- 06-Comware 7 CLI-based configuration examples (AP standalone deployment)
- 01-WPA2-PSK Encryption Configuration Examples
- 02-Client Rate Limiting Configuration Examples
- 03-NAT Configuration Examples
- 04-PPPoE Configuration Examples
- 05-Mesh WDS Configuration Examples
- 06-Local MAC Authentication (IPv6) Configuration Examples
- 07-IPv6 Configuration Examples
- 08-Layer 2 IPv6 Multicast Configuration Examples
- 09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
- 10-Remote 802.1X Authentication Configuration Examples
- 11-Remote MAC Authentication Configuration Examples
- 12-Anchor AC Mode Local Forwarding Configuration Examples
- 13-Anchor AC Mode Dual-Link Backup Configuration Examples
- 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples
- 15-Anchor AC Mode Remote Portal Auth in Local Forwarding Configuration Examples
- 16-Anchor AC Mode Remote Portal Auth in Centralized Forwarding Configuration Examples
- 17-Anchor AC Mode Remote 802.1X Auth in Local Forwarding Configuration Examples
- 18-Anchor AC Mode Remote 802.1X Auth in Centralized Forwarding Configuration Examples
- 19-Anchor AC Mode Remote AP Configuration Examples
| 11-Remote MAC Authentication Configuration Examples | 1.23 MB |
H3C Access Points |
Comware 7 Remote MAC Authentication |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring remote MAC authentication for clients
Configuring the ClearPass server
Introduction
The following information provides an example to configure remote MAC authentication for control of access to a wireless network.
The following information applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
The following information is provided based on the assumption that you have basic knowledge of MAC authentication, WLAN authentication, and WLAN access.
As shown in Figure 1, the clients access the WLAN through the AP. The switch acts as a DHCP server to assign IPv4 addresses to the clients. Aruba ClearPass acts as the RADIUS server.
Configure the AP, the switch, and the RADIUS server to meet the following requirements:
· The AP uses the RADIUS server to perform MAC authentication for wireless clients.
· The AP uses the PSK AKM mode to secure data transmission between the client and the AP.
Procedures
Configuring the AP
1. Configure AP interfaces:
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. Clients will use this VLAN to access the WLAN.
<AP> system-view
[AP] vlan 200
[AP-vlan200] quit
[AP] interface vlan-interface 200
[AP-Vlan-interface200] ip address 40.1.1.56 24
[AP-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 (the interface connected to the switch) as a trunk, add it to VLAN 200, and set its PVID to VLAN 200.
[AP] interface gigabitethernet 1/0/1
[AP-GigabitEthernet1/0/1] port link-type trunk
[AP-GigabitEthernet1/0/1] port trunk permit vlan 200
[AP-GigabitEthernet1/0/1] port trunk pvid vlan 200
[AP-GigabitEthernet1/0/1] quit
2. Configure a static route to the RADIUS server.
[AP] ip route-static 8.1.1.0 255.255.255.0 40.1.1.1
3. Configure the username format for MAC authentication users.
# Configure MAC authentication users to use their MAC addresses as both the username and password. The MAC addresses must be in hexadecimal notation without hyphens, and letters are in lower case. (Default setting.)
[AP] mac-authentication user-name-format mac-address without-hyphen lowercase
4. Configure a RADIUS scheme:
# Create a RADIUS scheme named radius1 and enter its view.
[AP] radius scheme radius1
# Configure the primary authentication/accounting server IP as 8.1.1.171, and set the UDP ports for authentication and accounting to 1812 and 1813, respectively.
[AP-radius-radius1] primary authentication 8.1.1.171 1812
[AP-radius-radius1] primary accounting 8.1.1.171 1813
# Configure the shared key for communication with the authentication/accounting RADIUS server as 12345678.
[AP-radius-radius1] key authentication simple 12345678
[AP-radius-radius1] key accounting simple 12345678
# Exclude the domain name from the usernames sent to the RADIUS server.
[AP-radius-radius1] user-name-format without-domain
# Configure the source IP address for outgoing RADIUS packets as 40.1.1.56.
[AP-radius-radius1] nas-ip 40.1.1.56
[AP-radius-radius1] quit
5. Configure an authentication domain that uses the RADIUS scheme for authentication, authorization, and accounting:
# Create an ISP domain named dom1 and enter its view.
[AP] domain dom1
# Use RADIUS scheme radius1 for authentication, authorization, and accounting of MAC authentication users.
[AP-isp-dom1] authentication lan-access radius-scheme radius1
[AP-isp-dom1] authorization lan-access radius-scheme radius1
[AP-isp-dom1] accounting lan-access radius-scheme radius1
[AP-isp-dom1] quit
6. Configure a service template:
# Create a service template named service1.
[AP] wlan service-template service1
# Configure the SSID of the service template as service.
[AP-wlan-st-service1] ssid service
# Add clients to VLAN 200 after they come online from the service template.
[AP-wlan-st-service1] vlan 200
# Configure the AKM mode as PSK. Configure the preshared key as 12345678 in plain text.
[AP-wlan-st-service1] akm mode psk
[AP-wlan-st-service1] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and security IE to RSN.
[AP-wlan-st-service1] cipher-suite ccmp
[AP-wlan-st-service1] security-ie rsn
# Configure the user access authentication mode as MAC authentication.
[AP-wlan-st-service1] client-security authentication-mode mac
# Use ISP domain dom1 as the authentication domain for MAC authentication users.
[AP-wlan-st-service1] mac-authentication domain dom1
# Enable the service template.
[AP-wlan-st-service1] service-template enable
[AP-wlan-st-service1] quit
7. Bind the service template to interface WLAN-Radio 1/0/1.
[AP] interface WLAN-Radio 1/0/1
[AP-WLAN-Radio1/0/1] undo shutdown
[AP-WLAN-Radio1/0/1] service-template service1
[AP-WLAN-Radio1/0/1] quit
Configuring the switch
1. Configure switch interfaces:
<Switch> system-view
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 40.1.1.1 24
[Switch-Vlan-interface200] quit
# Create VLAN 2, which is used to connect to the RADIUS server.
[Switch] vlan 2
[Switch-vlan2] quit
# Add GigabitEthernet 1/0/2 (the interface connected to the RADIUS server) to VLAN 2.
[Switch-GigabitEthernet1/0/2] port access vlan 2
# Create VLAN-interface 2 and assign it an IP address.
[Switch-Vlan-interface2] ip address 8.1.1.172 255.255.255.0
[Switch-Vlan-interface2] quit
# Configure GigabitEthernet 1/0/1 (the interface connected to the AP) as a trunk, add it to VLAN 200, and set its PVID to VLAN 200.
[Switch] interface GigabitEthernet 1/0/1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 200
2. Configure the DHCP service:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan200 to assign IP addresses to clients. In this pool, specify the subnet for dynamic allocation as 40.1.1.0/24, the gateway address as 40.1.1.1, the DNS server address as the gateway address (specify the actual DNS server address in your network), and forbidden IP address as 40.1.1.56.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 40.1.1.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan200] gateway-list 40.1.1.1
[Switch-dhcp-pool-vlan200] dns-list 40.1.1.1
[Switch-dhcp-pool-vlan200] forbidden-ip 40.1.1.56
[Switch-dhcp-pool-vlan200] quit
3. Configure the interface connected to the external network and the default route. (Details not shown.)
1. Log in to ClearPass:
# Enter the management IP address of the ClearPass server in the address bar of the Web browser to access the server Web interface. In this example, the management IP address is 8.1.1.171.
Figure 2 Logging in to ClearPass
# Click ClearPass Policy Manager. Enter username admin and password 123456, and then click Log In.
Figure 3 Logging in to ClearPass Policy Manager
2. Add the AP to ClearPass Policy Manager:
# From the left navigation pane, select Configuration > Network > Devices. On the page that opens, click Add in the upper right corner.
a. Specify IP address 40.1.1.56/24 on the AP.
Make sure the ClearPass server can reach this IP address.
b. Configure the RADIUS shared secret.
Make sure the shared secret specified here is the same as the shared key specified for the RADIUS server on the AP. In this example, the shared secret is 12345678.
c. Select vendor name H3C.
d. Click Add.
Figure 4 Adding a device
3. Add a user:
# From the left navigation pane, select Configuration > Identity > Local Users. On the page that opens, click Add in the upper right corner.
a. Set the user ID, name, and password to the MAC address of the client.
Make sure the MAC address format is the same as that on the AP.
In this example, the MAC address is in hexadecimal notation without hyphens and with letters in lower case.
b. Select predefined role Employee or a user-defined role. In this example, predefined role Employee is selected.
c. Click Add.
Figure 5 Adding a user
4. Add a service:
# From the left navigation pane, select Configuration > Services. On the page that opens, click Add in the upper right corner.
Figure 6 Services
# On the Service tab, select MAC Authentication from the Type list, and configure the name as MAC ACCESS.
Figure 7 Adding a service
# Click the Authentication tab. Select the Allow ALL MAC AUTH authentication method, and use the default setting for authentication sources.
Figure 8 Configuring authentication
# Use the default settings on the Roles and Enforcement tabs, and then click Save.
# On the Configuration > Services page, click Reorder to move the service named MAC ACCESS to the first.
Figure 9 Reordering services
# Connect the SSID service from the client and enter PSK key 12345678 to connect to the WLAN and perform MAC authentication.
# On the AP, verify that the client has come online in VLAN 200.
[AP] display wlan client
Total number of clients: 1
MAC address User name R IP address VLAN
fcdb-b3d4-d88c fcdbb3d4d88c 1 40.1.1.2 200
Configuration files
· AP:
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$m5CIzvY9/4O+wAggGDjUy11hsa/tSXsyhU6A
cipher-suite ccmp
security-ie rsn
interface Vlan-interface200
ip address 40.1.1.56 255.255.255.0
port trunk permit vlan 1 200
interface WLAN-Radio1/0/1
ip route-static 8.1.1.0 24 40.1.1.1
key authentication cipher $c$3$xjh3c8fY+G24S8ncMFgLAt7nWqTjMrzBtN7P
key accounting cipher $c$3$lAOpJkHtBfyb+SiV2eVCWirmjxOZYKvo/YtT
nas-ip 40.1.1.56
domain dom1
· Switch:
dhcp enable
vlan 2
vlan 200
dns-list 40.1.1.1
ip address 40.1.1.1 255.255.255.0
port link-mode bridge
port access vlan 2
Related documentation
· Network Connectivity Configuration Guide in H3C Access Points Configuration Guides
· Network Connectivity Command Reference in H3C Access Points Command References
· User Access and Authentication Configuration Guide in H3C Access Points Configuration Guides
· User Access and Authentication Command Reference in H3C Access Points Command References
· WLAN Access Configuration Guide in H3C Access Points Configuration Guides
· WLAN Access Command Reference in H3C Access Points Command References
