- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-QINQV2-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-HH3C-LswMSTP-MIB
- 16-HH3C-LswVLAN-MIB
- 17-IEEE8021-CFM-MIB
- 18-IEEE8021-CFM-V2-MIB
- 19-IEEE8023-LAG-MIB
- 20-LLDP-EXT-MED-MIB
- 21-LLDP-EXT-DOT1-MIB
- 22-LLDP-EXT-DOT1-V2-MIB
- 23-LLDP-EXT-DOT3-MIB
- 24-LLDP-EXT-DOT3-V2-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-Q-BRIDGE-MIB
- 29-RBRIDGE-MIB
14-HH3C-VOICE-VLAN-MIB | 58.83 KB |
HH3C-VOICE-VLAN-MIB
About this MIB
Use this MIB to configure voice VLAN. You can assign interfaces connecting to voice devices to a voice VLAN. Then, the system automatically modifies the QoS parameters for the voice packets to improve the priority of voice packets and ensure voice quality. Implementation varies by product.
MIB file name
hh3c-voice-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVoiceVlan(9)
Scalar objects
hh3cVoiceVlanAgingTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVoiceVlanAgingTime (1.3.6.1.4.1.25506.2.9.4) |
read-write |
Integer32 |
Integer32 (0|5..43200) |
Voice VLAN aging time. |
As per the MIB. |
hh3cVoiceVlanSecurityState
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVoiceVlanSecurityState (1.3.6.1.4.1.25506.2.9.6) |
read-write |
INTEGER |
security (1), normal (2) |
Voice VLAN security mode state. |
As per the MIB. |
Tabular objects
hh3cvoiceVlanOuiTable
About this table
Use this table to configure the OUI addresses that can be recognized by the voice VLAN.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cVoiceVlanOuiAddress. When you use the hh3cVoiceVlanOuiRowStatus to create a row, you must specify the hh3cVoiceVlanOuiMask object and can leave the hh3cVoiceVlanOuiDescription object empty.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVoiceVlanOuiAddress (1.3.6.1.4.1.25506.2.9.1.1.1) |
read-only |
MacAddress |
OCTET STRING (6) |
OUI address of the voice VLAN. |
As per the MIB. |
hh3cVoiceVlanOuiMask (1.3.6.1.4.1.25506.2.9.1.1.2) |
read-write |
MacAddress |
OCTET STRING (6) |
Mask for the OUI address of the voice VLAN. |
This object cannot be specified separately. |
hh3cVoiceVlanOuiDescription (1.3.6.1.4.1.25506.2.9.1.1.3) |
read-write |
OCTET STRING |
OCTET STRING (0..30) |
Description on the OUI address of the voice VLAN. |
The first letter of the description cannot be a space. |
hh3cVoiceVlanOuiRowStatus (1.3.6.1.4.1.25506.2.9.1.1.4) |
read-create |
RowStatus |
Standard MIB values. |
Row state of the OUI address of the voice VLAN. |
As per the MIB. |
hh3cvoiceVlanPortTable
About this table
Use this table to configure the voice VLAN features, for example, configure the voice VLAN operating mode, configure an interface to trust the priority of packets in a voice VLAN, and modify the CoS and DSCP values for packets in a voice VLAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cVoiceVlanPortifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVoiceVlanPortifIndex (1.3.6.1.4.1.25506.2.9.7.1.1) |
not-accessible |
Integer32 |
Integer32(1..2147483647) |
Index of a port in a voice VLAN. |
As per the MIB. |
hh3cVoiceVlanPortMode (1.3.6.1.4.1.25506.2.9.7.1.2) |
read-write |
INTEGER |
auto (1), manual (2) |
Voice VLAN assignment mode of a port. |
As per the MIB. |
hh3cVoiceVlanPortLegacy (1.3.6.1.4.1.25506.2.9.7.1.3) |
read-write |
TruthValue |
Voice VLAN configuration legacy status on a port. |
Not supported |
hh3cVoiceVlanPortQosTrust (1.3.6.1.4.1.25506.2.9.7.1.4) |
read-write |
TruthValue |
QoS settings on a port in a voice VLAN. |
Not supported |
