
This notification is generated when all member ports of the M-LAG interfaces in the same M-LAG group become unselected.
System impact
Service traffic might be interrupted because all M-LAG interfaces are down.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.2 hh3cMLagGroupIdForNotify |
M-LAG group ID. |
N/A |
Integer32 |
Recommended action
1. Verify that the M-LAG system settings are configured and consistent, such as the M-LAG system MAC address, priority, and number.
2. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cMLagPortGlobalUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.6 |
M-LAG group comes up. |
Informational |
Warning |
OFF |
This notification is generated when member ports of the M-LAG interfaces in the same M-LAG group become selected.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
M-LAG group ID. |
N/A |
Integer32 |
Recommended action
hh3cMLagPortSelected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.7 |
A local M-LAG interface has selected member ports. |
Informational |
Warning |
OFF |
This notification is generated when member ports of a local M-LAG interface become selected.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
M-LAG group ID. |
N/A |
Integer32 |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
hh3cMLagPortNoSelected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.8 |
All member ports of a local M-LAG interface become unselected. |
Informational |
Warning |
OFF |
This notification is generated when all member ports of a local M-LAG interface become unselected because the M-LAG interface is shut down or fails.
System impact
Traffic will fail over to the peer M-LAG member device, and the load on that device will increase.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
M-LAG group ID. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.176.2.1.3 (hh3cMLagPortNotSelectedReason) |
N/A |
OCTET STRING |
Recommended action
1. Check settings on member ports of the aggregation group and the cable connection status.
hh3cMLagPortPeerNoSelected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.9 |
All member ports of a peer M-LAG interface become unselected. |
Informational |
Warning |
OFF |
This notification is generated when all member ports of a peer M-LAG interface become unselected because the M-LAG interface is shut down or fails.
System impact
Traffic will fail over to the local M-LAG member device, and the load on this device will increase.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
M-LAG group ID. |
N/A |
Integer32 |
Recommended action
1. Check settings on member ports of the peer aggregation group and the cable connection status.
hh3cMLagPortPeerSelected
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.10 |
A peer M-LAG interface has selected member ports. |
Informational |
Warning |
OFF |
This notification is generated when member ports of a peer M-LAG interface become selected.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
M-LAG group ID. |
N/A |
Integer32 |
Recommended action
To resolve the issue, check settings on member ports of the peer aggregation group and the cable connection status.
hh3cMLagPeerLinkUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.11 |
The peer-link interface comes up. |
Informational |
Warning |
OFF |
This notification is generated if DRCPDUs can be sent and received correctly between the M-LAG member devices.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
hh3cMLagPeerLinkDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.12 |
The peer-link interface goes down. |
Informational |
Warning |
OFF |
This notification is generated when the peer-link interface goes down because the peer link status is abnormal on the local or peer M-LAG member device.
System impact
· The M-LAG member devices might have inconsistent MAC or ARP entries and cannot forward traffic correctly.
· For a VXLAN M-LAG system, inconsistent ARP entries might be generated for gateways, and traffic cannot be forwarded correctly between subnets.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
Interface index |
ifIndex |
Integer32 |
Interface name |
ifIndex |
OCTET STRING |
Recommended action
1. Verify that the M-LAG system settings are configured and consistent, such as the M-LAG system MAC address, priority, number, authentication password, and sequence number check.
2. Check the state of Layer 2 aggregate interface configured as the peer-link interface.
3. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cMLagKeepaliveDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.13 |
The keepalive link goes down. |
Informational |
Warning |
OFF |
This notification is generated when the keepalive link goes down because the keepalive link status is abnormal or the keepalive source address is incorrect on the local or peer M-LAG member device.
System impact
Multi-active collision might does not take effect.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.4 hh3cMLagKeepAliveDownReason |
N/A |
OCTET STRING |
Recommended action
1. Check the device role.
2. Verify that the source and destination IP addresses of keepalive packets are consistent between the M-LAG member devices.
3. Check the state of the Layer 3 link used for keepalive detection.
4. Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cMLagKeepaliveUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.14 |
The keepalive link comes up. |
Informational |
Warning |
OFF |
This notification is generated if keepalive packets can be sent and received correctly between the M-LAG member devices.
System impact
Status control
Objects
Recommended action
hh3cMLagDeviceMadDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.15 |
The device is placed in M-LAG MAD DOWN state. |
Informational |
Warning |
OFF |
This notification is generated when service interfaces are shut down by M-LAG MAD and the peer link flaps.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.5 hh3cMLagMadDownReason |
N/A |
OCTET STRING |
Recommended action
1. Check settings on both ends of the peer link.
hh3cMLagDeviceMadRecovery
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.16 |
The device brings up service interfaces that are placed in M-LAG MAD DOWN state. |
Informational |
Warning |
OFF |
This notification is generated when the device brings up service interfaces that are placed in M-LAG MAD DOWN state.
System impact
Status control
Objects
Recommended action
hh3cMLagDeviceRoleChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.17 |
The M-LAG member device role is changed. |
Informational |
Warning |
OFF |
This notification is generated when the M-LAG member device role is changed because of one of the following reasons:
· M-LAG roles are assigned during M-LAG system initialization.
· No local M-LAG interface is available.
· The peer M-LAG member device fails.
· Role switchover occurs after calculation is performed over the peer link.
· No peer M-LAG interface is available.
· The peer link fails.
System impact
The M-LAG system is unstable, and traffic forwarding might be interrupted.
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.176.2.1.6 hh3cMLagOldRole |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.176.2.1.7 hh3cMLagNewRole |
N/A |
INTEGER |
1.3.6.1.4.1.25506.2.176.2.1.8 hh3cMLagRoleChangeReason |
Reason for the device role change. |
N/A |
OCTET STRING |
Recommended action
To resolve this issue:
1. Identify the cause of the role change. If the change is triggered by manual configuration, no action is required.
2. Verify that the peer link is operating correctly.
3. Verify that all M-LAG interfaces are operating correctly.
4. Verify that the M-LAG system settings are correct.
5. Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.176.2.0.18 |
Failed to add a virtual MAC address |
Informational |
Warning |
OFF |
This notification is generated upon failure to add a virtual MAC address because of insufficient hardware resources when you configure the virtual IP address and virtual MAC address for the M-LAG system on an interface.
System impact
Status control
Objects
OID |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
ifIndex |
Integer32 |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
ifIndex |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.176.2.1.10 (hh3cMLagVirtualMac) |
N/A |
MacAddress |
OCTET STRING (6) |
1.3.6.1.4.1.25506.2.176.2.1.8 (hh3cMLagVmacInEffectiveReason) |
N/A |
OCTET STRING |
Recommended action
Add hardware resources.
