12-Security Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10012-Security Command References
32-FIPS commands
32-FIPS commands 61.69 KB
FIPS commands
The device does not support FIPS when it provides low encryption.
display crypto version
Use display crypto version to display the version number of the device algorithm base.
Each algorithm base version number represents a set of cryptographic algorithms.
# Display the version number of the current device algorithm base.
<Sysname> display crypto version
7.1.1.1.1.72
7.1.1.1.1.72
Version number in the 7.1.X format.
·     7.1—Comware V700R001.
·     X—Version number of the device algorithm base.
display fips status
Use display fips status to display the FIPS mode state.
display fips status
# Display the FIPS mode state.
<Sysname> display fips status
FIPS mode is enabled.
fips mode enable
fips mode enable
Use fips mode enable to enable FIPS mode.
Use undo fips mode enable to disable FIPS mode.
fips mode enable
FIPS mode is disabled.
CAUTION
CAUTION:
·     When you enable or disable FIPS mode, you must reboot the device manually or have the device reboot automatically. A system reboot might interrupt the ongoing services. Use caution when you perform this operation.
·     If you choose manual reboot when you enable FIPS mode, you must configure all settings required for login in FIPS mode before you reboot the device. If any settings are missing, you will be unable to log in to the device.
After you enable FIPS mode and reboot the device, the device operates in FIPS mode. The FIPS device has strict security requirements, and performs self-tests on cryptography modules to verify that they are operating correctly.
After you execute the fips mode enable command, the system provides the following methods to enter FIPS mode:
·     Automatic reboot
Select the automatic reboot method. The system automatically performs the following tasks:
a.     Create a default FIPS configuration file named fips-startup.cfg.
b.     Specify the default file as the startup configuration file.
c.     Require you to configure the username and password for next login.
You can press Ctrl+C to exit the configuring process so the fips mode enable command will not be executed.
The system automatically uses the specified startup configuration file to reboot the device after you configure the administrator's username and password.
·     Manual reboot
This method requires that you manually complete the configurations for entering FIPS mode, and then reboot the device.
To use manual reboot to enter FIPS mode:
a.     Enable the password control feature globally.
b.     Set the number of character types a password must contain to 4, and set the minimum number of characters for each type to one character.
c.     Set the minimum length of user passwords to 15 characters.
d.     Add a local user account for device management, including the following items:
-     A username.
-     A password that must comply with the password control policies.
-     A user role of network-admin.
-     A service type of terminal.
e.     Delete the FIPS-incompliant local user service types Telnet, HTTP, and FTP.
f.     Save the configuration file and specify it as the startup configuration file.
g.     Delete the original startup configuration file in binary format.
h.     Reboot the device.
After the fips mode enable command is executed, the system prompts you to choose a reboot method. If you do not make a choice within 30 seconds, the system uses the manual reboot method by default.
After the undo fips mode enable command is executed, the system provides the following methods to exit FIPS mode:
·     Automatic reboot
Select the automatic reboot method. The system automatically creates a default non-FIPS configuration file named non-fips-startup.cfg, and specifies the file as the startup configuration file. The system reboots the device by using the default non-FIPS configuration file. After the reboot, you are directly logged into the device.
·     Manual reboot
This method requires that you manually complete the configurations for entering non-FIPS mode, and then reboot the device. After the device reboots, you must enter user information according to the authentication mode to log in to the device.
# Enable FIPS mode, and choose the automatic reboot method to enter FIPS mode.
[Sysname] fips mode enable
FIPS mode change requires a device reboot. Continue? [Y/N]:y
Reboot the device automatically? [Y/N]:y
The system will create a new startup configuration file for FIPS mode. After you set the login username and password for FIPS mode, the device will reboot automatically.
Enter username(1-55 characters): root
Enter password(15-63 characters):
Confirm password:
Waiting for reboot... After reboot, the device will enter FIPS mode.
# Enable FIPS mode, and choose the manual reboot method to enter FIPS mode.
Reboot the device automatically? [Y/N]:n
Change the configuration to meet FIPS mode requirements, save the configuration to the next-startup configuration file, and then reboot to enter FIPS mode.
# Disable FIPS mode, and choose the automatic reboot method to enter non-FIPS mode.
[Sysname] undo fips mode enable
The system will create a new startup configuration file for non-FIPS mode and then reboot automatically. Continue? [Y/N]:y
Waiting for reboot... After reboot, the device will enter non-FIPS mode.
# Disable FIPS mode, and choose the manual reboot method to enter non-FIPS mode.
The system will create a new startup configuration file for non-FIPS mode, and then reboot automatically. Continue? [Y/N]:n
Change the configuration to meet non-FIPS mode requirements, save the configuration to the next-startup configuration file, and then reboot to enter non-FIPS mode.
display fips status
fips self-test
Use fips self-test to trigger a self-test on the cryptographic algorithms.
fips self-test
CAUTION
CAUTION:
A successful self-test requires that all cryptographic algorithms pass the self-test. If the self-test fails, the device reboots.
This command is supported only in FIPS mode. To examine whether the cryptography modules operate correctly, you can use this command to trigger a self-test on the cryptographic algorithms. The triggered self-test is the same as the power-up self-test.
# Trigger a self-test on the cryptographic algorithms.
[Sysname] fips self-test
Cryptographic algorithms tests are running.
Slot 1:
Starting Known-Answer tests in the user space.
Known-answer test for 3DES passed.
Known-answer test for SHA1 passed.
Known-answer test for SHA224 passed.
Known-answer test for SHA256 passed.
Known-answer test for SHA384 passed.
Known-answer test for SHA512 passed.
Known-answer test for HMAC-SHA1 passed.
Known-answer test for HMAC-SHA224 passed.
Known-answer test for HMAC-SHA256 passed.
Known-answer test for HMAC-SHA384 passed.
Known-answer test for HMAC-SHA512 passed.
Known-answer test for AES passed.
Known-answer test for RSA(signature/verification) passed.
Pairwise conditional test for RSA(signature/verification) passed.
Pairwise conditional test for RSA(encrypt/decrypt) passed.
Pairwise conditional test for DSA(signature/verification) passed.
Pairwise conditional test for ECDSA(signature/verification) passed.
Known-answer test for ECDH passed.
Known-answer test for random number generator(x931) passed.
Known-answer test for DRBG passed.
Known-Answer tests in the user space passed.
Starting Known-Answer tests in the kernel.
Known-answer test for GCM passed.
Known-answer test for GMAC passed.
Known-Answer tests in the kernel passed.
Starting Known-Answer tests in the engine.
Known-Answer tests in the engine passed.
Cryptographic algorithms tests passed.
  • Become a Partner
  • Partner Resources
