12-Security Command References
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers @CR@(V7)-R6749-6W10012-Security Command References
27-ARP attack protection commands
27-ARP attack protection commands 127.60 KB
Unresolvable IP attack protection commands
arp resolving-route enable
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable ARP blackhole routing.
The ARP blackhole routing feature is enabled.
Configure this command on the gateways.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
Use arp resolving-route probe-count to set the number of ARP blackhole route probes for each unresolved IP address.
Use undo arp resolving-route probe-count to restore the default.
arp resolving-route probe-count count
The device performs three ARP blackhole route probes for each unresolved IP address.
count: Sets the number of probes, in the range of 1 to 25.
# Configure the device to perform five ARP blackhole route probes for each unresolved IP address.
[Sysname] arp resolving-route probe-count 5
Use arp resolving-route probe-interval to set the interval at which the device probes ARP blackhole routes.
Use undo arp resolving-route probe-interval to restore the default.
arp resolving-route probe-interval interval
The device probes ARP blackhole routes every 1 second.
interval: Specifies the probe interval in the range of 1 to 5 seconds.
# Configure the device to probe ARP blackhole routes every 3 seconds.
[Sysname] arp resolving-route probe-interval 3
arp source-suppression enable
Use arp source-suppression enable to enable the ARP source suppression feature.
Use undo arp source-suppression enable to disable the ARP source suppression feature.
The ARP source suppression feature is disabled.
Configure this feature on the gateways.
# Enable the ARP source suppression feature.
[Sysname] arp source-suppression enable
display arp source-suppression
arp source-suppression limit
Use arp source-suppression limit to set the maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
Use undo arp source-suppression limit to restore the default.
The device can process a maximum of 10 unresolvable packets per source IP address within 5 seconds.
limit-value: Specifies the limit in the range of 2 to 1024.
If unresolvable packets received from an IP address within 5 seconds exceed the limit, the device stops processing the packets from that IP address until the 5 seconds elapse.
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Sysname] arp source-suppression limit 100
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
Maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
Source MAC-based ARP attack detection commands
arp source-mac
Use arp source-mac to enable the source MAC-based ARP attack detection feature and specify a handling method.
Use undo arp source-mac to disable the source MAC-based ARP attack detection feature.
arp source-mac { filter | monitor }
undo arp source-mac [ filter | monitor ]
The source MAC-based ARP attack detection feature is disabled.
filter: Specifies the filter handling method.
monitor: Specifies the monitor handling method.
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within 5 seconds exceeds a threshold, the device generates an ARP attack entry for the MAC address. Before the entry ages out, the device handles the attack by using either of the following methods:
·     Monitor—Only generates log messages.
·     Filter—Generates log messages and filters out subsequent ARP packets from the MAC address.
Make sure you have enabled the ARP logging feature before enabling the source MAC-based ARP attack detection feature. For information about the ARP logging feature, see ARP configuration in Layer 3—IP Services Configuration Guide.
If you do not specify any handling method in the undo arp source-mac command, the command disables this feature.
# Enable the source MAC-based ARP attack detection feature and specify the filter handling method.
[Sysname] arp source-mac filter
arp source-mac aging-time
Use arp source-mac aging-time to set the aging time for ARP attack entries.
Use undo arp source-mac aging-time to restore the default.
arp source-mac aging-time time
The aging time for ARP attack entries is 300 seconds.
time: Sets the aging time for ARP attack entries, in the range of 60 to 6000 seconds.
# Set the aging time for ARP attack entries to 60 seconds.
[Sysname] arp source-mac aging-time 60
arp source-mac exclude-mac
Use arp source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ARP attack detection.
Use undo arp source-mac exclude-mac to remove the excluded MAC addresses from source MAC-based ARP attack detection.
arp source-mac exclude-mac mac-address&<1-n>
undo arp source-mac exclude-mac [ mac-address&<1-n> ]
No MAC addresses are excluded from source MAC-based ARP attack detection.
mac-address&<1-n>: Specifies a MAC address list. The mac-address argument indicates an excluded MAC address in the format of H-H-H. &<1-n> indicates the number of excluded MAC addresses that you can configure. The value for n is 10.
If you do not specify a MAC address, the undo arp source-mac exclude-mac command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ARP attack detection.
[Sysname] arp source-mac exclude-mac 001e-1200-0213
arp source-mac threshold
Use arp source-mac threshold to set the threshold for source MAC-based ARP attack detection. If the number of ARP packets sent from a MAC address within 5 seconds exceeds this threshold, the device recognizes this as an attack.
Use undo arp source-mac threshold to restore the default.
arp source-mac threshold threshold-value
The threshold for source MAC-based ARP attack detection is 30.
threshold-value: Specifies the threshold for source MAC-based ARP attack detection. The value range for this argument is 1 to 5000.
# Set the threshold for source MAC-based ARP attack detection to 30.
[Sysname] arp source-mac threshold 30
display arp source-mac
Use display arp source-mac to display ARP attack entries detected by source MAC-based ARP attack detection.
In standalone mode:
display arp source-mac [ interface interface-type interface-number ]
In IRF mode:
display arp source-mac { interface interface-type interface-number | slot slot-number }
slot slot-number: Specifies an IRF member device by its ID. If you do not specify a member device, this command displays ARP attack entries for the master device. (In IRF mode.)
# Display the ARP attack entries detected by source MAC-based ARP attack detection on GigabitEthernet 1/0/1.
<Sysname> display arp source-mac interface gigabitethernet 1/0/1
Source-MAC          VLAN ID  Interface                Aging-time
23f3-1122-3344      4094     GE1/0/1                  10
Source-MAC
Source MAC address of the attack.
VLAN ID
ID of the VLAN in which the attack was detected.
Interface on which the attack was detected.
Aging-time
Aging time for the ARP attack entry, in seconds.
ARP packet source MAC consistency check commands
arp valid-check enable
Use arp valid-check enable to enable ARP packet source MAC address consistency check.
Use undo arp valid-check enable to disable ARP packet source MAC address consistency check.
ARP packet source MAC address consistency check is disabled.
Configure this feature on gateways. The gateways can filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp valid-check enable
ARP active acknowledgement commands
arp active-ack enable
Use arp active-ack enable to enable ARP active acknowledgement.
Use undo arp active-ack enable to disable ARP active acknowledgement.
arp active-ack [ strict ] enable
undo arp active-ack [ strict ] enable
ARP active acknowledgement is disabled.
strict: Enables strict mode for ARP active acknowledgement.
Configure this feature on gateways to prevent user spoofing.
# Enable ARP active acknowledgement.
[Sysname] arp active-ack enable
Authorized ARP commands
arp authorized enable
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to disable authorized ARP on an interface.
Authorized ARP is disabled on the interface.
VLAN interface view
# Enable authorized ARP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] arp authorized enable
The following matrix shows the compatibility of hardware and ARP attack detection commands:
Hardware
Remarks
·     Fixed Layer 2 Ethernet ports on the following routers:
¡     MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
¡     MSR2600-10-X1
¡     MSR 2630
¡     MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
¡     MSR3610-G, MSR3620-G
¡     MSR3640-X1-HI
¡     MSR3600-28, MSR3600-51
¡     MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP
¡     MSR3600-28-G-DP, MSR3600-51-G-DP
¡     MSR2600-6-WiNet
¡     MSR2600-10-X1-WiNet
¡     MSR2630-WiNet
¡     MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
¡     MSR3600-28-WiNet
¡     MSR2630-XS
¡     MSR3600-28-XS
¡     MSR3660-XS
¡     MSR2600-6-X1-GL
·     The following Layer 2 interface modules installed on routers:
¡     HMIM-24GSW
¡     HMIM-24GSW-PoE
¡     HMIM-8GSW
¡     HMIM-8GSWF
¡     SIC-4GSW
For information about the support of the routers for Layer 2 interface modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
arp detection enable
Use arp detection enable to enable ARP attack detection.
Use undo arp detection enable to disable ARP attack detection.
ARP attack detection is disabled.
VLAN view
# Enable ARP attack detection for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
arp detection rule
arp detection rule
Use arp detection rule to configure a user validity check rule.
Use undo arp detection rule to delete a user validity check rule.
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id ]
undo arp detection rule [ rule-id ]
No user validity check rule is configured.
rule-id: Assigns an ID to the user validity check rule. The ID value range is 0 to 511. A smaller value represents a higher priority.
deny: Denies matching ARP packets.
permit: Permits matching ARP packets.
ip { ip-address [ mask ] | any }: Specifies the sender IP address as the match criterion.
·     ip-address: Specifies an IP address in dotted decimal notation.
·     mask: Specifies the address mask in dotted decimal notation. If you do not specify the mask, the ip-address argument specifies a host IP address.
·     any: Matches any IP address.
mac { mac-address [ mask ] | any }: Specifies the sender MAC address as the match criterion.
·     mac-address: Specifies a MAC address in the H-H-H format.
·     mask: Specifies the MAC address mask in the H-H-H format. If you do not specify the mask, the argument specifies the host MAC address.
·     any: Matches any MAC address.
vlan vlan-id: Specifies the ID of a VLAN in the specified rule. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, the packets' VLAN information is not checked.
A user validity check rule takes effect only when ARP attack detection is enabled.
If you do not specify a rule ID, the undo arp detection rule command deletes all user validity check rules.
# Configure a user validity check rule and enable ARP detection for VLAN 2.
[Sysname] arp detection rule 0 permit ip 10.1.1.1 255.255.0.0 mac 0001-0203-0405 ffff-ffff-0000
[Sysname] vlan 2
arp detection trust
Use arp detection trust to configure an interface as an ARP trusted interface.
Use undo arp detection trust to restore the default.
arp detection trust
An interface is an ARP untrusted interface.
# Configure GigabitEthernet 1/0/1 as an ARP trusted interface.
[Sysname-GigabitEthernet1/0/1] arp detection trust
arp detection validate
Use arp detection validate to enable ARP packet validity check.
Use undo arp detection validate to disable ARP packet validity check.
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP packet validity check is disabled.
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
src-mac: Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
You can specify more than one object to be checked in one command line.
If no keyword is specified, the undo arp detection validate command disables ARP packet validity check for all objects.
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac ip src-mac
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
ARP restricted forwarding is disabled.
VLAN view
# Enable ARP restricted forwarding in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp restricted-forwarding enable
display arp detection
Use display arp detection to display the VLANs that are enabled with ARP attack detection.
# Display the VLANs that are enabled with ARP attack detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1-2, 4-5
display arp detection statistics
Use display arp detection statistics to display statistics for packets dropped by ARP attack detection.
display arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays dropped packet statistics for all interfaces.
This command displays numbers of packets discarded by user validity check and ARP packet validity check on interfaces.
# Display statistics for packets dropped by ARP attack detection.
<Sysname> display arp detection statistics
State: U-Untrusted  T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State)            IP        Src-MAC   Dst-MAC   Inspect
GE1/0/1(U)                  40        0         0         78
GE1/0/2(U)                  0         0         0         0
GE1/0/3(T)                  0         0         0         0
GE1/0/4(U)                  0         0         30        0
State of an interface:
·     U—ARP untrusted interface.
·     T—ARP trusted interface.
Interface(State)
Inbound interface of ARP packets. State specifies the port state, trusted or untrusted.
IP
Number of ARP packets discarded due to invalid sender and target IP addresses.
Src-MAC
Number of ARP packets discarded due to invalid source MAC address.
Dst-MAC
Number of ARP packets discarded due to invalid destination MAC address.
Inspect
Number of ARP packets that failed to pass user validity check.
reset arp detection statistics
Use reset arp detection statistics to clear statistics for packets dropped by ARP attack detection.
reset arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears dropped packet statistics for all interfaces.
# Clear statistics for packets dropped by ARP attack detection.
<Sysname> reset arp detection statistics
ARP scanning and fixed ARP commands
arp fixup
Use arp fixup to convert existing dynamic ARP entries to static ARP entries.
arp fixup
The ARP conversion is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
The static ARP entries converted from dynamic ARP entries have the same attributes as the manually configured static ARP entries. Due to the device's limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
The static ARP entries after conversion can include the following entries:
·     Existing dynamic and static ARP entries before conversion.
·     New dynamic ARP entries learned during the conversion.
Dynamic ARP entries that are aged out during the conversion are not converted to static ARP entries.
To delete a static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Convert existing dynamic ARP entries to static ARP entries.
[Sysname] arp fixup
arp scan
Use arp scan to trigger an ARP scanning in an address range.
arp scan [ start-ip-address to end-ip-address ]
VLAN interface view
start-ip-address: Specifies the start IP address of the scanning range.
end-ip-address: Specifies the end IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
CAUTION
CAUTION:
ARP scanning will take some time and occupy a lot of device and network resources. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
ARP scanning automatically creates ARP entries for devices in the specified address range. IP addresses already in existing ARP entries are not scanned.
If the interface's primary and secondary IP addresses are in the address range, the sender IP address in the ARP request is the address on the smallest network segment.
If no address range is specified, the device learns ARP entries for devices on the subnet where the primary IP address of the interface resides. The sender IP address in the ARP requests is the primary IP address of the interface.
The start and end IP addresses must be on the same subnet as the primary IP address or secondary IP addresses of the interface.
# Configure the device to scan neighbors on the network where the primary IP address of GigabitEthernet 1/0/1 resides.
[Sysname-GigabitEthernet1/0/1] arp scan
# Configure the device to scan neighbors in an address range.
[Sysname-GigabitEthernet1/0/1] arp scan 1.1.1.1 to 1.1.1.20
ARP gateway protection commands
arp filter source
Use arp filter source to enable ARP gateway protection for a gateway.
Use undo arp filter source to disable ARP gateway protection for a gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for a maximum of eight gateways on an interface.
You cannot configure both the arp filter source and arp filter binding commands on the same interface.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-Bridge-Aggregation1] arp filter source 1.1.1.1
ARP filtering commands
arp filter binding
Use arp filter binding to enable ARP filtering and configure an ARP permitted entry.
Use undo arp filter binding to remove an ARP permitted entry.
undo arp filter binding ip-address
ARP filtering is disabled.
ip-address: Specifies a permitted sender IP address.
mac-address: Specifies a permitted sender MAC address.
If the sender IP and MAC addresses of an ARP packet match an ARP permitted entry, the ARP packet is permitted. If the sender IP and MAC addresses of an ARP packet do not match an ARP permitted entry, the ARP packet is discarded.
You can configure a maximum of eight ARP permitted entries on an interface.
# Enable ARP filtering and configure an ARP permitted entry.
[Sysname-Bridge-Aggregation1] arp filter binding 1.1.1.1 0e10-0213-1023
  • Become a Partner
  • Partner Resources
