12-Security Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10012-Security Command References
05-Portal commands
05-Portal commands 1.03 MB
Portal commands· 1
aaa-fail nobinding enable· 1
ad-url 1
ad-url-group· 2
aging-time· 3
app-id (Facebook authentication server view) 4
app-id (QQ authentication server view) 5
app-id (WeChat authentication server view) 5
app-key (Facebook authentication server view) 6
app-key (QQ authentication server view) 7
app-key (WeChat authentication server view) 8
app-secret 9
authentication-timeout 10
auth-url 10
binding-retry· 11
captive-bypass enable· 12
cloud-binding enable· 13
cloud-server url 14
default-logon-page· 15
display portal 15
display portal authentication-location· 22
display portal ad-push statistics· 22
display portal auth-error-record· 23
display portal auth-fail-record· 26
display portal captive-bypass statistics· 29
display portal dns free-rule-host 30
display portal dns redirect-rule-host 31
display portal extend-auth-server 32
display portal local-ac-user 33
display portal local-binding mac-address· 36
display portal logout-record· 37
display portal mac-trigger user 40
display portal mac-trigger-server 41
display portal packet statistics· 44
display portal permit-rule statistics· 49
display portal redirect session· 49
display portal redirect session-statistics· 51
display portal redirect statistics· 52
display portal roaming-center statistics packet 53
display portal rule· 55
display portal safe-redirect statistics· 65
display portal server 67
display portal user 69
display portal user-block· 80
display portal user count 81
display portal user dhcp-lease· 82
display portal user dhcpv6-lease· 83
display portal web-server 84
display web-redirect rule· 86
exclude-attribute (MAC binding server view) 89
exclude-attribute (portal authentication server view) 90
free-traffic threshold· 92
if-match· 93
if-match temp-pass· 95
ip (MAC binding server view) 97
ip (portal authentication server view) 98
ip (portal roaming center view) 99
ipv6 (portal authentication server view) 99
ipv6 (portal roaming center view) 100
local-binding aging-time· 101
local-binding enable· 102
login failed-url 103
login success-url 103
logon-page bind· 104
logout-notify· 105
mail-domain-name· 106
mail-protocol 107
nas-port-type· 108
port (MAC binding server view) 108
port (portal authentication server view) 109
port (portal roaming center view) 110
portal ad-push· 111
portal ad-push embedded· 112
portal ad-push enable· 113
portal ad-push whitelist 113
portal ad-url-group· 114
portal apply mac-trigger-server 115
portal apply web-server 116
portal authentication-location switchto-central-ac· 117
portal auth-error-record enable· 118
portal auth-error-record export 118
portal auth-error-record max· 120
portal auth-fail-record enable· 122
portal auth-fail-record export 123
portal auth-fail-record max· 124
portal authorization strict-checking· 126
portal captive-bypass optimize delay· 127
portal client-gateway interface· 128
portal client-traffic-report interval 129
portal cloud report interval 129
portal delete-user 130
portal device-id· 131
portal domain· 132
portal dual-ip enable· 133
portal dual-stack enable· 133
portal dual-stack traffic-separate enable· 134
portal enable (interface view) 135
portal enable (service template view) 136
portal extend-auth domain· 137
portal extend-auth-server 137
portal fail-permit server 139
portal fail-permit web-server 140
portal forbidden-rule· 141
portal free-all except destination· 142
portal free-rule· 143
portal free-rule description· 145
portal free-rule destination· 145
portal free-rule source· 146
portal host-check enable· 148
portal idle-cut dhcp-capture enable· 148
portal ipv6 free-all except destination· 149
portal ipv6 layer3 source· 150
portal ipv6 user-detect 151
portal layer3 source· 152
portal local-web-server 153
portal logout-record enable· 155
portal logout-record export 155
portal logout-record max· 157
portal mac-trigger-server 159
portal max-user 160
portal nas-id profile· 160
portal nas-port-id format 161
portal nas-port-type· 164
portal oauth user-sync interval 165
portal outbound-filter enable· 165
portal packet log enable· 166
portal pre-auth domain· 167
portal pre-auth ip-pool 168
portal redirect log enable· 169
portal redirect max-session per-user 170
portal redirect-rule destination· 170
portal refresh enable· 172
portal roaming-center 172
portal roaming enable· 173
portal safe-redirect default-action· 174
portal safe-redirect enable· 175
portal safe-redirect forbidden-keyword· 176
portal safe-redirect forbidden-url 177
portal safe-redirect method· 178
portal safe-redirect permit-url 179
portal safe-redirect user-agent 180
portal server 181
portal temp-pass enable· 182
portal traffic-accounting disable· 182
portal traffic-backup threshold· 183
portal traffic-rate statistics-interval 184
portal url-param source-address code-base64· 184
portal url-unescape-chars· 185
portal user log enable· 186
portal user-block failed-times· 187
portal user-block reactive· 188
portal user-detect 188
portal user-dhcp-only· 190
portal user-log traffic-separate· 191
portal user-logoff after-client-offline enable· 191
portal user-logoff ssid-switch enable· 192
portal web-proxy port 193
portal web-server 194
portal wifidog user-sync interval 194
portal { bas-ip | bas-ipv6 } 195
portal { ipv4-max-user | ipv6-max-user } 196
redirect-url 197
reset portal ad-push statistics· 198
reset portal auth-error-record· 199
reset portal auth-fail-record· 200
reset portal captive-bypass statistics· 200
reset portal local-binding mac-address· 201
reset portal logout-record· 202
reset portal packet statistics· 202
reset portal roaming-center statistics packet 203
reset portal safe-redirect statistics· 204
response-timeout 204
retry· 205
roaming-center enable· 206
server-detect (portal authentication server view) 207
server-detect (portal Web server view) 208
server-detect url 209
server-register 210
server-type (MAC binding server view) 211
server-type (portal authentication server view/portal Web server view) 211
shop-id· 212
subscribe-required enable· 213
tcp-port 214
url 215
url-parameter 215
user-agent 218
user-password modify enable· 218
user-sync· 219
user-traffic deny· 220
version· 221
vpn-instance· 222
web-redirect track· 222
web-redirect url 223
Portal commands
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
Use aaa-fail nobinding enable to enable AAA failure unbinding.
Use undo aaa-fail nobinding enable to restore the default.
AAA failure unbinding is disabled.
If a portal user fails AAA in MAC-trigger authentication, the user cannot trigger authentication before the MAC-trigger entry of the user ages out. After the MAC-trigger entry ages out, the user triggers MAC-trigger authentication when it accesses the network.
After AAA failure unbinding is enabled, the device sets the MAC-trigger entry state for a user to unbound immediately after the user fails AAA in MAC-trigger authentication. Before the user's MAC-trigger entry ages out, the user can trigger normal portal authentication.
# Enable AAA failure unbinding for MAC binding server mts.
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts] aaa-fail nobinding enable
ad-url
Use ad-url to configure an advertisement URL in an advertisement group.
Use undo ad-url to delete an advertisement URL from an advertisement group.
ad-url url-string [ time-range time-range-name ]
undo ad-url url-string
No advertisement URLs are configured in an advertisement group.
Advertisement group view
url-string: Specifies the URL of an advertisement, a case-sensitive string of 1 to 256 characters. The URL must begin with http://.
time-range time-range-name: Specifies a time range for portal advertisement push. The time-range-name argument represents the name of the time range, a case-insensitive string of 1 to 32 characters. The time range name must begin with a letter and cannot be all. For more information about time ranges, see time range configuration in ACL and QoS Configuration Guide.
You can configure a maximum of 16 advertisement URLs in an advertisement group.
If the advertisement push method is time range-based, you must specify a time range for each advertisement URL. The time ranges for all advertisement URLs in an advertisement group must be different from each other.
# Configure advertisement URLs in advertisement group test.
[Sysname] portal ad-url-group test method interval
[Sysname-portal-ad-url-group-test] ad-url http://www.qq.com
[Sysname-portal-ad-url-group-test] ad-url http://www.sina.com
[Sysname-portal-ad-url-group-test] ad-url http://www.baidu.com
ad-url-group
ad-url-group
Use ad-url-group to set the time interval or traffic threshold for portal advertisement push in an advertisement group.
Use undo ad-url-group to restore the default.
ad-url-group { interval interval | traffic-threshold traffic-threshold }
undo ad-url-group
The interval is 360 minutes and the traffic threshold is 100 MB for portal advertisement push in an an advertisement group.
interval interval: Specifies the advertisement push interval, in the range of 5 to 1440 minutes. The interval begins when a portal user comes online.
traffic-threshold traffic-threshold: Specifies the traffic threshold for portal advertisement push in the range of 1 to 1024 MB.
This command takes effect only when the advertisement push method is time-based or traffic-based. The advertisement push interval is applicable to time-based advertisement push. The traffic threshold is applicable to traffic-based advertisement push.
Each time the interval for a user ends or the user's consumed traffic since the last push reaches the traffic threshold, the device pushes an advertisement to the user. The advertisements in the advertisement group are pushed to the portal user in the order they are configured.
# Set the advertisement push interval to 100 minutes in advertisement group test.
[Sysname-portal-ad-url-group-test] ad-url-group interval 100
ad-url
portal ad-url-group
aging-time
Use aging-time to set the aging time for MAC-trigger entries.
Use undo aging-time to restore the default.
aging-time seconds
undo aging-time
The aging time for MAC-trigger entries is 300 seconds.
seconds: Specifies the aging time for MAC-trigger entries. The value range is 60 to 7200 seconds.
With MAC-based quick portal authentication enabled, the device generates a MAC-trigger entry for a user when the device detects traffic from the user for the first time. The MAC-trigger entry records the following information:
·     MAC address of the user
·     Interface index
·     VLAN ID
·     Traffic statistics
·     Aging timer
When the aging time expires, the device deletes the MAC-trigger entry. The device re-creates a MAC-trigger entry for the user when it detects the user's traffic again.
# Specify the aging time as 300 seconds for MAC-trigger entries.
[Sysname-portal-mac-trigger-server-mts] aging-time 300
Use app-id to specify the app ID for Facebook authentication.
Use undo app-id to restore the default.
app-id app-id
undo app-id
No app ID is specified for Facebook authentication.
app-id: Specifies the app ID for Facebook authentication.
If a portal user uses Facebook authentication, the Facebook server authenticates and authorizes the user and sends an authorization code to the device after the authentication and authorization succeed. Then, the device sends the authorization code, app ID, and app key to the Facebook server to determine whether the user has passed authentication and authorization.
# Specify 123456789 as the app ID for Facebook authentication.
[Sysname] portal extend-auth-server facebook
[Sysname-portal-extend-auth-server-fb] app-id 123456789
Use app-id to specify the app ID for QQ authentication.
app-id app-id
undo app-id
An app ID for QQ authentication exists.
app-id: Specifies the app ID for QQ authentication.
To use QQ authentication for portal users, you must go to Tencent Open Platform (http://connect.qq.com/intro/login) to finish the following tasks:
1.     Register as a developer by using a valid QQ account.
2.     Apply the access to the platform for your website. The website is the webpage to which users are redirected after passing QQ authentication.
You will obtain the app ID and app key from the Tencent Open Platform after your application succeeds.
After a portal user passes QQ authentication, the QQ authentication server sends the authorization code of the user to the portal Web server. After the portal Web server receives the authorization code, it sends the authorization code of the user, the app ID, and the app key to the QQ authentication server for verification. If the information is verified as correct, the device determines that the user passes QQ authentication.
# Specify 101235509 as the app ID for QQ authentication.
[Sysname] portal extend-auth-server qq
[Sysname-portal-extend-auth-server-qq] app-id 101235509
Use app-id to specify the app ID for WeChat authentication.
app-id app-id
undo app-id
No app ID is specified for WeChat authentication.
app-id: Specifies the app ID for WeChat authentication.
The app ID specified in this command must be the same as the app ID obtained from the WeChat Official Account Admin Platform.
This configuration is required for the device to provide local WeChat authentication for portal users.
To obtain the app ID for WeChat authentication, you must perform the following tasks:
1.     Go to the WeChat Official Account Admin Platform (https://mp.weixin.qq.com) to apply a WeChat official account.
2.     Use the account to log in to the platform and enable the WeChat WiFi hotspot feature.
3.     Click the device management tab, and then add the device: select the shop where the device is deployed, select the portal device type, and enter the device setting (SSID of your WiFi network).
After the previous configurations, you will obtain the credentials (app ID, app key, and shop ID) for WeChat authentication.
When a WeChat user attempts to connect to the WiFi network provided in the specified shop, the device sends the credentials to the WeChat Official Account Platform for verification. After the credentials are verified, the device continues the portal authentication and allows the user to use the WiFi network after the authentication.
# Specify wx23fb4aaf04b8491e as the app ID for WeChat authentication.
[Sysname] portal extend-auth-server wechat
[Sysname-portal-extend-auth-server-wechat] app-id wx23fb4aaf04b8491e
Use app-key to specify the app key for Facebook authentication.
Use undo app-key to restore the default.
app-key { cipher | simple } app-key
undo app-key
No app key is specified for Facebook authentication.
cipher: Specifies the app key in encrypted form.
simple: Specifies the app key in plaintext form.
app-key: Specifies the app key string. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
# Specify 123 in plaintext form as the app key for Facebook authentication.
[Sysname-portal-extend-auth-server-fb] app-key simple 123
Use app-key to specify the app key for QQ authentication.
undo app-key
An app key for QQ authentication exists.
# Specify 8a5428e6afdc3e2a2843087fe73f1507 in plaintext form as the app key for QQ authentication.
[Sysname-portal-extend-auth-server-qq] app-key simple 8a5428e6afdc3e2a2843087fe73f1507
Use app-key to specify the app key for WeChat authentication.
undo app-key
No app key is specified for WeChat authentication.
This configuration is required for the device to provide local WeChat authentication for portal users. The app key specified in this command must be the same as the app key obtained from the WeChat Official Account Admin Platform.
To obtain the app key for WeChat authentication, you must perform the following tasks:
 # Specify nqduqg4816689geruhq3 in plaintext form as the app key for WeChat authentication.
[Sysname-portal-extend-auth-server-wechat] app-key simple nqduqg4816689geruhq3
app-secret
Use app-secret to specify the app secret for WeChat authentication.
Use undo app-secret to restore the default.
app-secret { cipher | simple } string
undo app-secret
No app secret is specified for WeChat authentication.
cipher: Specifies the app secret in encrypted form.
simple: Specifies the app secret in plaintext form.
app-key: Specifies the app secret string. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
When the subscribe-required feature is enabled, you must specify the app secret for WeChat authentication on the device.
To obtain the app secret for WeChat authentication, perform the following tasks:
1.     Use a WeChat official account to log in to the WeChat Official Account Admin Platform.
For more information about the WeChat official account, see WeChat authentication configuration in Security Configuration Guide.
2.     From the navigation tree, select Developer Centers.
In the Configuration Items area, you can see the app secret for the WeChat Official account.
# Specify nqduqg4816689geruhq3 in plaintext form as the app secret for WeChat authentication.
[Sysname-portal-extend-auth-server-wechat] app-secret simple nqduqg4816689geruhq3
Use authentication-timeout to set the authentication timeout, which is the maximum amount of time the device waits for portal authentication to complete after receiving the MAC binding query response.
Use undo authentication-timeout to restore the default.
authentication-timeout minutes
The authentication timeout time is 3 minutes.
minutes: Specifies the authentication timeout in the range of 1 to 15 minutes.
Upon receiving the MAC binding query response of a user from the MAC binding server, the device starts an authentication timeout timer for the user. When the timer expires, the device deletes the MAC-trigger entry of the user.
# Set the authentication timeout to 10 minutes.
[Sysname-portal-mac-trigger-server-mts] authentication-timeout 10
auth-url
Use auth-url to specify the URL of the QQ or Facebook authentication server.
Use undo auth-url to delete the URL of the QQ or Facebook authentication server.
auth-url url-string
undo auth-url
The URL of QQ authentication server is https://graph.qq.com.
The URL of Facebook authentication server is https://graph.facebook.com.
url-string: Specifies the URL of the QQ or Facebook authentication server, a case-sensitive string of 1 to 256 characters. Make sure that you specify the actual URL of the QQ or Facebook authentication server. The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
# Specify http://oauth.qq.com/ as the URL of the QQ authentication server.
[Sysname-portal-extend-auth-server-qq] auth-url http://oauth.qq.com
# Specify http://oauth.facebook.com as the URL of the Facebook authentication server.
[Sysname-portal-extend-auth-server-fb] auth-url http://oauth.facebook.com
binding-retry
Use binding-retry to specify the maximum number of attempts and the interval for sending MAC binding queries to the MAC binding server.
Use undo binding-retry to restore the default.
binding-retry { retries | interval interval } *
undo binding-retry
The maximum number of query attempts is 3 and the query interval is 1 second.
retries: Specifies the maximum number of MAC binding query attempts, in the range of 1 to 10.
interval interval: Specifies the query interval in the range of 1 to 60 seconds.
If the device does not receive a response from the MAC binding server after the maximum number is reached, the device determines that the MAC binding server is unreachable. The device performs normal portal authentication for the user. The user needs to enter the username and password for authentication.
If you execute this command multiple times in the same MAC binding server view, the most recent configuration takes effect.
# Set the maximum number of MAC binding query attempts to 3 and the query interval to 60 seconds.
[Sysname-portal-mac-trigger-server-mts] binding-retry 3 interval 60
Use captive-bypass enable to enable the captive-bypass feature.
Use undo captive-bypass enable to disable the captive-bypass feature.
captive-bypass [ android | ios [ optimize ] ] enable
undo captive-bypass [ android | ios [ optimize ] ] enable
The captive-bypass feature is disabled. The device automatically pushes the portal authentication page to the iOS devices and some Android devices when they are connected to the network.
Portal Web server view
android: Enables the captive-bypass feature for Android users.
ios: Enables the captive-bypass feature for iOS users.
optimize: Enables the optimized captive-bypass feature.
With the captive-bypass feature enabled, the device does not automatically push the portal authentication page to iOS devices and some Android devices when they are connected to the network. The device pushes the portal authentication page only when the user accesses the Internet by using a browser.
The optimized captive-bypass feature applies only to iOS mobile devices. The device automatically pushes the portal authentication page to iOS mobile devices when they are connected to the network. Users can press the home button to return to the desktop without triggering portal authentication, and the Wi-Fi connection is not terminated.
If you do not specify any parameters, this command enables the captive-bypass feature for both Android and iOS users.
# Enable the captive-bypass feature.
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs] captive-bypass enable
# Enable the optimized captive-bypass feature for iOS users.
[Sysname-portal-websvr-wbs] captive-bypass ios optimize enable
# Enable the captive-bypass feature for Android users.
[Sysname-portal-websvr-wbs] captive-bypass android enable
Use cloud-binding enable to enable cloud MAC-trigger authentication.
Use undo cloud-binding enable to disable cloud MAC-trigger authentication.
Cloud MAC-trigger authentication is disabled.
The cloud MAC-trigger authentication feature enables the cloud server to provide automated authentication to users as a unified portal authentication, portal Web, and MAC binding server. Users are required to perform manual authentication (entering the username and password) only for the first network access. They are automatically connected to the network without manual authentication for subsequent network access attempts.
# Enable cloud MAC-trigger authentication for MAC binding server mts.
[Sysname-portal-mac-trigger-server-mts] cloud-binding enable
cloud-server url
Use cloud-server url to specify the URL of the cloud portal authentication server.
Use undo cloud-server url to restore the default.
cloud-server url url-string
The URL of the cloud portal authentication server is not specified. The device uses the URL of the portal Web server as the URL of the cloud portal authentication server.
url-string: Specifies the URL of a cloud portal authentication server. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
To separate portal authentication and Web servers, specify the cloud portal authentication server URL by using this command, and specify a different URL for the portal Web server. In this way, you can use a different portal Web server to provide customized authentication pages to users.
# In the view of MAC binding server mts, specify http://lvzhou.h3c.com as the URL of the cloud portal authentication server.
[Sysname-portal-mac-trigger-server-mts] cloud-server url http://lvzhou.h3c.com
default-logon-page
Use default-logon-page to specify the default authentication page file for a local portal Web service.
Use undo default-logon-page to restore the default.
default-logon-page file-name
No default authentication page file is specified for a local portal Web service.
Local portal Web service view
file-name: Specifies the default authentication page file by the file name (without the file storage directory). The file name is a case-sensitive string of 1 to 91 characters. Valid characters are letters, digits, dots (.) and underscores (_).
You must edit the default authentication pages, compress them to a .zip file, and then upload the file to the root directory of the storage medium of the device.
After you use the default-logon-page command to specify the file, the device decompresses the file to get the authentication pages. The device then sets them as the default authentication pages for local portal authentication.
# Specify file pagefile1.zip as the default authentication page file for local portal authentication.
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] default-logon-page pagefile1.zip
display portal
Use display portal to display portal configuration and portal running state.
display portal { ap ap-name [ radio radio-id ] | interface interface-type interface-number }
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. Valid characters are letters, digits, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument is 1 to 4. If you do not specify a radio, this command displays portal configuration and portal running state for all radios of the AP.
# Display portal configuration and portal running state on GigabitEthernet 1/0/1.
<Sysname> display portal interface gigabitethernet 1/0/1
 Portal information of GigabitEthernet1/0/1
     NAS-ID profile: aaa
     Authorization : Strict checking
     ACL           : Enabled
     User profile  : Disabled
     Dual stack    : Disabled
     Dual traffic-separate: Disabled
     Dual IP       : Disabled
     Advertisement push: Enabled
     Embedded advertisement: Enabled
 IPv4:
     Portal status: Enabled
     Portal authentication method: Layer3
     Portal Web server: wbs(active)
     Secondary portal Web server: wbs sec
     Portal mac-trigger-server: mts
     Authentication domain: my-domain
     Pre-auth domain: abc
     Extend-auth domain: abc
     User-dhcp-only: Enabled
     Pre-auth IP pool: ab
     Max portal users: Not configured
     Bas-ip: Not configured
     User detection: Type: ICMP  Interval: 300s  Attempts: 5  Idle time: 180s
     Portal temp-pass: Enabled       Period: 30s
     Action for sever detection:
         Server type    Server name                        Action
         Web server     wbs                                fail-permit
         Portal server  pts                                fail-permit
     Layer3 source network:
         IP address               Mask
         1.1.1.1                  255.255.0.0
     Destination authentication subnet:
         IP address               Mask
         2.2.2.2                  255.255.255.0
     Advertisement push URL: http://192.168.56.3/welcome
IPv6:
     Portal status: enabled
     Portal Web server: wbsv6(active)
     Secondary portal Web server: Not configured
     Portal mac-trigger-server: Not configured
     Extend-auth domain: Not configured
     Bas-ipv6: Not configured
     User detection: Type: ICMPv6  Interval: 300s   Attempts: 5   Idle time: 180s
     Portal temp-pass: Disabled
         Web server     wbsv6                              fail-permit
         Portal server  ptsv6                              fail-permit
         IP address                                        Prefix length
         11::5                                             64
     Advertisement push: Not Configured
# Display portal configuration and portal running state on AP ap1.
<Sysname> display portal ap ap1
Portal information of ap1
 Radio ID: 1
 SSID: portal
     ACL           : Disable
     Dual IP       : Disabled
 IPv4:
     Portal authentication method: Direct
     Extend-auth domain: def
     Max portal users: 1024
     Bas-ip: 2.2.2.2
         IP address                             Mask
         2.2.2.2                                255.255.0.0
     Advertisement push url-group: test
 IPv6:
     User-dhcp-only: Disabled
     Max portal users: 512
     Bas-ipv6: 2000::1
3000::1                                64
# Display portal configuration and portal running state on VLAN-interface 30.
<Sysname> display portal interface Vlan-interface 30
 Portal information of Vlan-interface30
     NAS-ID profile: Not configured
     ACL           : Disable
     Dual IP       : Disabled
 IPv4:
     Portal Web server: pt(active)
     Authentication domain: test
     Pre-auth domain: Not configured
     Pre-auth IP pool: Not configured
     User detection: Not configured
     Portal temp-pass: Enabled,       Period: 30s
     Action for server detection:
         IP address               Mask
         IP address               Mask
     Advertisement push URL: http://192.168.56.3/welcome Traffic:10MB
 IPv6:
     Portal status: Disabled
     Portal authentication method: Disabled
     Portal Web server: Not configured
     Authentication domain: Not configured
     Advertisement push URL: http://[2000::1]/welcome Traffic:10MB
Portal information of interface
Portal configuration on the interface.
Radio ID
ID of the radio.
SSID
Service set identifier.
NAS-ID profile
NAS-ID profile on the interface.
Authorization
Authorization information type: ACL or user profile.
Strict checking
Whether strict checking is enabled on portal authorization information.
Dual stack
Status of the portal dual-stack feature on the interface:
·     Disabled.
·     Enabled.
Status of separate IPv4 and IPv6 traffic statistics for dual-stack portal users on the interface:
·     Disabled.
·     Enabled.
Dual IP
Status of the dual IP feature, disabled or enabled.
This feature enables the device to carry both an IPv4 address and an IPv6 address in RADIUS packets for single-stack users in remote portal authentication.
Advertisement-push
Status of portal advertisement push:
·     Disabled.
·     Enabled.
Status of embedded portal advertisement push:
·     Disabled.
·     Enabled.
IPv4
IPv4 portal configuration.
IPv6
IPv6 portal configuration.
Portal status
Portal authentication status on the interface:
·     Disabled—Portal authentication is disabled.
·     Enabled—Portal authentication is enabled.
·     Authorized—The portal authentication server or portal Web server is unreachable. The interface allows users to have network access without authentication.
Type of authentication enabled on the interface:
·     Direct—Direct authentication.
·     Redhcp—Re-DHCP authentication.
·     Layer3—Cross-subnet authentication.
Portal Web server
Name of the primary portal Web server specified on the interface.
This field displays the (active) flag next to the server name if the server is being used.
Name of the backup portal Web server specified on the interface.
Name of the MAC binding server specified on the interface.
Mandatory authentication domain on the interface.
Pre-auth domain
Preauthentication domain for portal users on the interface.
Extend-auth domain
Authentication domain configured for third-party authentication on an interface.
User-dhcp-only
Status of the user-dhcp-only feature:
·     Enabled—Only users with IP addresses obtained through DHCP can perform portal authentication.
·     Disabled—Both users with IP addresses obtained through DHCP and users with static IP addresses can pass authentication to get online.
Pre-auth ip-pool
Name of the IP address pool specified for portal users before authentication.
Max portal users
Maximum number of portal users allowed on an interface.
Bas-ip
BAS-IP attribute of the portal packets sent to the portal authentication server.
Bas-ipv6
BAS-IPv6 attribute of the portal packets sent to the portal authentication server.
User detection
Configuration for online detection of portal users on the interface, including detection method (ARP, ICMP, ND, or ICMPv6), detection interval, maximum number of detection attempts, and user idle time.
Portal temp-pass
Status of the temporary pass feature:
·     Enabled—The temporary pass feature is enabled.
·     Disabled—The temporary pass feature is disabled.
·     Period—Temporary pass period during which a user can access the Internet temporarily. This field is displayed only if the temporary pass feature is enabled.
Portal server detection configuration on the interface:
·     Server type—Type of the server. Portal server represents the portal authentication server, and Web server represents the portal Web server.
·     Server name—Name of the server.
·     Action—Action triggered by the result of server detection. This field displays fail-permit when the portal fail-permit feature is enabled.
Information of the portal authentication source subnet.
Information of the portal authentication destination subnet.
IP address
IP address of the portal authentication subnet.
Mask
Subnet mask of the portal authentication subnet.
Prefix length
Prefix length of the IPv6 portal authentication subnet address.
URL of the advertisement to be pushed to portal users and the push method related setting:
Possible settings include:
·     Interval—Interval for time-based advertisement push, in minutes.
·     Traffic—Traffic threshold for traffic-based advertisement push, in MB.
·     Time-range—Time range for time range-based advertisement push.
Name of an advertisement group. The advertisements in the group are pushed to portal users.
Use display portal authentication-location to display the portal authenticator, that is, the device that performs portal authentication on clients.
This command takes effect only on local ACs in an AC hierarchy.
# Display the portal authenticator.
<Sysname> display portal authentication-location
 Portal authentication-location: Local
Portal authenticator information:
·     Local—The portal authenticator is the local device.
·     Remote—The portal authenticator is another device.
Use display portal ad-push statistics to display statistics about portal advertisement push.
display portal ad-push statistics { ad-url-group | url }
ad-url-group: Displays statistics on an advertisement group basis.
url: Displays statistics on an advertisement URL basis.
# Display URL-based statistics about portal advertisement push.
<Sysname> display portal ad-push statistics url
PV = Page View        IP = IP        UV = Unique Visitor
   URL                     PV    IP   UV
   www.sina.com.cn         10    5    5
   www.baidu.com.cn        1     1    1
# Display advertisement group-based statistics about portal advertisement push.
<Sysname> display portal ad-push statistics ad-url-group
URL-group name: group1
   URL                     PV    IP    UV
   www.sina.com.cn         1     1     1
   www.dianying.com        2     1     1
URL-group name: group2
   URL                     PV    IP    UV
   www.qq.com              2     1     1
Url-group name
URL
URL of an advertisement.
PV
Number of times that a portal user visits the advertisement page.
This value increases by 1 each time the page is refreshed.
IP
Number of IP addresses from which portal users visit the advertisement page.
UV
Number of portal users with different usernames that visit the advertisement page.
Use display portal auth-error-record to display portal authentication error records.
display portal auth-error-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time }
all: Specifies all portal authentication error records.
ipv4 ipv4-address: Specifies the IPv4 address of a portal user.
ipv6 ipv6-address: Specifies the IPv6 address of a portal user.
start-time start-date start-time end-time end-date end-time: Specifies a time range. The start date and end date must be in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for MM is 1 to 12. The value range for DD varies with the specified month. The value range for YYYY is 1970 to 2037. The start time and end time must be in the format of hh:mm. The value range for the start time and end time is 00:00 to 23:59.
# Display all portal authentication error records.
<Sysname> display portal auth-error-record all
Total authentication error records: 2
User MAC               : 0016-ecb7-a879
Interface              : Vlan-interface100
User IP address        : 192.168.0.188
AP                     : ap1
SSID                   : byod
Auth error time        : 2016-03-04 16:49:07
Auth error reason      : The maximum number of users already reached.
User MAC               : 0016-ecb7-a235
User IP address        : 192.168.0.10
AP                     : ap1
SSID                   : byod
Auth error time        : 2016-03-04 16:51:07
# Display portal authentication error records for the portal user whose IPv4 address is 192.168.0.188.
<Sysname> display portal auth-error-record ip 192.168.0.188
AP                     : ap1
SSID                   : byod
# Display portal authentication error records for the portal user whose IPv6 address is 2000::2.
<Sysname> display portal auth-error-record ipv6 2000::2
User IP address        : 2000::2
AP                     : ap1
SSID                   : byod
# Display portal authentication error records with the error time in the range of 2016/3/4 14:20 to 2016/3/4 14:23.
<Sysname> display portal auth-error-record start-time 2016/3/4 14:20 end-time 2016/3/4 14:23
AP                     : ap1
SSID                   : byod
Auth error time        : 2016-03-04 14:22:25
Total number of portal authentication error records.
User MAC
MAC address of the portal user.
Access interface of the portal user.
User IP address
IP address of the portal user.
AP
AP name.
SSID
Auth error time
Time when the portal user encountered an authentication error, in the format of YYYY-MM-DD hh:mm:ss.
Auth error reason
Reason for the authentication error:
·     The maximum number of users already reached.
·     Failed to obtain user physical information.
·     Failed to receive the packet because packet length is 0.
·     Packet source unknown. Server IP:X.X.X.X, VRF index:0.
·     Packet validity check failed because packet length and version don't match.
·     Packet type invalid.
·     Packet validity check failed due to invalid key.
·     Memory insufficient.
·     Portal is disabled on the interface.
·     The maximum number of users on the interface already reached.
·     Failed to get the access token of the cloud user.
·     Failed to get the user information of the cloud user.
·     Failed to get the access token of the QQ user.
·     Failed to get the openID of the QQ user.
·     Failed to get the user information of the QQ user.
·     Email authentication failed.
·     Failed to get the access token of the Facebook user.
·     Failed to get the user information of the Facebook user.
·     Invalid JSON format of the access token for the cloud user.
·     Invalid JSON format of the user information for the cloud user.
·     Failed to get the user information of the local WeChat user.
·     Invalid access token or App secret.
·     Access token expired.
·     Invalid App ID.
·     Invalid device IP. The IP is not in the whitelist of the WeChat platform.
·     API unauthorized.
·     The WeChat user does not follow the WeChat official account.
·     Failed to create the user because VSRP was down on the interface.
·     Connection to the cloud server timed out.
·     Failed to connect to the cloud server.
·     Failed to get curl resource to request cloud access token.
·     Failed to get curl resource to request cloud user information.
·     Other connection error.
·     No parameters found in the authentication request.
·     Missing authentication parameters such as code, auth-type, portal_server.
·     Cloud user information retrieval timed out.
·     Local WeChat user information retrieval timed out.
·     Failed to create the PAM handle.
·     Failed to set PAM items for authentication.
·     NasPortType is wireless.
·     Packet validity check failed because of invalid packet mode.
·     The user doesn't follow the WeChat official account. Returned 200 OK..
·     User log on while the device is requesting the access token.
·     No matching local MAC-trigger binding entry.
·     Failed to update the local MAC-trigger rule.
·     Failed to get physical info by IP. Ignored the new MAC event.
·     Updated the state of the MAC-trigger rule to no bind when authentication failed.
·     Failed to get binding info for the user from the MAC-trigger server.
·     No matching binding info for the user from the MAC-trigger server.
·     Failed to update the MAC-trigger rule when processing ACK-MAC-BIND.
·     Failed to receive a packet from the portal server.
reset auth-error-record
Use display portal auth-fail-record to display portal authentication failure records.
display portal auth-fail-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
all: Specifies all portal authentication failure records.
username username: Specifies the username of a portal user, a case-sensitive string of 1 to 253 characters. The username cannot contain the domain name.
# Display all portal authentication failure records.
<Sysname> display portal auth-fail-record all
Total authentication fail records: 2
User name              : test@abc
AP                     : ap1
SSID                   : byod
Auth failure time      : 2016-03-04 16:49:07
Auth failure reason    : Authorization information does not exist.
User name              : coco
AP                     : ap1
SSID                   : byod
Auth failure time      : 2016-03-04 16:50:07
# Display portal authentication failure records for the portal user whose IPv4 address is 192.168.0.8.
<Sysname> display portal auth-fail-record ip 192.168.0.188
AP                     : ap1
SSID                   : byod
# Display portal authentication failure records for the portal user whose IPv6 address is 2000::2.
<Sysname> display portal auth-fail-record ipv6 2000::2
AP                     : ap1
SSID                   : byod
# Display portal authentication failure records for the portal user whose username is chap1.
<Sysname> display portal auth-fail-record username chap1
User name              : chap1
AP                     : ap1
SSID                   : byod
# Display portal authentication failure records with the failure time in the range of 2016/3/4 14:20 to 2016/3/4 14:23.
<Sysname> display portal auth-fail-record start-time 2016/3/4 14:20 end-time 2016/3/4 14:23
User name              : chap1
AP                     : ap1
SSID                   : byod
Auth failure time      : 2016-03-04 14:22:25
Table 5 Command output
Total number of portal authentication failure records.
User name
Username of the portal user.
User MAC
User IP address
AP
AP name.
SSID
Auth failure time
Time when the portal user failed authentication, in the format of YYYY/MM/DD hh:mm:ss.
Auth failure reason
Reason why the user failed portal authentication:
·     Failed to get physical information.
·     ACL does not exist.
·     User profile does not exist.
·     Group profile does not exist.
·     ACL authorization failed.
·     QoS deployment failed on LIP.
·     User profile deployment failed on LIP.
·     Group profile deployment failed on LIP.
·     User car deployment failed on LIP.
·     AAA authorization failed.
·     Failed to get valid authorization information from AAA.
·     AAA accounting failed.
·     AAA authentication failed.
·     AAA returned an error.
·     AAA server unreachable.
Use display portal captive-bypass statistics to display packet statistics for portal captive-bypass.
In standalone mode:
In IRF mode:
display portal captive-bypass statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays portal captive-bypass packet statistics on all member devices. (In IRF mode.)
# (In standalone mode.) Display portal captive-bypass packet statistics.
<Sysname> display portal captive-bypass statistics
User type       Packets
iOS:            1
Android:        0
# (In IRF mode.) Display portal captive-bypass packets on the specified slot.
<Sysname> display portal captive-bypass statistics slot 1
Slot 1:
User type       Packets
iOS             1
Android         0
Table 6 Command output
User type
Type of users:
·     iOS.
·     Android.
Packets
Number of portal captive-bypass packets sent to the users.
Use display portal dns free-rule-host to display IP addresses corresponding to host names in destination-based portal-free rules.
display portal dns free-rule-host [ host-name ]
host-name: Specifies a host by its name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), dots (.), and wildcards (asterisks *). The host name cannot be ip or ipv6. If you do not specify a host name, this command displays IP addresses corresponding to all host names in destination-based portal-free rules.
# Display IP addresses corresponding to host name http://www.baidu.com/ in a destination-based portal-free rule.
<Sysname> display portal dns free-rule-host www.baidu.com
 Host name                     IP
 www.baidu.com                 10.10.10.10
# Display IP addresses corresponding to host name *abc.com in a destination-based portal-free rule.
<Sysname> display portal dns free-rule-host *abc.com
 Host name                     IP
 *abc.com                      12.12.12.12
                               111.8.33.100
                               3.3.3.3
Table 7 Command output
Host name
Host name specified in a destination-based portal-free rule.
IP
IP address corresponding to the host name.
Use display portal dns redirect-rule-host to display IP addresses resolved by host names in destination-based portal redirection rules.
display portal dns redirect-rule-host [ host-name ]
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.). If you do not specify a host name, this command displays IP addresses resolved by all host names in all destination-based portal redirection rules.
For destination-based portal redirection rules that specify host names, the device will resolve the host names to IP addresses. Use this command to display IP addresses that are resolved by the host names in redirection rules.
The system can save a maximum of 16 resolved IPv4 addresses and 16 resolved IPv6 addresses. If the maximum number is reached, the new resolved IP address will override the oldest resolved IP address.
# Display IP addresses resolved by host name www.baidu.com in a destination-based portal redirection rule.
<Sysname> display portal dns redirect-rule-host www.baidu.com
 Host name                     IP
# Display IP addresses resolved by host name www.abc.com in a destination-based portal redirection rule.
<Sysname> display portal dns redirect-rule-host www.abc.com
 Host name                     IP
 www.abc.com                   12.12.12.12
                               111.8.33.100
                               3.3.3.3
# Display IP addresses resolved by all host names in all destination-based portal redirection rules.
 Host name                     IP
                               111.8.33.100
                               3.3.3.3
Table 8 Command output
Host name
Host name in a destination-based portal redirection rule.
IP
IP address resolved by the host name.
Use display portal extend-auth-server to display information about third-party authentication servers.
display portal extend-auth-server { all | facebook | mail | qq | wechat }
all: Specifies all third-party authentication servers.
facebook: Specifies the Facebook authentication server.
mail: Specifies the email authentication server.
qq: Specifies the QQ authentication server.
wechat: Specifies the WeChat authentication server.
# Display information about all third-party authentication servers.
<Sysname> display portal extend-auth-server all
Portal extend-auth-server: qq
   Authentication URL : http://graph.qq.com
   APP ID            : 101235509
   APP key           : ******
   Redirect URL      : http://oauthindev.h3c.com/portal/qqlogin.html
Portal extend-auth-server: mail
   Mail protocol      : POP3
   Mail domain name   : @qq.com
Portal extend-auth-server: wechat
  App ID             : wx23fb4aaf04b8491e
  App key            : ******
  App secret         : ******
  Subscribe-required : Enabled
  Shop ID            : 6747662
Portal extend-auth-server: facebook
   Authentication URL : https://graph.facebook.com
   APP ID             : 123456789
   APP key            : ******
   Redirect URL       : http://oauthindev.h3c.com/portal/fblogin.html
Table 9 Command output
Type of the third-party authentication server.
Authentication URL
URL of the third-party authentication server.
APP ID
App ID for the third-party authentication.
APP key
App key for the third-party authentication.
APP secret
App secret for WeChat authentication.
Subscribe-required
Status of the subscribe-required feature:
·     Enabled.
·     Disabled.
Redirect URL
URL to which portal users are redirected after they pass third-party authentication.
Mail protocol
Protocols of the email authentication service.
Mail domain name
Email domain name of the email authentication service.
Shop ID
ID of the shop where the device is deployed as a portal device for WeChat authentication.
Use display portal local-ac-user on the central AC to display information about portal users that come online from local ACs.
display portal local-ac-user { all | ip ipv4-address | ipv6 ipv6-address | mac mac-address | local-ac local-ac-name | username username }
all: Specifies all portal users.
ip ipv4-address: Specifies a portal user by its IPv4 address.
ipv6 ipv6-address: Specifies a portal user by its IPv6 address.
mac mac-address: Specifies a portal user by its MAC address in the format of H-H-H.
local-ac local-ac-name: Specifies a local AC by its name, a case-insensitive string of 1 to 64 characters.
username username: Specifies a portal user by its username, a case-sensitive string of 1 to 253 characters. The username cannot contain a domain name.
Use this command on the central AC in an AC hierarchy. Before you execute this command, enable wireless portal client validity check on the central AC by using the portal host-check enable command.
If you use this command on local ACs, no portal user information is displayed. You can use the display portal user command on local ACs to display portal user information.
# Display information about all portal users that come online from local ACs.
<Sysname> display portal local-ac-user all
Total portal users: 3
Username: abc
IP address: 1.1.1.1
MAC address: 000d-88f8-0eab
Local AC name: local1
Local AC IP address: 2.2.2.2
Username: abd
IP address: 1.1.1.2
MAC address: 00fd-88f8-0eab
Username: def
IP address: 1.1.1.3
MAC address: 000d-88f8-0ecd
Local AC name: local2
Local AC IP address: 2.2.2.3
# Display information about the portal user that uses IP address 1.1.1.1 and comes online from a local AC.
<Sysname> display portal local-ac-user ip 1.1.1.1
Username: abc
IP address: 1.1.1.1
# Display information about the portal user that uses IPv6 address 200::2 and comes online from a local AC.
<Sysname> display portal local-ac-user ipv6 200::2
Username: af
IPv6 address: 200::2
MAC address: 000d-88f5-0eab
# Display information about the portal user that uses MAC address 000d-88f8-0eab and comes online from a local AC.
<Sysname> display portal local-ac-user mac 000d-88f8-0eab
Username: abc
IP address: 1.1.1.1
# Display information about portal users that come online from local AC local1.
<Sysname> display portal local-ac-user local-ac local1
Total portal users: 2
Username: abc
IP address: 1.1.1.1
Username: def
IP address: 1.1.1.2
# Display information about portal user abc that comes online from a local AC.
<Sysname> display portal local-ac-user username abc
Username: abc
IP address: 1.1.1.1
Table 10 Command output
Total portal users
Total number of portal users on local ACs.
Username
IP address
MAC address
Interface through which the portal user passes portal authentication and come online.
Local AC name
Name of the local AC from which the portal user comes online.
Local AC IP address
IP address of the local AC from which the portal user comes online.
display portal user
Use display portal local-binding mac-address to display information about local MAC-account binding entries on the local MAC binding server.
display portal local-binding mac-address { mac-address | all }
mac-address: Specifies the MAC address of a portal user, in the format H-H-H.
all: Specifies all local MAC-account binding entries.
# Display information about all local MAC-account binding entries.
<Sysname> display portal local-binding mac-address all
Total MAC addresses: 5
MAC address                Username            Aging(hh:mm:ss)
0015-e9a6-7cfe             wlan_user1          00:41:38
0000-e27c-6e80             wlan_user2          00:41:38
000f-e212-ff01             wlan_user3          00:41:38
001c-f08f-f804             wlan_user4          00:41:38
000f-e233-9000             wlan_user5          00:41:38
# Display information about the local MAC-account binding entry for the user with MAC address 0015-e9a6-7cfe.
<Sysname> display portal local-binding mac-address 0015-e9a6-7cfe
Total MAC addresses: 1
Table 11 Command output
MAC address
MAC address of a portal user.
Username
Username of a portal user.
Aging
Remaining lifetime of the local MAC-account binding entry.
Use display portal logout-record to display portal user offline records.
display portal logout-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
all: Specifies all portal user offline records.
# Display all portal user offline records.
<Sysname> display portal logout-record all
Total logout records: 2
User IP address        : 192.168.0.8
AP                     : ap1
SSID                   : byod
User login time        : 2016-03-04 14:20:19
User logout time       : 2016-03-04 14:22:05
Logout reason          : Admin Reset
User name              : coco
AP                     : ap1
SSID                   : byod
User login time        : 2016-03-04 14:10:15
User offline time      : 2016-03-04 14:22:05
Offline reason         : Admin Reset
# Display offline records for the portal user whose IP address is 192.168.0.8.
<Sysname> display portal logout-record ip 192.168.0.8
AP                     : ap1
SSID                   : byod
User login time        : 2016-03-04 14:26:12
User logout time       : 2016-03-04 14:27:35
# Display offline records for the portal user whose username is chap1.
<Sysname> display portal logout-record username chap1
User name              : chap1
AP                     : ap1
SSID                   : byod
User login time        : 2016-03-04 17:20:19
User logout time       : 2016-03-04 17:22:05
# Display portal user offline records with the logout time in the range of 2016/3/4 14:20 to 2016/3/4 14:23.
<Sysname> display portal logout-record start-time 2016/3/4 14:20 end-time 2016/3/4 14:23
AP                     : ap1
SSID                   : byod
Table 12 Command output
Total number of portal user offline records.
User name
User MAC
User IP address
AP
AP name.
SSID
User login time
Time when the portal user came online, in the format of YYYY-MM-DD hh:mm:ss.
User logout time
Time when the portal user went offline, in the format of YYYY-MM-DD hh:mm:ss.
Logout reason
Reason why the portal user went offline:
·     User request.
·     DHCP entry deleted.
·     Idle timeout.
·     Session timeout.
·     User detection failure.
·     Force logout by RADIUS server.
·     Interface down.
·     Failed to assign a user rule.
·     Authorization info changed.
·     Force logout by access device.
·     User info synchronization failure.
·     User recovery failure.
·     Authorization ACL for the online user changed.
·     Authorization user profile for the online user changed.
·     Accounting update failure.
·     Failed to start accounting.
·     User traffic reached threshold.
·     Authorization VPN instance deleted.
·     Authorization ACL does not exist.
·     Failed to get physical info.
·     Failed to add an ARP or ND entry for the user.
·     User information does not match user profile.
·     Authorization user profile does not exist.
·     Failed to issue the user rule to the AP.
·     Deleted the user for SSID switchover.
·     Failed to issue an OpenFlow rule to the AP.
·     Logged out the user after the wireless client disconnected.
·     Logged out the user when a new user with the same MAC address performed MAC-trigger authentication.
·     Logged out the user when a new dual-stack user with the same MAC address came online.
·     The portal server failed to instruct the device to change the user IP address.
·     Authorization VPN instance does not exist.
·     Portal failed to cooperate with NAT444.
·     Portal-NAT444 cooperation not supported.
·     DHCP received a DHCP release packet.
·     DHCP lease expired.
·     DHCP received a DHCP release packet from the WLAN roaming center.
·     WLAN roaming center instructed portal to log out the user.
·     Logged out the user after user synchronization through WiFiDog.
·     The cloud portal server instructed portal to log out the user.
Use display portal mac-trigger user to display information about MAC-trigger authentication users (portal users that perform MAC-trigger authentication).
display portal mac-trigger user { all | ip ipv4-address | mac mac-address }
all: Specifies all MAC-trigger authentication users.
ip ipv4-address: Specifies a MAC-trigger authentication user by its IP address.
mac mac-address: Specifies a MAC-trigger authentication user by its MAC address, in the format of H-H-H.
# Display information about all MAC-trigger authentication users.
<Sysname> display portal mac-trigger user all
Total portal mac-trigger users: 8
MAC address      IP address     VLAN ID   Interface          Traffic(Bytes)  State
0050-ba50-732a   1.1.1.6        1         Vlan-interface1    0               NOBIND
0050-ba50-7328   1.1.1.4        1         Vlan-interface1    0               NOBIND
0050-ba50-7326   1.1.1.2        1         Vlan-interface1    0               NOBIND
0050-ba50-732c   1.1.1.8        1         Vlan-interface1    0               NOBIND
0050-ba50-7329   1.1.1.5        1         Vlan-interface1    0               NOBIND
# Display information about the MAC-trigger authentication user whose MAC address is 0050-ba50-7777.
<Sysname> display portal mac-trigger user mac 0050-ba50-7777
0050-ba50-777    1.1.5.83       1         Vlan-interface1    0               NOBIND
# Display information about the MAC-trigger authentication user whose IP address is 1.1.2.126.
<Sysname> display portal mac-trigger user ip 1.1.2.126
0050-ba50-74a2   1.1.2.126      1         Vlan-interface1    0               NOBIND
Table 13 Command output
MAC address
MAC address of the user.
IP address
IP address of the user.
VLAN ID
ID of the VLAN to which the user belongs.
Interface through which the user accesses the network.
Traffic(Bytes)
Traffic of the user, in bytes.
Status of the user:
·     DEFAULT—The user's traffic is below the free-traffic threshold and the user can access the network without authentication.
·     WAIT—The binding status between the user's MAC address and account is being queried.
·     NOBIND—The user's MAC address is not bound with the user's account.
·     BIND—The user's MAC address is bound with the user's account.
·     DISABLE—The MAC-trigger entry for the user is deleted on the device.
Use display portal mac-trigger-server to display information about MAC binding servers.
display portal mac-trigger-server { all | name server-name }
all: Specifies all MAC binding servers.
name server-name: Specifies a MAC binding server by its name, a case-sensitive string of 1 to 32 characters.
# Display information about all MAC binding servers.
<Sysname> display portal mac-trigger-server all
Portal mac-trigger server name: ms1
  Version                    : 2.0
  Server type                : CMCC
  IP                         : 10.1.1.1
  Port                       : 100
  VPN instance               : Not configured
  Aging time                 : 120 seconds
  Free-traffic threshold     : 1000 bytes
  NAS-Port-Type              : 255
  Binding retry times        : 5
  Binding retry interval     : 2 seconds
  Authentication timeout     : 5 minutes
  Local-binding              : Disabled
  Local-binding aging time   : 12 minutes
  aaa-fail nobinding         : Disabled
  Excluded attribute list    : 1
  Cloud-binding              : Disabled
  Cloud server URL           : Not configured
Portal mac-trigger server name: mts
  Version                    : 1.0
  Server type                : IMC
  IP                         : 4.4.4.2
  Port                       : 50100
  Aging time                 : 300 seconds
  Free-traffic threshold     : 0 bytes
  NAS-Port-Type              : Not configured
  Binding retry times        : 3
  Binding retry interval     : 1 seconds
  Authentication timeout     : 3 minutes
  Local-binding aging-time   : 12 minutes
# Display information about MAC binding server ms1.
<Sysname> display portal mac-trigger-server name ms1
  Version                    : 2.0
  Server type                : CMCC
  IP                         : 10.1.1.1
  Port                       : 100
  NAS-Port-Type              : 255
Table 14 Command output
Portal mac trigger server name
Name of the MAC binding server.
Version
Version of the portal protocol:
·     1.0—Version 1.
·     2.0—Version 2.
·     3.0—Version 3.
Server type
Type of the MAC binding server:
·     CMCC—CMCC server.
·     IMC—IMC server.
IP
IP address of the MAC binding server.
Port
UDP port number on which the MAC binding server listens for MAC binding query packets.
VPN instance
MPLS L3VPN where the MAC binding server resides.
Aging time
Aging time in seconds. A MAC-trigger entry is aged out when the aging time expires.
Free-traffic threshold in bytes. If a user's traffic is below the threshold, the user can access the network without authentication.
NAS-Port-Type
NAS-Port-Type attribute value in RADIUS request packets sent to the RADIUS server.
Binding retry times
Maximum number of attempts for sending MAC binding queries to the MAC binding server.
Interval at which the device sends MAC binding queries to the MAC binding server.
Maximum amount of time that the device waits for portal authentication to complete after receiving the MAC binding query response.
Numbers of attributes excluded from portal protocol packets.
Local-binding
Status of local MAC-trigger authentication:
·     Disabled.
·     Enabled.
Aging time for local MAC-account binding entries, in minutes.
Cloud-binding
Status of cloud MAC-trigger authentication:
·     Disabled.
·     Enabled.
Cloud server URL
aaa-fail nobinding
Status of the AAA failure unbinding feature:
·     Disabled.
·     Enabled.
display portal packet statistics
Use display portal packet statistics to display packet statistics for portal authentication servers and MAC binding servers.
display portal packet statistics [ extend-auth-server { cloud | facebook | mail | qq | wechat } | mac-trigger-server server-name | server server-name ] *
extend-auth-server: Specifies a third-party authentication server.
cloud: Specifies the cloud authentication server.
mac-trigger-server server-name: Specifies a MAC binding server by its name, a case-sensitive string of 1 to 32 characters.
server server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters.
If you do not specify any parameters, this command displays packet statistics for all third-party authentication servers, portal authentication servers, and MAC binding servers.
# Display packet statistics for portal authentication server pts.
<Sysname> display portal packet statistics server pts
 Portal server :  pts
 Invalid packets: 0
 Pkt-Type                            Total    Drops    Errors
 REQ_CHALLENGE                       3        0        0
 ACK_CHALLENGE                       3        0        0
 REQ_AUTH                            3        0        0
 ACK_AUTH                            3        0        0
 REQ_LOGOUT                          1        0        0
 ACK_LOGOUT                          1        0        0
 AFF_ACK_AUTH                        3        0        0
 NTF_LOGOUT                          1        0        0
 REQ_INFO                            6        0        0
 ACK_INFO                            6        0        0
 NTF_USERDISCOVER                    0        0        0
 NTF_USERIPCHANGE                    0        0        0
 AFF_NTF_USERIPCHAN                  0        0        0
 ACK_NTF_LOGOUT                      1        0        0
 NTF_HEARTBEAT                       0        0        0
 NTF_USER_HEARTBEAT                  2        0        0
 ACK_NTF_USER_HEARTBEAT              0        0        0
 NTF_CHALLENGE                       0        0        0
 NTF_USER_NOTIFY                     0        0        0
 AFF_NTF_USER_NOTIFY                 0        0        0
# Display packet statistics for MAC binding server newpt.
<Sysname> display portal packet statistics mac-trigger-server newpt
 MAC-trigger server: newpt
 Invalid packets: 0
 REQ_MACBIND                         1        0        0
 ACK_MACBIND                         1        0        0
 NTF_MTUSER_LOGON                    1        0        0
 NTF_MTUSER_LOGOUT                   0        0        0
 REQ_MTUSER_OFFLINE                  0        0        0
# Display packet statistics for the cloud authentication server.
<Sysname> display portal packet statistics extend-auth-server cloud
Extend-auth server:  cloud
 Update interval:  60
  Pkt-Type               Success    Error      Timeout    Conn-failure
  REQ_ACCESSTOKEN        1          0          0          0
  REQ_USERINFO           1          0          0          0
  RESP_ACCESSTOKEN       1          0          0          0
  RESP_USERINFO          1          0          0          0
  POST_ONLINEDATA        0          0          0          0
  RESP_ONLINEDATA        0          0          0          0
  POST_OFFLINEUSER       1          0          0          0
  REPORT_ONLINEUSER      1          0          0          0
  REQ_CLOUDBIND          1          0          0          0
  RESP_CLOUDBIND         1          0          0          0
  REQ_BINDUSERINFO       0          0          0          0
  RESP_BINDUSERINFO      0          0          0          0
  AUTHENTICATION         0          1          0          0
Table 15 Command output
Portal server
Name of the portal authentication server.
Invalid packets
Number of invalid packets.
Pkt-Type
Packet type.
Total
Total number of packets.
Drops
Number of dropped packets.
Errors
Number of packets that carry error information.
REQ_CHALLENGE
Challenge request packet the portal authentication server sent to the access device.
ACK_CHALLENGE
Challenge acknowledgment packet the access device sent to the portal authentication server.
REQ_AUTH
Authentication request packet the portal authentication server sent to the access device.
ACK_AUTH
Authentication acknowledgment packet the access device sent to the portal authentication server.
REQ_LOGOUT
Logout request packet the portal authentication server sent to the access device.
ACK_LOGOUT
Logout acknowledgment packet the access device sent to the portal authentication server.
AFF_ACK_AUTH
Affirmation packet the portal authentication server sent to the access device after receiving an authentication acknowledgment packet.
NTF_LOGOUT
Forced logout notification packet the access device sent to the portal authentication server.
REQ_INFO
Information request packet.
ACK_INFO
Information acknowledgment packet.
NTF_USERDISCOVER
User discovery notification packet the portal authentication server sent to the access device.
NTF_USERIPCHANGE
User IP change notification packet the access device sent to the portal authentication server.
AFF_NTF_USERIPCHAN
User IP change success notification packet the portal authentication server sent to the access device.
ACK_NTF_LOGOUT
Forced logout acknowledgment packet the portal authentication server sent to the access device.
NTF_HEARTBEAT
Server heartbeat packet the portal authentication server periodically sent to the access device.
NTF_USER_HEARTBEAT
User synchronization packet the portal authentication server sent to the access device.
User synchronization acknowledgment packet the access device sent to the portal authentication server.
NTF_CHALLENGE
Challenge request packet the access device sent to the portal authentication server.
NTF_USER_NOTIFY
User information notification packet the access device sent to the portal authentication server.
AFF_NTF_USER_NOTIFY
NTF_USER_NOTIFY acknowledgment packet the portal authentication server sent to the access device.
MAC-trigger server
REQ MACBIND
MAC binding request packet the access device sent to the MAC binding server.
ACK_MACBIND
MAC binding acknowledgment packet the MAC binding server sent to the access device.
NTF_MTUSER_LOGON
User logon notification packet the access device sent to the MAC binding server.
NTF_MTUSER_LOGOUT
User logout notification packet the access device sent to the MAC binding server.
REQ_MTUSER_OFFLINE
Forced offline request packet the MAC binding server sent to the access device.
Extend-auth server
Type of the third-party authentication server:
·     qq—QQ authentication server.
·     mail—Email authentication server.
·     wechat—WeChat authentication server.
·     cloud—Cloud authentication server.
·     facebook—Facebook authentication server.
Update interval
Interval at which the device sends online user information to the cloud server, in seconds.
This field is displayed only if the third-party authentication server is the cloud authentication server.
Success
Number of packets that have been successfully sent or received.
Timeout
Number of packets that timed out of establishing a connection to the third-party authentication server.
Conn-failure
Number of packets that failed to establish a connection to the third-party authentication server.
Deny
Number of packets denied access to the third-party authentication server.
This field is displayed only if the third-party authentication server is the email authentication server.
REQ_ACCESSTOKEN
Access token request packet the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is QQ, Facebook, cloud, or WeChat authentication server.
REQ_OPENID
Open ID request packet the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is the QQ authentication server.
REQ_USERINFO
User information request packet the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is the QQ, Facebook, cloud, or WeChat authentication server.
RESP_ACCESSTOKEN
Access token response packet the access device received from the third-party authentication server.
RESP_OPNEID
Open ID response packet the access device received from the third-party authentication server.
RESP_USERINFO
User information response packet the access device received from the third-party authentication server.
REQ_POP3
POP3 authentication request packet the access device sent to the third-party authentication server.
REQ_IMAP
IMAP authentication request packet the access device sent to the third-party authentication server.
POST_ONLINEDATA
Cloud user information request packet the access device sent to the third-party authentication server.
RESP_ONLINEDATA
Cloud user information response packet the access device received from the third-party authentication server.
POST_OFFLINEUSER
Cloud user offline packet the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is the cloud or WeChat authentication server.
REPORT_ONLINEUSER
Cloud user online packet the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is cloud or WeChat authentication server.
REQ_CLOUDBIND
Cloud user binding status query request that the access device sent to the third-party authentication server.
This field is displayed only if the third-party authentication server is cloud authentication server.
RESP_CLOUDBIND
Cloud user binding status query response that the access device received from the third-party authentication server.
REQ_BINDUSERINFO
Cloud user information request packet that the access device sent to the third-party authentication server.
RESP_BINDUSERINFO
Cloud user information response packet that the access device received from the third-party authentication server.
AUTHENTICATION
Result of third-party authentication.
reset portal packet statistics
display portal permit-rule statistics
Use display portal permit-rule statistics to display statistics for portal permit rules.
Portal permit rules refer to category-1 and category-2 portal filtering rules, which permit user packets to pass.
# Display statistics for portal permit rules.
<Sysname> display portal permit-rule statistics
Interface             Free rules           Fuzzy rules            User rules
Vlan-interface30      2                    5                      10
Vlan-interface30      2                    3                      6
Table 16 Command output
Interface on which portal permit rules are used.
Free rules
Number of permit rules generated based on configured portal-free rules, excluding permit rules generated based on fuzzy matches of destination-based portal-free rules.
Fuzzy rules
Number of permit rules generated based on fuzzy matches of destination-based portal-free rules.
User rules
Number of permit rules generated after portal users pass authentication.
display portal redirect session
Use display portal redirect session to display redirect session statistics for online portal users.
In standalone mode:
display portal redirect session [ ip ipv4-address | ipv6 ipv6-address ]
In IRF mode:
display portal redirect session [ ip ipv4-address | ipv6 ipv6-address ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays redirect session statistics for online portal users on all member devices. (In IRF mode.)
If you do not specify a user IPv4 or IPv6 address, this command displays redirect session statistics for all online portal users.
# (In standalone mode.) Display redirect session statistics for all online portal users.
<Sysname> display portal redirect session
Total HTTP sessions: 40
Total HTTP rejected: 2542
Total HTTPS sessions: 40
Total HTTPS rejected: 0
IP: 192.168.0.1
  HTTP sessions: 20
  HTTP rejected: 10
  HTTPS sessions: 20
  HTTPS rejected: 40
IP: 192.168.0.2
  HTTP sessions: 20
  HTTP rejected: 8
  HTTPS sessions: 20
  HTTPS rejected: 40
# (In IRF mode.) Display redirect session statistics for all online portal users on the specified slot.
<Sysname> display portal redirect session slot 0
IP: 192.168.0.1
  HTTP sessions: 20
  HTTP rejected: 10
  HTTPS sessions: 20
  HTTPS rejected: 40
IP: 192.168.0.2
  HTTP sessions: 20
  HTTP rejected: 8
  HTTPS sessions: 20
  HTTPS rejected: 40
# (In standalone mode.) Display redirect session statistics for online portal user at 192.168.0.2.
<Sysname> display portal redirect session ip 192.168.0.2
IP: 192.168.0.2
  HTTP sessions: 128
  HTTP rejected: 10
  HTTPS sessions: 0
  HTTPS rejected: 0
# (In IRF mode.) Display redirect session statistics for online portal user at 192.168.0.2 on the specified slot.
<Sysname> display portal redirect session ip 192.168.0.2 slot 0
IP: 192.168.0.2
  HTTP sessions: 128
  HTTP rejected: 10
  HTTPS sessions: 0
  HTTPS rejected: 0
Table 17 Command output
Total HTTP sessions
Total number of HTTP redirect sessions.
Total HTTP rejected
Total number of discarded HTTP redirect session requests.
Total number of HTTPS redirect sessions.
Total number of discarded HTTPS redirect session requests.
IP
IP address of the online portal user.
HTTP sessions
Number of HTTP redirect sessions for the user.
HTTP rejected
Number of discarded HTTP redirect requests for the user.
HTTPS sessions
Number of HTTPS redirect sessions for the user.
HTTPS rejected
Number of discarded HTTPS redirect requests for the user.
portal redirect max-session
portal redirect max-session per-user
display portal redirect session-statistics
Use display portal redirect session-statistics to display summary statistics about portal redirect sessions.
In standalone mode:
In IRF mode:
display portal redirect session-statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays summary statistics about portal redirect sessions on all member devices. (In IRF mode.)
# (In standalone mode.) Display summary statistics about portal redirect sessions.
<Sysname> display portal redirect session-statistics
  HTTP sessions  HTTP rejected  HTTPS sessions  HTTPS rejected
  30             2              73              3
# (In IRF mode.) Display summary statistics about portal redirect sessions on the specified slot.
<Sysname> display portal redirect session-statistics slot 0
  30             2              73              3
Table 18 Command output
HTTP sessions
Number of HTTP redirect sessions for all portal users.
HTTP rejected
Number of rejected HTTP redirect session requests for all portal users.
HTTPS sessions
Number of HTTPS redirect sessions for all portal users.
HTTPS rejected
Number of rejected HTTPS redirect session requests for all portal users.
display portal redirect statistics
Use display portal redirect statistics to display portal redirect packet statistics.
In standalone mode:
In IRF mode:
display portal redirect statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays portal redirect packet statistics on all member devices. (In IRF mode.)
# (In standalone mode.) Display portal redirect packet statistics.
<Sysname> display portal redirect statistics
 HTTP requests  HTTP responses  HTTPS requests  HTTPS responses
 1              1               1               1
# (In IRF mode.) Display portal redirect packet statistics on the specified slot.
<Sysname> display portal redirect statistics slot 1
 1              1               1               1
Table 19 Command output
HTTP requests
Total number of HTTP redirect requests.
HTTP responses
Total number of HTTP redirect responses.
HTTPS requests
Total number of HTTPS redirect requests.
HTTPS responses
Total number of HTTPS redirect responses.
display portal roaming-center statistics packet
Use display portal roaming-center statistics packet to display packet statistics for the portal roaming center.
# Display packet statistics for the portal roaming center.
<Sysname> display portal roaming-center statistics packet
Total sent packets: 0
Total received packets: 0
Invalid packets: 0
Pkt-Type                   Success                  Failed             Timeout
RC_REQ_INFO                1                        1                  0
RC_ACK_INFO                1                        2                  1
RC_REQ_ONLINE              1                        2                  0
RC_ACK_ONLINE              1                        1                  1
RC_REQ_OFFLINE             1                        1                  0
RC_ACK_OFFLINE             1                        1                  1
RC_REQ_DHCPINFO            1                        1                  1
RC_ACK_DHCPINFO            1                        1                  1
RC_REQ_NTY_OFFLINE         1                        1                  0
RC_ACK_NTY_OFFLINE         1                        1                  1
Table 20 Command output
Total sent packets
Total number of packets that the portal roaming center sent to the WLAN roaming center.
Total number of packets that the portal roaming center received from the WLAN roaming center.
Invalid packets
Total number of incoming invalid packets.
Pkt-Type
Type of the packet:
·     RC_REQ_INFO—User query request that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_INFO—User query response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_ONLINE—User online packet that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_ONLINE—User online response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_OFFLINE—User offline packet that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_OFFLINE—User offline response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_DHCPINFO—User DHCP information packet that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_DHCPINFO—User DHCP information response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_NTY_OFFLINE—User offline packet that the WLAN roaming center sends to the portal roaming center.
·     RC_ACK_NTY_OFFLINE—User offline response that the portal roaming center sends to the WLAN roaming center.
Success
Total number of packets that have been successfully transmitted from the portal roaming center to the WLAN roaming center.
·     For RC_REQ_DHCPINFO packets, this field counts all the user DHCP information packets successfully exchanged between the portal roaming center and the WLAN roaming center.
·     For RC_ACK_DHCPINFO packets, this field counts all the user DHCP information responses successfully exchanged between the portal roaming center and the WLAN roaming center.
Failed
Total number of packets that failed to be transmitted from the portal roaming center to the WLAN roaming center.
·     For RC_REQ_DHCPINFO packets, this field counts all the user DHCP information packets that failed to be exchanged between the portal roaming center and the WLAN roaming center.
·     For RC_ACK_DHCPINFO packets, this field counts all the user DHCP information responses that failed to be exchanged between the portal roaming center and the WLAN roaming center.
Timeout
Number of times that the packet transmission timed out.
reset portal roaming-center statistics packet
display portal rule
Use display portal rule to display portal filtering rules.
In standalone mode:
display portal rule { all | dynamic | static } { ap ap-name [ radio radio-id ] | interface interface-type interface-number }
In IRF mode:
display portal rule { all | dynamic | static } { ap ap-name [ radio radio-id ] | interface interface-type interface-number [ slot slot-number ] }
all: Displays all portal filtering rules, including dynamic and static portal filtering rules.
dynamic: Displays dynamic portal filtering rules, which are generated after users pass portal authentication. These rules allow packets with specific source IP addresses to pass the interface.
static: Displays static portal filtering rules, which are generated after portal authentication is enabled. The interface filters packets by these rules when portal authentication is enabled.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument is 1 to 4. If you do not specify a radio, this command displays portal filtering rules for all radios of the AP.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays portal filtering rules on all member devices. (In IRF mode.)
# (In standalone mode.) Display all portal filtering rules on GigabitEthernet 1/0/1.
<Sysname> display portal rule all interface gigabitethernet 1/0/1
IPv4 portal rules on GigabitEthernet1/0/1:
Rule 1:
 Type                : Static
 Action              : Forbid
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    SSID           : portal
    Interface      : GigabitEthernet1/0/1
Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
Rule 2:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    MAC            : 0000-0000-0000
    VLAN           : Any
 Destination:
    IP             : 192.168.0.111
    Mask           : 255.255.255.255
    Port           : Any
Rule 3:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 2.2.2.2
    MAC            : 000d-88f8-0eab
    VLAN           : Any
 Author ACL:
    Number         : 3001
 Author Web URL    : http://1.1.1.1
Rule 4:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
    Protocol       : TCP
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
IPv6 portal rules on GigabitEthernet1/0/1:
Rule 1:
 Type                : Static
 Action              : Forbid
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length   : 0
    Port           : Any
    SSID           : portal
Destination:
    IP               : 3000::1
    Prefix length    : 64
    Port             : Any
Rule 2:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    Port           : Any
    VLAN           : Any
 Destination:
    IP             : 3000::1
    Prefix length  : 64
    Port           : Any
Rule 3:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP              : 3000::1
    MAC             : 0015-e9a6-7cfe
    VLAN            : Any
 Author ACL:
    Number          : 3001
 Author Web URL     : http://4000::1
Rule 4:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP              : ::
    Prefix length   : 0
    VLAN            : Any
    Protocol        : TCP
 Destination:
    IP              : ::
    Prefix length   : 0
    Port            : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    VLAN           : Any
 Destination:
    IP             : ::
    Prefix length  : 0
Rule 6:
 Type                : Static
 Action              : Match pre-auth ACL
 Status              : Active
 Source:
Pre-auth ACL:
    Number          : 3002
# (In standalone mode.) Display all portal filtering rules on AP ap1.
<Sysname> display portal rule all ap ap1
Slot 1:
IPv4 portal rules on ap1:
Radio ID : 1
SSID     : portal
Rule 1:
 Type                : Static
 Action              : Forbid
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    SSID           : portal
    Interface      : WLAN-BSS1/0/1
Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
Rule 2:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP        : 0.0.0.0
    Mask      : 0.0.0.0
    Port      : 23
    VLAN      : any
 Destination:
    IP        : 192.168.0.111
    Port      : Any
Rule 3:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP        : 2.2.2.2
    VLAN      : 2
 Author ACL:
    Number    : N/A
Rule 4:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP        : 0.0.0.0
    Mask      : 0.0.0.0
    VLAN      : any
    Protocol  : TCP
 Destination:
    IP        : 0.0.0.0
    Mask      : 0.0.0.0
    Port      : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP        : 0.0.0.0
    Mask      : 0.0.0.0
    VLAN      : Any
 Destination:
    IP        : 0.0.0.0
    Mask      : 0.0.0.0
# (In IRF mode.) Display all portal filtering rules on GigabitEthernet 1/0/1 for the specified slot.
<Sysname> display portal rule all interface gigabitethernet 1/0/1 slot 1
Slot 1:
Rule 1:
 Type                : Static
 Action              : Forbid
 Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    SSID           : portal
Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
Rule 2:
 Type                : Static
 Action              : Permit
Protocol            : Any
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : Any
    VLAN           : Any
 Destination:
    IP             : 192.168.0.111
    Port           : Any
Rule 3:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 2.2.2.2
    VLAN           : Any
 Author ACL:
    Number         : 3001
Rule 4:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
    Protocol       : TCP
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    Port           : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
    VLAN           : Any
 Destination:
    IP             : 0.0.0.0
    Mask           : 0.0.0.0
Rule 1:
 Type                : Static
 Action              : Forbid
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length   : 0
    Port           : Any
    SSID           : portal
Destination:
    IP               : 3000::1
    Prefix length    : 64
    Port             : Any
Rule 2:
 Type                : Static
 Action              : Permit
 Protocol            : Any
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    Port           : Any
    VLAN           : Any
 Destination:
    IP             : 3000::1
    Prefix length  : 64
    Port           : Any
Rule 3:
 Type                 : Dynamic
 Action               : Permit
 Status               : Active
 Source:
    IP              : 3000::1
    VLAN            : Any
 Author ACL:
    Number          : 3001
Rule 4:
 Type                 : Static
 Action               : Redirect
 Status               : Active
 Source:
    IP              : ::
    Prefix length   : 0
    VLAN            : Any
    Protocol        : TCP
 Destination:
    IP              : ::
    Prefix length   : 0
    Port            : 80
Rule 5:
 Type                : Static
 Action              : Deny
 Status              : Active
 Source:
    IP             : ::
    Prefix length  : 0
    VLAN           : Any
 Destination:
    IP             : ::
    Prefix length  : 0
Rule 6:
 Type                : Static
 Status              : Active
 Source:
Pre-auth ACL:
    Number         : 3002
Table 21 Command output
Radio ID
ID of the radio.
SSID
Rule
Number of the portal rule. IPv4 portal filtering rules and IPv6 portal filtering rules are numbered separately.
Type of the portal filtering rule:
·     Static—Static portal rule.
·     Dynamic—Dynamic portal rule.
Action
Action triggered by the portal filtering rule:
·     Permit—The interface allows packets to pass.
·     Forbid—The interface forbids packets to pass.
·     Redirect—The interface redirects packets.
·     Deny—The interface denies packets.
·     Match pre-auth ACL—The interface matches packets against the authorized ACL rules in the preauthentication domain.
Protocol
Transport layer protocol permitted by the portal filtering rule:
·     Any—Permits any transport layer protocol.
·     TCP—Permits TCP.
·     UDP—Permits UDP.
Status
Status of the portal filtering rule:
·     Active—The portal rule is effective.
·     Unactuated—The portal rule is not activated.
Source
Source information of the portal filtering rule.
IP
Source IPv4 or IPv6 address.
If the IPv6 address of a portal user changes after the user has come online, this field displays colons (::). This value indicates that no IP address is specified in the portal filtering rule.
Mask
Subnet mask of the source IPv4 address.
Prefix length
Prefix length of the source IPv6 address.
Port
Source transport layer port number.
MAC
Source MAC address.
SSID
Source SSID.
This field is displayed only if an SSID is specified in the portal-forbidden rule configured by using the portal forbidden-rule command.
Layer 2 or Layer 3 interface on which the portal rule is implemented.
VLAN
Source VLAN ID.
Protocol
Transport layer protocol of the portal redirect rule. This field always displays TCP.
Destination
Destination information of the portal filtering rule.
IP
Destination IP address.
Port
Destination transport layer port number.
Mask
Subnet mask of the destination IPv4 address.
Prefix length
Prefix length of the destination IPv6 address.
Author ACL
Authorized ACL assigned to authenticated portal users. This field is displayed only for a dynamic portal filtering rule.
Pre-auth ACL
Authorized ACL assigned to preauthentication portal users. This field is displayed only for the Match pre-auth ACL action.
Number
Number of the authorized ACL. This field displays N/A if the AAA server does not assign an ACL.
Author Web URL
Authorized Web URL assigned to portal users. This field is displayed only for a dynamic portal filtering rule.
display portal safe-redirect statistics
Use display portal safe-redirect statistics to display portal safe-redirect packet statistics.
In standalone mode:
In IRF mode:
display portal safe-redirect statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics on all member devices. (In IRF mode.)
# (In standalone mode.) Display portal safe-redirect packet statistics.
<Sysname> display portal safe-redirect statistics
Redirect statistics:
  Success: 5
  Failure: 6
  Total: 11
Method statistics:
  Get: 6
  Post: 2
  Others: 3
Default-action statistics:
  Permit: 1
  Forbid: 0
User agent statistics:
  Safari: 3
  Chrome: 2
Forbidden User URL statistics:
  http://www.abc.com: 0
Forbidden filename extension statistics:
.jpg: 0
# (In IRF mode.) Display portal safe-redirect packet statistics on the specified slot.
<Sysname> display portal safe-redirect statistics slot 1
Slot 1:
  Success: 7
  Failure: 8
  Total  : 15
Method statistics:
  Get    : 11
  Post   : 1
  Others : 3
  Permit: 1
  Forbid: 0
  Safari: 3
  Chrome: 2
  www.qq.com: 4
  .jpg: 0
Table 22 Command output
Success
Number of packets redirected successfully.
Failure
Number of packets failed redirection.
Total
Method statistics
Statistics of HTTP request methods.
Get
Number of packets with the GET request method.
Post
Number of packets with the POST request method.
Other
Number of packets with other request methods.
Browser types (in HTTP User Agent) allowed by portal safe-redirect, and packet statistics for the browsers.
Forbidden URL statistics
URLs forbidden by portal safe-redirect, and statistics for packets dropped by forbidden URL filtering.
File extensions forbidden by portal safe-redirect, and statistics for packets dropped by forbidden file extension filtering.
Permit user URL statistics
URLs permitted by portal safe-redirect, and packet statistics for the URLs.
Statistics on packets processed by the default actions of portal safe-redirect.
reset portal safe-redirect statistics
display portal server
Use display portal server to display information about portal authentication servers.
display portal server [ server-name ]
server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters. If you do not specify the server-name argument, this command displays information about all portal authentication servers.
# Display information about portal authentication server pts.
<Sysname> display portal server pts
Portal server: pts
  Type                  : IMC
  IP                    : 192.168.0.111
  Port                  : 50100
  Server detection      : Timeout 60s  Action: log, trap
  User synchronization  : Timeout 200s
  Status                : Up
  Exclude-attribute     : Not configured
  Logout notification   : Retry 3 interval 5s
Table 23 Command output
Portal authentication server type:
·     CMCC—CMCC server.
·     IMC—IMC server.
Portal server
IP
IP address of the portal authentication server.
VPN instance
MPLS L3VPN where the portal authentication server resides.
Port
Listening port on the portal authentication server.
Server detection
Parameters for portal authentication server detection:
·     Detection timeout in seconds.
·     Actions (log and trap) triggered by the reachability status change of the portal authentication server.
User idle timeout in seconds for portal user synchronization.
Status
Reachability status of the portal authentication server:
·     Up—This value indicates one of the following conditions:
¡     Portal authentication server detection is disabled.
¡     Portal authentication server detection is enabled and the server is reachable.
·     Down—Portal authentication server detection is enabled and the server is unreachable.
Exclude-attribute
Attributes that are not carried in portal protocol packets sent to the portal authentication server.
Logout notification
Maximum number of times and the interval (in seconds) for retransmitting a logout notification packet.
portal enable
portal server
server-detect (portal authentication server view)
user-sync
display portal user
Use display portal user to display information about portal users.
display portal user { all | ap ap-name [ radio radio-id ] | auth-type { cloud | email | facebook | local | mac-trigger | normal | qq | wechat } | interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address | mac mac-address | pre-auth [ interface interface-type interface-number | ip ipv4-address | ipv6 ipv6-address ] | username username } [ brief | verbose ]
all: Displays information about all portal users.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. Valid characters are letters, digits, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument is 1 to 4. If you do not specify a radio, this command displays information about portal users for all radios of the AP.
auth-type: Specifies an authentication type.
cloud: Specifies the cloud authentication (a cloud portal authentication server performs portal authentication on portal users).
email: Specifies the email authentication.
facebook: Specifies the Facebook authentication.
local: Specifies the local authentication (a local portal authentication server performs portal authentication on portal users).
mac-trigger: Specifies the MAC-trigger authentication.
normal: Specifies the normal authentication (a remote portal authentication server performs portal authentication on portal users).
qq: Specifies QQ authentication.
wechat: Specifies WeChat authentication.
interface interface-type interface-number: Displays information about portal users on the specified interface.
ip ipv4-address: Specifies the IPv4 address of a portal user.
mac mac-address: Specifies the MAC address of a portal user, in the format of H-H-H.
pre-auth: Displays information about preauthentication portal users. A preauthentication user is a user who is authorized with the authorization attributes in a preauthentication domain before portal authentication. If you do not specify the pre-auth keyword, this command displays information about authenticated portal users.
brief: Displays brief information about portal users.
verbose: Displays detailed information about portal users.
If you specify neither the brief nor the verbose keyword, this command displays portal authentication-related information for portal users.
# Display information about all portal users.
<Sysname> display portal user all
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
  MAC                IP                 VLAN   Interface
  000d-88f8-0eab     2.2.2.2            --     GigabitEthernet1/0/1
  Authorization information:
    DHCP IP pool: N/A
    User profile: abc (active)
    Session group profile: N/A
    ACL number/name: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
    Web URL: N/A
Username: def
  Portal server: pts
  State: Online
  VPN instance: N/A
  000d-88f8-0eac     3.3.3.3            --     GigabitEthernet1/0/2
    DHCP IP pool: N/A
    User profile: N/A
    ACL number/name: 3000
    Inbound CAR: CIR 9000       bps PIR 20500      bps
                 CBS 20500      bit (active)
    Outbound CAR: CIR 9000       bps PIR 20400      bps
                  CBS 20400      bit (active)
    Web URL: http://1.1.1.1
# Display information about portal users whose authentication type is normal portal authentication.
<Sysname> display portal user auth-type normal
Total normal users: 1
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
# Display information about the portal user whose MAC address is 000d-88f8-0eab.
<Sysname> display portal user mac 000d-88f8-0eab
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
# Display information about the portal user whose username is abc.
<Sysname> display portal user username abc
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Total portal users: 1
Username: def
  AP name: ap1
  Radio ID: 1
  SSID: portal
  Portal server: pts
  State: Online
  VPN instance: vpn1
  000d-88f8-0eac     4.4.4.4            2     Bss1/2
    DHCP IP pool: N/A
    User profile: N/A
# Display information about portal users whose authentication type is normal authentication.
Total remote users: 1
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
  000d-88f8-0eab     2.2.2.2            2      WLAN-BSS1/0/1
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Table 24 Command output
Total portal users
Total number of portal users.
Total normal users
Total number of portal users whose authentication type is normal authentication.
Total local users
Total number of portal users whose authentication type is local authentication.
Total email users
Total number of portal users whose authentication type is email authentication.
Total cloud users
Total number of portal users whose authentication type is cloud authentication.
Total QQ users
Total number of portal users whose authentication type is QQ authentication.
Total WeChat users
Total number of portal users whose authentication type is WeChat authentication.
Total facebook users
Total number of portal users whose authentication type is Facebook authentication.
Total MAC-trigger users
Total number of portal users whose authentication type is MAC-trigger authentication.
Username
Name of the user.
Portal server
Current state of the portal user:
·     Initialized—The user is initialized and ready for authentication.
·     Authenticating—The user is being authenticated.
·     Waiting SetRule—Deploying portal rules to the user.
·     Authorizing—The user is being authorized.
·     Online—The user is online.
·     Waiting Traffic—Waiting for traffic from the user.
·     Stop Accounting—Stopping accounting for the user.
·     Done—The user is offline.
VPN instance
Name of the authorization VPN instance. If no VPN instance is authorized for the portal user, this field displays the MPLS L3VPN that the portal user belongs to. If the portal user is on a public network, this field displays N/A.
MAC
MAC address of the portal user.
IP
IP address of the portal user.
VLAN
VLAN where the portal user resides.
Access interface of the portal user.
Authorization information for the portal user.
DHCP IP pool
Name of the authorized IP address pool. If no IP address pool is authorized for the portal user, this field displays N/A.
User profile
Authorized user profile:
·     N/A—The AAA server authorizes no user profile.
·     active—The AAA server has authorized the user profile successfully.
·     inactive—The AAA server failed to authorize the user profile or the user profile does not exist on the device.
Authorized session group profile:
·     N/A—The AAA server authorizes no session group profile.
·     active—The AAA server has authorized the session group profile successfully.
·     inactive—The AAA server failed to authorize the session group profile or the session group profile does not exist on the device.
ACL number/name
Number or name of the authorized ACL:
·     N/A—The AAA server authorizes no ACL.
·     active—The AAA server has authorized the ACL successfully.
·     inactive—The AAA server failed to authorize the ACL or the ACL does not exist on the device.
Inbound CAR
Authorized inbound CAR information:
·     CIR—Committed information rate in bps.
·     PIR—Peak information rate in bps.
·     CBS—Committed burst size in bits.
·     active—The AAA server has authorized the inbound CAR successfully.
·     inactive—The AAA server failed to authorize the inbound CAR.
If no inbound CAR is authorized, this field displays N/A.
Outbound CAR
Authorized outbound CAR information:
·     active—The AAA server has authorized the outbound CAR successfully.
·     inactive—The AAA server failed to authorize the outbound CAR.
If no outbound CAR is authorized, this field displays N/A.
Web URL
Authorized Web URL. This field displays N/A if no Web URL is authorized.
# Display detailed information about the portal user with IP address 50.50.50.3.
<Sysname> display portal user ip 50.50.50.3 verbose
Basic:
  Current IP address: 50.50.50.3
  Original IP address: 30.30.30.2
  Username: user1@hrss
  User ID: 0x18000002
  Access interface: eth0/1
  Service-VLAN/Customer-VLAN: -/-
  MAC address: 0000-0000-0001
  Authentication type: Normal
  Domain: hrss
  VPN instance: 123
  Status: Online
  Portal server: test
  Vendor: Apple
  Portal authentication method: Direct
AAA:
 Realtime accounting interval: 60s, retry times: 3
  Idle-cut:180 sec, 10240 bytes
  Session duration: 500 sec, remaining: 300 sec
  Remaining traffic: 10240000 bytes
  Login time: 2014-01-19  2:42:3 UTC
  DHCP IP pool: abc
ACL&QoS&Multicast:
  ACL number/name:3000 (inactive)
  User profile: portal (active)
  Max multicast addresses: 4
  Multicast address list: 1.2.3.1, 1.34.33.1, 3.123.123.3, 4.5.6.7
                          2.2.2.2, 3.3.3.3, 4.4.4.4
NAT444:
  Global IP address: 111.8.0.234
  Port block: 1024-1033
Traffic statistic:
  Uplink   packets/bytes: 7/546
  Downlink packets/bytes: 0/0
Traffic average rate:
  Uplink   rate: 3194 bytes/s
  Downlink rate: 3194 bytes/s
Dual-stack traffic statistics:
  IPv4 address: 50.50.50.3
            Uplink   packets/bytes: 3/200
  IPv6 address: 2001::2
            Uplink   packets/bytes: 4/346
# Display detailed information about the portal user whose IP address is 18.18.0.20.
<Sysname> display portal user ip 18.18.0.20 verbose
Basic:
AP name: ap1
  Radio ID: 1
  SSID: portal
  Current IP address: 18.18.0.20
  Original IP address: 18.18.0.20
  Username: chap1
  User ID: 0x10000001
  Access interface: WLAN_BSS1/0/1
  Service-VLAN/Customer-VLAN: 50/-
  MAC address: 7854-2e1c-c59e
  Domain name: portal
  VPN instance: N/A
  Status: Online
  Portal server: pt
  Vendor: Apple
AAA:
  Realtime accounting interval: 720s, retry times: 5
  Idle cut: N/A
  Session duration: 0 sec, remaining: 0 sec
  Remaining traffic: N/A
  Online duration (hh:mm:ss): 1:53:7
  Login time: 2014-12-25 10:47:53 UTC
  DHCP IP pool: N/A
ACL&QoS&Multicast:
  Inbound CAR: N/A
  Outbound CAR: N/A
  User profile: N/A
Traffic statistic:
  Uplink packets/bytes: 6/412
  IPv4 address: 18.18.0.20
            Uplink   packets/bytes: 3/212
Table 25 Command output
Current IP address
IP address of the portal user after passing authentication.
Original IP address
IP address of the portal user during authentication.
Username
Name of the portal user.
User ID
Portal user ID.
Access interface
Public VLAN/Private VLAN to which the portal user belongs. If no VLAN is configured for the portal user, this field displays -/-.
MAC address
Authentication type
Type of portal authentication:
·     Normal—Normal authentication.
·     Local—Local authentication.
·     Email—Email authentication.
·     Cloud—Cloud authentication.
·     QQ—QQ authentication.
·     WeChat—WeChat authentication.
·     Facebook—Facebook authentication.
·     MAC-trigger—MAC-trigger authentication.
Domain
ISP domain name for portal authentication.
VPN instance
Name of the authorized VPN instance. If no VPN instance is authorized, this field displays the MPLS L3VPN to which the portal user belongs. If the portal user is on a public network, this field displays N/A.
Status
Status of the portal user:
Portal server
Name of the portal server.
Vendor
Vendor name of the endpoint.
Portal authentication method on the access interface:
·     Direct—Direct authentication.
·     Re-Dhcp—Re-DHCP authentication.
·     Layer3—Cross-subnet authentication.
AAA
AAA information about the portal user.
Interval for sending real-time accounting updates, and the maximum number of accounting attempts. If the real-time accounting is not authorized, this field displays N/A.
Idle-cut
Idle timeout period and the minimum traffic threshold. If idle-cut is not authorized, this field displays N/A.
Session duration
Session duration and the remaining session time. If the session duration is not authorized, this field displays N/A.
Remaining traffic
Remaining traffic for the portal user. If the remaining traffic is not authorized, this field displays N/A.
Login time
Time when the user logged in. The field uses the device time format, for example, 2023-1-19  2:42:30 UTC.
DHCP IP pool
Authorized DHCP IP address pool. If no DHCP IP address pool is authorized for the portal user, this field displays N/A.
Web URL
Authorized Web URL. If no Web URL is authorized for the portal user, this field displays N/A.
Inbound CAR
Outbound CAR
ACL number/name
User profile
Maximum number of multicast groups the portal user can join.
NAT444
NAT444 mapping information for the portal user. This field is displayed only when portal is used in conjunction with NAT444.
Global IP address
Public IP address.
Port block
Port block: start port-end port.
Multicast group list the portal user can join. If no multicast group is authorized, this field displays N/A.
Traffic statistic
Traffic statistics for the portal user.
Packet and byte statistics of the upstream traffic.
Packet and byte statistics of the downstream traffic.
Average traffic rate statistics for the portal user.
Uplink rate
Average rate of the upstream traffic in bytes per second.
Downlink rate
Average rate of the downstream traffic in bytes per second.
level-n uplink packets/bytes
Packet and byte statistics of the upstream traffic in accounting level n. Number n is in the range of 1 to 8.
level-n downlink packets/bytes
Packet and byte statistics of the downstream traffic in accounting level n. Number n is in the range of 1 to 8.
IPv4 and IPv6 traffic statistics for the dual-stack user.
IPv4 address
IPv4 address of the portal user.
IPv6 address
IPv6 address of the portal user.
# Display brief information about all portal users.
<Sysname> display portal user all brief
IP address       MAC address       Online duration       Username
2.2.2.2          000d-88f8-0eab    1:53:7                abc
3.3.3.3          000d-88f8-0eac    1:53:7                def
Table 26 Command output
IP address
MAC address
Online duration
Online duration of the portal user, in hh:ss:mm.
Username
Username of the portal user.
portal enable
display portal user-block
Use display portal user-block to display information about portal users blocked for portal authentication failure.
display portal user-block [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | username username ]
ip ipv4-address: Specifies a blocked portal user by its IPv4 address.
ipv6 ipv6-address: Specifies a blocked portal user by its IPv6 address.
mac mac-address: Specifies a blocked portal user by its MAC address in the format of H-H-H.
username username: Specifies a blocked portal user by its username, a case-insensitive string of 1 to 253 characters.
If you do not specify any parameters, this command displays information about all blocked portal users.
# Display information about all blocked portal users.
<Sysname> display portal user-block
Total blocked users: 2
IP address: 10.2.33.2
MAC address: E0A5-66BB-B2AA
Remaining block time: 01h:38m:44s
Username: test
IP address: 19.19.0.4
MAC address: B577-CDCB-D49C
Remaining block time: 01h:26m:44s
Username: school
# Display information about the blocked portal user at IPv4 address 10.2.33.2.
<Sysname> display portal user-block ip 10.2.33.2
Username: test
# Display information about the blocked portal user at IPv6 address 20::0:2.
<Sysname> display portal user-block ipv6 20::0:2
IP address: 20::0:2
Remaining blocking time: 01h:38m:44s
Username: test
# Display information about the blocked portal user at MAC address E0-A5-66-BH.
<Sysname> display portal user-block mac E0-A5-66-BH
Username: test
# Display information about the blocked portal user whose username is test.
<Sysname> display portal user-block username test
Username: test
Table 27 Command output
IP address
IP address of the blocked portal user.
MAC address
MAC address of the blocked portal user.
Username
Username of the blocked portal user.
Remaining block time(hh:mm:ss)
Remaining blocking timeout time, in the format of hh:mm:ss.
portal user-block failed-times
portal user-block reactive
display portal user count
Use display portal user count to display the number of portal users.
# Display the number of portal users.
<Sysname> display portal user count
Total number of users: 1
portal enable
portal delete-user
display portal user dhcp-lease
Use display portal user dhcp-lease to display DHCP lease information for IPv4 portal users.
display portal user dhcp-lease [ ipv4 ipv4-address ]
ipv4 ipv4-address: Specify an IPv4 portal user by its IPv4 address. If you do not specify an IPv4 portal user, this command displays DHCP lease information about all IPv4 portal users.
Use this command only when DHCP packet capture is enabled to detect online status of portal users. To enable the DHCP packet capture feature, use the portal idle-cut dhcp-capture enable command.
# Display DHCP lease information for all IPv4 portal users.
<Sysname> display portal user dhcp-lease
Total DHCP lease entries: 2
IPv4 address      MAC address           Lease time          Remaining time
1.1.1.1           AABB-CCDD-1122        02h 00m 00s         01h 10m 46s
1.1.1.2           AABB-CCDD-1133        01h 00m 00s         00h 08m 46s
# Display DHCP lease information for an IPv4 portal user.
<Sysname> display portal user dhcp-lease ip 1.1.1.1
Table 28 Command output
Total number of DHCP lease entries of IPv4 portal users.
IPv4 address
IPv4 address of an IPv4 portal user.
MAC
MAC address of the IPv4 portal user.
Lease time
Lease time period for the IPv4 address.
·     If the time period is less than one day, this field is displayed in the xxh xxm xxs format.
·     If the time period is less than one week, this field is displayed in the xd xxh format.
·     If the time period is greater than one week, this field is displayed in the xw xd xxh format.
The w, d, h, m, and s represent weeks, days, hours, minutes, and seconds, respectively.
Remaining time
Remaining lease time period for the IPv4 address.
display portal user dhcpv6-lease
display portal user dhcpv6-lease to display DHCPv6 lease information for IPv6 portal users.
display portal user dhcpv6-lease [ ipv6 ipv6-address ]
ipv6 ipv6-address: Specify an IPv6 portal user by its IPv6 address. If you do not specify an IPv6 portal user, this command displays DHCPv6 lease information about all IPv6 portal users.
# Display DHCPv6 lease information for all IPv6 portal users.
<Sysname> display portal user dhcpv6-lease
Total DHCPv6 lease entries: 2
IPv6 address            MAC address       Lease time     Remaining time
2000::1                 AABB-CCDD-1144    02h 00m 00s    01h 10m 46s
2000::2                 AABB-CCDD-1155    01h 00m 00s    00h 08m 46s
# Display DHCPv6 lease information for an IPv6 portal user.
<Sysname> display portal user dhcpv6-lease ipv6 2000::1
Table 29 Command output
Total number of DHCPv6 lease entries of IPv6 portal users.
IPv4 address
IPv4 address of an IPv6 portal user.
MAC
MAC address of the IPv6 portal user.
Lease time
Remaining time
display portal web-server
Use display portal web-server to display information about portal Web servers.
display portal web-server [ server-name ]
server-name: Specifies a portal Web server by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a portal Web server, this command displays information about all portal Web servers.
# Display information about portal Web server wbs.
<Sysname> display portal web-server wbs
Portal Web server: wbs
    Type IMC
    URL: http://www.test.com/portal
    URL parameters:
       basip=bas-ip
       userip=source-address
    VPN instance: Not configured
    Server detection:
      Interval: 120s
      Attempts: 5
      Action: log, trap
      Detection URL: http://www.test.com/portal
      Detection type: TCP
    IPv4 status: Up
    IPv6 status: Up
    Captive-bypass: Disabled
    If-match: original-url:  http://2.2.2.2, redirect-url:  http://192.168.56.2
              original-url:   http://1.1.1.1, temp-pass redirect-url:
              http://192.168.1.1
Table 30 Command output
Portal Web server type:
·     CMCC—CMCC server.
·     IMC—IMC server.
·     ISE—ISE sever.
·     OAuth—Cloud platform server.
·     WiFiDog—WiFiDog server.
Portal Web server
Name of the portal Web server.
URL
URL of the portal Web server.
URL parameters
URL parameters for the portal Web server.
VPN instance
Name of the MPLS L3VPN where the portal Web server resides.
Server detection
Parameters for portal Web server detection.
Interval
Detection interval in seconds.
Attempts
Maximum number of detection attempts.
Action
Actions (log and trap) to take when a reachability status change of the portal Web server is detected.
Detection URL
Portal Web server detection URL.
Detection type
Type of portal Web server detection:
·     TCP.
·     HTTP.
IPv4 status
Current state of the IPv4 portal Web server:
¡     Portal Web server detection is disabled.
¡     Portal Web server detection is enabled and the server is reachable.
·     Down—Portal Web server detection is enabled and the server is unreachable.
IPv6 status
Current state of the IPv6 portal Web server:
Captive-bypass
Status of the captive-bypass feature:
·     Disabled—Captive-bypass is disabled.
·     Enabled—Captive-bypass is enabled.
·     Optimize Enabled—Optimized captive-bypass is enabled.
If-match
Match rules configured for URL redirection. This field displays Not configured if no match rules for URL redirection are configured.
portal enable
portal web-server
server-detect (portal Web server view)
server-detect url
display web-redirect rule
Use display web-redirect rule to display information about Web redirect rules.
In standalone mode:
display web-redirect rule { ap ap-name [ radio radio-id ] | interface interface-type interface-number }
In IRF mode:
display web-redirect rule { ap ap-name [ radio radio-id ] | interface interface-type interface-number [ slot slot-number ] }
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument is 1 to 4. If you do not specify this option, the command displays Web redirect rules for all radios of the AP.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays Web redirect rules for the master device. (In IRF mode.)
# Display all Web redirect rules on GigabitEthernet 1/0/1.
<Sysname> display web-redirect rule interface gigabitethernet 1/0/1
IPv4 web-redirect rules on GigabitEthernet1/0/1:
Rule 1:
 Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 192.168.2.114
    VLAN           : Any
Rule 2:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    VLAN           : Any
    Protocol       : TCP
 Destination:
    Port           : 80
IPv6 web-redirect rules on GigabitEthernet1/0/1:
Rule 1:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    VLAN           : Any
    Protocol       : TCP
 Destination:
    Port           : 80
# Display all Web redirect rules on AP ap1.
<Sysname> display web-redirect rule ap ap1
IPv4 web-redirect rules on ap1:
Radio ID: 1
SSID     : portal
Rule 1:
Type                : Dynamic
 Action              : Permit
 Status              : Active
 Source:
    IP             : 192.168.2.114
    VLAN           : Any
Rule 2:
 Type                : Static
 Action              : Redirect
 Status              : Active
 Source:
    VLAN           : Any
    Protocol       : TCP
 Destination:
    Port           : 80
Table 31 Command output
Rule
Number of the Web redirect rule.
Type of the Web redirect rule:
·     Static—Static Web redirect rule, generated when the Web redirect feature takes effect.
·     Dynamic—Dynamic Web redirect rule, generated when a user visits a redirect webpage.
Action
Action in the Web redirect rule:
·     Permit—Allows packets to pass.
·     Redirect—Redirects the packets.
Status
Status of the Web redirect rule:
·     Active—The Web redirect rule is effective.
·     Inactive—The Web redirect rule is not effective.
Source
Source information in the Web redirect rule.
IP
Source IP address.
Mask
Prefix length
VLAN
Source VLAN. If not specified, this field displays Any.
Protocol
Transport layer protocol in the Web redirect rule:
·     Any—No transport layer protocol is limited.
·     TCP—Transmission Control Protocol.
Destination
Destination information in the Web redirect rule.
Port
Destination transport layer port number. The default port number is 80.
exclude-attribute (MAC binding server view)
Use exclude-attribute to exclude an attribute from portal protocol packets.
Use undo exclude-attribute to not exclude an attribute from portal protocol packets.
exclude-attribute attribute-number
undo exclude-attribute attribute-number
No attributes are excluded from portal protocol packets.
attribute-number: Specifies an attribute by its number in the range of 1 to 255.
Support of the portal authentication server for portal protocol attributes varies by the server type. During MAC-trigger authentication, the device and the server cannot communicate if the device sends the portal authentication server a packet that contains an attribute unsupported by the server.
To address this issue, you can configure this command to exclude the unsupported attributes from portal protocol packets sent to the portal authentication server.
You can specify multiple excluded attributes.
Table 32 describes all attributes of the portal protocol.
Table 32 Portal attributes
Name
Number
UserName
1
Name of the user to be authenticated.
PassWord
2
User password in plaintext form.
Challenge
3
Random challenge for CHAP authentication.
ChapPassWord
4
CHAP password encrypted by MD5.
TextInfo
5
The device uses this attribute to transparently transport prompt information of a RADIUS server or packet error information to the portal authentication server.
The attribute value can be any string excluding the end character '\0'. This attribute can exist in any packet from the device to the portal server. A packet can contain multiple TextInfo attributes. As a best practice, carry only one TextInfo attribute in a packet.
UpLinkFlux
6
Uplink (output) traffic of the user, an 8-byte unsigned integer, in KB.
DownLinkFlux
7
Downlink (input) traffic of the user, an 8-byte unsigned integer, in KB.
Port
8
Port information, a string excluding the end character '\0'.
IP-Config
9
This attribute has different meanings in different types of packets.
·     The device uses this attribute in ACK _AUTH (Type=0x04) packets to notify the portal server that the user requires re-DHCP.
·     The device uses this attribute in ACK_LOGOUT (Type=0x06) and NTF_LOGOUT (Type=0x08) packets to indicate that the current user IP address must be released. The portal server must notify the user to release the public IP address through DHCP. The device will reallocate a private IP address to the user.
BAS-IP
10
IP address of the access device. For re-DHCP portal authentication, the value of this attribute is the public IP address of the access device.
Session-ID
11
Identification of a portal user. Generally, the value of this attribute is the MAC address of the portal user.
Delay-Time
12
Delay time for sending a packet. This attributes exists in NTF_LOGOUT (Type=0x08) packets.
User-List
13
List of IP addresses of an IPv4 portal user.
EAP-Message
14
An EAP attribute that needs to be transported transparently. This attribute is applicable to EAP TLS authentication. Multiple EAP-Message attributes can exist in a portal authentication packet.
User-Notify
15
Value of the hw_User_Notify attribute in a RADIUS accounting response. This attribute needs to be transported transparently.
BAS-IPv6
100
IPv6 address of the access device.
UserIPv6-List
101
List of IPv6 addresses of an IPv6 portal user.
# Exclude the BAS-IP attribute (number 10) from portal packets sent to MAC binding server 123.
[Sysname] portal mac-trigger-server 123
[Sysname-portal-mac-trigger-server-123] exclude-attribute 10
exclude-attribute (portal authentication server view)
exclude-attribute number { ack-auth | ack-logout | ntf-logout }
undo exclude-attribute number { ack-auth | ack-logout | ntf-logout }
Portal authentication server view
ack-auth: Excludes the attribute from ACK_AUTH packets.
ack-logout: Excludes the attribute from ACK_LOGOUT packets.
ntf-logout: Excludes the attribute from NTF_LOGOUT packets.
Support of the portal authentication server for portal protocol attributes varies by the server type. If the device sends the portal authentication server a packet that contains an attribute unsupported by the server, the device and the server cannot communicate.
To address this issue, you can configure this command to exclude the unsupported attributes from specific portal protocol packets sent to the portal authentication server.
You can specify multiple excluded attributes. For an excluded attribute, you can specify multiple types of portal protocol packets (ack-auth, ntf-logout, and ack-logout).
Table 33 describes all attributes of the portal protocol.
Table 33 Portal attributes
Name
Number
UserName
1
PassWord
2
Challenge
3
ChapPassWord
4
TextInfo
5
UpLinkFlux
6
DownLinkFlux
7
Port
8
IP-Config
9
BAS-IP
10
Session-ID
11
Delay-Time
12
User-List
13
EAP-Message
14
User-Notify
15
BAS-IPv6
100
UserIPv6-List
101
# Exclude the UpLinkFlux attribute (number 6) from portal ACK_AUTH packets.
[Sysname] portal server pts
[Sysname-portal-server-pts] exclude-attribute 6 ack-auth
free-traffic threshold
Use free-traffic threshold to set the free-traffic threshold for portal users.
Use undo free-traffic threshold to restore the default.
free-traffic threshold value
The free-traffic threshold is 0 bytes.
value: Specifies the free-traffic threshold in the range of 0 to 10240000 bytes. If the free-traffic threshold is set to 0, the device immediately triggers MAC-based quick portal authentication for a user once the user's traffic is detected.
After MAC-based quick portal authentication is configured, the device monitors a user's network traffic (sent and received) in real time before the MAC-trigger entry for the user ages out. A user can access the network without authentication if the user's network traffic is below the free-traffic threshold. When the user's network traffic reaches the threshold, the device triggers MAC-based quick portal authentication for the user.
If the user passes portal authentication, the device deletes the MAC-trigger entry and clears the user traffic statistics. If the user fails authentication, the device does not trigger MAC-based quick authentication for the user before the MAC-trigger entry ages out. When the MAC-trigger entry ages out, the device clears the user traffic statistics.
When traffic is detected from the user again, the device re-creates a MAC-trigger entry for the user and repeats the previous procedure.
In wireless networks where APs are configured to forward client data traffic, APs report traffic statistics to the AC at a regular interval. The AC can determine whether a user's traffic exceed the free-traffic threshold only after receiving the traffic statistics report from the associated AP. To set the interval for APs to report traffic statistics to the AC, use the portal client-traffic-report interval command.
# Set the free-traffic threshold for portal users to 10240 bytes.
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts] free-traffic threshold 10240
display portal mac-trigger-server
if-match
Use if-match to configure a match rule for URL redirection.
Use undo if-match to delete a URL redirection match rule.
if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent string redirect-url url-string }
undo if-match { original-url url-string | user-agent user-agent }
No URL redirection match rules exist.
Portal Web server view
original-url url-string: Specifies the user-requested URL to be matched. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
redirect-url url-string: Specifies the URL to which the user is redirected. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
url-param-encryption: Specifies an encryption algorithm to encrypt the parameters carried in the redirection URL. If you do not specify an encryption algorithm, the parameters carried in the redirection URL are not encrypted.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the case-sensitive key string. The string length varies by the selected encryption method:
·     If des cipher is specified, the string length is 41 characters.
·     If des simple is specified, the string length is 8 characters.
·     If aes cipher is specified, the string length is 1 to 73 characters.
·     If aes simple is specified, the string length is 1 to 31 characters.
user-agent user-agent: Specifies a user agent string to match the User-Agent string in HTTP/HTTPS requests. The user agent string is a case-sensitive string of 1 to 255 characters. The User-Agent string in HTTP or HTTPS requests includes information about hardware manufacturer, operating system, browser, and search engine.
A URL redirection match rule matches Web requests (HTTP or HTTPS requests) by user-requested URL or User-Agent information, and redirects the matching Web requests to the specified redirection URL.
For a user to successfully access a redirection URL, configure a portal-free rule to allow HTTP or HTTPS requests destined for the redirection URL to pass. For information about configuring portal-free rules, see the portal free-rule command.
For a portal Web server, you can configure the url command and the if-match command for URL redirection. The url command redirects all Web requests from unauthenticated users to the portal Web server for authentication. The if-match command allows for flexible URL redirection by redirecting specific Web requests to specific redirection URLs. If both commands are executed, the if-match command takes priority to perform URL redirection.
If both portal safe-redirect and URL redirection match rules are configured, the device preferentially uses URL redirection match rules to perform URL redirection.
If you configure encryption for parameters in the redirection URL, you must add an encryption prompt field after the redirection URL address. For example, to redirect HTTP requests to URL 10.1.1.1 with encrypted URL parameters, specify the redirection URL as http://10.1.1.1?yyyy=. The value of yyyy depends on the portal Web server configuration. For more information, see the portal Web server configuration guide.
You can configure a URL in a URL redirection match rule in one of the following ways:
·     For exact match—Specify a complete URL. For example, if you configure the URL as abc.com.cn, only Web requests that contain URL abc.com.cn match the rule.
·     For fuzzy match—Specify a URL by placing the asterisk (*) wildcard character at the beginning or end of the URL string. For example, if you configure the URL as *abc.com.cn, abc*, or *abc*, Web requests that carry the URL ending with abc.com.cn, starting with abc, or including abc match the rule.
¡     The asterisk (*) wildcard character represents any characters. The device treats multiple consecutive asterisks as one.
¡     The configured URL cannot contain only asterisks (*).
You cannot configure two URL redirection match rules with the same user-requested URL.
# Configure a match rule to redirect HTTP requests destined for the URL http://www.abc.com.cn to the URL http://192.168.0.1.
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs] if-match original-url http://www.abc.com.cn redirect-url http://192.168.0.1
# Configure a match rule to redirect HTTP requests that carry the user agent string 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 to the URL http://192.168.0.1.
[Sysname-portal-websvr-wbs] if-match user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 redirect-url http://192.168.0.1
portal free-rule
url
url-parameter
if-match temp-pass
Use if-match temp-pass to configure a match rule for temporary pass.
Use undo if-match temp-pass to restore the default.
if-match { original-url url-string | user-agent user-agent } * temp-pass [ redirect-url url-string | original ]
undo if-match { original-url url-string | user-agent user-agent } * temp-pass
No match rules for temporary pass are configured.
original-url url-string: Specifies a URL string to match the URL in HTTP/HTTPS requests of portal users. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
redirect-url url-string: Redirects the matching Web requests to the specified URL. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
original: Redirects the matching Web requests to the originally requested URLs.
A match rule for temporary pass matches Web requests by URL or User-Agent information. Only the matching Web requests are temporarily permitted to pass.
A permitted request can be redirected to the specified redirection URL or to the originally requested URL, depending on the redirection action in the match rule. If you do not configure a redirection action (by using the redirect-url url-string option or the original keyword), the device permits the matching requests to pass without redirection.
For the match rules to take effect, make sure the portal temporary pass feature is enabled.
If you configure the same match criteria but different redirection actions in two match rules, the new configuration overwrites the existing one.
If both portal safe-redirect and portal temporary pass match rules are configured, portal temporary pass match rules take precedence.
# Configure a temporary pass match rule to temporarily allow user packets that access URL http://www.abc.com.cn to pass.
[Sysname-portal-websvr-wbs] if-match original-url http://www.abc.com.cn temp-pass
# Configure a temporary pass match rule to temporarily allow user packets that access the URL http://www.abc.com.cn/ to pass and then redirect the packets to the originally requested URL.
[Sysname-portal-websvr-wbs] if-match original-url http://www.abc.com.cn temp-pass original
# Configure a temporary pass match rule to allow user packets that contain user agent information 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 to pass and then redirect the packets to URL http://192.168.0.1.
[Sysname-portal-websvr-wbs] if-match user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 temp-pass redirect-url http://192.168.0.1
# Configure a temporary pass match rule. This rule allows user packets that access the URL  http://www.abc.com.cn/ and contain user agent information 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 to pass and then redirects the packets to URL http://192.168.0.1.
[Sysname-portal-websvr-wbs] if-match original-url http://www.123.com.cn user-agent 5.0(WindowsNT6.1)AppleWebKit/537.36(KHTML,likeGecko)Chrome/36.0.1985.125Safari/537.36 temp-pass redirect-url http://192.168.0.1
portal free-rule
portal temp-pass enable
url
url-parameter
ip (MAC binding server view)
Use ip to specify the IP address of a MAC binding server.
Use undo ip to restore the default.
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ip
The IP address of the MAC binding server is not specified.
ipv4-address: Specifies the IP address of a MAC binding server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the MAC binding server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the MAC binding server belongs to the public network, do not specify this option.
key: Specifies a shared key to be used to authenticate packets between the device and the MAC binding server. Portal packets exchanged between the device and MAC binding server carry an authenticator that is generated with the shared key. The receiver uses the authenticator to verify the correctness of the received portal packets. If you do not specify a shared key, the device and MAC binding server do not authenticate the packets between them.
cipher: Specifies a shared key in encrypted form.
simple: Specifies a shared key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the shared key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 33 to 117 characters.
If you execute this command multiple times in the same MAC binding server view, the most recent configuration takes effect.
# Specify the IP address of the MAC binding server as 192.168.0.111 and the plaintext key as portal.
[Sysname-portal-mac-trigger-server-mts] ip 192.168.0.111 key simple portal
ip (portal authentication server view)
Use ip to specify the IPv4 address of a portal authentication server.
undo ip
The IPv4 address of the portal authentication server is not specified.
ipv4-address: Specifies the IPv4 address of the portal authentication server.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN where the portal authentication server resides by the VPN instance name, a case-sensitive string of 1 to 31 characters. If the portal authentication server is on the public network, do not specify this option.
key: Specifies a shared key for communication with the portal authentication server. Portal packets exchanged between the access device and the portal authentication server carry an authenticator that is generated with the shared key. The receiver uses the authenticator to check the correctness of the received portal packets.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 33 to 117 characters.
A portal authentication server has only one IPv4 address. Therefore, in portal authentication server view, only one IPv4 address exists. If you execute this command multiple times, the most recent configuration takes effect.
Do not configure the same IPv4 address and VPN instance for different portal authentication servers.
# Specify 192.168.0.111 as the  IPv4 address of portal authentication server pts and plaintext key portal as the shared key for communication with the portal authentication server.
[Sysname-portal-server-pts] ip 192.168.0.111 key simple portal
portal server
ip (portal roaming center view)
Use ip to specify the IP address for communication with the WLAN roaming center.
ip ip-address
undo ip
No IP address for communication with the WLAN roaming center is specified.
Portal roaming center view
ip-address: Specifies the IP address for communication with the WLAN roaming center.
The specified IP address is used by the portal roaming center to exchange packets with the WLAN roaming center. You can specify any IPv4 address of the WLAN roaming center that can be used for communication with the portal roaming center.
You can specify only one IP address for communication with the WLAN roaming center. If you configure this command multiple times, the most recent configuration takes effect. You cannot specify both an IPv4 address and an IPv6 address for communication with the WLAN roaming center.
As a best practice, do not change the IP address when online portal users exist on the device. A violation might cause data inconsistency between the portal roaming center and the WLAN roaming center and further roaming failure. In this case, a roaming portal user must pass authentication on the new device to come online.
# Specify 192.168.0.111 as the IP address for communication with the WLAN roaming center.
[Sysname] portal roaming-center
[Sysname-portal-roaming-center] ip 192.168.0.111
ipv6 (portal authentication server view)
Use ipv6 to specify the IPv6 address of a portal authentication server.
Use undo ipv6 to restore the default.
ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo ipv6
The IPv6 address of the portal authentication server is not specified.
ipv6-address: Specifies the IPv6 address of the portal authentication server.
simple: Specifies a key in plaintext form. For security purposes, the key in plaintext form will be stored in encrypted form.
A portal authentication server has only one IPv6 address. Therefore in portal authentication server view, only one IPv6 address exists. If you execute this command multiple times, the most recent configuration takes effect.
Do not configure the same IPv6 address and VPN instance for different portal authentication servers.
# Specify 2000::1 as the  IPv6 address of portal authentication server pts and plaintext key portal as the shared key for communication with the portal authentication server.
[Sysname-portal-server-pts] ipv6 2000::1 key simple portal
portal server
ipv6 (portal roaming center view)
Use ipv6 to specify the IPv6 address for communication with the WLAN roaming center.
ipv6 ipv6-address
undo ipv6
No IPv6 address for communication with the WLAN roaming center is specified.
ipv6-address: Specifies the IPv6 address for communication with the WLAN roaming center.
The specified IPv6 address is used by the portal roaming center to exchange packets with the WLAN roaming center. You can specify any IPv6 address of the WLAN roaming center that can be used for communication with the portal roaming center.
You can specify only one IPv6 address for communication with the WLAN roaming center. If you configure this command multiple times, the most recent configuration takes effect. You cannot specify both an IPv4 address and an IPv6 address for communication with the WLAN roaming center.
As a best practice, do not change the IPv6 address when online portal users exist on the device. A violation might cause data inconsistency between the portal roaming center and the WLAN roaming center and further roaming failure. In this case, a roaming user must pass authentication on the new device to come online.
# Specify 10::2 as the IPv6 address for communication with the WLAN roaming center.
[Sysname-portal-roaming-center] ipv6 10::2
local-binding aging-time
Use local-binding aging-time to set the aging time for local MAC-account binding entries.
Use undo local-binding aging-time to restore the default.
local-binding aging-time minutes
The aging time for local MAC-account binding entries is 720 minutes.
minutes: Specifies the aging time for local MAC-account binding entries. The value range for this argument is 1 to 129600 minutes.
The local MAC binding server uses a local MAC-account binding entry to record the MAC address and portal account information (username and password) of a portal user.
The local MAC-account binding entry of a portal user is deleted when the entry ages out. The device creates a local MAC-account binding entry for the user again when the user triggers and passes a new portal authentication.
If you disable local MAC-trigger authentication, the device does not delete existing local MAC-account binding entries. These entries are automatically deleted when they age out.
# Set the aging time for local MAC-account binding entries to 240 minutes in the view of MAC binding server mts.
[Sysname-portal-mac-trigger-server-mts] local-binding aging-time 240
local-binding enable
Use local-binding enable to enable local MAC-trigger authentication.
Use undo local-binding enable to disable local MAC-trigger authentication.
Local MAC-trigger authentication is disabled.
This feature enables the device to act as a local MAC binding server to provide MAC-trigger authentication for local portal authentication users.
After a user passes portal authentication for the first time, the access device (local MAC binding server) generates a local MAC-account binding entry for the user. The local MAC binding-account entry records the MAC address and portal account information (username and password) of the user. Then, the user can automatically connect to the network without manual authentication for subsequent network access attempts.
# Enable local MAC-trigger authentication in the view of MAC binding server mts.
[Sysname-portal-mac-trigger-server-mts] local-binding enable
login failed-url
Use login failed-url to configure the redirect URL for authentication failure.
Use undo login failed-url to restore the default.
login failed-url url-string
No redirection URL for authentication failure is configured.
Local portal Web service view
url-string: Specifies the redirect URL for authentication failure, a case-sensitive string of 1 to 256 characters.
The device redirects portal users to the specified URL after they fail authentication.
# Configure the redirect URL for authentication failure as https://1.1.1.1/portal/iselogin.html.
[Sysname] portal local-web-server https
[Sysname-portal-local-websvr-https] login failure-url https://1.1.1.1/portal/iselogin.html
login success-url
Use login success-url to configure the redirect URL for authentication success.
Use undo login success-url to restore the default.
login success-url url-string
No redirection URL for authentication success is configured.
url-string: Specifies the redirect URL for authentication success, a case-sensitive string of 1 to 256 characters.
The device redirects portal users to the specified URL after they pass authentication.
# Configure the redirect URL for authentication success as https://1.1.1.1/portal/iselogin.html.
[Sysname-portal-local-websvr-https] login success-url https://1.1.1.1/portal/iselogin.html
logon-page bind
Use logon-page bind to bind an endpoint name, SSID, or endpoint type to an authentication page file.
Use undo logon-page bind to unbind the endpoint name, SSID, or endpoint type from the authentication page file.
logon-page bind { device-type { computer | pad | phone } | device-name device-name | ssid ssid-name } * file file-name
undo logon-page bind { all | device-type { computer | pad | phone } | device-name device-name | ssid ssid-name } *
No endpoint name, SSID, or endpoint type is bound to an authentication page file.
all: Specifies all endpoint names, SSIDs, and endpoint types.
device-type type-name: Specifies an endpoint type.
computer: Specifies the endpoint type as computer.
pad: Specifies the endpoint type as tablet.
phone: Specifies the endpoint type as mobile phone.
device-name device-name: Specify an endpoint by its name, a case-sensitive string of 1 to 127 characters. The specified endpoint name must have been predefined on the device. Otherwise, the bound authentication page file does not take effect.
ssid ssidname: Specifies an SSID by its name, a case-insensitive string of 1 to 32 characters. An SSID string can contain letters, digits, and spaces, but the start and end characters cannot be spaces. An SSID string cannot be f, fi, fil, or file.
file file-name: Specifies an authentication page file by the file name (without the file storage directory). A file name is a string of 1 to 91 characters, and can contain letters, digits, and underscores (_). You must edit the authentication pages, compress them to a .zip file, and then upload the file to the root directory of the storage medium of the device.
This command implements customized authentication page pushing for portal users. After you configure this command, the device pushes authentication pages to users according to the user's, endpoint name, SSID, and endpoint type.
When a Web user triggers local portal authentication, the device searches for a binding that matches the user's endpoint name, SSID, and endpoint type.
·     If the binding exists, the device pushes the bound authentication pages to the user.
·     If multiple matching binding entries are found, the device selects an entry in the following order:
a.     The entry that specifies the SSID, endpoint name, and endpoint type.
b.     The entry that specifies the SSID and endpoint name.
c.     The entry that specifies the SSID and endpoint type.
d.     The entry that specifies only the SSID.
e.     The entry that specifies the endpoint name and endpoint type.
f.     The entry that specifies only the endpoint name.
g.     The entry that specifies only the endpoint type.
·     If the binding does not exist, the device pushes the default authentication pages to the user.
When you configure this command, follow these restrictions and guidelines:
·     If the name or content of the file in a binding entry is changed, you must reconfigure the binding.
·     To reconfigure or modify a binding, you can simply re-execute this command without canceling the existing binding.
·     If you execute this command multiple times to bind an endpoint name, SSID, or endpoint type to different authentication page files, the most recent configuration takes effect.
·     You can configure multiple binding entries on the device.
# Create an HTTP-based local portal Web service.
# Bind SSID SSID1 to authentication page file file1.zip.
[Sysname-portal-local-websvr-http] logon-page bind ssid SSID1 file file1.zip
# Bind endpoint type phone to authentication page file file2.zip.
[Sysname-portal-local-websvr-http] logon-page bind device-type phone file file2.zip
default-logon-page
logout-notify
Use logout-notify to set the maximum number of times and the interval for retransmitting a logout notification packet.
Use undo logout-notify to restore the default.
logout-notify retry retries interval interval
undo logout-notify
The device does not retransmit a logout notification packet.
retry retries: Specifies the maximum number of retries, in the range of 1 to 5.
interval interval: Specifies the retry interval, in the range of 1 to 10 seconds.
A logout notification packet is a UDP packet that the device sends to the portal authentication server for forcibly logging out a portal user. To increase the delivery reliability, you can set the maximum number of times and the interval for retransmitting a logout notification packet.
After the device sends a logout notification packet for logging out a portal user, it waits for a response from the portal authentication server. If the device receives a response within the specified period of time (maximum number of retries × retry interval), it logs out and deletes the user immediately. If the device does not receive a response within the period of time, the device logs out and deletes the user when the period of time elapses.
# Set the maximum number of times for retransmitting a logout notification packet to 3 and the retry interval to 5 seconds.
[Sysname-portal-server-pt] logout-notify retry 3 interval 5
mail-domain-name
Use mail-domain-name to specify an email domain name for email authentication.
Use undo mail-address to remove an email domain name for email authentication.
mail-domain-name string
undo mail-domain-name [ string ]
No email domain names are specified for email authentication.
Email authentication server view
string: Specifies an email domain name for email authentication, a case-sensitive string of 1 to 255 characters, in the format of @XXX.XXX.
If you do not specify an email domain name in the undo form of this command, this command removes all email domain names for email authentication.
After you configure this command, the device performs email authentication only on portal users that use the specified email domain names.
You can specify a maximum of 16 email domain names for email authentication.
# Specify @qq.com and @sina.com email domain names for email authentication.
[Sysname] portal extend-auth-server mail
[Sysname-portal-extend-auth-server-mail] mail-domain-name @qq.com
[Sysname-portal-extend-auth-server-mail] mail-domain-name @Sina.com
display portal extend-auth-server
mail-protocol
Use mail-protocol to specify protocols for email authentication.
Use undo mail-protocol to restore the default.
mail-protocol { imap | pop3 } *
undo mail-protocol
No protocols are specified for email authentication.
imap: Specifies the Internet Message Access Protocol (IMAP).
pop3: Specifies the Post Office Protocol 3 (POP3).
This command specifies email protocols that the device uses to interact with the email server to perform authentication and authorization on portal users who uses email authentication.
# Specify POP3 as the protocol for email authentication.
[Sysname-portal-extend-auth-server-mail] mail-protocol pop3
nas-port-type
Use nas-port-type to specify the NAS-Port-Type value carried in RADIUS requests sent to the RADIUS server.
Use undo nas-port-type to restore the default.
nas-port-type value
undo nas-port-type
The NAS-Port-Type value carried in RADIUS requests is 15.
value: Specifies the NAS-Port-Type value in the range of 1 to 255.
Some MAC binding servers identify MAC-based quick portal authentication by a specific NAS-Port-Type value in received RADIUS requests. To communicate with such a MAC binding server, you must configure the device to use the NAS-Port-Type value required by the MAC binding server.
# Set the NAS-Port-Type value in RADIUS requests sent to the MAC binding server mts to 30.
[Sysname-portal-mac-trigger-server-mts] nas-port-type 30
port (MAC binding server view)
Use port to set the UDP port number the MAC binding server uses to listen for MAC binding query packets.
Use undo port to restore the default.
port port-number
undo port
The MAC binding server listens for MAC binding query packets on UDP port 50100.
port-number: Specifies the listening UDP port number in the range of 1 to 65534.
The specified port number must be the same as the query listening port number configured on the MAC binding server.
# Set the UDP port number to 1000 for the MAC binding server pts to listen for MAC binding query packets.
<sysname> system-view
[sysname] portal mac-trigger-server mts
[sysname-portal-mac-trigger-server-mts] port 1000
port (portal authentication server view)
Use port to set the destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
port port-number
undo port
The device uses 50100 as the destination UDP port number for unsolicited portal packets.
port-number: Specifies a destination UDP port number the device uses to send unsolicited portal packets to the portal authentication server. The value range for this argument is 1 to 65534.
The specified port must be the port that listens to portal packets on the portal authentication server.
# Set the destination UDP port number to 50000 for the device to send unsolicited portal packets to the portal authentication server pts.
[Sysname-portal-server-pts] port 50000
portal server
port (portal roaming center view)
Use port to specify the UDP port number for communication with the WLAN roaming center.
port port-number
undo port
The UDP port 1088 is used by the portal roaming center to communicate with the WLAN roaming center.
port-number: Specifies the UDP port number for communication with the WLAN roaming center. The value range is 1 to 65534.
The specified UDP port is used by the portal roaming center to exchange packets with the WLAN roaming center.
The specified UDP port number must be the same as that specified on the WLAN roaming center.
As a best practice, do not change the UDP port number when online portal users exist on the device. A violation might cause data inconsistency between the portal roaming center and the WLAN roaming center and further roaming failure. In this case, a roaming user must pass authentication on the new device to come online.
As a best practice to avoid data remanence, disable the WLAN roaming center before you change the UDP port number. When you finish changing the UDP port number, re-enable the WLAN roaming center.
# Specify port 50102 as the UDP port for communication with the WLAN roaming center.
[Sysname-portal-roaming-center] port 50102
roaming-center enable
portal ad-push
Use portal ad-push to specify an advertisement URL or advertisement group for portal advertisement push.
Use undo portal ad-push to restore the default.
portal [ ipv6 ] ad-push { url url-string [ interval interval | time-range time-range-name | traffic-threshold traffic-threshold ] | url-group group-name }
undo portal [ ipv6 ] ad-push { url | url-group }
No advertisement URL or advertisement group is specified for portal advertisement push.
Interface view
Service template view
ipv6: Specifies IPv6 URLs. To specify IPv4 URLs, do not specify this keyword.
url url-string: Specifies the URL of an advertisement to be pushed to portal users. The URL is a case-sensitive string of 1 to 256 characters and must begin with http://. If you specify the ipv6 keyword, the URL of the advertisement must be an IPv6 URL.
url-group group-name: Specifies an advertisement group by its name, a case-sensitive string of 1 to 32 characters. The device will push advertisements in this group to portal users. If you specify the ipv6 keyword, the URLs of advertisements in this group must be IPv6 URLs.
interval interval: Specifies the advertisement push interval, in the range of 5 to 1440 minutes. The interval begins when a portal user comes online.
time-range time-range-name: Specifies a time range for portal advertisement push. The time-range-name argument represents the name of the time range, a case-insensitive string of 1 to 32 characters. The time range name must begin with a letter and cannot be all. For more information about time ranges, see time range configuration in ACL and QoS Configuration Guide.
traffic-threshold traffic-threshold: Specifies the traffic threshold for portal advertisement push. The value range for the argument is 1 to 1024, in MB.
If you specify an advertisement group for portal advertisement push, the device uses the group advertisement push method specified by using the portal ad-url-group command.
If you specify an advertisement URL without configuring a push method, the device only pushes the advertisement to the portal user five seconds after the user comes online.
# Configure the device to push the advertisement on URL http://192.168.56.1/welcome every 60 minutes to portal users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal ad-push url http://192.168.56.1/welcome interval 60
# Configure the device to push advertisements in advertisement group test to portal users on GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] portal ad-push url-group test
# Configure the device to push the advertisement on URL http://192.168.56.1/welcome to portal users on service template service1 in time range tr.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] portal ad-push url http://192.168.56.1/welcome time-range tr
# Configure the device to push advertisements in advertisement group test to portal users on service template service1.
[Sysname] wlan service-template service2
[Sysname-wlan-st-service2] portal ad-push url-group test
portal ad-push enable
portal ad-url-group
portal ad-push embedded
Use portal ad-push embedded to enable embedded portal advertisement push.
Use undo portal ad-push embedded to disable embedded portal advertisement push.
Embedded portal advertisement push is disabled. The advertisements that the device pushes to portal users are independent of the user visited webpages.
Interface view
This feature enables the device to embed advertisements in webpages that portal users visit.
# Enable embedded portal advertisement push on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal ad-push embedded
# Enable embedded portal advertisement push on service template service1.
[Sysname-wlan-st-service1] portal ad-push embedded
Use portal ad-push enable to enable portal advertisement push.
Use undo portal ad-push enable to disable portal advertisement push.
Portal advertisement push is disabled.
Interface view
This feature enables the device to push advertisements to portal users after they pass portal authentication.
# Enable portal advertisement push on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal ad-push enable
# Enable portal advertisement push on service template service1.
[Sysname-wlan-st-service1] portal ad-push enable
portal ad-push url
portal ad-push whitelist
Use portal ad-push whitelist to add a portal user to a portal advertisement whitelist.
Use undo ad-push whitelist to remove portal users from the portal advertisement whitelist.
portal ad-push whitelist { ip ipv4-address | ipv6 ipv6-address | mac-address mac-address }
undo portal ad-push whitelist { all | ip ipv4-address | ipv6 ipv6-address | mac-address mac-address }
No portal advertisement whitelist exists.
all: Specifies all portal users.
ip ipv4-address: Specifies a portal user by its IPv4 address.
ipv6 ipv6-address: Specifies a portal user by its IPv6 address.
mac-address mac-address: Specifies a portal user by its MAC address in the format of H-H-H.
If a portal user has been added to the portal advertisement whitelist, the device does not push advertisements to the portal user.
You can execute this command multiple times to add multiple portal users to the portal advertisement whitelist. A maximum of 1024 portal users can be added to the whitelist.
# Add portal user at IPv4 address 20.20.20.3 to the portal advertisement whitelist.
[Sysname] portal ad-push whitelist ip 20.20.20.3
# Add portal user at IPv6 address 2000::0:3 to the portal advertisement whitelist.
[Sysname] portal ad-push whitelist ipv6 2000::0:3
portal ad-push url
portal ad-url-group
Use portal ad-url-group to create an advertisement group and enter its view, or enter the view of an existing advertisement group.
Use undo portal ad-url-group to delete an advertisement group.
portal ad-url-group group-name [ method { interval | time-range | traffic } ]
undo portal ad-url-group group-name
No advertisement groups exist.
group-name: Specifies an advertisement group name, a case-sensitive string of 1 to 32 characters.
method: Specifies the advertisement push method. If you do not specify a method, the device uses the time-based advertisement push method.
interval: Specifies the time-based advertisement push method.
time-range: Specifies the time range-based advertisement push method. For more information about time ranges, see time range configuration in ACL and QoS Configuration Guide.
traffic: Specifies the traffic-based advertisement push method.
If you have specified an advertisement push method for an advertisement group, you cannot directly change the method. To change the method, use the undo form of this command to delete the advertisement group and then recreate it with the new method specified.
# Create an advertisement group named test and specify the time-based advertisement push method.
[Sysname] portal ad-url-group test method interval
[Sysname-portal-ad-url-group-test]
portal ad-push
portal apply mac-trigger-server
Use portal apply mac-trigger-server to specify a MAC binding server.
Use undo portal apply mac-trigger-server to restore the default.
portal apply mac-trigger-server server-name
No MAC binding server is specified.
VLAN interface view
server-name: Specifies a MAC binding server by its name, a case-sensitive string of 1 to 32 characters.
Only direct IPv4 portal authentication and cross-subnet authentication support MAC-based quick portal authentication.
For MAC-based quick portal authentication to take effect, perform the following tasks:
·     Configure normal portal authentication.
·     Configure a MAC binding server.
·     Specify the MAC binding server on a portal-enabled interface or service template.
# Specify the MAC binding server mts on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal apply mac-trigger-server mts
portal apply web-server
Use portal apply web-server to specify a portal Web server. The device redirects the HTTP or HTTPS requests sent by unauthenticated portal users to the portal Web server.
Use undo portal apply web-server to delete a portal Web server.
portal [ ipv6 ] apply web-server server-name [ secondary ]
undo portal [ ipv6 ] apply web-server [ server-name ]
No portal Web servers are specified.
Interface view
ipv6: Specifies an IPv6 portal Web server. If the server is an IPv4 portal Web server, do not specify this keyword.
secondary: Specifies the backup portal Web server. If you do not specify this keyword, the specified server is the primary portal Web server.
server-name: Specifies a portal Web server to be specified on the interface by its name, a case-sensitive string of 1 to 32 characters. The name must already exist. If you do not specify a server name in the undo form of this command, all portal Web servers on the interface or service template are removed.
IPv4 and IPv6 portal authentication can both be enabled on an interface or on a service template.
You can specify both a primary portal Web server and a backup portal Web server after enabling each type (IPv4 or IPv6) of portal authentication.
The device first uses the primary portal Web server for portal authentication. When the primary portal Web server is unreachable but the backup portal Web server is reachable, the device uses the backup portal Web server. When the primary portal Web server becomes reachable, the device switches back to the primary portal Web server for portal authentication.
To automatically switch between the primary portal Web server and the backup portal Web server, configure portal Web server detection on both servers.
# Specify portal Web server wbs as the backup portal Web server on GigabitEthernet 1/0/1 for portal authentication.
[Sysname-GigabitEthernet1/0/1] portal apply web-server wbs secondary
# Specify portal Web server wbs as the backup portal Web server on service template service1 for portal authentication.
[Sysname-wlan-st-service1] portal apply web-server wbs secondary
display portal
portal fail-permit server
portal web-server
portal authentication-location switchto-central-ac
Use portal authentication-location switchto-central-ac to switch the portal authenticator from the local AC to the central AC.
Use this command on an AC hierarchy where the portal authenticator is switched from a local AC to the central AC and the forwarding mode is changed from centralized forwarding to local forwarding. This command allows for the portal authenticator switching without device reboot.
Execute this command on a local AC. If you execute this command on devices of other roles, portal authentication will fail.
Before you execute this command, disable portal authentication on the interface or service template first.
# Switch the portal authenticator to the central AC.
[Sysname] portal authentication-location switchto-central-ac
display portal authentication-location
portal auth-error-record enable
Use portal auth-error-record enable to enable portal authentication error recording.
Use undo portal auth-error-record enable to disable portal authentication error recording.
Portal authentication error recording is enabled.
This feature enables the device to save all portal authentication error records and to periodically send the records to the authentication server.
# Enable portal authentication error recording.
[Sysname] portal auth-error-record enable
display portal auth-error-record
portal auth-error-record export
Use portal auth-error-record export to export portal authentication error records to a path.
portal auth-error-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
url url-string: Specifies the URL to which portal authentication error records are exported. The URL is a case-insensitive string of 1 to 255 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
start-time start-date start-time end-time end-date end-time: Specifies a time range. The start date and end date must be in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for MM is 1 to 12. The value range for DD varies with the specified month. The value range for YYYY is 1970 to 2037. The start time and end time must be in the format of hh:mm. The value range for the start time and end time is 00:00 to 23:59.
The device supports FTP, TFTP, and HTTP file transfer methods. Table 34 describes the valid URL format for each method.
Table 34 URL formats
Protocol
URL format
Remarks
FTP
ftp://username[:password]@server-address[:port-number]/file-path
Example: ftp://a:[email protected]/authfail/
The username and password must be the same as those on the server.
If the server authenticates only the username, no password is required.
TFTP
tftp://server-address[:port-number]/file-path
Example: tftp://1.1.1.1/ autherror/
N/A
HTTP
http://username[:password]@server-address[:port-number]/file-path
Example: http://1.1.1.1/autherror/
If the server address is an IPv6 address, bracket the IPv6 address to distinguish the IPv6 address from the port number. For example, if the server address is 2001::1 and the port number is 21, the URL is ftp://test:test@[2001::1]/test/.
# Export all portal authentication error records to path tftp://1.1.1.1/record/autherror/.
[Sysname] portal auth-error-record export url tftp://1.1.1.1/record/autherror/
# Export portal authentication error records in the time range from 2016/3/4 14:20 to 2016/3/4 15:00 to path tftp://1.1.1.1/record/autherror/.
[Sysname] portal auth-error-record export url tftp://1.1.1.1/record/autherror/ start-time 2016/3/4 14:20 end-time 2016/3/4 15:00
reset portal auth-error-record
portal auth-error-record max
Use portal auth-error-record max to set the maximum number of portal authentication error records.
Use undo portal auth-error-record max to restore the default.
portal auth-error-record max number
The maximum number of portal authentication error records is the maximum value set by the number argument.
number: Specifies the maximum number of portal authentication error records.
The following compatibility matrixes show the value ranges for this argument:
Hardware
Value range
MSR610
1 to 6000
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
1 to 6000
MSR810-LMS, MSR810-LUS
1 to 6000
MSR810-SI, MSR810-LM-SI
1 to 6000
MSR810-LMS-EA, MSR810-LME
1 to 6000
MSR1004S-5G, MSR1004S-5G-CN
1 to 6000
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN
1 to 6000
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
1 to 6000
MSR2600-10-X1
1 to 6000
MSR 2630
1 to 6000
MSR3600-28, MSR3600-51
1 to 6000
MSR3600-28-SI, MSR3600-51-SI
1 to 6000
1 to 6000
MSR3600-28-G-DP, MSR3600-51-G-DP
1 to 24000
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
1 to 60000
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
1 to 24000
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
1 to 24000
MSR3610-G, MSR3620-G
1 to 24000
MSR3640-G
1 to 24000
MSR3640-X1-HI
1 to 60000
Hardware
Value range
MSR810-W-WiNet, MSR810-LM-WiNet
1 to 6000
MSR830-4LM-WiNet
1 to 6000
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
1 to 6000
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
1 to 6000
MSR2600-6-WiNet
1 to 6000
MSR2600-10-X1-WiNet
1 to 6000
MSR2630-WiNet
1 to 6000
MSR3600-28-WiNet
1 to 6000
MSR3610-X1-WiNet
1 to 24000
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
1 to 24000
Hardware
Value range
MSR860-6EI-XS
1 to 6000
MSR860-6HI-XS
1 to 6000
MSR2630-XS
1 to 6000
MSR3600-28-XS
1 to 6000
MSR3610-XS
1 to 24000
MSR3620-XS
1 to 24000
MSR3610-I-XS
1 to 60000
MSR3610-IE-XS
1 to 60000
MSR3620-X1-XS
1 to 24000
MSR3640-XS
1 to 24000
MSR3660-XS
1 to 60000
Hardware
Value range
MSR810-LM-GL
1 to 6000
MSR810-W-LM-GL
1 to 6000
MSR830-6EI-GL
1 to 6000
MSR830-10EI-GL
1 to 6000
MSR830-6HI-GL
1 to 6000
MSR830-10HI-GL
1 to 6000
MSR1004S-5G-GL
1 to 6000
MSR2600-6-X1-GL
1 to 6000
MSR3600-28-SI-GL
1 to 6000
When the maximum number of portal authentication error records is reached, a new record overwrites the oldest one.
# Set the maximum number of portal authentication error records to 50.
[Sysname] portal auth-error-record max 50
portal auth-fail-record enable
Use portal auth-fail-record enable to enable portal authentication failure recording.
Use undo portal auth-fail-record enable to disable portal authentication failure recording.
Portal authentication failure recording is enabled.
This feature enables the device to save portal authentication failure records and to periodically send the records to the authentication server.
# Enable portal authentication failure recording.
[Sysname] portal auth-fail-record enable
display portal auth-fail-record
portal auth-fail-record export
Use portal auth-fail-record export to export portal authentication failure records to a path.
portal auth-fail-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
url url-string: Specifies the URL to which portal authentication failure records are exported. The URL is a case-insensitive string of 1 to 255 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
The device supports FTP, TFTP, and HTTP file transfer methods. Table 35 describes the valid URL format for each method.
Table 35 URL formats
Protocol
URL format
Remarks
FTP
TFTP
N/A
HTTP
# Export all portal authentication failure records to path tftp://1.1.1.1/record/authfail/.
[Sysname] portal auth-fail-record export url tftp://1.1.1.1/record/authfail/
# Export portal authentication failure records in the time range from 2016/3/4 14:20 to 2016/3/4 15:00 to path tftp://1.1.1.1/record/authfail/.
[Sysname] portal auth-fail-record export url tftp://1.1.1.1/record/authfail/ start-time 2016/3/4 14:20 end-time 2016/3/4 15:00
reset portal auth-fail-record
portal auth-fail-record max
Use portal auth-fail-record max to set the maximum number of portal authentication failure records.
Use undo portal auth-fail-record max to restore the default.
portal auth-fail-record max number
The maximum number of portal authentication failure records is the maximum value set by the number argument.
number: Specifies the maximum number of portal authentication failure records.
Hardware
Value range
MSR610
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
MSR2600-10-X1
1 to 6000
MSR 2630
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 24000
1 to 60000
1 to 24000
1 to 24000
1 to 24000
MSR3640-G
1 to 24000
MSR3640-X1-HI
1 to 60000
Hardware
Value range
1 to 6000
MSR830-4LM-WiNet
1 to 6000
1 to 6000
1 to 6000
MSR2600-6-WiNet
1 to 6000
MSR2600-10-X1-WiNet
1 to 6000
MSR2630-WiNet
1 to 6000
MSR3600-28-WiNet
1 to 6000
MSR3610-X1-WiNet
1 to 24000
1 to 24000
Hardware
Value range
MSR860-6EI-XS
1 to 6000
MSR860-6HI-XS
1 to 6000
MSR2630-XS
1 to 6000
MSR3600-28-XS
1 to 6000
MSR3610-XS
1 to 24000
MSR3620-XS
1 to 24000
MSR3610-I-XS
1 to 60000
MSR3610-IE-XS
1 to 60000
MSR3620-X1-XS
1 to 24000
MSR3640-XS
1 to 24000
MSR3660-XS
1 to 60000
Hardware
Value range
MSR810-LM-GL
1 to 6000
MSR810-W-LM-GL
1 to 6000
MSR830-6EI-GL
1 to 6000
MSR830-10EI-GL
1 to 6000
MSR830-6HI-GL
1 to 6000
MSR830-10HI-GL
1 to 6000
MSR1004S-5G-GL
1 to 6000
MSR2600-6-X1-GL
1 to 6000
MSR3600-28-SI-GL
1 to 6000
When the maximum number of portal authentication failure records is reached, a new record overwrites the oldest one.
# Set the maximum number of portal authentication failure records to 50.
[Sysname] portal auth-fail-record max 50
portal authorization strict-checking
Use portal authorization strict-checking to enable strict checking on portal authorization information.
Use undo portal authorization strict-checking to disable strict checking on portal authorization information.
portal authorization { acl | user-profile } strict-checking
undo portal authorization { acl | user-profile } strict-checking
Strict checking mode on portal authentication information is disabled. If an authorized ACL or user profile does not exist on the device or the ACL or user profile fails to be deployed, the user will not be logged out.
Interface view
acl: Enables strict checking on authorized ACLs.
user-profile: Enables strict checking on authorized user profiles.
CAUTION
CAUTION:
·     The strict checking feature on an interface or service template allows a portal user to stay online only when the authorization information for the user is successfully deployed. The strict checking fails if the authorized ACL or user profile does not exist on the device or the device fails to deploy the authorized ACL or user profile.
·     You can enable strict checking on the authorized ACL, authorized user profile, or both. If you enable both strict ACL checking and user profile checking, the user will be logged out if either checking fails.
# Enable strict checking on authorized ACLs on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] portal authorization acl strict-checking
# Enable strict checking on authorized ACLs on service template service1
[Sysname-wlan-st-service1] portal authorization acl strict-checking
display portal
portal captive-bypass optimize delay
Use portal captive-bypass optimize delay to set the captive-bypass detection timeout time.
Use undo portal captive-bypass optimize delay to restore the default.
portal captive-bypass optimize delay seconds
The captive-bypass detection timeout time is 6 seconds.
seconds: Specifies the captive-bypass detection timeout time, in the range of 1 to 120 seconds.
This command applies only to iOS mobile clients.
With optimized captive-bypass enabled, the device automatically pushes the portal authentication page to iOS mobile devices when they are connected to the network. Users can perform authentication on the page or press the home button to return to the desktop without performing authentication, and the Wi-Fi connection is not terminated.
Optimized captive-bypass might fail when the network condition is poor. The device cannot detect a server reachability detection packet from an iOS mobile device within the captive-bypass detection timeout time. Therefore, the Wi-Fi connection will be terminated on the iOS mobile device. To avoid Wi-Fi disconnections caused by server reachability detection failure, you can set a longer captive-bypass detection timeout time when the network condition is poor.
# Set the captive-bypass detection timeout time to 20 seconds.
[Sysname] portal captive-bypass optimize delay 20
portal client-gateway interface
Use portal client-gateway interface to specify the AC’s interface for portal clients to access during third-party authentication.
Use undo portal client-gateway interface to restore the default.
portal client-gateway interface interface-type interface-number
No AC's interface is specified for portal clients to access during third-party authentication.
When client traffic is forwarded by APs and third-party portal authentication is used, the client does not know the IP address of the AC. For the client to access AC successfully, specify an interface of the AC, so the client can obtain the AC's IP address and access the AC.
# Specify VLAN-interface 10 on the AC for clients to access during third-party authentication.
[Sysname] portal client-gateway interface vlan-interface 10
Use portal client-traffic-report interval to set the interval at which an AP reports traffic statistics to the AC.
Use undo portal client-traffic-report interval to restore the default.
portal client-traffic-report interval interval
An AP reports traffic statistics to the AC at intervals of 60 seconds.
interval: Specifies the interval at which an AP reports traffic statistics to the AC, in the range of 1 to 3600 seconds.
Before you execute this command, make sure the client traffic forwarding location is at APs.
# Set the interval at which an AP reports traffic statistic to the AC to 120 seconds.
[Sysname] portal client-traffic-report interval 120
client forwarding-location (WLAN Command Reference)
portal cloud report interval
Use portal cloud report interval to configure the time interval at which portal authentication information is reported to the cloud platform server.
Use undo portal cloud report interval to restore the default.
portal cloud report interval minutes
The portal authentication information is reported to the cloud platform server at intervals of 5 minutes.
minutes: Specifies the time interval at which portal authentication information is reported to the cloud platform server. The value range for the time interval is 0 to 60 minutes. If you set the interval to 0 minutes, the device does not report portal authentication information to the cloud platform server.
After you configure this command, the device reports portal authentication failure and error information to the cloud platform server. The first report is sent to the cloud platform server 30 seconds after the device is connected to the server. The subsequent reports are sent at regularly intervals as configured by the command.
If you modify the report interval, the modified interval takes effect for the next report.
# Configure the device to report portal authentication failure and error information to the cloud platform server at intervals of 60 minutes.
[Sysname] portal cloud report interval 60
portal delete-user
Use portal delete-user to log out online portal users.
portal delete-user { ipv4-address | all | auth-type { cloud | email | facebook | local | normal | qq | wechat } | interface interface-type interface-number | ipv6 ipv6-address | mac mac-address | username username }
ipv4-address: Specifies the IP address of an IPv4 online portal user.
all: Specifies IPv4 and IPv6 online portal users on all interfaces.
auth-type: Specifies online portal users by the authentication type.
cloud: Specifies the cloud authentication.
email: Specifies the email authentication.
facebook: Specifies the Facebook authentication.
local: Specifies the local authentication.
normal: Specifies the normal authentication.
qq: Specifies the QQ authentication.
wechat: Specifies the WeChat authentication.
interface interface-type interface-number: Specifies an interface by its type and number. If you specify this option, this command logs out all IPv4 and IPv6 online portal users on the interface.
ipv6 ipv6-address: Specifies the IP address of an IPv6 online portal user.
mac mac-address: Specifies the MAC address of an online portal user, in the format of H-H-H.
username username: Specifies the username of an online portal user, a case-sensitive string of 1 to 253 characters. The username cannot contain the domain name.
# Log out the portal user whose IP address is 1.1.1.1.
[Sysname] portal delete-user 1.1.1.1
# Log out the portal user whose MAC address is 000d-88f8-0eab.
[Sysname] portal delete-user mac 000d-88f8-0eab
# Log out all portal users that come online through email authentication.
[Sysname] portal delete-user auth-type email
# Log out the portal user whose username is abc.
[Sysname] portal delete-user username abc
display portal user
portal device-id
Use portal device-id to specify the device ID.
Use undo portal device-id to restore the default.
portal device-id device-id
A device is not configured with a device ID.
device-id: Specifies a device ID for the device, a case-sensitive string of 1 to 63 characters.
The portal authentication server uses device IDs to identify the device that sends protocol packets to the portal server.
Make sure the configured device ID is different than any other access devices communicating with the same portal authentication server.
# Set the device ID of the device to 0002.0010.100.00.
[Sysname] portal device-id 0002.0010.100.00
portal domain
Use portal domain to configure a portal authentication domain. All portal users accessing through the interface or service template must use the authentication domain.
Use undo portal domain to delete the configured portal authentication domain.
portal [ ipv6 ] domain domain-name
undo portal [ ipv6 ] domain
No portal authentication domain is configured.
Interface view
ipv6: Specifies an authentication domain for IPv6 portal users. Do not specify this keyword for IPv4 portal users.
domain-name: Specifies an ISP authentication domain by its name, a case-insensitive string of 1 to 255 characters.
You can specify both an IPv4 portal authentication domain and an IPv6 portal authentication domain on an interface or on a service template.
Do not specify the ipv6 keyword for IPv4 portal users.
# Configure the authentication domain for IPv4 portal users as my-domain on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] portal domain my-domain
# Configure the authentication domain for IPv4 portal users as my-domain on service template service1.
[Sysname-wlan-st-service1] portal domain my-domain
display portal
portal dual-ip enable
Use portal dual-ip enable to enable the dual IP feature.
Use undo portal dual-ip enable to disable the dual IP feature.
The dual IP feature is disabled.
Interface view
This feature enables the device to carry both the IPv4 address and the IPv6 address for dual-stack portal users in the authentication requests during remote portal authentication. For single-stack portal users, the device carries only the IPv4 or IPv6 address of the users.
This feature is applicable only to RADIUS-based remote portal authentication.
Some RADIUS servers require that both IPv4 and IPv6 addresses of portal users must be carried in portal authentication requests. To avoid authentication failure, enable this feature when such a RADIUS server is used.
# Enable the dual IP feature on VLAN-interface 100.
[Sysname–Vlan-interface100] portal dual-ip enable
# Enable the dual IP feature on service template service1.
[Sysname-wlan-st-service1] portal dual-ip enable
portal dual-stack enable
Use portal dual-stack enable to enable the portal dual-stack feature.
Use undo portal dual-stack enable to disable the portal dual-stack feature.
The portal dual-stack feature is disabled.
Interface view
The portal dual-stack feature enables portal users to access both IPv4 and IPv6 networks after passing one type (IPv4 or IPv6) of portal authentication.
Only direct portal authentication supports this feature.
# Enable the portal dual-stack feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal dual-stack enable
# Enable the portal dual-stack feature on servive template service1
[Sysname-wlan-st-service1] portal dual-stack enable
portal dual-stack traffic-separate enable
Use portal dual-stack traffic-separate enable to enable separate IPv4 and IPv6 traffic statistics for dual-stack portal users.
Use undo portal dual-stack traffic-separate enable to disable separate IPv4 and IPv6 traffic statistics for dual-stack portal users.
Separate IPv4 and IPv6 traffic statistics is disabled for dual-stack portal users. The device collects IPv4 and IPv6 traffic statistics collectively.
Interface view
This feature enables the device to separately collect IPv4 traffic statistics and IPv6 traffic statistics for a dual-stack portal user. Then, the AAA server can separately perform accounting on IPv4 traffic and IPv6 traffic of the user.
For this feature to take effect, you must enable the portal dual-stack feature.
This command has a higher priority over the accounting dual-stack command in ISP domain view. For more information about the accounting dual-stack command, see "AAA commands."
# Enable separate IPv4 and IPv6 traffic statistics for dual-stack portal users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal dual-stack traffic-separate enable
# Enable separate IPv4 and IPv6 traffic statistics for dual-stack portal users on service template service1.
[Sysname-wlan-st-service1] portal dual-stack traffic-separate enable
portal enable (interface view)
Use portal enable to enable portal authentication.
Use undo portal enable to disable portal authentication.
portal enable method { direct | layer3 | redhcp }
portal ipv6 enable method { direct | layer3 }
undo portal [ ipv6 ] enable
Portal authentication is disabled.
Interface view
ipv6: Enables IPv6 portal authentication. Do not specify this keyword for IPv4 portal authentication.
method: Specifies an authentication mode.
direct: Specifies direct authentication.
layer3: Specifies cross-subnet authentication.
redhcp: Specifies re-DHCP authentication.
To modify the portal authentication mode, first execute the undo form of this command to disable portal authentication.
Make sure the device supports IPv6 ACL and IPv6 forwarding before you enable IPv6 portal authentication on the interface.
IPv6 portal authentication does not support the re-DHCP authentication mode.
You can enable both IPv4 portal authentication and IPv6 portal authentication on an interface.
Do not add a portal authentication-enabled Ethernet interface to an aggregation group. Otherwise, portal authentication cannot take effect on the interface.
# Enable direct IPv4 portal authentication on GigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] portal enable method direct
display portal
portal enable (service template view)
Use portal enable to enable direct portal authentication.
Use undo portal enable to disable direct portal authentication.
portal [ ipv6 ] enable method direct
Direct portal authentication is disabled.
ipv6: Enables IPv6 direct portal authentication. Do not specify this keyword for IPv4 direct portal authentication.
Only direct portal authentication is supported on a service template.
You can enable both IPv4 portal authentication and IPv6 portal authentication on a service template.
Do not enable portal authentication on both an interface and a service template.
# Enable direct IPv4 portal authentication on service template service1.
[Sysname-wlan-st-service1] portal enable method direct
display portal
portal extend-auth domain
Use portal extend-auth domain to specify the authentication domain for third-party authentication.
Use undo portal extend-auth domain to remove the authentication domain for third-party authentication.
portal extend-auth domain domain-name
No authentication domain is specified for third-party authentication.
Interface view
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
The specified ISP domain takes effect only on IPv4 portal users that use third-party authentication.
Make sure the authentication, authorization, and accounting methods in the authentication domain are none.
# Specify authentication domain my-domain for third-party authentication on GigabitEthernet1/0/1.
[Sysname–GigabitEthernet1/0/1] portal extend-auth domain my-domain
# Specify authentication domain my-domain for third-party authentication on service template service1.
[Sysname-wlan-st-service1] portal extend-auth domain my-domain
display portal
Use portal extend-auth-server to create a third-party authentication server and enter its view, or enter the view of an existing third-party authentication server.
Use undo portal extend-auth-server to delete a third-party authentication server.
portal extend-auth-server { facebook | mail | qq | wechat }
undo portal extend-auth-server { facebook | mail | qq | wechat }
No third-party authentication servers exist.
facebook: Specifies the Facebook authentication server.
mail: Specifies the email authentication server.
qq: Specifies the QQ authentication server.
wechat: Specifies the WeChat authentication server.
The device supports using a third-party portal authentication server for portal authentication. A portal user can use a third-party account instead of a portal account to perform portal authentication. If the user passes third-party authentication, the third-party server notifies the third-party authentication success of the user to the device. Then, the device interacts with the local portal Web service to complete the remaining process of portal authentication.
Only direct portal authentication that uses a local portal Web portal service supports third-party authentication.
# Create a QQ authentication server and enter its view.
[Sysname] portal extend-auth-server qq
[Sysname-portal-extend-auth-server-qq]
# Create an email authentication server and enter its view.
# Create a WeChat authentication server and enter its view.
[Sysname] portal extend-auth-server wechat
[Sysname-portal-extend-auth-server-wechat]
# Create a Facebook authentication server and enter its view.
[Sysname] portal extend-auth-server facebook
[Sysname-portal-extend-auth-server-fb]
Use portal fail-permit server to enable the portal fail-permit feature for a portal authentication server.
Use undo portal fail-permit server to disable the portal fail-permit feature for the portal authentication server.
portal [ ipv6 ] fail-permit server server-name
undo portal [ ipv6] fail-permit server
Portal fail-permit is disabled for the portal authentication server.
Interface view
ipv6: Specifies an IPv6 portal authentication server. Do not specify this keyword for an IPv4 portal authentication server.
server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters.
On an interface, you can enable portal fail-permit for both the portal authentication server and the portal Web servers.
On an interface enabled with portal fail-permit for a portal authentication server and portal Web servers, portal authentication on the interface is disabled in either of the following conditions:
·     All portal Web servers are unreachable.
·     The specified portal authentication server is unreachable.
Portal authentication resumes on the interface when the specified portal authentication server and a minimum of one portal Web server becomes reachable. After portal authentication resumes, unauthenticated portal users need to pass authentication to access network resources. Portal users who have passed authentication can continue accessing network resources.
# Enable portal fail-permit for portal authentication server pts1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal fail-permit server pts1
display portal
portal fail-permit web-server
Use portal fail-permit web-server to enable the portal fail-permit feature for portal Web servers.
Use undo portal fail-permit web-server to disable the portal fail-permit feature for portal Web servers.
portal [ ipv6 ] fail-permit web-server
undo portal [ ipv6 ] fail-permit web-server
Portal fail-permit is disabled for portal Web servers.
Interface view
ipv6: Specifies IPv6 portal Web servers. To specify IPv4 portal Web servers, do not specify this keyword.
Before you configure this feature for a service template, make sure the service template is disabled.
On a service template enabled with fail-permit for a portal authentication server and portal Web servers, portal authentication on the service template is disabled in either of the following conditions:
Portal authentication resumes on the service template when the specified portal authentication server and a minimum of one portal Web server becomes reachable. After portal authentication resumes, unauthenticated portal users need to pass authentication to access network resources. Portal users who have passed authentication can continue accessing network resources.
# Enable portal fail-permit for the portal Web servers on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] portal fail-permit web-server
# Enable portal fail-permit for the portal Web servers on service template service1.
[Sysname-wlan-st-service1] portal fail-permit web-server
display portal
portal forbidden-rule
Use portal forbidden-rule to configure a portal-forbidden rule.
Use undo portal forbidden-rule to delete portal-forbidden rules.
portal forbidden-rule rule-number [ source { ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | ssid ssid-name } * ] destination { host-name | ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] }
portal forbidden-rule rule-number [ source { ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | ssid ssid-name } * ] destination { host-name | ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] }
undo portal forbidden-rule { rule-number | all }
No portal-forbidden rules are configured.
rule-number: Specifies the number of a portal-forbidden rule. The value range for this argument is 0 to 4294967295.
source: Specifies the source information.
ip ipv4-address: Specifies an IPv4 address.
{ mask-length | mask }: Specifies the subnet mask of the IPv4 address. The mask-length argument represents the length of a subnet mask, in the range of 0 to 32. The mask argument represents a subnet mask in dotted decimal notation.
ip any: Specifies any IPv4 address.
tcp tcp-port-number: Specifies a TCP port number in the range of 0 to 65535.
udp udp-port-number: Specifies a UDP port number in the range of 0 to 65535.
ipv6 ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the prefix length of the IPv6 address, in the range of 0 to 128.
ipv6 any: Specifies any IPv6 address.
ssid ssid-name: Specifies an SSID by its name, a case-sensitive string of 1 to 32 characters.
host-name: Specifies a destination host by its name, a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.). The host name cannot be i, ip, ipv, or ipv6.
all: Specifies all portal-forbidden rules.
Portal-forbidden rules are used to filter user packets from the specified sources or destined for the specified destinations. The device drops user packets that match the portal-forbidden rules.
Portal-forbidden rules take effect only when portal authentication is enabled.
In a portal-forbidden rule, the source and destination IP addresses must be of the same IP type, and the source and destination ports must be of the same transport protocol type.
You can configure multiple portal-forbidden rules.
If the source or destination information in a portal-free rule and that in a portal-forbidden rule overlap, the portal-forbidden rule takes effect.
If you specify a destination host name in a portal-forbidden rule, the device drops users' DNS query packets for the specified host name. In addition, if a DNS server is correctly configured on the device, the device also drops user packets destined for the IP address resolved from the specified host name. If the DNS server is not correctly configured, the rule does not take effect on user packets destined for that IP address.
# Configure portal-forbidden rule 10 to prohibit portal users from accessing website www.xyz.com.
[Sysname] portal forbidden-rule 10 source ip any destination www.xyz.com
# Configure portal-forbidden rule 12 to prohibit the portal user with IP address 1.1.1.1/32 from accessing IP address 2.2.2.2/32.
[Sysname] portal forbidden-rule 12 source ip 1.1.1.1 32 destination ip 2.2.2.2 32
display portal rule
portal free-all except destination
Use portal free-all except destination to configure an IPv4 portal authentication destination subnet on an interface.
Use undo portal free-all except destination to delete the IPv4 portal authentication destination subnets on the interface.
portal free-all except destination ipv4-network-address { mask-length | mask }
undo portal free-all except destination [ ipv4-network-address ]
No IPv4 portal authentication destination subnet is configured on the interface. Portal users must pass portal authentication to access any subnet.
Interface view
ipv4-network-address: Specifies an IPv4 portal authentication subnet address.
mask-length: Specifies the subnet mask length for the authentication subnet address, in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal format.
Portal users on the interface are authenticated when accessing the specified authentication destination subnet (except IP addresses and subnets specified in portal-free rules). The users can access other subnets without portal authentication.
If you do not specify the ipv4-network-address argument in the undo portal free-all except destination command, this commands deletes all IPv4 portal authentication destination subnets on the interface.
Re-DHCP authentication does not support authentication destination subnets.
If you configure both an authentication source subnet and an authentication destination subnet on an interface, only the authentication destination subnet takes effect.
You can repeat this command to configure multiple authentication destination subnets.
# Configure an IPv4 portal authentication destination subnet of 11.11.11.0/24 on GigabitEthernet 1/0/1. Portal users need to pass authentication to access this subnet and can access other subnets without authentication.
[Sysname–GigabitEthernet1/0/1] portal free-all except destination 11.11.11.0 24
display portal
portal free-rule
Use portal free-rule to configure an IP-based portal-free rule.
Use undo portal free-rule to delete portal-free rules.
portal free-rule rule-number { destination ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
undo portal free-rule { rule-number | all }
No IP-based portal-free rule is configured.
rule-number: Specifies a portal-free rule number. The value range for this argument is 0 to 4294967295.
destination: Specifies the destination information.
ip ipv4-address: Specifies an IPv4 address for the portal-free rule.
{ mask-length | mask }: Specifies the subnet mask of the IPv4 address. The value range for the mask-length argument is 0 to 32. The mask argument is in dotted decimal format.
ip any: Represents any IPv4 address.
tcp tcp-port-number: Specifies a TCP port number for the portal-free rule, in the range of 0 to 65535.
udp udp-port-number: Specifies a UDP port number for the portal-free rule, in the range of 0 to 65535.
ipv6 ipv6-address: Specifies an IPv6 address for the portal-free rule.
ipv6 any: Represents any IPv6 address.
all: Specifies all portal-free rules.
interface interface-type interface-number: Specifies a Layer 3 interface on which the portal-free rule takes effect.
You can specify both the source and destination keyword for a portal-free rule. If you specify only one keyword, the other keyword does not act as a filtering criterion.
If you specify both a source port number and a destination port number for a portal-free rule, the two port numbers must belong to the same transport layer protocol.
If you do not specify a Layer 3 interface, the portal-free rule takes effect on all portal-enabled interfaces.
You cannot configure two portal-free rules with the same filtering criteria.
# Configure an IPv4-based portal-free rule numbered 1 for GigabitEthernet 1/0/1. In the rule, the source IP address is 10.10.10.1/24, the destination IP address is 20.20.20.1/32, the destination TCP port number is 23.
[Sysname] portal free-rule 1 destination ip 20.20.20.1 32 tcp 23 source ip 10.10.10.1 24 interface gigabitethernet 1/0/1
# Configure an IPv6-based portal-free rule numbered 2 for GigabitEthernet 1/0/1. In this rule, the source IPv6 address is 2000::1/64, the destination IPv6 address is 2001::1/128, the destination TCP port number is 23.
[Sysname] portal free-rule 2 destination ipv6 2001::1 128 tcp 23 source ipv6 2000::1 64 interface gigabitethernet 1/0/1
display portal rule
portal free-rule description
Use portal free-rule description to configure a description for a portal-free rule.
Use undo portal free-rule description to delete the description of a portal-free rule.
portal free-rule rule-number description text
undo portal free-rule rule-number description
No description is configured for a portal-free rule.
rule-number: Specifies a portal-free rule by its rule number. The value range for this argument is 0 to 4294967295.
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
Executing the undo portal free-rule all command deletes all portal-free rules and their descriptions.
# Configure a description of This is IT department for portal-free rule 2.
[Sysname] portal free-rule 2 description This is IT department
portal free-rule destination
Use portal free-rule destination to configure a destination-based portal-free rule.
portal free-rule rule-number destination host-name
No destination-based portal-free rule is configured.
destination: Specifies the destination host.
host-name: Specifies the destination host by its name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), dots (.), and asterisks (*). The host name string cannot be i, ip, ipv, or ipv6.
Before you configure destination-based portal-free rules, make sure a DNS server has been deployed in the network.
You can configure a host name in one of the following ways:
·     For exact match—Specify a complete host name. For example, if you configure the host name as abc.com.cn in the portal-free rule, only packets that contain the host name abc.com.cn match the rule. Packets that carry any other host names (such as dfabc.com.cn) do not match the rule.
·     For fuzzy match—Specify a host name by placing the asterisk (*) wildcard character at the beginning or end of the host name string. For example, if you configure the host name as *abc.com.cn, abc*, or *abc*, packets that carry the host name ending with abc.com.cn, starting with abc, or including abc match the rule.
The asterisk (*) wildcard character represents any characters. The device treats multiple consecutive asterisks as one.
The configured host name cannot contain only asterisks (*).
The fuzzy match feature takes effect only on HTTP or HTTPS requests initiated by Web browsers.
You cannot configure two destination-based portal-free rules with the same destination information. Otherwise the system prompts you that the same rule already exists.
# Configure a destination-based portal-free rule: specify the rule number as 4 and host name as www.abc.com. This rule allows the portal user who sends the HTTP/HTTPS request that carries the host name www.abc.com to access network resources without authentication.
[Sysname] portal free-rule 4 destination www.abc.com
display portal rule
portal free-rule source
Use portal free-rule source to configure a source-based portal-free rule. The filtering criteria include source MAC address, source interface, and source VLAN.
Use undo portal free-rule to delete a specific or all portal-free rules.
portal free-rule rule-number source { ap ap-name | { interface interface-type interface-number | mac mac-address | object-group object-group-name | vlan vlan-id } * }
No source-based portal-free rules exist.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. Valid characters are letters, digits, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-). This option is applicable only when portal authentication is enabled on a service template.
interface interface-type interface-number: Specifies a source interface by its type and number for the portal-free rule.
mac mac-address: Specifies a source MAC address for the portal-free rule, in the form of H-H-H.
object-group object-group-name: Specifies a source object group by its name, a case-insensitive string of 1 to 63 characters.
vlan vlan-id: Specifies a source VLAN ID for the portal-free rule. This option takes effect only on portal users that access the network through VLAN interfaces.
If you specify both the source VLAN and the source Layer 2 interface, the interface must be in the VLAN.
For a source-based portal-free rule to be correctly created, make sure the object group you specified already exists. Only IPv4 address groups and IPv6 address groups are supported.
If portal users have come online before source-based portal-free rules are configured, the device keeps accounting on traffic of the users.
# Configure a source-based portal-free rule: specify the rule number as 3, source MAC address as 1-1-1, and source VLAN ID as 10. This rule allows the portal user whose source MAC address is 1-1-1 from VLAN 10 to access network resources without authentication.
[Sysname] portal free-rule 3 source mac 1-1-1 vlan 10
# Configure a source-based portal-free rule: specify the rule number as 4 and source AP name as ap10. This rule allows portal users on AP 10 to access network resources without authentication.
[Sysname] portal free-rule 4 source ap ap10
display portal rule
portal host-check enable
Use portal host-check enable to enable validity check on wireless portal clients.
Use undo portal host-check enable to disable validity check on wireless portal clients.
Validity check on wireless portal clients is disabled. The device checks wireless portal client validity according to ARP entries only.
In wireless networks, the device might not have ARP entries for clients. Therefore, the device cannot check the validity of portal clients by using ARP entries. To ensure that valid users can perform portal authentication, you must enable wireless client validity check on the device.
This feature enables the device to validate a client by looking up the client information in the WLAN snooping table, DHCP snooping table, and ARP table. If the client information exists, the device determines the client to be valid for portal authentication.
To view information about WLAN or DHCP snooping entries, execute the display ip source binding command.
# Enable validity check on wireless portal clients.
[Sysname] portal host-check enable
portal idle-cut dhcp-capture enable
Use portal idle-cut dhcp-capture enable to enable DHCP packet capture to detect online status of portal users by capturing DHCP packets of the portal users.
Use undo portal idle-cut dhcp-capture enable to disable DHCP packet capture.
DHCP packet capture is enabled.
This feature enables the AC to detect the online status of portal users by capturing DHCP packets of the portal users.
When this feature is enabled, the AC captures DHCP packets between a portal user and the DHCP server and obtains the IP address lease information of the user. The AC then detects the online status of the portal user as follows:
·     If the AC captures a DHCP lease renewal packet from the portal user before the lease expires, the AC determines that the portal user is online.
·     If no DHCP lease renewal packet is captured before the lease expires, the AC forcibly logs out the portal user.
For more information about DHCP packets, see DHCP configuration in Layer 3—IP Services Configuration Guide.
The timeout time of the DHCP packet capture timer is the same as the IP address lease time in DHCP packets. This timer resets each time a DHCP packet is captured.
# Enable DHCP packet capture to detect online status of portal users.
[Sysname] portal idle-cut dhcp-capture enable
portal ipv6 free-all except destination
Use portal ipv6 free-all except destination to configure an IPv6 portal authentication destination subnet on an interface.
Use undo portal ipv6 free-all except destination to delete IPv6 portal authentication destination subnets on the interface.
portal ipv6 free-all except destination ipv6-network-address prefix-length
undo portal ipv6 free-all except destination [ ipv6-network-address ]
No IPv6 portal authentication destination subnet is configured on the interface. Portal users must pass portal authentication to access any IPv6 subnet.
Interface view
ipv6-network-address: Specifies an IPv6 portal authentication destination subnet.
prefix-length: Specifies the prefix length of the IPv6 subnet, in the range of 0 to 128.
If you do not specify the ipv6-network-address argument in the undo portal ipv6 free-all except destination command, this command deletes all IPv6 portal authentication destination subnets on the interface.
# Configure an IPv6 portal authentication destination subnet of 1::2/16 on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] portal ipv6 free-all except destination 1::2 16
display portal
portal ipv6 layer3 source
Use portal ipv6 layer3 source to configure an IPv6 portal authentication source subnet on an interface.
Use undo portal ipv6 layer3 source to delete IPv6 portal authentication source subnets on an interface.
portal ipv6 layer3 source ipv6-network-address prefix-length
undo portal ipv6 layer3 source [ ipv6-network-address ]
No IPv6 portal authentication source subnet is configured on the interface. Portal users from any IPv6 subnet must pass portal authentication.
Interface view
ipv6-network-address: Specifies an IPv6 portal authentication source subnet address.
With IPv6 authentication source subnets configured, only packets from IPv6 users on the authentication source subnets can trigger portal authentication. If an unauthenticated IPv6 user is not on any authentication source subnet, the access device discards all the user's packets that do not match any portal-free rule.
If you do not specify the ipv6-network-address argument in the undo portal ipv6 layer3 source command, this command deletes all IPv6 portal authentication source subnets on the interface.
Only cross-subnet authentication supports authentication source subnets.
# Configure an IPv6 portal authentication source subnet of 1::1/16 on GigabitEthernet 1/0/1. Only portal users from subnet 1::1/16 trigger portal authentication.
[Sysname–GigabitEthernet1/0/1] portal ipv6 layer3 source 1::1 16
display portal
portal ipv6 user-detect
Use portal ipv6 user-detect to enable online detection of IPv6 portal users.
Use undo ipv6 portal user-detect to disable online detection of IPv6 portal users.
portal ipv6 user-detect type { icmpv6 | nd } [ retry retries ] [ interval interval ] [ idle time ]
undo portal ipv6 user-detect
Online detection of IPv6 portal users is disabled.
Interface view
type: Specifies the detection type.
icmpv6: Specifies ICMPv6 detection.
nd: Specifies ND detection.
retry retries: Specifies the maximum number of detection attempts, in the range of 1 to 10. The default value is 3.
interval interval: Specifies a detection interval in the range of 1 to 1200 seconds. The default interval is 3 seconds.
idle time: Specifies the user idle timeout in the range of 60 to 3600 seconds. The default idle timeout is 180 seconds. When the timeout expires, online detection of portal users is started.
If the device receives no packets from a portal user within the idle time, the device detects the user's online status as follows:
·     ICMPv6 detection—Sends ICMPv6 requests to the user at configurable intervals to detect the user status.
¡     If the device receives a reply within the maximum number of detection attempts, it considers that the user is online and stops sending detection packets. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the device receives no reply after the maximum number of detection attempts, the device logs out the user.
·     ND detection—Sends ND requests to the user and detects the ND entry status of the user at configurable intervals.
¡     If the ND entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detecting the user's ND entry. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the ND entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
Direct authentication and re-DHCP authentication support both ND detection and ICMPv6 detection. Cross-subnet authentication only supports ICMPv6 detection.
If the access device filters out ICMPv6 packets, ICMPv6 detection might fail and result in the logout of portal users. Make sure the access device does not block ICMPv6 packets before you enable ICMPv6 detection on an interface.
# Enable online detection of IPv6 portal users on GigabitEthernet 1/0/1. Configure the detection type as ICMPv6, the maximum number of detection attempts as 5, the detection interval as 10 seconds, and the user idle timeout as 300 seconds.
[Sysname–GigabitEthernet1/0/1] portal ipv6 user-detect type icmpv6 retry 5 interval 10 idle 300
display portal
portal layer3 source
Use portal layer3 source to configure an IPv4 portal authentication source subnet.
Use undo portal layer3 source to delete IPv4 portal authentication source subnets.
portal layer3 source ipv4-network-address { mask-length | mask }
undo portal layer3 source [ ipv4-network-address ]
No IPv4 portal authentication source subnet is configured. Portal users from any IPv4 subnet must pass portal authentication.
Interface view
ipv4-network-address: Specifies an IPv4 portal authentication source subnet address.
mask-length: Specifies the subnet mask length of the IPv4 address, in the range of 0 to 32.
With IPv4 authentication source subnets configured, only packets from IPv4 users on the authentication source subnets can trigger portal authentication. If an unauthenticated IPv4 user is not on any authentication source subnet, the access device discards all the user's packets that do not match any portal-free rule.
If you do not specify the ipv4-network-address argument in the undo portal layer3 source command, this command deletes all IPv4 portal authentication source subnets on the interface.
# Configure an IPv4 portal authentication source subnet of 10.10.10.0/24 on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] portal layer3 source 10.10.10.0 24
display portal
portal local-web-server
Use portal local-web-server create an HTTP- or HTTPS-based local portal Web service and enter its view, or enter the view of the existing HTTP- or HTTPS-based local portal Web service.
Use undo portal local-web-server to delete the HTTP- or HTTPS-based local portal Web service.
portal local-web-server { http | https [ ssl-server-policy policy-name ] [ tcp-port port-number ] }
undo portal local-web-server { http | https }
No local portal Web services exist.
http: Specifies the HTTP-based local portal Web service, which uses HTTP to exchange authentication information with clients.
https: Specifies the HTTPS-based local portal Web service, which uses HTTPS to exchange authentication information with clients.
ssl-server-policy policy-name: Specifies an existing SSL server policy for HTTPS. The policy name is a case-insensitive string of 1 to 31 characters.
tcp-port port-number: Specifies the listening TCP port number for the HTTPS-based local portal Web service. The value range for the port-number argument is 1 to 65535. The default port number is 443.
In the local portal Web service, the access device also acts as the portal Web server and the portal authentication server. No external portal Web server and portal authentication server are needed.
For an interface to use the local portal Web service, the URL of the portal Web server specified for the interface must meet the following requirements:
·     The IP address in the URL must be a local IP address on the device.
·     The URL must be ended with /portal/. For example: http://1.1.1.1/portal/.
You cannot delete an SSL server policy by using the undo ssl server-policy command when the policy is associated with HTTPS.
To specify a new SSL server policy for HTTPS, first execute the undo form of this command to delete the existing HTTPS-based local portal Web service.
When you specify the listening TCP port number for the HTTPS-based local portal Web service, follow these restrictions and guidelines:
·     For HTTPS-based local portal Web service and other services that use HTTPS:
¡     If they use the same SSL server policy, they can use the same TCP port number to listen to HTTPS.
¡     If they use different SSL server policies, they cannot use the same TCP port number to listen to HTTPS.
·     Do not configure the HTTPS listening TCP port number as the port number used by a known protocol (except HTTPS) or other service.
·     Do not configure the same TCP port number for HTTP-based local portal Web service and HTTPS-based local portal Web service.
# Create an HTTP-based local portal Web service and enter its view.
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] quit
# Create an HTTPS-based local portal Web service and associate SSL server policy policy1 with the service.
[Sysname] portal local-web-server https ssl-server-policy policy1
[Sysname-portal-local-websvr-https] quit
# Change the SSL server policy to policy2.
[Sysname] undo portal local-web-server https
[Sysname] portal local-web-server https ssl-server-policy policy2
# Create an HTTPS-based local portal Web service. In the service, the associated SSL server policy is policy1 and the listening port number is 442.
[Sysname] portal local-web-server https ssl-server-policy policy1 tcp-port 442
default-logon-page
ssl server-policy
portal logout-record enable
Use portal logout-record enable to enable portal user offline recording.
Use undo portal logout-record enable to disable portal user offline recording.
Portal user offline recording is disabled.
This feature enables the device to save all portal user offline records and to periodically send the records to the authentication server.
# Enable portal user offline recording.
[Sysname] portal logout-record enable
display portal logout-record
portal logout-record export
Use portal logout-record export to export portal user offline records to a path.
portal logout-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
url url-string: Specifies the URL to which portal user offline records are exported. The URL is a case-insensitive string of 1 to 255 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
The device supports FTP, TFTP, and HTTP file transfer methods. Table 36 describes the valid URL format for each method.
Table 36 URL formats
Protocol
URL format
Remarks
FTP
TFTP
N/A
HTTP
# Export all portal user offline records to path tftp://1.1.1.1/record/logout/.
[Sysname] portal logout-record export url tftp://1.1.1.1/record/logout/
# Export portal user offline records in the time rang of 2016/3/4 14:20 to 2016/3/4 15:00 to path tftp://1.1.1.1/record/logout/.
[Sysname] portal logout-record export url tftp://1.1.1.1/record/logout/ start-time 2016/3/4 14:20 end-time 2016/3/4 15:00
reset portal logout-record
portal logout-record max
Use portal logout-record max to set the maximum number of portal user offline records.
Use undo portal logout-record max to restore the default.
portal logout-record max number
The maximum number of portal user offline records is the maximum value set by the number argument.
number: Specifies the maximum number of portal user offline records.
Hardware
Value range
MSR610
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 6000
MSR2600-10-X1
1 to 6000
MSR 2630
1 to 6000
1 to 6000
1 to 6000
1 to 6000
1 to 24000
1 to 60000
1 to 24000
1 to 24000
1 to 24000
MSR3640-G
1 to 24000
MSR3640-X1-HI
1 to 60000
Hardware
Value range
1 to 6000
MSR830-4LM-WiNet
1 to 6000
1 to 6000
1 to 6000
MSR2600-6-WiNet
1 to 6000
MSR2600-10-X1-WiNet
1 to 6000
MSR2630-WiNet
1 to 6000
MSR3600-28-WiNet
1 to 6000
MSR3610-X1-WiNet
1 to 24000
1 to 24000
Hardware
Value range
MSR860-6EI-XS
1 to 6000
MSR860-6HI-XS
1 to 6000
MSR2630-XS
1 to 6000
MSR3600-28-XS
1 to 6000
MSR3610-XS
1 to 24000
MSR3620-XS
1 to 24000
MSR3610-I-XS
1 to 60000
MSR3610-IE-XS
1 to 60000
MSR3620-X1-XS
1 to 24000
MSR3640-XS
1 to 24000
MSR3660-XS
1 to 60000
Hardware
Value range
MSR810-LM-GL
1 to 6000
MSR810-W-LM-GL
1 to 6000
MSR830-6EI-GL
1 to 6000
MSR830-10EI-GL
1 to 6000
MSR830-6HI-GL
1 to 6000
MSR830-10HI-GL
1 to 6000
MSR1004S-5G-GL
1 to 6000
MSR2600-6-X1-GL
1 to 6000
MSR3600-28-SI-GL
1 to 6000
When the maximum number of portal user offline records is reached, a new record overwrites the oldest one.
# Set the maximum number of portal user offline records to 50.
[Sysname] portal logout-record max 50
portal mac-trigger-server
Use portal mac-trigger-server to create a MAC binding server and enter its view, or enter the view of an existing MAC binding server.
Use undo portal mac-trigger-server to delete the MAC binding server.
portal mac-trigger-server server-name
undo portal mac-trigger-server server-name
No MAC binding servers exist.
server-name: Specifies a MAC binding server name, a case-sensitive string of 1 to 32 characters.
After you create a MAC binding server, you can configure MAC binding server parameters, such as the server's IP address and port number.
# Create the MAC binding server mts and enter its view.
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts]
display portal mac-trigger-server
portal apply mac-trigger-server
portal max-user
Use portal max-user to set the maximum number of total portal users allowed in the system.
Use undo portal max-user to restore the default.
portal max-user max-number
No limit is placed on the total number of portal users allowed in the system.
max-number: Specifies the maximum number of total portal users in the system. The value range for this argument is 1 to 4294967295.
If you configure the maximum total number smaller than the number of current online portal users on the device, this command still takes effect. The online users are not affected by this command, but the system forbids new portal users to log in.
This command sets the maximum number of online IPv4 and IPv6 portal users in all.
Make sure the maximum combined number of IPv4 and IPv6 portal users specified on all interfaces or service templates does not exceed the system-allowed maximum number. Otherwise, the exceeding portal users will not be able to log in to the device.
# Set the maximum number of online portal users allowed in the system to 100.
[Sysname] portal max-user 100
display portal user
portal { ipv4-max-user | ipv6-max-user }
portal nas-id profile
Use portal nas-id-profile to specify a NAS-ID profile for an interface.
Use undo portal nas-id-profile to restore the default.
portal nas-id-profile profile-name
No NAS-ID profile is specified for an interface.
Interface view
profile-name: Specifies the name of a NAS-ID profile, a case-insensitive string of 1 to 31 characters.
A NAS-ID profile defines the binding relationship between VLANs and NAS-IDs. To configure a NAS-ID profile, use the aaa nas-id profile command. For more information about the aaa nas-id profile command, see "AAA commands."
Portal access matches only the inner VLAN ID of QinQ packets. For more information about QinQ, see Layer 2—LAN Switching Configuration Guide.
If an interface is specified with a NAS-ID profile, the interface prefers to use the bindings defined in the profile.
If no NAS-ID profile is specified for an interface or no matching binding is found in the specified profile, the device uses the device name as the interface NAS-ID.
# Specify the NAS-ID profile aaa for GigabitEthernet 1/0/1
[Sysname–GigabitEthernet1/0/1] portal nas-id-profile aaa
aaa nas-id profile
portal nas-port-id format
Use portal nas-port-id format to specify the NAS-Port-Id attribute format.
Use undo portal nas-port-id format to restore the default.
portal nas-port-id format { 1 | 2 | 3 | 4 }
The format for the NAS-Port-Id attribute is format 2.
1: Uses format 1 for the NAS-Port-Id attribute.
2: Uses format 2 for the NAS-Port-Id attribute.
3: Uses format 3 for the NAS-Port-Id attribute.
4: Uses format 4 for the NAS-Port-Id attribute.
The NAS-Port-Id format supported by RADIUS servers varies by vendor. Use this command to specify the format of the NAS-Port-Id attribute in the RADIUS packets sent for portal users to the RADIUS server. The device then automatically constructs a value for the NAS-Port-Id attribute in the specified format to meet the RADIUS server requirements.
Format 1 contains three space-separated strings: interface-type port-location access-node-id. Spaces are not allowed within a string.
·     The interface-type string specifies the interface type of the NAS port. Available options include:
¡     atm—ATM interface.
¡     eth—Common Ethernet interface.
¡     trunk—Ethernet trunk interface.
¡     0—The interface type information will be reported by the access node to the BRAS.
·     The port-location string represents the location of the access line on the BRAS. Its format is NAS_slot/NAS_subslot/NAS_port:XPI.XCI.
NAS_slot
Slot number of the BRAS, in the range of 0 to 31.
NAS_subslot
Subslot number of the BRAS, in the range of 0 to 31.
NAS_Port
Port number of the BRAS, in the range of 0 to 63.
XPI.XCI
For ATM interfaces:
·     XPI is VPI in the range of 0 to 255.
·     XCI is VCI in the range of 0 to 65535.
For Ethernet interfaces or Ethernet trunk interfaces:
·     XPI is PVLAN in the range of 0 to 4095. This field is set to 4096 if there is no PVLAN.
·     XCI is CVLAN in the range of 0 to 4095. This field is set to 4096 if the user is not assigned to a VLAN as in the situation where the end user device is directly connected to a BRAS port.
For the access node to report its access line information to the BRAS, all fields will be set to 0s except for the XPI and XCI fields.
·     The access-node-id string specifies the attributes the of BRAS. Its format is AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port:ANI_XPI.ANI_XCI, in which the :ANI_XPI.ANI_XCI portion is optional.
Identifier description of the access node, a string not longer than 50 characters without spaces.
ANI_rack
Rack number of the access node, in the range of 0 to 15.
ANI_frame
Frame number of the access node, in the range of 0 to 31.
ANI_slot
Slot number of the access node, in the range of 0 to 127.
ANI_subslot
Subslot number of the access node, in the range of 0 to 31.
ANI_port
Port number of the access node, in the range of 0 to 255.
ANI_XPI.ANI_XCI
Optional.
This field is mainly used to carry CPE-side service information, identifying the further service type requirement. For example, use this field to identify specific services in a multi-PVC scenario.
For ATM interfaces:
·     ANI_XPI is VPI in the range of 0 to 255.
·     ANI_XCI is VCI in the range of 0 to 65535.
·     ANI_XPI is PVLAN in the range of 0 to 4095. This field is set to 4096 if there is no PVLAN.
·     ANI_XCI is CVLAN in the range of 0 to 4095. This field is set to 4096 if the user is not assigned to a VLAN as in the situation where the end user device is directly connected to a BRAS port.
If the device does not have rack, frame, or subslot information, 0 is padded in the corresponding field.
For ATM interfaces, all fields in the access-node-id string are filled with 0s except for the ANI_XPI and ANI_XCI fields.
·     Examples of format 1:
NAS-Port-Id
atm 31/31/7:255.65535 0/0/0/0/0/0
The subscriber interface type is an ATM interface.
The slot number is 31, the BRAS subslot number is 31, the BRAS port number is 7, the VPI is 255, and the VCI is 65535.
eth 31/31/7:1234.2345 0/0/0/0/0/0
The subscriber interface type is an Ethernet interface.
The slot number is 31, the subslot number is 31, the port number is 7, the PVLAN is 1234, and the CVLAN is 2345.
If there is no PVLAN, 1234 will be replaced with 4096.
eth 31/31/7:4096.2345 0/0/0/0/0/0
The subscriber interface type is Ethernet.
The slot number is 31, the subslot number is 31, the port number is 7, and the VLAN ID is 2345.
eth 31/31/7:4096.2345 guangzhou001/1/31/63/31/127
The access node identifier of the DSLAM is guangzhou001, the rack number is 1, the frame number is 31, the slot number is 63, the subslot number is 31, and the port number is 127.
Format 2 is SlotID00IfNOVlanID.
·     SlotIDSlot number, a string of 2 characters.
·     IfNOSlot number, a string of 3 characters.
·     VlanIDVLAN ID, a string of 9 characters.
Format 3 is SlotID00IfNOVlanIDDHCPoption.
·     IfNOInterface number, a string of 3 characters.
·     DHCPoptionDHCP option 82 is appended for IPv4 users and DHCP option 1 is appended for IPv6 users.
Format 4 is slot=**;subslot=**;port=**;vlanid=**;vlanid2=**.
·     For non-VLAN interfaces, the slot=**;subslot=**;port=**;vlanid=0 format is used.
·     For interfaces that terminate only the outermost VLAN tag, the slot=**;subslot=**;port=**;vlanid=** format is used.
# Set the format of the NAS-Port-Id attribute to format 1.
[Sysname] portal nas-port-id format 1
portal nas-port-type
Use portal nas-port-type to specify the NAS-Port-Type value carried in RADIUS requests sent to the RADIUS server.
Use undo portal nas-port-type to restore the default.
portal nas-port-type { ethernet | wireless }
The NAS-Port-Type value carried in RADIUS requests is the user's access interface type value obtained by the access device.
Interface view
Service template view
ethernet: Specifies the NAS-Port-Type attribute value as Ethernet (number 15).
wireless: Specifies the NAS-Port-Type attribute value as WLAN-IEEE 802.11 (number 19).
As the access device, the BAS might not be able to correctly obtain a user's interface type when multiple network devices exist between the BAS and the portal client. For example, the access interface type obtained by the BAS for a wireless portal user might be the type of the wired interface that authenticated the user. For the BAS to send correct user interface type to the RADIUS server, use this command to specify the correct NAS-Port-Type value.
# On GigabitEthernet 1/0/1, specify the NAS-Port-Type value in RADIUS requests sent to the RADIUS server as WLAN-IEEE 802.11.
[Sysname-GigabitEthernet1/0/1] portal nas-port-type wireless
# On service template service1, specify the NAS-Port-Type value in RADIUS requests sent to the RADIUS server as WLAN-IEEE 802.11.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] portal nas-port-type wireless
display portal interface
portal oauth user-sync interval
Use portal oauth user-sync interval to set the user synchronization interval for portal authentication using OAuth.
Use undo portal oauth user-sync interval to restore the default.
portal oauth user-sync interval interval
The user synchronization interval is 60 seconds for portal authentication using OAuth.
interval: Specifies the user synchronization interval, in seconds. The value for this argument can be 0 or in the range of 60 to 3600.
If portal authentication uses OAuth, the device periodically reports user information to the portal authentication server for user synchronization on the server. To disable user synchronization from the device to the portal authentication server, set the user synchronization interval to 0 seconds on the device.
# Set the user synchronization interval to 120 seconds for portal authentication using OAuth.
[Sysname] portal oauth user-sync interval 120
portal outbound-filter enable
Use portal outbound-filter enable to enable outgoing packets filtering.
Use undo portal outbound-filter enable to disable outgoing packets filtering.
portal [ ipv6 ] outbound-filter enable
undo portal [ ipv6 ] outbound-filter enable
Outgoing packets filtering is disabled. A portal-enabled interface or service template can send any packets.
Interface view
ipv6: Specifies outgoing IPv6 packets. If you do not specify this keyword, the command is for outgoing IPv4 packets.
When you enable this feature on a portal-enabled interface or service template, the device permits the interface or service template to send the following packets:
·     Packets whose destination IP addresses are IP addresses of authenticated portal users.
·     Packets that match portal-free rules.
Other outgoing packets on the interface or service template are dropped.
# Enable outgoing packets filtering on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal outbound-filter enable
# Enable outgoing packets filtering on service template service1
[Sysname-wlan-st-service1] portal outbound-filter enable
portal packet log enable
Use portal packet log enable to enable logging for portal protocol packets.
Use undo portal packet log enable to disable logging for portal protocol packets.
Portal protocol packet logging is disabled.
This feature logs information about portal protocol packets, including the username, IP address, authentication type, SSID, AP MAC, and packet type. For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable logging for portal protocol packets.
[Sysname] portal packet log enable
portal redirect log enable
portal user log enable
portal pre-auth domain
Use portal pre-auth domain to specify a preauthentication domain for portal users.
Use undo portal pre-auth domain to restore the default.
portal [ ipv6 ] pre-auth domain domain-name
undo portal [ ipv6 ] pre-auth domain
No preauthentication domain is specified for portal users.
Interface view
ipv6: Specifies IPv6 portal users. Do not specify this keyword for IPv4 portal users.
domain-name: Specifies an existing ISP domain by its name, a case-insensitive string of 1 to 255 characters. The string cannot contain the following characters: slashes (/), backslashes (\), vertical bars (|), quotation marks ("), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), and at signs (@).
After you configure a preauthentication domain on a portal-enabled interface, the device authorizes users on the interface as follows:
1.     After an unauthenticated user obtains an IP address, the user is assigned with authorization attributes configured for the preauthentication domain.
The authorization attributes in a preauthentication domain include ACL, user profile, and CAR.
An unauthenticated user who is authorized with the authorization attributes in a preauthentication domain is called a preauthentication user.
2.     After the user passes portal authentication, the user is assigned with new authorization attributes from the AAA server.
3.     After the user goes offline, the user is reassigned with the authorization attributes in the preauthentication domain.
Make sure you specify an existing ISP domain as a preauthentication domain. If the specified ISP domain does not exist, the device might operate incorrectly. You must delete a preauthentication domain (by using the undo portal [ ipv6 ] pre-auth domain command) and reconfigure it in the following situations:
·     You create the ISP domain after specifying it as the preauthentication domain.
·     You delete the specified ISP domain and then re-create it.
The preauthentication domain takes effect only on portal users with IP addresses assigned by DHCP or DHCPv6.
If you change the preauthentication domain on an interface, the interface uses the new preauthentication domain for both new and existing preauthentication users.
If authorization attributes in the preauthentication domain are modified, the modified attributes take effect only on new preauthentication users. Existing preauthentication users use the original authorization attributes.
If both a preauthentication domain and MAC-trigger authentication are configured on the device, set the free-traffic threshold for MAC-trigger authentication to 0 bytes.
# Create preauthentication domain abc for VLAN-interface 2.
[Sysname-Vlan-interface2] portal pre-auth domain abc
display portal
portal pre-auth ip-pool
Use portal pre-auth ip-pool to specify a preauthentication IP address pool for portal users.
Use undo portal pre-auth ip-pool to restore the default.
portal [ ipv6 ] pre-auth ip-pool pool-name
undo portal [ ipv6 ] pre-auth ip-pool
No preauthentication IP address pool is specified for portal users.
Interface view
pool-name: Specifies an IP address pool by its name, a case-insensitive string of 1 to 63 characters.
You must use this command to specify a preauthentication IP address pool on a portal-enabled Layer 3 interface in the following situation:
·     Portal users access the network through a subinterface of the portal-enabled Layer 3 interface.
·     The subinterface does not have an IP address.
·     Portal users need to obtain IP addresses through DHCP.
DHCP assigns an IP address from the specified IP address pool to a user. Then, the user can use this IP address to perform portal authentication.
The specified IP address pool takes effect only when the direct portal authentication mode is used on the interface.
For the preauthentication IP address pool to take effect, make sure the specified IP address pool exists and has been correctly configured.
# Specify IPv4 address pool abc as the preauthentication IP address pool for portal users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal pre-auth ip-pool abc
dhcp server ip-pool (Layer 3—IP Services Command Reference)
display portal
ipv6 dhcp pool (Layer 3—IP Services Command Reference)
Use portal redirect log enable to enable logging for portal redirect.
Use undo portal redirect log enable to disable logging for portal redirect.
Portal redirect logging is disabled.
This feature logs information about portal redirect packets, including the user IP address, MAC address, SSID, BAS IP, and Web server IP address. For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable logging for portal redirect.
[Sysname] portal redirect log enable
portal redirect max-session per-user
Use portal redirect max-session per-user to set the maximum number of portal redirect sessions for a single user.
Use undo portal redirect max-session per-user to disable logging for portal redirect.
portal redirect max-session per-user number
undo redirect max-session per-user
No limit is set on the number of portal redirect sessions for a single user.
number: Specifies the maximum number of portal redirect sessions for a single user, in the range of 1 to 128.
If a user client is attacked by malicious software or viruses, it might initiate a large number of portal redirect sessions. You can use this command to limit the number of portal redirect sessions that can be established for a user and limit the portal redirect session processing rate.
The value set by this command applies to the HTTP redirect sessions and HTTPS redirect sessions separately. For example, assume you set the maximum value to 50. Then, the maximum number of portal redirect sessions that can be established per user and that can be processed per second are both 100 (50 for HTTP and 50 for HTTPS).
In wireless networks, this command takes effect only in centralized forwarding mode.
# Set the maximum number of portal redirect sessions for a single user to 128.
[Sysname] portal redirect max-session per-user 128
display portal redirect
portal redirect-rule destination
Use portal redirect-rule destination to configure a destination-based portal redirection rule.
Use undo portal redirect-rule destination to delete a destination-based portal redirection rule.
portal redirect-rule destination { host { host-name | ip-address } | ipv6 ipv6-address } [ redirect-url url ]
undo portal redirect-rule destination { host { host-name | ip-address } | ipv6 ipv6-address | all }
Destination-based portal redirection rules with destination addresses 10.1.0.6 and 10.168.168.1 are configured.
host host-name: Specifies a destination host by its host name, a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
host ip-address: Specifies a destination IPv4 address.
ipv6 ipv6-address: Specifies a destination IPv6 address.
redirect-url url: Specifies the redirection URL. The device will redirect Web requests destined for the specified destination to the specified redirection URL. The specified URL must be a complete URL starting with http:// or https://, a case-sensitive string of 1 to 256 characters. If you do not specify a redirection URL, the device redirects the user to the redirection URL in a URL redirection match rule (if-match rule) that matches the user's Web request. If no matching if-match rule is found, the device redirects the user to the URL of the portal Web server.
all: Specifies all destination-based portal redirection rules.
The device uses destination-based portal redirection rules to perform URL redirection. If the Web request of a portal user matches the specified destination in a redirection rule, the device redirects the user to the URL specified in the redirection rule.
If the Web request of a portal user matches a destination-based portal redirection rule and a URL redirection match rule (configured by using the if-match command), the redirection rule takes effect.
If you specify a host name or IP address in a destination-based portal redirection rule, do not specify a URL that includes the host name or IP address as the redirection URL in another rule. A violation will cause redirect loops.
The system supports a maximum of 10 destination-based portal redirection rules. For the same host or IP address, only one destination-based portal redirection rule is supported.
# Configure a destination-based portal redirection rule to redirect Web requests destined for host http://www.abc.com.cn to http://192.168.0.1.
[Sysname] portal redirect-rule destination host www.abc.com.cn redirect-url http://192.168.0.1
display portal dns redirect-rule-host
portal refresh enable
Use portal refresh enable to enable the Rule ARP or ND entry feature for portal clients.
Use undo portal refresh enable to disable the Rule ARP or ND entry feature for portal clients.
portal refresh { arp | nd } enable
undo portal refresh { arp | nd } enable
The Rule ARP or ND entry feature is enabled for portal clients.
arp: Enables the Rule ARP entry feature.
nd: Enables the Rule ND entry feature.
When the Rule ARP or ND entry feature is enabled for portal clients, ARP or ND entries for portal clients are Rule entries after the clients come online. These entries will not age out and will be deleted immediately after the portal clients go offline. If portal clients go offline and then try to come online before these entries are relearned for them, the clients will fail the authentication. In this case, disable this feature so that ARP or ND entries are dynamic entries after the clients come online. The dynamic ARP or ND entries are deleted only when they age out.
Enabling or disabling of this feature does not affect existing Rule ARP or ND entries for portal users.
# Disable the Rule ARP entry feature for portal clients.
[Sysname] undo portal refresh arp enable
portal roaming-center
Use portal roaming-center to create a portal roaming center and enter its view, or enter the view of an existing portal roaming center.
Use undo portal roaming-center to delete the portal roaming center.
No portal roaming center exists.
The inter-AC roaming feature allows portal users that have been authenticated on an AC to roam to another AC so as to access network resources without re-authentication.
The portal roaming center is required for this feature. For inter-AC roaming to operate, you must create a portal roaming center on both the source AC and the destination AC.
As a best practice, do not delete the portal roaming center when online portal users exist on the device. A violation might cause data inconsistency between the portal roaming center and the WLAN roaming center and further roaming failure. In this case, a roaming user must pass authentication on the new device to come online.
# Create a portal roaming center and enter its view.
[Sysname] portal roaming-center
[Sysname-portal-roaming-center]
display portal roaming-center statistics packet
portal roaming enable
Use portal roaming enable to enable intra-VLAN roaming for portal users.
Use undo portal roaming enable to disable intra-VLAN roaming for portal users.
Intra-VLAN roaming is disabled for portal users.
If intra-VLAN roaming is enabled for portal users, an online portal user can access network resources from any Layer 2 port in its local VLAN. If intra-VLAN roaming is disabled for portal users, the portal user can access network resources only from the Layer 2 port on which it passes authentication.
For intra-VLAN roaming for portal users to take effect, you must disable the Rule ARP or ND entry feature by using the undo portal refresh { arp | nd } enable command.
Intra-VLAN roaming applies only to portal users that log in from VLAN interfaces.
This command cannot be executed when online users or preauthentication portal users are present on the device.
# Enable intra-VLAN roaming for portal users.
[Sysname] portal roaming enable
portal safe-redirect default-action
Use portal safe-redirect default-action to configure the default action for portal safe-redirect.
Use undo portal safe-redirect default-action to restore the default.
portal safe-redirect default-action { forbidden | permit }
No default action is configured for portal safe-redirect.
forbidden: Sets the default action to forbid, which drops a packet.
permit: Sets the default action to permit, which permits a packet.
The portal safe-redirect default action rule matches URLs that are not permitted or forbidden by portal safe-redirect, and applies the default action to packets containing the matching URLs.
For this command to take effect, make sure portal safe-redirect is enabled.
Portal safe-redirect matches URL information of a Web request packet in the following order:
1.     Matches the HTTP request methods specified for portal safe-redirect.
¡     If the packet does not match a specified HTTP request method, the packet is dropped.
¡     If the packet matches a specified method or no HTTP request methods are specified for portal safe-redirect, the next step applies.
2.     Matches the browser types specified for portal safe-redirect.
¡     If the packet does not match a specified browser type, the packet is dropped.
¡     If the packet matches a specified browser type or no browser types are specified for portal sate-redirect, the next step applies.
3.     Matches the forbidden URLs configured for portal safe-redirect.
¡     If the packet matches a forbidden URL, the packet is dropped.
¡     If the packet does not match a forbidden URL or no forbidden URLs are configured, the next step applies.
4.     Matches the forbidden filename extensions configured for portal safe-redirect.
¡     If the packet matches a forbidden filename extension, the packet is dropped.
¡     If the packet does not match a forbidden filename extension or no forbidden filename extensions are configured for portal safe-redirect, the next step applies.
5.     Matches the permitted URLs configured for portal safe-redirect.
¡     If the packet matches a permitted URL, the packet is permitted.
¡     If the packet does not match a permitted URL or no permitted URLs are configured for portal safe-redirect, the packet is dropped.
6.     Matches the default HTTP request method of portal safe-redirect.
¡     If the packet does not match the default HTTP request method, the packet is dropped.
¡     If the packet matches the default HTTP request method, the next step applies.
7.     Identifies whether browser types are specified portal safe-redirect.
¡     If browser types are specified for portal safe-redirect, the packet is permitted.
¡     If no browser types are specified for portal safe-redirect, the next step applies.
8.     Matches the portal safe-redirect default action rule.
¡     If the packet matches the default action rule, the packet is processed according to the default action.
¡     If the packet does not match the default action rule or the default action is not configured, the next step applies.
9.     Matches the default browser types of portal safe-redirect.
¡     If the packet matches a default browser type, the packet is permitted.
¡     If the packet does not match a default browser type, the packet is dropped.
# Configure the default action as permit for portal safe-redirect.
[Sysname] portal safe-redirect default-action permit
portal safe-redirect enable
portal safe-redirect forbidden-file
portal safe-redirect forbidden-url
portal safe-redirect method
portal safe-redirect permit-url
portal safe-redirect user-agent
Use portal safe-redirect enable to enable the portal safe-redirect feature.
Use undo portal safe-redirect enable to restore the default.
The portal safe-redirect feature is disabled.
Portal redirects all HTTP requests except HTTP requests that match portal-free rules to the portal Web server, which might overload the server.
Portal safe-redirect filters HTTP requests by HTTP request method, browser type (in HTTP User Agent), and destination URL, and redirects only the permitted HTTP requests.
As a best practice to avoid server overload and improve security, enable portal safe-redirect on the device.
# Enable the portal safe-redirect feature.
[Sysname] portal safe-redirect enable
portal safe-redirect forbidden-keyword
Use portal safe-redirect forbidden-keyword to configure a URL keyword forbidden by portal safe-redirect.
Use undo portal safe-redirect forbidden-keyword to delete a portal safe-redirect forbidden URL keyword.
portal safe-redirect forbidden-keyword keyword
undo portal safe-redirect forbidden-keyword keyword
No forbidden URL keywords are configured. The device redirects HTTP requests regardless of the keywords in the URL.
keyword: Specifies a URL keyword forbidden by portal safe-redirect, a case-insensitive string of 1 to 16 characters.
If the URL in an HTTP request of a portal user contains a specified forbidden URL keyword, the device drops the HTTP request.
·     If the HTTP request comes from an unauthenticated user, the device does not redirect the user to the portal Web server for authentication.
·     If the HTTP request comes from an authenticated user, the device does not redirect the user to the specified redirection webpages (such as an advertisement webpage configured by using the ad-url command).
You can configure multiple portal safe-redirect forbidden URL keywords.
# Specify .jpg as a portal safe-redirect forbidden URL keywords.
display portal safe-redirect statistics
Use portal safe-redirect forbidden-url to configure a URL forbidden by portal safe-redirect.
Use undo portal safe-redirect forbidden-url to delete a portal safe-redirect forbidden URL.
portal safe-redirect forbidden-url user-url-string
undo portal safe-redirect forbidden-url user-url-string
No forbidden URLs are configured. The device can redirect HTTP requests with any URLs.
user-url-string: Specifies a URL forbidden by portal safe-redirect, a case sensitive string of 1 to 256 characters. Valid characters are letters, digits, hyphens (-), underscores (_), and wildcards (asterisks *). The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
You can repeat this command to configure multiple portal safe-redirect forbidden URLs. The device does not redirect HTTP requests destined for the specified URLs to the portal Web server.
You can configure a forbidden URL in one of the following ways:
·     For exact match—Specify a complete URL. For example, if you configure the URL as abc.com.cn, only Web requests that contain URL abc.com.cn match the rule.
·     For fuzzy match—Specify a URL by placing the asterisk (*) wildcard character at the beginning or end of the URL string. For example, if you configure the URL as *abc.com.cn, abc*, or *abc*, Web requests that carry the URL ending with abc.com.cn, starting with abc, or including abc match the rule.
¡     The asterisk (*) wildcard character represents any characters. The device treats multiple consecutive asterisks as one.
¡     The configured URL cannot contain only asterisks (*).
# Specify http://www.abc.com as a portal safe-redirect forbidden URL.
[Sysname] portal safe-redirect forbidden-url http://www.abc.com
Use portal safe-redirect method to specify HTTP request methods permitted by portal safe-redirect.
Use undo portal safe-redirect method to delete HTTP request methods permitted by portal safe-redirect.
portal safe-redirect method { get | post }*
undo portal safe-redirect method { get | post }*
After portal safe-redirect is enabled, the device redirects only HTTP requests with the GET method.
get: Specifies the GET request method.
post: Specifies the POST request method.
After you specify HTTP request methods for portal safe-redirect, the device redirects only the HTTP requests with the specified methods to the portal Web server.
If you configure this command multiple times, the most recent configuration takes effect.
# Specify the GET request method for portal safe-redirect.
[Sysname] portal safe-redirect method get
Use portal safe-redirect permit-url to configure a URL permitted by portal safe-redirect.
Use undo portal safe-redirect permit-url to delete a portal safe-redirect permitted URL.
portal safe-redirect permit-url user-url-string
undo portal safe-redirect permit-url user-url-string
The device can redirect Web requests with any URLs.
user-url-string: Specifies a URL permitted by portal safe-redirect, a case sensitive string of 1 to 256 characters. Valid characters are letters, digits, hyphens (-), underscores (_), and wildcards (asterisks *). The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
You can repeat this command to configure multiple portal safe-redirect permitted URLs.
You can configure a permitted URL in one of the following ways:
# Specify http://www.abc.com as a portal safe-redirect permitted URL.
[Sysname] portal safe-redirect permit-url http://www.abc.com
portal safe-redirect action
Use portal safe-redirect user-agent to specify a browser type for portal safe-redirect.
Use undo portal safe-redirect user-agent to delete a browser type for portal safe-redirect.
portal safe-redirect user-agent user-agent-string
undo portal safe-redirect user-agent user-agent-string
After portal safe-redirect is enabled, the device redirects the HTTP packets matching any browser types in Table 37.
user-agent-string: Specifies a browser type in HTTP User Agent, a case-sensitive string of 1 to 255 characters. You can specify the browser types as shown in Table 37.
Table 37 Browser type and description
Browser type
Safari
Apple browser
Chrome
Google browser
Firefox
Firefox browser
UC
UC browser
QQBrowser
QQ browser
LBBROWSER
Cheetah browser
TaoBrowser
Taobao browser
Maxthon
Maxthon browser
BIDUBrowser
Baidu browser
MSIE 10.0
Microsoft IE 10.0 browser
MSIE 9.0
Microsoft IE 9.0 browser
MSIE 8.0
Microsoft IE 8.0 browser
MSIE 7.0
Microsoft IE 7.0 browser
MSIE 6.0
Microsoft IE 6.0 browser
MetaSr
Sogou browser
You can execute this command for multiple times to specify multiple browser types. The device redirects an HTTP request only when its User-Agent string contains a specified browser type.
# Specify browser types Chrome and Safari for portal safe-redirect.
[Sysname] portal safe-redirect user-agent Chrome
[Sysname] portal safe-redirect user-agent Safari
portal server
Use portal server to create a portal authentication server and enter its view, or enter the view of an existing portal authentication server.
Use undo portal server to delete the specified portal authentication server.
portal server server-name
undo portal server server-name
No portal authentication servers exist.
server-name: Specifies a portal authentication server by its name, a case-sensitive string of 1 to 32 characters.
In portal authentication server view, you can configure the following parameters and features for the portal authentication server:
·     IP address of the server.
·     Destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
·     Pre-shared key for communication between the access device and the server.
·     Server detection feature.
You can configure multiple portal authentication servers for an access device.
# Create the portal authentication server pts and enter its view.
[Sysname] portal server pts
[Sysname-portal-server-pts]
display portal server
portal temp-pass enable
Use portal temp-pass enable to enable portal temporary pass and set the temporary pass period.
Use undo portal temp-pass enable to disable portal temporary pass.
portal temp-pass [ period period-value ] enable
Portal temporary pass is disabled.
Interface view
period period-value: Specifies the temporary pass period. The value range for the period-value argument is 10 to 3600 seconds, and the default is 30 seconds.
This command is available only for direct portal authentication mode.
Typically, a portal user cannot access the network before passing portal authentication. This feature allows a user to access the Internet temporarily if the user uses a WeChat account to perform portal authentication. During the temporary pass period, the user provides WeChat authentication information to the WeChat server for the server to interact with the access device to finish portal authentication.
# On GigabitEthernet1/0/1, enable portal temporary pass and set the temporary pass period to 25 seconds.
[Sysname-GigabitEthernet1/0/1] portal temp-pass period 25 enable
display portal
portal traffic-accounting disable
Use portal traffic-accounting disable to disable traffic accounting for portal users.
Use undo portal traffic-accounting disable to restore the default.
Traffic accounting for portal users is enabled.
The accounting server might perform time-based or traffic-based accounting, or it might not perform accounting. If the accounting server does not perform traffic-based accounting, disable traffic accounting for portal users on the device. The device will provide quick accounting for portal users, and the traffic statistics will be imprecise. If the accounting server performs traffic-based accounting, enable traffic accounting for portal users. The device will provide precise traffic statistics for portal users.
# Disable traffic accounting for portal users.
[Sysname] portal traffic-accounting disable
portal traffic-backup threshold
Use portal traffic-backup threshold to set the user traffic backup threshold.
Use undo portal traffic-backup threshold to restore the default.
portal traffic-backup threshold value
The user traffic backup threshold is 10 MB.
value: Specifies the user traffic backup threshold, in MB. The value range for this argument is 0 to 100000. If you set the threshold to 0 MB, the device backs up user traffic in real time.
The device backs up traffic for a user when the user's traffic reaches the user traffic backup threshold. A smaller threshold provides more accurate backup for user traffic. However, when a large number of users exist, a small threshold results in frequent user traffic backups, affecting the user online, offline, and accounting processes. Set a proper threshold to balance between service performance and traffic backup accuracy.
# Set the user traffic backup threshold to 10240 MB.
[Sysname] portal traffic-backup threshold 10240
portal traffic-rate statistics-interval
Use portal traffic-rate statistics-interval to configure the time interval for traffic rate calculation of portal users.
Use undo portal traffic-rate statistics-interval to restore the default.
portal traffic-rate statistics-interval interval
The time interval for traffic rate calculation of portal users is 1 second.
interval: Specifies the time interval for traffic rate calculation of portal users, in the range of 1 to 3600 seconds.
By default, the device calculates the portal user traffic rate per second to obtain the instantaneous traffic rate of the users. For more accurate and effective analysis of the user traffic, you can use this command to specify a longer time interval to calculate the average traffic rate. The device divides the total user traffic obtained in the specified time interval by the time interval to get the average traffic rate. To view the average traffic rate of portal users, use the display portal user command.
# Set the time interval for traffic rate calculation of portal users to 10 seconds.
[Sysname] portal traffic-rate statistics-interval 10
display portal user
portal url-param source-address code-base64
Use portal url-param source-address code-base64 to enable base64 encoding for the user IP address in redirection URLs.
Use undo url-param source-address code-base64 to disable base64 encoding for the user IP address in redirection URLs.
undo portal url-param source-address code-base64
Base64 encoding is disabled for the user IP address in redirection URLs.
Interface view
During OAuth-based local portal WeChat authentication, if the redirection URL for portal users carries a user IP address, the WeChat authentication server might fail to identify the user IP address. This will cause portal authentication page push failure. To resolve this issue, perform this task so the device will perform base64 encoding on the user IP address in redirection URLs. In this way, the WeChat authentication server can parse the redirection URL and can correctly push portal authentication pages.
Use this command only when the following conditions are met:
·     OAuth-based local portal WeChat authentication is used.
·     The user IP address parameter is carried in the URL of a portal Web server by specifying the source-address parameter in the url-parameter command.
# On GigabitEthernet 1/0/1, enable base64 encoding for the user IP address in redirection URLs.
[Sysname-GigabitEthernet1/0/1] portal url-param source-address code-base64
url-parameter
portal url-unescape-chars
Use portal url-unescape-chars to specify the unescaped special characters in the portal Web server URLs redirected to users.
Use undo portal url-unescape-chars to cancel the configuration of unescaped special characters.
portal url-unescape-chars character-string
undo portal url-unescape-chars character-string
The device escapes all special characters in the portal Web server URLs redirected to users.
character-string: Specifies the special characters to be unescaped in the URL. The string can contain dollar signs ($), hyphens (-), underscores (_), dots (.), plus signs (+),exclamatory marks (!), asterisks (*),single quotation marks ('), parentheses (()), semicolons (;), commas (,), slashes (/), question marks (?), colons (:), and the at signs (@). Since the value can contain question marks (?), you cannot obtain the online help for this parameter by entering a question mark in the CLI.
By default, the device escapes all special characters in the portal Web server URLs redirected to users (converts them to secure forms) to prevents the clients from misunderstanding the original semantics.
Some portal Web servers cannot identify the escape characters of some special characters, so they cannot correctly provide the Web authentication page to users. To resolve this issue, you can execute this command to unescape these special characters.
Before configuring special characters, identify whether the portal Web server can recognize the escape characters of these special characters.
# Configure the unescaped special characters in redirect portal Web server URLs as ;().
[Sysname] portal url-unescape-chars ;()
Use portal user log enable to enable logging for portal user logins and logouts.
Use undo portal user log enable to disable logging for portal user logins and logouts.
Portal user login and logout logging is disabled.
This feature logs information about portal user login and logout events, including the username, IP address, user's MAC address, interface name, VLAN, SSID, AP's MAC address, and reason for login failure. For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable logging for portal user logins and logouts.
[Sysname] portal user log enable
portal user-block failed-times
Use portal user-block failed-times to configure the device to block portal users that fail portal authentication.
Use undo portal user-block failed-times to configure the device not to block portal users that fail portal authentication.
portal user-block failed-times failed-times period period [ method { ip | mac | username } ]
The device does not block portal users that fail portal authentication.
failed-times: Specifies the maximum number of consecutive authentication failures allowed for a portal user in the specified failure detection period. The value range for this argument is 0 to 10. If you specify value 0 for this argument, the device does not block portal users that fail portal authentication.
period period: Specifies the authentication failure detection period, in the range of 1 to 120 minutes.
method: Specifies the method to block portal users that fail portal authentication. If you do not specify this keyword, the device blockes portal users that fail portal authentication by IP address.
ip: Blocks portal users by IP address. If portal users at the same IP address consecutively fail portal authentication for the specified times within the failure detection period, the device blocks the IP address.
mac: Blocks portal users by MAC address. If portal users at the same MAC address consecutively fail portal authentication for the specified times within the failure detection period, the device blocks the MAC address.
username: Blocks portal users by username. If portal users using the same username consecutively fail portal authentication for the specified times within the failure detection period, the device blocks the username.
This feature prevents exhaustive password cracking. It blocks a portal user if the user consecutively fails authentication for the specified times within the failure detection period. All authentication requests from the user are dropped by the device till the blocking times out. To set the blocking timeout time, use the portal user-block reactive command.
This feature does not block preauthentication portal users.
# Configure the device to block portal users at a MAC address if the users consecutively fail portal authentication twice within 100 minutes.
[Sysname] portal user-block failed-times 2 period 100 method mac
Use portal user-block reactive to set the portal user blocking timeout time.
Use undo portal user-block reactive to restore the default.
portal user-block reactive period
The portal user blocking timeout time is 30 minutes.
period: Specifies the blocking timeout time, in the range of 0 to 1000 minutes. If you specify value 0 for this argument, blocked portal users cannot perform portal authentication again.
A portal user is blocked after the user consecutively fails portal authentication for the specified times within the specified failure detection period (set by using the portal user-block failed-times command). This user can perform portal authentication again only after the portal user blocking timeout time expires.
# Set the portal user blocking timeout time to 20 minutes.
[Sysname] portal user-block reactive 20
portal user-detect
Use portal user-detect to enable online detection of IPv4 portal users.
Use undo portal user-detect to disable online detection of IPv4 portal users.
portal user-detect type { arp | icmp } [ retry retries ] [ interval interval ] [ idle time ]
Online detection of IPv4 portal users is disabled.
Interface view
type: Specifies the detection type.
arp: Specifies ARP detection.
icmp: Specifies ICMP detection.
retry retries: Specifies the maximum number of detection attempts, in the range of 1 to 10. The default value is 3.
interval interval: Specifies a detection interval in the range of 1 to 1200 seconds. The default interval is 3 seconds.
idle time: Specifies a user idle timeout in the range of 60 to 3600 seconds. The default idle timeout is 180 seconds. When the timeout expires, online detection of IPv4 portal users is started.
If the device receives no packets from a portal user within the configured idle time, the device detects the user's online status as follows:
·     ICMP detection—Sends ICMP requests to the user at configurable intervals to detect the user status.
¡     If the device receives a reply within the maximum number of detection attempts, it considers that the user is online and stops sending detection packets. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the device receives no reply after the maximum number of detection attempts, the device logs out the user.
·     ARP detection—Sends ARP requests to the user and detects the ARP entry status of the user at configurable intervals.
¡     If the ARP entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detecting the user's ARP entry. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the ARP entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
Direct authentication and re-DHCP authentication support both ARP detection and ICMP detection. Cross-subnet authentication only supports ICMP detection.
If the access device filters out ICMP packets, ICMP detection might fail and result in the logout of portal users. Make sure the access device does not block ICMP packets before you enable ICMP detection on an interface.
# Enable online detection of IPv4 portal users on GigabitEthernet 1/0/1. Configure the detection type as ICMP, the maximum number of detection attempts as 5, the detection interval as 10 seconds, and the user idle timeout as 300 seconds.
[Sysname–GigabitEthernet1/0/1] portal user-detect type icmp retry 5 interval 10 idle 300
display portal
portal user-dhcp-only
Use portal user-dhcp-only to allow only users with DHCP-assigned IP addresses to pass portal authentication.
Use undo portal user-dhcp-only to restore the default.
portal [ ipv6 ] user-dhcp-only
undo portal [ ipv6 ] user-dhcp-only
Both users with DHCP-assigned IP addresses and users with static IP addresses can pass portal authentication to come online.
Interface view
CAUTION
CAUTION:
·     With this feature enabled, users with static IP addresses cannot pass portal authentication to come online.
·     On an AC+fit AP network, this feature takes effect only when the AC acts as the DHCP server.
·     To ensure that IPv6 users can pass portal authentication when this feature is enabled, disable the temporary IPv6 address feature on terminal devices. Otherwise, IPv6 users will use temporary IPv6 addresses to access the IPv6 network and will fail portal authentication.
# Allow only users with DHCP-assigned IP addresses on GigabitEthernet 1/0/1 to pass portal authentication.
[Sysname-GigabitEthernet1/0/1] portal user-dhcp-only
# Allow only users with DHCP-assigned IP addresses on service template service1 to pass portal authentication.
[Sysname-wlan-st-service1] portal user-dhcp-only
display portal
portal user-log traffic-separate
Use portal user-log traffic-separate to enable separate IPv4 and IPv6 traffic statistics in portal user offline logs.
Use undo portal user-log traffic-separate to restore the default.
IPv4 and IPv6 traffic statistics of portal users are collectively counted as IPv4 traffic statistics in portal user offline logs. No IPv6 traffic statistics is displayed in portal user offline logs.
For single-stack users:
·     If this feature is enabled, both IPv4 and IPv6 traffic statistics are displayed in user offline logs. For IPv4 users, the IPv6 traffic statistics is displayed as 0. For IPv6 users, the IPv4 traffic statistics is displayed as 0.
·     If this feature is disabled, traffic statistics of both IPv4 users and IPv6 users are displayed as IPv4 traffic statistics in portal user offline logs.
For dual-stack users:
·     If this feature is enabled, IPv4 and IPv6 traffic statistics of a user are displayed separately in the user offline logs.
·     If this feature is disabled, IPv4 and IPv6 traffic statistics of a user are collectively counted as IPv4 traffic statistics in portal user offline logs.
# Enable separate IPv4 and IPv6 traffic statistics in portal user offline logs.
[Sysname] portal user-log traffic-separate
portal user-logoff after-client-offline enable
Use portal user-logoff after-client-offline enable to enable automatic logout for wireless portal users.
Use undo portal user-logoff after-client-offline enable to disable automatic logout for wireless portal users.
Automatic logout is disabled for wireless portal users. Portal users will not be automatically logged out after the wireless clients are disconnected from the wireless network.
After automatic logout is enabled for wireless portal users, the device will automatically log out a portal user after the user is disconnected from the wireless network.
# Enable automatic logout for wireless portal users.
[Sysname] portal user-logoff after-client-offline enable
portal user-logoff ssid-switch enable
Use portal user-logoff ssid-switch enable to enable the device to log out wireless portal users when they switch SSIDs.
Use undo portal user-logoff ssid-switch enable to disable the device from logging out wireless portal users when they switch SSIDs.
The device does not log out wireless portal users when they switch SSIDs and the users stay online.
When an authenticated user switches the SSID to access through another service template associated with the same VLAN with the original service template, the user fails portal authentication.
Use this command to log out wireless portal users on the original service template when they switch SSIDs so that they can pass portal authentication on the new service template.
# Enable the device to log out wireless portal users when they switch SSIDs.
[Sysname] portal user-logoff ssid-switch enable
portal web-proxy port
Use portal web-proxy port to specify the port number of a Web proxy server.
Use undo portal web-proxy port to delete port numbers of Web proxy servers.
portal web-proxy { http | https } port port-number
undo portal web-proxy { { http | https } port port-number | all-port }
No port numbers of Web proxy servers are specified. Proxied HTTP and HTTPS requests are dropped.
http: Specifies the HTTP service.
https: Specifies the HTTPS service.
port-number: Specifies the TCP port number of a Web proxy server. The value range for this argument is 1 to 65535. Do not specify TCP port number 80 or 443 because 80 and 443 are port numbers reserved for portal.
all-port: Specifies all port numbers of Web proxy servers.
To allow HTTP or HTTPS requests proxied by Web proxy servers to trigger portal authentication, specify the port numbers of the Web proxy servers on the device. If a Web proxy server port is not specified on the device, HTTP or HTTPS requests proxied by the Web proxy server are dropped, and portal authentication cannot be triggered.
You can configure this command multiple times to specify a maximum of 64 Web proxy server ports for HTTP and HTTPS.
Do not specify the same Web proxy server port for HTTP and HTTPS.
If a user's browser uses the Web Proxy Auto-Discovery (WPAD) protocol to discover Web proxy servers, you must perform the following tasks on the device:
·     Specify the port numbers of the Web proxy servers on the device.
·     Configure portal-free rules to allow user packets destined for the IP address of the WPAD server to pass without authentication.
If portal users enable Web proxy in their browsers, the users must add the IP address of the portal authentication server as a proxy exception in their browsers. Then, HTTP or HTTPS packets that the users send to the portal authentication server will not be sent to Web proxy servers.
# Specify TCP port number 8080 as a Web proxy server port that allows HTTP requests to trigger portal authentication.
[Sysname] portal web-proxy http port 8080
portal enable method
portal web-server
Use portal web-server to create a portal Web server and enter its view, or enter the view of an existing portal Web server.
Use undo portal web-server to delete a portal Web server.
portal web-server server-name
undo portal web-server server-name
No portal Web servers exist.
server-name: Specifies a portal Web server by its name, a case-sensitive string of 1 to 32 characters.
The portal Web server pushes portal authentication pages to portal users during authentication. The access device redirects HTTP requests of unauthenticated portal users to the portal Web server. In portal Web server view, you can configure the URL and URL parameters for the portal Web server and the portal Web server detection feature.
# Create the portal Web server wbs and enter its view.
[Sysname] portal web-server wbs
[Sysname-portal-websvr-wbs]
display portal web-server
portal apply web-server
portal wifidog user-sync interval
Use portal wifidog user-sync interval to enable user information synchronization and set the synchronization interval for portal authentication using WiFiDog.
Use undo portal wifidog user-sync interval to disable user information synchronization and cancel the synchronization interval setting for portal authentication using WiFiDog.
portal wifidog user-sync interval interval
User information synchronization is disabled for portal authentication using WiFiDog.
interval: Specifies the user information synchronization interval, in the range of 60 to 1440 minutes.
Use this feature when users perform portal authentication using the WiFiDog protocol. This feature enables the device to periodically synchronize user information with the portal server to ensure user information consistency between the device and the portal server.
For this feature to take effect, make sure the type of the portal Web server is Wifidog before you perform this task. To specify the type of the portal Web server, use the server-type command.
# Enable user information synchronization and set the synchronization interval to 61 minutes for portal authentication using WiFiDog.
[Sysname] portal wifidog user-sync interval 61
server-type
portal { bas-ip | bas-ipv6 }
Use portal { bas-ip | bas-ipv6 } to configure the BAS-IP or BAS-IPv6 attribute carried in the portal packets sent to the portal authentication server.
Use undo portal { bas-ip | bas-ipv6 } to delete the BAS-IP or BAS-IPv6 attribute setting.
portal { bas-ip ipv4-address | bas-ipv6 ipv6-address }
The BAS-IP attribute of an IPv4 portal reply packet sent to the portal authentication server is the source IPv4 address of the packet. The BAS-IPv6 attribute of an IPv6 portal reply packet sent to the portal authentication server is the source IPv6 address of the packet.
The BAS-IP attribute of an IPv4 portal notification packet sent to the portal authentication server is the IPv4 address of the packet's outgoing interface. The BAS-IPv6 attribute of an IPv6 portal notification packet sent to the portal authentication server is the IPv6 address of the packet's outgoing interface.
Interface view
bas-ip ipv4-address: Specifies BAS-IP for portal packets sent to the portal authentication server. The ipv4-address argument must be the IPv4 address of an interface on the device. It cannot be 0.0.0.0, 1.1.1.1, a class D address, a class E address, or a loopback address.
bas-ipv6 ipv6-address: Specifies BAS-IPv6 for portal packets sent to the portal authentication server. The ipv6-address argument must be the IPv6 address of an interface on the device. It cannot be a multicast address, an all 0 address, or a link-local address.
If the device runs Portal 2.0, unsolicited portal packets (such as a logout notification packet) sent to the portal authentication server must carry the BAS-IP attribute. If the device runs Portal 3.0, unsolicited portal packets sent to the portal authentication server must carry the BAS-IP or BAS-IPv6 attribute.
After this command takes effect, the source IP address for unsolicited notification portal packets the device sends to the portal authentication server is the configured BAS-IP or BAS-IPv6. If the BAS IP address is not configured, the source IP address of the packets is the IP address of the packet output interface.
You must configure the BAS-IP or BAS-IPv6 attribute on a portal authentication-enabled interface or service template if the following conditions are met:
·     The portal authentication server is an H3C IMC server or the portal authentication mode on the interface is re-DHCP.
·     The portal device IP address specified on the portal authentication server is not the IP address of the portal packet output interface.
# On GigabitEthernet 1/0/1, configure the BAS-IP attribute as 2.2.2.2 for portal packets sent to the portal authentication server.
[Sysname-GigabitEthernet1/0/1] portal bas-ip 2.2.2.2
# On service template service1, configure the BAS-IP attribute as 2.2.2.2 for portal packets sent to the portal authentication server.
[Sysname-wlan-st-service1] portal bas-ip 2.2.2.2
display portal
portal { ipv4-max-user | ipv6-max-user }
Use portal { ipv4-max-user | ipv6-max-user } to set the maximum number of portal users allowed on an interface or a service template.
Use undo portal { ipv4-max-user | ipv6-max-user } to restore the default.
portal { ipv4-max-user | ipv6-max-user } max-number
No limit is placed on the number of portal users on an interface or service template.
Interface view
max-number: Specifies the maximum number of IPv4 or IPv6 portal users allowed on an interface or a service template. The value range for this argument is 1 to 4294967295.
If the specified maximum number is smaller than the number of current online portal users on the interface or service template, the limit can be set successfully. The limit does not impact the online portal users. However, the device does not allow new portal users to log in from the interface or service template until the number drops down below the limit.
Make sure the maximum combined number of IPv4 and IPv6 portal users specified on all interfaces or service templates does not exceed the system-allowed maximum number. Otherwise, the exceeding portal users will not be able to log in to the device.
# Set the maximum number of IPv4 portal users to 100 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] portal ipv4-max-user 100
# Set the maximum number of IPv4 portal users to 100 on service template service1.
[Sysname-wlan-st-service1] portal ipv4-max-user 100
display portal user
portal max-user
redirect-url
Use redirect-url to specify the URL to which portal users are redirected after they pass QQ or Facebook authentication.
Use undo redirect-url to restore the default.
redirect-url url-string
undo redirect-url
Portal users are redirected to URLs http://lvzhou.h3c.com/portal/qqlogin.html and http://oauthindev.h3c.com/portal/fblogin.html after they pass QQ authentication and Facebook authentication, respectively.
QQ authentication server view
Facebook authentication server view
url-string: Specifies the URL to which portal users are redirected after they pass QQ or Facebook authentication. The URL is a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
After a portal user passes QQ or Facebook authentication, the user is redirected to the specified webpage to complete portal authentication.
You must enable DNS proxy and specify the IP address of an interface on the device as the DNS server.
# Configure the device to redirect portal users to URL http://www.abc.com/portal/qqlogin.html after they pass QQ authentication.
[Sysname] portal extend-auth-server qq
[Sysname-portal-extend-auth-server-qq] redirect-url http://www.abc.com/portal/qqlogin.html
# Configure the device to redirect portal users to URL http://www.abc.com/portal/qqlogin.html after they pass Facebook authentication.
display portal extend-auth-server
reset portal ad-push statistics
Use reset portal ad-push statistics to clear statistics about portal advertisement push.
reset portal ad-push statistics { ad-url-group | url }
ad-url-group: Clears advertisement group-based statistics about portal advertisement push.
url: Clears URL-based statistics about portal advertisement push.
# Clear advertisement group-based statistics about portal advertisement push.
<Sysname> reset portal ad-push statistics url
# Clear URL-based statistics about portal advertisement push.
<Sysname> reset portal ad-push statistics ad-url-group
display portal ad-push statistics
reset portal auth-error-record
Use reset portal auth-error-record to clear portal authentication error records.
reset portal auth-error-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time }
all: Specifies all portal authentication error records.
ipv4 ipv4-address: Specifies the IPv4 address of a portal user.
ipv6 ipv6-address: Specifies the IPv6 address of a portal user.
start-time start-date start-time end-time end-date end-time: Specifies a time range. The start date and end date must be in the format of MM/DD/YYYY or YYYY/MM/DD. The value range for MM is 1 to 12. The value range for DD varies with the specified month. The value range for YYYY is 1970 to 2037. The start time and end time must be in the format of hh:mm. The value range for the start time and end time is 00:00 to 23:59.
# Clear all portal authentication error records.
<Sysname> reset portal auth-error-record all
# Clear portal authentication error records of the portal user whose IPv4 address is 11.1.0.1.
<Sysname> reset portal auth-error-record ipv4 11.1.0.1
# Clear portal authentication error records of the portal user whose IPv6 address is 2000::2.
<Sysname> reset portal auth-error-record ipv6 2000::2
# Clear portal authentication error records with the error time in the range of 2016/3/4 14:20 to 2016/3/4 16:23.
<Sysname> reset portal auth-error-record start-time 2016/3/4 14:20 end-time 2016/3/4 16:23
display portal auth-error-record
reset portal auth-fail-record
Use reset portal auth-fail-record to clear portal authentication failure records.
reset portal auth-fail-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
all: Specifies all portal authentication failure records.
username username: Specifies the username of a portal user, a case-sensitive string of 1 to 253 characters. The username cannot contain the domain name.
# Clear all portal authentication failure records.
<Sysname> reset portal auth-fail-record all
# Clear portal authentication failure records of the portal user whose IPv4 address is 11.1.0.1.
<Sysname> reset portal auth-fail-record ipv4 11.1.0.1
# Clear portal authentication failure records of the portal user whose IPv6 address is 2000::2.
<Sysname> reset portal auth-fail-record ipv6 2000::2
# Clear portal authentication failure records of the portal user whose username is abc.
<Sysname> reset portal auth-fail-record username abc
# Clear portal authentication failure records with the failure time in the range of 2016/3/4 14:20 to 2016/3/4 16:23.
<Sysname> reset portal auth-fail-record start-time 2016/3/4 14:20 end-time 2016/3/4 16:23
display portal auth-fail-record
reset portal captive-bypass statistics
Use reset portal captive-bypass statistics to clear portal captive-bypass packet statistics.
In standalone mode:
In IRF mode:
reset portal captive-bypass statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears portal captive-bypass packet statistics on all member devices. (In IRF mode.)
# (In standalone mode.) Clear portal captive-bypass packet statistics.
<Sysname> reset portal captive-bypass statistics
# (In IRF mode.) Clear portal captive-bypass packet statistics on the specified slot.
<Sysname> reset portal captive-bypass statistics slot 0
display portal captive-bypass statistics
reset portal local-binding mac-address
Use reset portal local-binding mac-address to clear local MAC-account binding entries.
reset portal local-binding mac-address { mac-address | all }
mac-address: Specifies the MAC address of a portal user, in the format of H-H-H.
all: Specifies all local MAC-account binding entries.
# Clear all local MAC-account binding entries.
<Sysname> reset portal local-binding mac-address all
display portal local-binding mac-address
local-binding aging-time
reset portal logout-record
Use reset portal logout-record to clear portal user offline records.
reset portal logout-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
all: Specifies all portal user offline records.
# Clear all portal user offline records.
<Sysname> reset portal logout-record all
# Clear offline records of the portal user whose IPv4 address is 11.1.0.1.
<Sysname> reset portal logout-record ipv4 11.1.0.1
# Clear offline records of the portal user whose IPv6 address is 2000::2.
<Sysname> reset portal logout-record ipv6 2000::2
# Clear offline records of the portal user whose username is abc.
<Sysname> reset portal logout-record username abc
# Clear portal user offline records with the logout time in the range of 2016/3/4 14:20 to 2016/3/4 16:23.
<Sysname> reset portal logout-record start-time 2016/3/4 14:20 end-time 2016/3/4 16:23
display portal logout-record
reset portal packet statistics
Use reset portal packet statistics to clear packet statistics for portal authentication servers.
reset portal packet statistics [ extend-auth-server { cloud | facebook | mail | qq | wechat } | mac-trigger-server server-name | server server-name ]
extend-auth-server: Specifies a third-party authentication server by its type.
facebook: Specifies the Facebook authentication server.
cloud: Specifies the cloud authentication server.
mail: Specifies the email authentication server.
qq: Specifies the QQ authentication server.
wechat: Specifies the WeChat authentication server.
mac-trigger-server: Specify a MAC binding server by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a MAC binding server, this command clears packet statistics for the specified portal authentication server.
server server-name: Specifies a normal portal authentication server by its name, a case-sensitive string of 1 to 32 characters. If you do not specify this parameter, this command clears packet statistics for the specified MAC binding server.
If you do not specify any parameters, this command clears packet statistics for all portal authentication servers and MAC binding servers.
# Clear packet statistics for portal authentication server pts.
<Sysname> reset portal packet statistics server pts
# Clear packet statistics for MAC binding server newps.
<Sysname> reset portal packet statistics mac-trigger-server newpt
# Clear packet statistics for the cloud authentication server.
<Sysname> reset portal packet statistics extend-auth-server cloud
display portal packet statistics
reset portal roaming-center statistics packet
Use reset portal roaming-center statistics packet to clear packet statistics for the portal roaming center.
# Clear packet statistics for the portal roaming center.
<Sysname> reset portal roaming-center statistics packet
reset portal safe-redirect statistics
Use reset portal safe-redirect statistics to clear portal safe-redirect packet statistics.
In standalone mode:
In IRF mode:
reset portal safe-redirect statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears portal safe-redirect packet statistics on all member devices. (In IRF mode.)
# (In standalone mode.) Clear portal safe-redirect packet statistics.
<Sysname> reset portal safe-redirect statistics
# (In IRF mode.) Clear portal safe-redirect packet statistics on the specified slot.
<Sysname> reset portal safe-redirect statistics slot 0
response-timeout
Use response-timeout to set the wait timer for responses from the WLAN roaming center.
Use undo response-timeout to restore the default.
response-timeout timeout
The wait timer for responses from the WLAN roaming center is 3 seconds.
Portal roaming center view
timeout: Specifies the wait timer for responses from the WLAN roaming center. The value range is 1 to 10 seconds.
After the portal roaming center sends a packet to the WLAN roaming center, it starts a timer to wait for a response from the WLAN roaming center. If the portal roaming center does not receive a response before the timer expires, it retransmits the packet till the maximum number of transmission attempts is reached.
# Set the wait timer for responses from the WLAN roaming center to 2 seconds.
[Sysname-portal-roaming-center] response-timeout 2
retry
Use retry to set the maximum number of attempts to transmit a packet to the WLAN roaming center.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of attempts is 5 for the portal roaming center to transmit a packet to the WLAN roaming center.
retries: Specifies the maximum number of attempts to transmit a packet to the WLAN roaming center. The value range is 1 to 10.
After the portal roaming center sends a packet to the WLAN roaming center, it starts a timer to wait for a response from the WLAN roaming center. If the portal roaming center does not receive a response before the timer expires, it retransmits the packet. If the maximum number of attempts is reached, it still does not receive a response from the WLAN roaming center, the process goes as follows:
·     If the portal roaming center does not receive a user query response, the portal roaming center performs authentication on the user.
·     If the portal roaming center does not receive a user deletion response, it determines that the WLAN roaming center does not delete the user.
·     If the portal roaming center does not receive a user information update response, it determines that the WLAN roaming center does not update the user information.
# Set the maximum number of attempts to 4 for the portal roaming center to transmit a packet to the WLAN roaming center.
[Sysname-portal-roaming-center] retry 4
response-timeout
roaming-center enable
Use roaming-center enable to enable the portal roaming center.
Use undo roaming-center enable to disable the portal roaming center.
The portal roaming center is disabled.
After you disable the portal roaming center on an AC, online portal users on the AC still can access the network resources and roams to other ACs. However, portal users on other ACs cannot roam to this AC. If a portal user goes offline through this AC, this AC cannot send a user offline packet to the WLAN roaming center. The WLAN roaming center cannot update or delete the user data timely.
For inter-AC roaming to operate, make sure of the following:
·     The WLAN roaming center is enabled on an AC.
·     The portal roaming center is enabled and correctly configured on the roaming source and destination ACs.
For more information about WLAN roaming, see WLAN Configuration Guide.
# Enable the portal roaming center.
[Sysname-portal-roaming-center] roaming-center enable
roaming-center enable (WLAN Command Reference)
server-detect (portal authentication server view)
Use server-detect to enable portal authentication server detection. After server detection is enabled for a portal authentication server, the device periodically detects portal packets from the server to identify its reachability status.
Use undo server-detect to disable portal authentication server detection.
server-detect [ timeout timeout ] { log | trap } *
undo server-detect
Portal authentication server detection is disabled.
Portal authentication server view
timeout timeout: Specifies the detection timeout in the range of 10 to 3600 seconds. The default is 60 seconds.
log: Enables the device to send a log message when reachability status of the portal authentication server changes. The log message contains the name, the original state, and the current state of the portal authentication server.
trap: Enables the device to send a trap message to the NMS when reachability status of the portal authentication server changes. The trap message contains the name and the current state of the portal authentication server.
The portal authentication server detection feature takes effect only when the device has a portal-enabled interface.
To test server reachability by detecting heartbeat packets, you must enable the server heartbeat feature on the portal authentication server. Only the IMC portal authentication server supports sending heartbeat packets.
The detection timeout configured on the device must be greater than the server heartbeat interval configured on the portal authentication server.
If the device receives portal packets from the portal authentication server before the detection timeout expires and verifies the correctness of the packets, the device considers the portal authentication server is reachable. Otherwise, the device considers the portal authentication server is unreachable.
# Enable server detection for the portal authentication server pts:
·     Set the detection timeout to 600 seconds.
·     Configure the device to send a log message if the server reachability status changes.
[Sysname-portal-server-pts] server-detect timeout 600 log
portal server
server-detect (portal Web server view)
Use server-detect to enable portal Web server detection.
Use undo server-detect to disable portal Web server detection.
server-detect [ interval interval ] [ retry retries ] { log | trap } *
undo server-detect
Portal Web server detection is disabled.
Portal Web server view
interval interval: Specifies a detection interval in the range of 1 to 1200 seconds. The default is 5 seconds. As a best practice, set the detection interval to a value no less than 5.
retry retries: Specifies the maximum number of consecutive detection failures, in the range of 1 to 10. The default is 3. If the number of consecutive failed detections reaches this threshold, the device considers the server as unreachable.
log: Enables the device to send a log message when reachability status of the portal Web server changes. The log message contains the name, the original state, and the current state of the portal Web server.
trap: Enables the device to send a trap message to the NMS when reachability status of the portal Web server changes. The trap message contains the name and the current state of the portal Web server.
The access device performs server detection independently. No configuration on the portal Web server is required for the detection.
The portal Web server detection feature takes effect only when the URL of the portal Web server is specified and the device has a portal-enabled interface.
# Enable server detection for the portal Web server wbs:
·     Set the detection interval to 600 seconds.
·     Set the maximum number of consecutive detection failures to 2.
·     Configure the device to send a log message and a trap massage after server reachability status changes.
[Sysname-portal-websvr-wbs] server-detect interval 600 retry 2 log trap
portal web-server
server-detect url
Use server-detect url to configure the URL and the type for portal Web server detection.
Use undo server-detect url to restore the default.
server-detect url string [ detect-type { http | tcp } ]
The URL for portal Web server detection is the URL of the portal Web server. The type of portal Web server detection is TCP detection.
string: Specifies a URL to detect the reachability of the portal Web server. The URL is a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
detect-type: Specifies the type of portal Web server detection. If this keyword is not specified, TCP detection is used.
tcp: Specifies the TCP detection.
http: Specifies the HTTP detection.
This configuration takes effect only when portal Web server detection is enabled.
# Configure http://www.test.com/portal as the portal Web server detection URL.
[Sysname-portal-websvr-wbs] server-detect url http://www.test.com/portal
# Configure http://www.test.com/portal as the portal Web server detection URL and specify TCP as the detection type.
[Sysname-portal-websvr-wbs] server-detect url http://www.test.com/portal detect-type tcp
# Configure http://www.test.com/portal as the portal Web server detection URL and specify HTTP as the detection type.
[Sysname-portal-websvr-wbs] server-detect url http://www.test.com/portal detect-type http
server-register
Use server-register to configure the device to periodically send register packets to the portal authentication server.
Use undo server-register to restore the default.
server-register [ interval interval ]
The device does not send register packets to a portal authentication server.
interval interval: Specifies the interval at which the device sends register packets to the portal authentication server, in seconds. The value range for the interval argument is 1 to 3600, and the default value is 600.
This feature is typically used in scenarios where a NAT device exists between a portal authentication server and a large number of access devices.
Before this feature is used, you must configure a static NAT mapping for each access device on the NAT device, causing much workload. After this feature is enabled on an access device, the access device automatically sends a register packet to the portal authentication server. When the server receives the register packet, it records register information for the access device, including the device name, and the IP address and port number after NAT. The register information is used for subsequent authentication information exchanges between the server and the access device. The access device updates its register information on the server by sending register packets at regular intervals.
Only CMCC portal authentication servers support this feature.
# Configure the device to send register packets to portal authentication server pts at intervals of 120 seconds.
[Sysname-portal-server-pts] server-register interval 120
server-type (portal authentication server view/portal Web server view)
server-type (MAC binding server view)
Use server-type to specify the type of a MAC binding server.
Use undo server-type to restore the default.
server-type { cmcc | imc }
undo server-type
The type of the MAC binding server is IMC.
cmcc: Specifies the MAC binding server type as CMCC.
imc: Specifies the MAC binding server type as IMC.
# Specify the type of the MAC binding server as cmcc.
[Sysname] portal mac-trigger-server mts
[Sysname-portal-mac-trigger-server-mts] server-type cmcc
Use server-type to specify the type of a portal authentication server or portal Web server.
server-type { cmcc | imc | ise | oauth | wifidog }
undo server-type
The type of the portal authentication server and portal Web server is IMC.
cmcc: Specifies the portal server type as CMCC.
imc: Specifies the portal server type as IMC.
ise: Specifies the portal server type as ISE. This keyword is supported only in portal Web server view.
oauth: Specifies the portal server type as cloud platform. This keyword is supported only in portal Web server view.
wifidog: Specifies the server type as WiFiDog. This keyword is supported only in portal Web server view.
Specify the portal server type on the device with the server type the device actually uses.
# Specify the type of the portal authentication server as cmcc.
[Sysname-portal-server-pts] server-type cmcc
# Specify the type of the portal Web server as cmcc.
[Sysname] portal web-server pts
[Sysname-portal-websvr-pts] server-type cmcc
shop-id
Use shop-id to specify the shop ID for WeChat authentication.
Use undo shop-id to restore the default.
shop-id shop-id
undo shop-id
No shop ID is specified for WeChat authentication.
WeChat authentication server view
shop-id: Specifies the ID of the shop where the device is deployed as a portal device for WeChat authentication.
This configuration is required for the device to provide local WeChat authentication for portal users.
To obtain the shop ID for WeChat authentication, you must perform the following tasks:
1.     Go to the WeChat Official Account Admin Platform (https://mp.weixin.qq.com) to apply a WeChat official account.
2.     Use the account to log in to the platform and enable the WeChat WiFi hotspot feature.
3.     Click the device management tab, add the device: select the shop where the device is deployed, select the portal device type, and enter the device settings (SSID of your WiFi network).
After the previous configurations, you will obtain the credentials (app ID, app key, and shop ID) for WeChat authentication.
When a WeChat user attempts to connect to the WiFi network provided in the specified shop, the device sends the credentials to the WeChat Official Account Platform for verification. After the credentials are verified, the device continues the portal authentication and allows the user to use the WiFi network after the authentication.
The shop ID specified in this command must be the same as the shop ID obtained from the WeChat Official Account Admin Platform.
# Specify 6747662 as the shop ID for WeChat authentication.
[Sysname] portal extend-auth-server wechat
[Sysname-portal-extend-auth-server-wechat] shop-id 6747662
subscribe-required enable
Use subscribe-required enable to enable the subscribe-required feature for WeChat authentication.
Use undo subscribe-required enable to disable the subscribe-required feature for WeChat authentication.
The subscribe-required feature is disabled for WeChat authentication.
When the subscribe-required feature is enabled, portal users must follow WeChat official accounts to pass WeChat authentication.
This feature must be used with the portal temporary pass feature. As a best practice, set the temporary pass period to 600 seconds.
# Enable the subscribe-required feature for WeChat authentication.
[Sysname-portal-extend-auth-server-wechat] subscribe-required enable
tcp-port
Use tcp-port to configure a listening TCP port for a local portal Web service.
Use undo tcp-port to restore the default.
tcp-port port-number
undo tcp-port
The listening TCP port number for HTTP is 80 and that for HTTPS is the TCP port number set by using the portal local-web-server command.
Local portal Web service view
port-number: Specifies the listening TCP port number in the range of 1 to 65535.
To use the local portal Web service, make sure the port number in the portal Web server URL and the port number configured in this command are the same.
For successful local portal authentication, follow these guidelines:
·     Do not configure the listening TCP port number for a local portal Web service as the port number used by a known protocol. For example, do not specify port numbers 21 and 23, which are used by FTP and Telnet, respectively.
·     Do not configure the HTTP listening port number as the default HTTPS listening port number 443.
·     Do not configure the HTTPS listening port number as the default HTTP listening port number 80.
·     Do not configure the same listening port number for HTTP and HTTPS.
·     For the HTTPS-based local portal Web service and other services that use HTTPS:
¡     If they use the same SSL server policy, they can use the same TCP port number to listen to HTTPS.
¡     If they use different SSL server policies, they cannot use the same TCP port number to listen to HTTPS.
# Set the listening port number to 2331 for the HTTP-based local portal Web service.
[Sysname] portal local-web-server http
[Sysname-portal-local-websvr-http] tcp-port 2331
url
Use url to specify a URL for a portal Web server.
Use undo url to restore the default.
url url-string
undo url
No URL is specified for a portal Web server.
url-string: Specifies a URL for the portal Web server, a case-sensitive string of 1 to 256 characters. The URL string can include question marks (?). If you enter a question mark (?) in the place of this argument, the CLI does not display help information for this argument.
This command specifies a URL that can be accessed through standard HTTP or HTTPS. The URL should start with http:// or https://. If the URL you specify does not start with http:// or https://, the system considers the URL begins with http:// by default.
# Configure the URL for the portal Web server wbs as http://www.test.com/portal.
[Sysname-portal-websvr-wbs] url http://www.test.com/portal
url-parameter
Use url-parameter to configure the parameters carried in the URL of a portal Web server. The access device redirects a portal user by sending the URL with the parameters to the user.
Use undo url-parameter to delete the parameters carried in the URL of the portal Web server.
url-parameter param-name { bas-ip | nas-id | nas-port-id | original-url | source-address | ssid | { ap-mac | low-mac | source-mac } [ format section { 1 | 3 | 6 } { lowercase | uppercase } ] [ encryption { aes | des } key { cipher | simple } string ] | value expression | vlan }
undo url-parameter param-name
No URL parameters are configured for a portal Web server.
param-name: Specifies a URL parameter name, a case-sensitive string of 1 to 32 characters. Content of the parameter is determined by the following keyword you specify.
bas-ip: Specifies the BAS-IP attribute.
nas-id: Specifies the NAS-ID.
nas-port-id: Specifies the NAS-Port-ID.
original-url: Specifies the URL of the original webpage that a portal user visits.
source-address: Specifies the user IP address.
ssid: Specifies the SSID of the AP.
ap-mac: Specifies the MAC address of the AP.
low-mac: Specifies the MAC address on the device label, which is typically the loweset MAC address on the device.
source-mac: Specifies the user MAC address.
format: Specifies the format of the MAC address.
section: Specifies the number of sections that a MAC address contains.
1: Specifies the one-section format XXXXXXXXXXXX.
3: Specifies the three-section format XXXX-XXXX-XXXX.
6: Specifies the six-section format XX-XX-XX-XX-XX-XX.
lowercase: Specifies the letters in a MAC address to be in lower case.
uppercase: Specifies the letters in a MAC address to be in upper case.
encryption: Specifies the encryption algorithm to encrypt the MAC address of the AP or user.
aes: Specifies the AES algorithm.
des: Specifies the DES algorithm.
key: Specifies a key for encryption.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the case-sensitive key string. The string length varies by the selected encryption method:
·     If des cipher is specified, the string length is 41 characters.
·     If des simple is specified, the string length is 8 characters.
·     If aes cipher is specified, the string length is 1 to 73 characters.
·     If aes simple is specified, the string length is 1 to 31 characters.
value expression: Specifies a custom case-sensitive string of 1 to 256 characters. The string can include question marks (?). If you enter a question mark (?) in the place of the expression argument, the CLI does not display help information for this argument.
vlan: Specifies the user VLAN ID.
Working mechanism
After you configure the URL parameters, the access device sends the portal Web server URL with these parameters to portal users. For example, assume that the URL of a portal Web server is http://www.test.com/portal, and you execute the url-parameter userip source-address and url-parameter userurl value http://www.abc.com/welcome commands. Then, the access device sends to the user whose IP address is 1.1.1.1 the URL http://www.test.com/portal?userip=1.1.1.1&userurl=http://www.abc.com/welcome.
When you configure the param-name argument in this command, you must use the URL parameter name supported by the actual portal server. Different portal server types support different URL parameter names.
For example, the IMC server supports parameter names userurl, userip, and usermac for the keywords original-url, source-address, and source-mac, respectively. To carry the user IP information in the portal Web server URL, you must configure the parameter name as userip and specify the source-address keyword.
You can configure multiple URL parameters.
To avoid redirection failure, add only necessary URL parameters to the portal Web server URL. Ensure that the total length of the portal Web server URL is no longer than 2048 bytes.
If you execute this command multiple times to configure the same URL parameter, the most recent configuration takes effect.
If you specify the encryption algorithm for a parameter, the redirection URL carries the encrypted value for the parameter. Execute the url-parameter usermac source-mac encryption des key simple 12345678 command. Then, the access device sends to the user with MAC address 1111-1111-1111 the URL http://www.test.com/portal?usermac=xxxxxxxxx&userip=1.1.1.1&userurl= http://www.test.com/welcome, where xxxxxxxxx represents the encrypted user MAC address.
When you configure the BAS-IP attribute as the URL parameter, if you have configured the BAS-IP attribute for portal packets sent to the portal authentication server in interface view or service template view, the configured BAS-IP attribute is used as the BAS-IP attribute carried in the URL of a portal Web server. If no BAS-IP attribute is configured in interface view or service template view, the BAS-IP attribute carried in the URL of a portal Web server is the IP address of the interface connected to the portal web server.
# Configure URL parameters userip and userurl for portal Web server wbs. Configure the value of the userip parameter as source-address (the IP addresses of users) and that of the userurl parameter as http://www.abc.com/welcome.
[Sysname-portal-websvr-wbs] url-parameter userip source-address
[Sysname-portal-websvr-wbs] url-parameter userurl value http://www.abc.com/welcome
# Configure URL parameter usermac for portal Web server wbs. Configure the value of the usermac parameter as source-mac (the MAC addresses of users) and specify DES to encrypt the MAC addresses.
[Sysname-portal-websvr-wbs] url-parameter usermac source-mac encryption des key simple 12345678
# Configure URL parameter uservlan for portal Web server wbs. Configure the value of the uservlan parameter as vlan (the VLAN IDs of users.)
[Sysname-portal-websvr-wbs] url-parameter uservlan vlan
# Configure URL parameter interfacebas-ip for portal Web server wbs. The value of the interfacebas-ip parameter is the BAS-IP attribute of portal packets.
[Sysname-portal-websvr-wbs] url-parameter interfacebas-ip bas-ip
url
user-agent
Use user-agent to configure the User-Agent match string.
Use undo user-agent to restore the default.
user-agent user-agent-string
undo user-agent
The User-Agent match string is MicroMessenger.
user-agent-string: Specifies the User-Agent match string, a case-sensitive string of 1 to 255 characters.
# Configure the User-Agent match string as text.
[Sysname-portal-local-websvr-http] user-agent text
user-password modify enable
Use user-password modify enable to enable local portal user password modification.
Use undo user-password modify enable to disable local portal user password modification.
Local portal user password modification is disabled.
This feature enables the local portal Web service to display the password modification button on the portal authentication page. Local portal users can change their passwords through this button.
If global password control is enabled by using the password-control enable network-class command, the new password of a local portal user must meet the password control requirements. For more information about password control, see password control configuraiton in Security Configuration Guide.
# In local portal Web service view, enable local portal user password modification.
[Sysname-portal-local-websvr-http] user-password modify enable
user-sync
Use user-sync to enable portal user synchronization for a portal authentication server.
Use undo user-sync to disable portal user synchronization for a portal authentication server.
user-sync timeout timeout
undo user-sync
Portal user synchronization is disabled for a portal authentication server.
timeout timeout: Specifies a detection timeout for synchronization packets, in the range of 60 to 18000 seconds.
This feature enables the device to reply to and periodically detect the synchronization packets from the portal authentication server. In this way, information about online portal users on the device and on the portal authentication server remains consistent.
·     For information of the users considered as nonexistent on the portal authentication server, the device deletes the information after the configured detection timeout expires.
·     If the user information from the portal authentication server does not exist on the device, the device encapsulates IP addresses of the users in user heartbeat reply packets to the server. The portal authentication server then deletes the users.
Portal user synchronization requires that the portal authentication server support the portal user heartbeat feature. Now, only the IMC portal authentication server supports portal user heartbeat. To implement portal user synchronization, you need to configure the user heartbeat feature on the portal authentication server. Make sure the user heartbeat interval configured on the portal authentication server is not greater than the synchronization detection timeout configured on the access device.
Deleting a portal authentication server on the device also deletes the user synchronization configuration for the server.
# Enable portal user synchronization for the portal authentication server pts and set the detection timeout to 600 seconds. If a use has not appeared in the synchronization packets sent by the portal authentication server for 600 seconds, the access device logs out the user.
[Sysname] portal server pts
[Sysname-portal-server-pts] user-sync timeout 600
portal server
user-traffic deny
user-traffic deny to enable the portal roaming center to deny user traffic.
undo user-traffic deny to disable the portal roaming center from denying user traffic.
user-traffic deny
The portal roaming center is disabled from denying user traffic.
This configuration determines whether a portal user can access the network resources when the portal roaming center is querying the user entry of the user.
·     If the portal roaming center is enabled to deny user traffic, the user cannot access the network resources.
·     If the portal roaming center is disabled from denying user traffic, the user can access the network resources.
After the portal roaming center finishes the user query, it denies or permits the user traffic according to the query result.
A user might access a network deployed with inter-AC roaming and other networks deployed with portal authentication at the same time. To prevent the traffic of the user from triggering portal authentication in networks other than the inter-AC roaming network, enable the portal roaming center to deny user traffic.
Typically, you need to enable the portal roaming center only on the roaming destination ACs to deny user traffic.
# Enable the portal roaming center to deny user traffic.
[Sysname] portal roaming-center
[Sysname–-portal-roaming-center] user-traffic deny
version
Use version to specify the version of the portal protocol.
Use undo version to restore the default.
version version-number
undo version
The version of the portal protocol is 1.
version-number: Specifies the portal protocol version in the range of 1 to 3.
The specified portal protocol version must be the that required by the MAC binding server.
# Configure the device to use portal protocol version 2 to communicate with the MAC binding server mts.
[Sysname-portal-mac-trigger-server-mts] version 2
display portal mac-trigger-server
vpn-instance
Use vpn-instance to specify the MPLS L3VPN where a portal Web server resides.
Use undo vpn-instance to restore the default.
undo vpn-instance
A portal Web server is on the public network.
vpn-instance-name: Specifies the name of the MPLS L3VPN where the portal Web server resides, a case-sensitive string of 1 to 31 characters.
A portal Web server belongs to only one MPLS L3VPN.
# Configure the MPLS L3VPN for the portal Web server wbs as abc.
[Sysname-portal-websvr-wbs] vpn-instance abc
web-redirect track
Use web-redirect track to enable Web redirect track to monitor the interface status or signal information.
Use undo web-redirect track to disable Web redirect track.
web-redirect track interface interface-type interface-number
Web redirect track is disabled.
Interface view
This feature pushes a destination-unreachable notification webpage to users who attempt to access the Internet when it detects the tracked interface is down or receives 2G signal or no signal.
In the current software version, this feature can track signal information only for Etherchannel interfaces.
This feature applies only to IPv4 users.
This feature requires that the webpage to which the redirect URL points must be configured on the device. The redirect URL is specified by the web-redirect url command.
# Enable Web redirect track on GigabitEthernet 1/0/1 to track network signal information on Etherchannel 0.
[Sysname-GigabitEthernet1/0/1] web-redirect track interface eth-channel 0
display web-redirect rule
web-redirect url
web-redirect url
Use web-redirect url to enable the Web redirect feature.
Use undo web-redirect url to disable the Web redirect feature.
web-redirect [ ipv6 ] url url-string [ interval interval ]
undo web-redirect [ ipv6 ]
The Web redirect feature is disabled.
Interface view
Service template view
ipv6: Specifies the IPv6 Web redirect feature. Do not specify this keyword for the IPv4 Web redirect feature.
url url-string: Specifies the URL to which the user is redirected, a string of 1 to 256 characters. The URL must exist and must be a complete URL beginning with http:// or https://. The URL string can include question marks (?). If you enter a question mark (?) in the place of the url-string argument, the CLI does not display help information for this argument.
interval interval: Specifies the time interval at which the user is redirected to the specified URL. It is in the range of 60 to 86400 seconds. The default interval is 86400 seconds.
This feature redirects a user on an interface or a service template to the specified URL before the user can access an external network through a Web browser. After the specified interval, the user is redirected to the specified URL again.
The Web redirect feature takes effect only on HTTP packets that use the default port number 80.
Both Web redirect and portal authentication can be enabled at the same time on supported interfaces.
Do not enable both Web redirect and portal authentication on a service template. If you do so, portal authentication will not take effect.
To use the device URL as the Web redirect URL or allow users to successfully access the device URL, you must enable the HTTP service. To enable the HTTP service, use the ip http enable command.
To push different advertisement pages to different users, you can carry parameters in the redirect URL (by using the url url-string option) as needed. The following parameters are available:
·     userip=%c—IP address of the user.
·     usermac=%m—MAC address of the user.
·     nasid=%n—NAS identifier of the device.
·     ssid=%E—SSID with which the user associates.
·     originalurl=%o—Original URL that the user enters in the browser.
Make sure the arrangement of the parameters conforms to the format of http://XXXX/index.html?userip=%c&usermac=%m&nasid=%n&ssid=%E&originalurl=%o.
# Configure IPv4 Web redirect on GigabitEthernet 1/0/1. Set the redirect URL to http://192.0.0.1 /index.html?userip=%c&usermac=%m&nasid=%n&ssid=%E&originalurl=%o and the interval to 3600 seconds.
[Sysname-GigabitEthernet1/0/1] web-redirect url http://192.0.0.1 /index.html?userip=%c&usermac=%m&nasid=%n&ssid=%E&originalurl=%o interval 3600
# Configure IPv4 Web redirect on service template service1. Set the redirect URL to http://192.0.0.1 /index.html?userip=%c&usermac=%m&nasid=%n&ssid=%E&originalurl=%o and the interval to 3600 seconds.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] web-redirect url http://192.0.0.1/index.html?userip=%c&usermac=%m&nasid=%n&ssid=%E&originalurl=%o interval 3600
  • Become a Partner
  • Partner Resources
