06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 6715-6W10006-Layer 2 - LAN Switching
13-HH3C-VMAP-MIB
13-HH3C-VMAP-MIB 118.89 KB
HH3C-VMAP-MIB
About this MIB
Use this MIB to configure VLAN mapping features, for example, one-to-one VLAN mapping, many-to-one VLAN mapping, one-to-two VLAN mapping, two-to-two VLAN mapping, and two-to-one VLAN mapping. VLAN mapping re-marks VLAN traffic with new VLAN IDs. Implementation varies by product.
MIB file name
hh3c-vmap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVmap(138)
Tabular objects
hh3cVMAPNNITable
About this table
Use this table to configure many-to-one VLAN mapping on the network side.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNNIState (1.3.6.1.4.1.25506.2.138.1.1.1)
read-write
TruthValue
true(1),
false(2)
Configure VLAN mapping.
hh3cVMAP1to1Table
About this table
Use this table to configure one-to-one VLAN mapping.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAP1to1Vlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to1Vlan (1.3.6.1.4.1.25506.2.138.2.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Configure one-to-one VLAN mapping.
As per the MIB.
hh3cVMAP1to1TranslatedVlan (1.3.6.1.4.1.25506.2.138.2.1.2)
read-create
Integer32
Translated VLAN for one-to-one VLAN mapping.
hh3cVMAP1to1RowStatus
(1.3.6.1.4.1.25506.2.138.2.1.3)
read-create
RowStatus
Standard MIB values.
One-to-one VLAN mapping row state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cVMAPNto1RangeTable
About this table
Use this table to configure many-to-one VLAN mapping on the user side. The original VLANs are specified in a list, for example, VLANs 20 through 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAPNto1StartVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNto1StartVlan (1.3.6.1.4.1.25506.2.138.3.1.1)
not-accessible
Integer32
Start VLAN of the original VLAN list for many-to-one VLAN mapping.
As per the MIB.
hh3cVMAPNto1EndVlan (1.3.6.1.4.1.25506.2.138.3.1.2)
read-create
Integer32
End VLAN of the original VLAN list for many-to-one VLAN mapping.
hh3cVMAPNto1RangeTranslatedVlan (1.3.6.1.4.1.25506.2.138.3.1.3)
read-create
Integer32
Translated VLAN for many-to-one VLAN mapping.
hh3cVMAPNto1RangeRowStatus
(1.3.6.1.4.1.25506.2.138.3.1.4)
read-create
RowStatus
Many-to-one VLAN mapping row state.
hh3cVMAPNto1SingleTable
About this table
Use this table to configure many-to-one VLAN mapping on the user side. The original VLANs are single VLANs, for example, VLAN 20 and VLAN 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAPNto1Vlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAPNto1Vlan (1.3.6.1.4.1.25506.2.138.4.1.1)
not-accessible
Integer32
Many-to-one VLAN mapping.
As per the MIB.
hh3cVMAPNto1SingleTranslatedVlan (1.3.6.1.4.1.25506.2.138.4.1.2)
read-create
Integer32
hh3cVMAPNto1SingleRowStatus
(1.3.6.1.4.1.25506.2.138.4.1.3)
read-create
RowStatus
hh3cVMAP1to2RangeTable
About this table
Use this table to configure two-to-one VLAN mapping. The original VLANs are specified in a list, for example, VLANs 20 through 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex and hh3cVMAP1to2StartVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to2StartVlan (1.3.6.1.4.1.25506.2.138.5.1.1)
not-accessible
Integer32
Start VLAN of the original VLAN list for one-to-two VLAN mapping.
As per the MIB.
hh3cVMAP1to2EndVlan (1.3.6.1.4.1.25506.2.138.5.1.2)
read-create
Integer32
End VLAN of the original VLAN list for one-to-two VLAN mapping.
hh3cVMAP1to2RangeNestedVlan (1.3.6.1.4.1.25506.2.138.5.1.3)
read-create
Integer32
Outer VLAN for one-to-two VLAN mapping.
hh3cVMAP1to2RangeRowStatus
(1.3.6.1.4.1.25506.2.138.5.1.4)
read-create
RowStatus
One-to-two VLAN mapping row state.
hh3cVMAP1to2RangeNestedPrio
(1.3.6.1.4.1.25506.2.138.5.1.5)
read-create
Integer32
Outer VLAN priority for one-to-two VLAN mapping.
The value range is 0 to 7. If no priority is configured, the default is 65535.
hh3cVMAP1to2SingleTable
About this table
Use this table to configure one-to-two VLAN mapping. The original VLANs are single VLANs, for example, VLAN 20 and VLAN 30.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cVMAP1to2Vlan (1.3.6.1.4.1.25506.2.138.6.1.1)
not-accessible
Integer32
Configure one-to-two VLAN mapping.
As per the MIB.
hh3cVMAP1to2SingleNestedVlan (1.3.6.1.4.1.25506.2.138.6.1.2)
read-create
Integer32
Single outer VLAN for one-to-two VLAN mapping.
hh3cVMAP1to2SingleRowStatus
(1.3.6.1.4.1.25506.2.138.6.1.3)
read-create
RowStatus
hh3cVMAP1to2SingleNestedPrio
(1.3.6.1.4.1.25506.2.138.6.1.4)
read-create
Integer32
Single outer VLAN priority for one-to-two VLAN mapping.
hh3cVMAP2to2Table
About this table
Use this table to configure two-to-two VLAN mapping.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cVMAP2to2OuterVlan, and hh3cVMAP2to2InnerVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP2to2OuterVlan (1.3.6.1.4.1.25506.2.138.7.1.1)
not-accessible
Integer32
Original outer VLAN for two-to-two VLAN mapping.
As per the MIB.
hh3cVMAP2to2InnerVlan  (1.3.6.1.4.1.25506.2.138.7.1.2)
not-accessible
Integer32
Original inner VLAN for two-to-two VLAN mapping.
As per the MIB.
hh3cVMAP2to2TranslatedOuterVlan (1.3.6.1.4.1.25506.2.138.7.1.3)
read-create
Integer32
Translated outer VLAN for two-to-two VLAN mapping.
hh3cVMAP2to2TranslatedInnerVlan  (1.3.6.1.4.1.25506.2.138.7.1.4)
read-create
Integer32
Translated inner VLAN for two-to-two VLAN mapping.
hh3cVMAP2to2RowStatus
(1.3.6.1.4.1.25506.2.138.7.1.5)
read-create
RowStatus
Two-to-two VLAN mapping row state.
hh3cVMAP2to1Table
About this table
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cVMAP2to1OuterVlan, and hh3cVMAP2to1InnerVlan.
Object (OID)
Access
Value range
Implementation
hh3cVMAP2to1OuterVlan (1.3.6.1.4.1.25506.2.138.8.1.1)
not-accessible
Integer32
Original outer VLAN for two-to-one VLAN mapping.
As per the MIB.
hh3cVMAP2to1InnerVlan  (1.3.6.1.4.1.25506.2.138.8.1.2)
not-accessible
Integer32
Original inner VLAN for two-to-one VLAN mapping.
As per the MIB.
hh3cVMAP2to1TranslatedOuterVlan (1.3.6.1.4.1.25506.2.138.8.1.3)
read-create
Integer32
Translated outer VLAN for two-to-one VLAN mapping.
hh3cVMAP2to1RowStatus
(1.3.6.1.4.1.25506.2.138.8.1.4)
read-create
RowStatus
Two-to-one VLAN mapping row state.
hh3cVMAPTrapGroup
About this table
Use this table to report traps.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cVMAPIfChassis (1.3.6.1.4.1.25506.2.138.9.1.0)
accessible-for-notify
Integer32
Integer32 (0..4294967295)
Chassis number
As per the MIB.
hh3cVMAPIfSlot (1.3.6.1.4.1.25506.2.138.9.2.0)
Integer32
Slot number
As per the MIB.
hh3cVMAPThresholdRatio (1.3.6.1.4.1.25506.2.138.9.3.0)
Integer32
Integer32 (0..100)
Resource threshold percentage
Notifications
hh3cVMAPCountThresholdAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.138.10.0.1
The number of configured VLAN Mapping and VLAN Stacking entries exceeds the upper threshold.
Informational
N/A
N/A
ON
Notification triggers
This notification is generated when the number of configured VLAN Mapping and VLAN Stacking entries exceeds the upper threshold.
Status control
This notification cannot be disabled.
Objects
OID
Index nodes
Value range
Chassis number
No
Integer32
0-65535
hh3cVMAPIfSlot
(1.3.6.1.4.1.25506.2.138.9.1.2.0)
Slot number
No
Integer32
0-65535
(1.3.6.1.4.1.25506.2.138.9.1.3.0)
Threshold percentage
No
Integer32
1-100
Recommended action
No action is required.
hh3cVMAPCountThresholdResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.138.10.0.2
The number of configured VLAN Mapping and VLAN Stacking entries drops below the upper threshold
Informational
N/A
N/A
ON
This notification is generated when the number of configured VLAN Mapping and VLAN Stacking entries drops below the upper threshold.
Status control
Objects
OID
Index nodes
Value range
Chassis number
No
Integer32
0-65535
hh3cVMAPIfSlot
Slot number
No
Integer32
0-65535
No
Integer32
1-100
Recommended action
