06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
08-HH3C-MAC-TRAP-MIB
08-HH3C-MAC-TRAP-MIB 173.44 KB
HH3C-MAC-TRAP-MIB
About this MIB
This MIB defines the MAC module notifications.
MIB file name
hh3c-mac-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMACTrap(245)
Scalar objects
hh3cMACTrapEntryLearnIfName
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryLearnIfName (1.3.6.1.4.1.25506.2.245.1.1.1)
accessible-for-notify
OCTET STRING
OCTET STRING (0..255)
Interface name.
As per the MIB.
hh3cMACTrapEntryLearnVlan
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryLearnVlan (1.3.6.1.4.1.25506.2.245.1.1.2)
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cMACTrapEntryLearnVsiName
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryLearnVsiName (1.3.6.1.4.1.25506.2.245.1.1.3)
OCTET STRING
OCTET STRING (1..31)
VSI name.
As per the MIB.
hh3cMACTrapEntryLearnThreshold
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryLearnThreshold (1.3.6.1.4.1.25506.2.245.1.1.4)
Unsigned32
Unsigned32(1..2147483647)
MAC address learning limit on the interface.
As per the MIB.
hh3cMACTrapEntryCurLearnCount
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryCurLearnCount (1.3.6.1.4.1.25506.2.245.1.1.5)
Unsigned32
Number of learned MAC address entries.
As per the MIB.
hh3cMACTrapEntryChassis
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntryChassis (1.3.6.1.4.1.25506.2.245.1.1.6)
Unsigned32
Unsigned32(0..65535)
Chassis ID.
As per the MIB.
hh3cMACTrapEntrySlot
Object (OID)
Access
Value range
Implementation
hh3cMACTrapEntrySlot (1.3.6.1.4.1.25506.2.245.1.1.7
Unsigned32
Slot ID.
As per the MIB.
hh3cMACTrapRcvIllegalPktIfName
Object (OID)
Access
Value range
Implementation
hh3cMACTrapRcvIllegalPktIfName (1.3.6.1.4.1.25506.2.245.2.1.1)
OCTET STRING
Interface name.
As per the MIB.
hh3cMACHashConflictMac
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictMac (1.3.6.1.4.1.25506.2.245.3.1.1)
OCTET STRING
Standard MIB values.
MAC addresses in the hash collision.
As per the MIB.
hh3cMACHashConflictMacVlan
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictMacVlan (1.3.6.1.4.1.25506.2.245.3.1.2)
Unsigned32
Unsigned32(1..4094)
VLAN name for the MAC address in the hash collision.
As per the MIB.
hh3cMACHashConflictMacIfName
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictMacIfName (1.3.6.1.4.1.25506.2.245.3.1.3
OCTET STRING
Interface name or interface and service instance for the MAC address in the hash collision.
As per the MIB.
hh3cMACHashConflictMacVsiName
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictMacVsiName (1.3.6.1.4.1.25506.2.245.3.1.4)
OCTET STRING
VSI name for the MAC address in the hash collision.
As per the MIB.
hh3cMACHashConflictChassis
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictChassis (1.3.6.1.4.1.25506.2.245.3.1.5)
Unsigned32
Chassis ID.
As per the MIB.
hh3cMACHashConflictSlot
Object (OID)
Access
Value range
Implementation
hh3cMACHashConflictSlot (1.3.6.1.4.1.25506.2.245.3.1.6)
Unsigned32
Slot ID.
As per the MIB.
Notifications
hh3cMACTrapIfThresholdAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.245.1.0.1
MAC addresses learned on an interface reached or exceeded the limit.
Error
Minor
1.3.6.1.4.1.25506.2.245.1.0.2 (hh3cMACTrapIfThresholdResume)
ON
Notification triggers
This notification is generated when the MAC addresses learned on an interface reaches or exceeds the limit.
System impact
The interface stops learning new MAC addresses.
Status control
ON
CLI: snmp-agent trap enable mac-address [ entry-limit ]
OFF
CLI: undo snmp-agent trap enable mac-address [ entry-limit ]
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.245.1.1.1 (hh3cMACTrapEntryLearnIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.245.1.1.4 (hh3cMACTrapEntryLearnThreshold)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.245.1.1.6 (hh3cMACTrapEntryChassis)
Chassis ID.
N/A
Unsigned32
In a non-multichassis system, the value takes 65535.
(hh3cMACTrapEntrySlot)
Slot ID.
N/A
Unsigned32
Recommended action
Recommended action
Execute the display mac-address dynamic interface interface-type interface-number command to identify whether all dynamic MAC address entries are necessary.
·     If yes, execute the mac-address max-mac-count count command to increase the MAC learning limit on the interface.
·     If no, execute the undo mac-address dynamic mac-address vlan vlan-id command to delete unnecessary MAC address entries.
Basic information
OID
Event
Severity
Default status
MAC addresses learned on an interface dropped below the limit.
Recovery
Minor
N/A
ON
This notification is generated when the number of MAC addresses learned on an interface dropped below the limit.
System impact
An interface can learn new MAC addresses.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
Interface name.
N/A
OCTET STRING
N/A
Unsigned32
1.3.6.1.4.1.25506.2.245.1.1.5 (hh3cMACTrapEntryCurLearnCount)
Number of learned MAC address entries on the interface.
N/A
Unsigned32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
No action is required.
hh3cMACTrapVlanThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.245.1.0.3
MAC addresses learned for a VLAN reached or exceeded the limit.
Error
Minor
1.3.6.1.4.1.25506.2.245.1.0.4 (hh3cMACTrapVlanThresholdResume)
ON
This notification is generated when the number of MAC addresses learned for a VLAN reaches the MAC learning limit for the VLAN.
System impact
No more MAC addresses are learned for a VLAN.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.245.1.1.2 (hh3cMACTrapEntryLearnVlan)
VLAN ID.
N/A
Unsigned32
Unsigned32(1..4094)
MAC address learning limit on the VLAN.
N/A
Unsigned32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
Execute the display mac-address dynamic vlan vlan-id command to identify whether all dynamic MAC address entries are necessary.
·     If yes, execute the mac-address max-mac-count count command in VLAN view to increase the MAC learning limit for the VLAN.
·     If no, execute the undo mac-address dynamic mac-address vlan vlan-id command in interface view to delete unnecessary MAC address entries.
Basic information
OID
Event
Severity
Default status
MAC addresses learned on a VLAN dropped below the limit.
Recovery
Minor
N/A
ON
This notification is generated when the number of the MAC addresses learned for a VLAN drops below the limit.
System impact
New MAC addresses can be learned for a VLAN.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
VLAN ID.
N/A
Unsigned32
Unsigned32(1..4094)
MAC address learning limit for the VLAN.
N/A
Unsigned32
N/A
Unsigned32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACTrapVsiThresholdAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.245.1.0.5
MAC addresses learned for a VSI reached the limit.
Error
Minor
1.3.6.1.4.1.25506.2.245.1.0.6(hh3cMACTrapVsiThresholdResume)
ON
This notification is generated when the number of MAC addresses learned for a VSI reached the limit.
System impact
No more MAC addresses are learnt for a VSI.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.245.1.1.3  (hh3cMACTrapEntryLearnVsiName)
VSI name.
N/A
OCTET STRING
MAC address learning limit on the VSI.
N/A
Unsigned32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
Execute the display l2vpn mac-address vsi vsi-name dynamic command to identify whether all dynamic MAC address entries are necessary.
·     If yes, execute the mac-table limit mac-limit command in VSI view to increase the MAC learning limit for the VSI.
·     If no, delete unnecessary MAC address entries.
Basic information
OID
Event
Severity
Default status
MAC addresses learned on a VSI dropped below the limit.
Recovery
Minor
N/A
ON
This notification is generated when the number of the MAC addresses learned for a VSI drops below the limit.
System impact
New MAC addresses can be learned for a VSI.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
VSI name.
N/A
OCTET STRING
N/A
Unsigned32
Number of learned MAC address entries on the VSI.
N/A
Unsigned32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACTrapRcvIllegalMacPktAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.245.2.0.1
A port received a packet with the source MAC or destination MAC all zeros.
Informational
Warning
N/A
ON
This notification is generated when a port receives a packet with the source MAC or destination MAC all zeros.
System impact
The device receives illegal packets.
Status control
ON
CLI: snmp-agent trap enable mac-address [ illegal-mac ]
OFF
CLI: undo snmp-agent trap enable mac-address [ illegal-mac ]
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.245.2.1.1 (hh3cMACTrapRcvIllegalPktIfName)
Interface name.
N/A
OCTET STRING
Recommended action
hh3cMACTrapVlanHashConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.245.3.0.1
A hash collision occurred for MAC addresses learned on a VLAN.
Informational
Warning
N/A
ON
This notification is generated when a hash conflict occurs for MAC addresses learned on a VLAN.
System impact
When the device cannot learn some MAC addresses, the device will broadcast the traffic destined for these unknown MAC addresses, which consumes bandwidth and resources.
Status control
ON
CLI: snmp-agent trap enable mac-address [ hash-conflict ]
OFF
CLI: undo snmp-agent trap enable mac-address [ hash-conflict ]
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.245.3.1.1 (hh3cMACHashConflictMac)
N/A
OCTET STRING
Standard MIB values
1.3.6.1.4.1.25506.2.245.3.1.2 (hh3cMACHashConflictMacVlan)
N/A
Unsigned32
Unsigned32(1..4094)
(hh3cMACHashConflictMacIfName)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.245.3.1.5 (hh3cMACHashConflictChassis)
Chassis ID.
N/A
Unsigned32
(hh3cMACHashConflictSlot)
Slot ID.
N/A
Unsigned32
Recommended action
If the hash conflict is not serious on the MAC address table, no action is required.
If the hash conflict is serious, you can use the mac-address hash-bucket-size command to increase the hash bucket size of the MAC address table to reduce MAC address hash conflicts.
hh3cMACTrapVsiHashConflictAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.245.3.0.2
A hash conflict occurred on the MAC addresses learned for a VSI.
Informational
Warning
N/A
ON
This notification is generated when a hash conflict occurs on MAC addresses learned on a VSI.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.245.3.1.3 (hh3cMACHashConflictMacIfName)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.245.3.1.4  (hh3cMACHashConflictMacVsiName)
N/A
OCTET STRING
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
If the hash conflict is serious, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
