06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
03-HH3C-LAG-MIB
03-HH3C-LAG-MIB 314.67 KB
HH3C-LAG-MIB
About this MIB
This MIB contains information in ieee8023-lag.mib and hh3c-lag.mib.
MIB file name
hh3c-lag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cLAG(25)
Scalar objects
hh3cAggResourceAllocationValue
Object (OID)
Access
Value range
Implementation
hh3cAggResourceAllocationValue (1.3.6.1.4.1.25506.8.25.1.3)
read-only
Octets
OCTET STRING (1)
Whether link aggregation is implemented by Huawei or H3C.
As per the MIB.
hh3cAggPortName
Object (OID)
Access
Value range
Implementation
hh3cAggPortName (1.3.6.1.4.1.25506.8.25.4.1)
accessible-for-notify
OCTET_STRING
OCTET_STRING (0..255)
Aggregate interface name.
As per the MIB.
hh3cAggMemberPortName
Object (OID)
Access
Value range
Implementation
hh3cAggMemberPortName (1.3.6.1.4.1.25506.8.25.4.2)
OCTET_STRING
Aggregation member port name.
As per the MIB.
hh3cAggOldPduInfo
Object (OID)
Access
Value range
Implementation
hh3cAggOldPduInfo (1.3.6.1.4.1.25506.8.25.4.3)
OCTET_STRING
OCTET_STRING (0..512)
Old PDU information.
As per the MIB.
hh3cAggNewPduInfo
Object (OID)
Access
Value range
Implementation
hh3cAggNewPduInfo (1.3.6.1.4.1.25506.8.25.4.4)
OCTET_STRING
New PDU information.
As per the MIB.
hh3cAggPduChangeCode
Object (OID)
Access
Value range
Implementation
hh3cAggPduChangeCode (1.3.6.1.4.1.25506.8.25.4.5)
OCTET_STRING
Changed PDU information.
As per the MIB.
hh3cAggTotalActiveNum
Object (OID)
Access
Value range
Implementation
hh3cAggTotalActiveNum (1.3.6.1.4.1.25506.8.25.4.6)
Integer32
1..2147483647
Number of selected ports.
As per the MIB.
hh3cAggUpThreshold
Object (OID)
Access
Value range
Implementation
hh3cAggUpThreshold (1.3.6.1.4.1.25506.8.25.4.7)
Integer32
1..2147483647
Maximum number of selected ports.
As per the MIB.
hh3cAggReasonCode
Object (OID)
Access
Value range
Implementation
hh3cAggReasonCode (1.3.6.1.4.1.25506.8.25.4.8)
OCTET_STRING
Cause of change.
As per the MIB.
hh3cAggChangeType
Object (OID)
Access
Value range
Implementation
hh3cAggChangeType (1.3.6.1.4.1.25506.8.25.4.9)
INTEGER
unknown(1)
join(2)
leave(3)
Aggregation member port change type.
As per the MIB.
Tabular objects
hh3cAggLinkTable
About this table
This table contains aggregation group information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cAggLinkNumber.
Object (OID)
Access
Value range
Implementation
hh3cAggLinkNumber (1.3.6.1.4.1.25506.8.25.1.1.1.1)
Integer32
Standard MIB values.
Aggregation group ID.
As per the MIB.
hh3cAggLinkName (1.3.6.1.4.1.25506.8.25.1.1.1.2)
read-create
DisplayString
SIZE (0..32)
Aggregation group name.
Not supported
hh3cAggLinkMode (1.3.6.1.4.1.25506.8.25.1.1.1.3)
read-create
INTEGER
manual(1)
static(2)
dynamic(3)
Aggregation mode.
Supports only 2 and 3.
hh3cAggLinkPortList (1.3.6.1.4.1.25506.8.25.1.1.1.4)
read-create
PortList
OCTET STRING (0..255)
Aggregation member ports.
As per the MIB.
hh3cAggLinkState (1.3.6.1.4.1.25506.8.25.1.1.1.5)
read-create
RowStatus
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
hh3cAggPortListSelectedPorts (1.3.6.1.4.1.25506.8.25.1.1.1.6)
read-only
PortList
Selected member ports.
As per the MIB.
hh3cAggPortListSamePartnerPorts (1.3.6.1.4.1.25506.8.25.1.1.1.7)
read-only
PortList
Member ports attached to the same peer.
As per the MIB.
A value of the PortList type specifies a list of ports in the format of an octet string. Each octet specifies eight ports. Within each octet, the most significant bit represents the lowest-numbered port, and the least significate bit represents the highest-numbered port. Thus, each port of the device is represented by a single bit within the value of this object. If that bit has a value of 1, then that port is included in the set of ports. The port is not included if its bit has a value of 0.
Example:
hh3cAggLinkPortList.1 (PortList) 00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.34 (hex)
Hexadecimal string 00 indicates that no ports are included in an octet. The last octet is 34 in hexadecimal format and 00110100 in binary format. Therefore, the following ports are included in the list:
Port 307 (38 × 8 + 3 = 307, where 38 is the number of times that hexadecimal string 00 appears.)
Port 308 (38 × 8 + 4 = 308)
Port 310 (38 × 8 + 6 = 310)
To view the member ports of an aggregate interface:
1.     Check the hh3cAggLinkPortList object in the hh3cAggLinkTable table to obtain the member port list.
¡     For a Layer 2 aggregate interface, this object is suffixed with the aggregate interface ID. For example, hh3cAggLinkPortList.3 lists the member ports of Bridge-Aggregation 3.
¡     For a Layer 3 aggregate interface, this object is suffixed with the sum of the aggregate interface ID and 16384. For example, hh3cAggLinkPortList.16387 lists the member ports of Route-Aggregation 3.
2.     Calculate the logical ID of each member port based on the value of the hh3cAggLinkPortList object.
3.     Check the dot1dBasePortIfIndex object in the dot1dBasePortTable table for the ifindex value mapped to the logical ID of each member port.
4.     Check the ifXTable table for the interface name mapped to each ifindex value.
Example:
The value of the hh3cAggLinkTable object is as follows:
11:hh3cAggLinkPortList.16387(PortList)00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.80.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.40 (hex)
The following member ports are included in the list:
Port 409 (51 × 8 + 1= 409, where 51 is the number of times that hexadecimal string 00 appears.)
Port 2690 (336 × 8 + 2= 2690)
The value of the dot1dBasePortIfIndex object is as follows:
127:dot1dBasePortIfIndex.409(INTEGER) 385
234:dot1dBasePortIfIndex.2690 (INTEGER) 2690
The ifindex value of port 409 is 385, and the ifindex value of port 2690 is 2690.
The value of the ifXTable table is as follows:
177:ifName.9173 (DisplayString) Route-Aggregation3[52.6F.75.74.65.2D.41.67.67.72.65.67.61.74.69.6F.6E.33 (hex)]
5:ifName.385(DisplayString) GigabitEthernet1/4/2/1[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.34.2F.32.2F.31 (hex)]
112:ifName.2690(DisplayString) GigabitEthernet2/5/1/2[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.32.2F.35.2F.31.2F.32 (hex)]
Therefore, the interface name is GigabitEthernet 1/4/2/1 for port 409 and GigabitEthernet 2/5/1/2 for port 2690.
On the device, the ports are as follows:
[H3C]dislink-aggregation verbose Route-Aggregation 3
AggregateInterface: Route-Aggregation3
AggregationMode: Static
LoadsharingType: Shar
  Port             Status  Priority Oper-Key
  GE1/4/2/1        S       32768    2
  GE2/5/1/2        S       32768    2
[H3C]
hh3cAggPortTable
About this table
This table contains aggregation member port information.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cAggPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cAggPortIndex (1.3.6.1.4.1.25506.8.25.1.2.1.1)
Gauge32
Member port index.
As per the MIB.
hh3cAggPortNotAttachedReason (1.3.6.1.4.1.25506.8.25.1.2.1.2)
read-write
Integer32
0..10
Why the port is unselected.
Read-only.
hh3cAggPortLacpState (1.3.6.1.4.1.25506.8.25.1.2.1.3)
read-write
TruthValue
true(1)
false(2)
Status of LACP.
Read-only.
hh3cAggPortNotAttachedString (1.3.6.1.4.1.25506.8.25.1.2.1.4)
read-write
DisplayString
SIZE (0..255)
Detailed cause for the unselected state of the member port.
Read-only.
Notifications
hh3cAggPortInactiveNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.25.2.2
An aggregation member port became unselected.
Informational
Warning
ON
Notification triggers
This notification is generated when an aggregation member port becomes unselected.
System impact
Traffic interruption
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.25.1.1.1.1 (hh3cAggLinkNumber)
hh3cAggLinkNumber
Integer32
1..40960
Recommended action
To resolve this issue:
1.     Verify that the aggregation member port is physically up.
2.     Verify that the attribute configuration of the aggregation member port is the same as that of the aggregate interface.
3.     Repeat step 1 and step 2 on the peer port if the aggregate interface operates in dynamic mode.
4.     If the issue persists, contact H3C Support.
hh3cAggPortInactiveNotification2
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.2.3
Informational
Warning
ON
System impact
Service interruption.
Status control
Objects
OID (object name)
Index nodes
Value range
hh3cAggLinkNumber
Integer32
1..40960
1.3.6.1.4.1.25506.8.25.1.2.1.1 (hh3cAggPortIndex)
Aggregation member port index.
hh3cAggPortIndex
Integer32
As per the MIB.
1.3.6.1.4.1.25506.8.25.4.1 (hh3cAggPortName)
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.2 (hh3cAggMemberPortName)
N/A
OCTET_STRING
Recommended action
hh3cAggPortActiveNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.2.4
An aggregation member port becomes selected.
Informational
Warning
N/A
ON
This notification is generated when an aggregation member port becomes selected.
System impact
The aggregation member port can forward traffic.
Status control
Objects
OID (object name)
Index nodes
Value range
hh3cAggLinkNumber
Integer32
1..40960
hh3cAggPortIndex
Integer32
As per the MIB.
N/A
OCTET_STRING
N/A
OCTET_STRING
Recommended action
No action is required.
hh3cAggAllMemberDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.7
All member ports in an aggregation group go down.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.8 (hh3cAggAllMemberDownRecovery)
ON
This notification is generated when all member ports in an aggregation group go down.
System impact
The aggregate interface of the aggregation group cannot forward traffic.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
Recommended action
1.     Execute the display interface brief command and check whether all member ports are down:
¡     If yes, go to step 2.
¡     If not, go to step 5.
2.     Use the undo shutdown command to bring up the member ports. If the alarm is not cleared, go to step 3.
3.     Check whether physical link issues exist, such as a loose cable or transceiver module:
¡     If yes, go to step 4.
4.     Install the physical link correctly. If the alarm is not cleared, go to step 5.
5.     Execute the display link-aggregation verbose command to check whether the aggregation group contains member ports:
¡     If yes, go to step 7.
¡     If not, go to step 6.
6.     Use the port link-aggregation group command to assign Ethernet interfaces to the aggregation group. If the alarm is not cleared, go to step 7.
7.     Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
An aggregation group has the first up member port.
Recovery
Warning
ON
This notification is generated when an aggregation group has the first up member port.
System impact
The aggregate interface of the aggregation group can forward traffic.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
Recommended action
hh3cAggAllMemberUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.9
All member ports in an aggregation group came up.
Informational
Warning
ON
This notification is generated when all member ports in an aggregation group come up.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
Recommended action
hh3cAggMemberLinkDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.10
A member port went down in an aggregation group.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.11 (hh3cAggMemberLinkUp)
ON
This notification is generated when a member port goes down in an aggregation group.
System impact
Traffic forwarding is interrupted on the member port.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
Recommended action
1.     Execute the display interface brief command and check whether the member port is down:
2.     Use the undo shutdown command to bring up the member port. If the alarm is not cleared, go to step 3.
5.     Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cAggMemberLinkUp
Basic information
OID
Event
Severity
Default status
A member port came up in an aggregation group.
Recovery
Warning
ON
This notification might be generated when the following events occur:
·     A member port is brought up by using the undo shutdown command.
·     Interface or link failure is resolved on a member port.
·     The link layer comes up on a member port.
System impact
The member port can forward traffic.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
Recommended action
hh3cAggMemberCoutExceedThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.12
The maximum number of selected ports was exceeded in an aggregation group.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.13 (hh3cAggMemberCoutExceedRecovery)
ON
This notification is generated when the maximum number of selected ports is exceeded in an aggregation group.
System impact
No negative impact on services.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.7 (hh3cAggUpThreshold)
N/A
Integer32
Integer32 (1..2147483647)
Recommended action
1.     Execute the display link-aggregation verbose command to verify that all member ports are up and forwarding traffic.
2.     If some member ports are not in use, remove them from the aggregation group by using the undo port link-aggregation group command.
Basic information
OID
Event
Severity
Default status
The number of selected ports in an aggregation group dropped to or below the maximum number of selected ports.
Recovery
Warning
ON
This notification is generated when the number of selected ports in an aggregation group drops below the maximum number of selected ports.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
Integer32
Recommended action
hh3cAggMemberNumberChanged
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.14
The number of selected ports changed in an aggregation group.
Informational
Warning
ON
·     A member port comes up.
·     A member port goes down.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.6 (hh3cAggTotalActiveNum)
N/A
Integer32
1.3.6.1.4.1.25506.8.25.4.8 (hh3cAggReasonCode)
Cause of change.
N/A
OCTET_STRING
Recommended action
·     If a member port comes up, no action is required.
·     If a member port goes down, check for the link down alarm for the member port and resolve the issue based on the cause.
hh3cAggLacpPartnerExpired
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.15
The LACP timeout timer expired for the peer of an aggregation member port.
Informational
Warning
ON
This notification is generated when the LACP timeout timer expires for the peer of an aggregation member port.
System impact
The bandwidth of the member port decreases or even drops to 0, and traffic of some or even all services is interrupted.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
1..40960
Recommended action
5.     Verify that dynamic link aggregation is correctly configured on the peer. If the alarm is not cleared, go to step 6.
6.     Collect alarm information and configuration data, and then contact H3C Support for help.
hh3cAggPortLacpInactive
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.16
An aggregation member port cannot be selected after receiving an LACPDU.
Event alarm
Warning
ON
·     The peer system ID in LACPDUs changes.
·     The peer key in LACPDUs changes.
·     The peer port number in LACPDUs changes.
·     The aggregation bit of the peer state field in LACPDUs changes.
·     The aggregation bit of the local state field in LACPDUs changes.
System impact
The member port cannot forward traffic.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Interger32 (1..40960)
1.3.6.1.4.1.25506.8.25.4.3 (hh3cAggOldPduInfo)
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.4 (hh3cAggNewPduInfo)
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.5 (hh3cAggPduChangeCode)
N/A
OCTET_STRING
Recommended action
5.     Execute the display link-aggregation verbose command to verify whether the aggregation group contains the member port:
6.     Use the port link-aggregation group command to assign the member port to the aggregation group. If the alarm is not cleared, go to step 7.
hh3cAggPortLacpNegotiateFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.17
Negotiation failed on a member port in a dynamic aggregation group.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.18 (hh3cAggPortLacpNegotiateRecovery)
ON
·     A link goes down.
·     No LACPDUs are received before the LACPDU reception timeout timer expires.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
1.     Execute the display this command and check whether the ports at the ends of the link are shut down:
¡     If yes, use the undo shutdown command to bring up the member ports. If the alarm is not cleared, go to step 2.
¡     If not, go to step 2.
2.     Check whether physical link issues exist, such as a loose cable or transceiver module:
¡     If yes, install the physical link correctly. If the alarm is not cleared, go to step 3.
¡     If not, go to step 3.
3.     Execute the display link-aggregation verbose command to verify whether the local or peer member port exits its aggregation group:
¡     If the member port exits its aggregation group unexpectedly, use the port link-aggregation group command to assign it to the aggregation group. If the alarm is not cleared, go to step 4.
¡     If the member port exits its aggregation group correctly, go to step 4.
4.     Collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Negotiation succeeded on a member port in a dynamic aggregation group.
Recovery
Warning
ON
·     The first negotiation succeeds on a member link.
·     Negotiation on a member link has failed, and the hh3cAggPortLacpNegotiateFailed notification has been triggered. When the member link recovers, the hh3cAggPortLacpNegotiateRecovery notification is triggered.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
hh3cAggMemberChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.19
Aggregation member port change.
Informational
Warning
ON
This notification is generated when the status of an aggregation member port changes.
System impact
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
1.3.6.1.4.1.25506.8.25.4.9 (hh3cAggChangeType)
N/A
INTEGER
INTEGER
(1, 2, 3)
Recommended action
Check the status of the involved aggregation member port.
hh3cAggPortLacpActive
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.20
An aggregation member port received an LACPDU that notifies it to become selected.
Informational
Warning
ON
This notification is generated when an aggregation member port receives an LACPDU that notifies it to become selected.
System impact
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
hh3cAggTotalLinkLoss
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.21
The bandwidth became 0 on all member ports in an aggregation group.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.22 (hh3cAggTotalLinkLossResume)
ON
This notification is generated when the bandwidth becomes 0 on all member ports in an aggregation group because no member port is selected.
System impact
Traffic forwarding is interrupted.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
¡     If not, go to step 4.
2.     Use the undo shutdown command to bring up the member ports. Check whether the alarm is cleared:
¡     If yes, no action is required.
3.     Check whether physical link issues exist:
¡     If yes, go to step 5
4.     Execute the display link-aggregation verbose command to check whether the aggregation group contains member ports:
5.     Install the physical link correctly. Check whether the alarm is cleared:
6.     Use the port link-aggregation group command to assign Ethernet interfaces to the aggregation group. Check whether the alarm is cleared:
¡     If not, go to step 7.
Basic information
OID
Event
Severity
Default status
The bandwidth recovered on all member ports in an aggregation group.
Recovery
Warning
ON
This notification is generated when the bandwidth recovers on all member ports in an aggregation group.
System impact
Traffic forwarding is resumed on the aggregate interface of the aggregation group.
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
hh3cAggPartialLinkLoss
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.23
The bandwidth became 0 on a member port in an aggregation group.
Error
Warning
1.3.6.1.4.1.25506.8.25.0.24 (hh3cAggPartialLinkLossResume)
ON
This notification is generated when the bandwidth becomes 0 on a member port in an aggregation group because the member port is not selected.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
2.     Use the undo shutdown command to bring up the member port. Check whether the alarm is cleared:
4.     Execute the display link-aggregation verbose command to check whether the aggregation group contains the member port:
6.     Use the port link-aggregation group command to assign the member port to the aggregation group. Check whether the alarm is cleared:
Basic information
OID
Event
Severity
Default status
The bandwidth recovered on a member port in an aggregation group.
Recovery
Warning
ON
This notification is generated when the bandwidth recovers on a member port in an aggregation group.
System impact
Traffic forwarding is resumed on the member port.
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
hh3cAggPortMadDetect
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.25.0.25
MAD for the aggregate interface.
Informational
Warning
N/A
ON
This notification is generated when the aggregate interface perform MAD.
System impact
No negative impact on the system.
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET_STRING
hh3cAggLinkNumber
Integer32
Recommended action
