- 06-Comware 7 CLI-based configuration examples (AP standalone deployment)
- 01-WPA2-PSK Encryption Configuration Examples
- 02-Client Rate Limiting Configuration Examples
- 03-NAT Configuration Examples
- 04-PPPoE Configuration Examples
- 05-Mesh WDS Configuration Examples
- 06-Local MAC Authentication (IPv6) Configuration Examples
- 07-IPv6 Configuration Examples
- 08-Layer 2 IPv6 Multicast Configuration Examples
- 09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
- 10-Remote 802.1X Authentication Configuration Examples
- 11-Remote MAC Authentication Configuration Examples
- 12-Anchor AC Mode Local Forwarding Configuration Examples
- 13-Anchor AC Mode Dual-Link Backup Configuration Examples
- 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples
- 15-Anchor AC Mode Remote Portal Auth in Local Forwarding Configuration Examples
- 16-Anchor AC Mode Remote Portal Auth in Centralized Forwarding Configuration Examples
- 17-Anchor AC Mode Remote 802.1X Auth in Local Forwarding Configuration Examples
- 18-Anchor AC Mode Remote 802.1X Auth in Centralized Forwarding Configuration Examples
- 19-Anchor AC Mode Remote AP Configuration Examples
| 05-Mesh WDS Configuration Examples | 130.75 KB |
H3C Access Points |
Comware 7 Mesh WDS |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Mesh WDS configuration examples
Example: Configuring point-to-point WDS of fat APs
Example: Configuring point-to-point WDS of both fat and fit APs
Introduction
The following information provides examples for configuring mesh WDS.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of WLAN mesh.
As shown in Figure 1, deploy a point-to-point WDS of two fat APs to provide Layer 2 wireless connectivity between two LANs. Configure the APs to use 802.11ax to establish a WDS link on channel 149.
NOTE: Support for the 802.11ax mode depends on the device model. |
Procedures
Configuring AP 1
1. Configure AP interfaces:
# Create VLAN-interface 1, and assign an IP address to the VLAN interface.
[AP1] interface vlan-interface 1
[AP1-Vlan-interface1] ip address 192.168.0.1 24
[AP1-Vlan-interface1] quit
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. Hosts in LAN 1 will communicate with hosts in LAN 2 through this interface.
[AP1] vlan 100
[AP1-vlan100] quit
[AP1] interface vlan-interface 100
[AP1-Vlan-interface100] ip address 192.168.1.1 24
[AP1-Vlan-interface100] quit
# Assign GigabitEthernet 1/0/1 to VLAN 2.
[AP1] vlan 100
[AP1-vlan100] port GigabitEthernet 1/0/1
[AP1-vlan100] quit
2. Configure a mesh profile:
# Create mesh profile 1.
[AP1] wlan mesh-profile 1
# Assign mesh ID 1 to the mesh profile.
[AP1-wlan-mesh-profile-1] mesh-id 1
# Set the AKM mode to SAE.
[AP1-wlan-mesh-profile-1] akm mode sae
# Configure simple character string 12345678 as the PSK.
[AP1-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
# Enable the mesh profile.
[AP1-wlan-mesh-profile-1] mesh-profile enable
[AP1-wlan-mesh-profile-1] quit
3. Configure the radio interface:
# Bind mesh profile 1 to interface WLAN-Radio 1/0/1.
[AP1] interface wlan-radio 1/0/1
[AP1-WLAN-Radio1/0/1] mesh-profile 1
# Specify the radio mode as 802.11ax.
[AP1-WLAN-Radio1/0/1] type dot11ax
# Specify channel 149 as the working channel.
[AP1-WLAN-Radio1/0/1] channel 149
# Add the MAC address of AP 2 to the mesh peer whitelist. This enables AP 1 to establish a mesh link only with AP 2 to avoid loops.
[AP1-WLAN-Radio1/0/1] mesh peer-mac-address d461-fe59-4d20
# Enable the radio interface.
[AP1-WLAN-Radio1/0/1] undo shutdown
[AP1-WLAN-Radio1/0/1] quit
4. Configure a static route.
[AP1] ip route-static 192.168.2.0 255.255.255.0 192.168.0.2
Configuring AP 2
<AP2> system-view
[AP2] interface vlan-interface 1
[AP2-Vlan-interface1] ip address 192.168.0.2 24
[AP2-Vlan-interface1] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. Hosts in LAN 2 will communicate with hosts in LAN 1 through this interface.
[AP2] vlan 200
[AP2-vlan200] quit
[AP2] interface vlan-interface 200
[AP2-Vlan-interface200] ip address 192.168.2.1 24
[AP2-Vlan-interface200] quit
# Assign GigabitEthernet 1/0/1 to VLAN 200.
[AP2] vlan 200
[AP2-vlan200] port GigabitEthernet 1/0/1
[AP2-vlan200] quit
[AP2] wlan mesh-profile 1
[AP2-wlan-mesh-profile-1] mesh-id 1
[AP2-wlan-mesh-profile-1] akm mode sae
[AP2-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
[AP2-wlan-mesh-profile-1] mesh-profile enable
[AP2-wlan-mesh-profile-1] quit
[AP2] interface wlan-radio 1/0/1
[AP2-WLAN-Radio1/0/1] mesh-profile 1
[AP2-WLAN-Radio1/0/1] type dot11ax
[AP2-WLAN-Radio1/0/1] channel 149
# Add the MAC address of AP 1 to the mesh peer whitelist. This enables AP 2 to establish a mesh link only with AP 1 to avoid loops.
[AP2-WLAN-Radio1/0/1] mesh peer-mac-address 84d9-316b-93a0
[AP2-WLAN-Radio1/0/1] undo shutdown
[AP2-WLAN-Radio1/0/1] quit
[AP2] ip route-static 192.168.1.0 255.255.255.0 192.168.0.1
# Verify that you can view information about the mesh link on AP 1.
<AP1> display wlan mesh-link
Peer MAC RSSI BSSID Interface Link state Online time
d461-fe59-4d20 87 84d9-316b-93a0 WLAN-MeshLink51 Active 00h 00m 12s
# Verify that you can view information about the mesh link on AP 2.
<AP2> display wlan mesh-link
84d9-316b-93a0 84 d461-fe59-4d20 WLAN-MeshLink259 Active 00h 06m 31s
# Verify that hosts in LAN 1 and hosts in LAN 2 can ping each other successfully.
Configuration files
· AP 1:
sysname AP1
wlan mesh-profile 1
mesh-id 1
akm mode sae
preshared-key pass-phrase cipher $c$3$vn2DU2ACd3o9CbivCPPh9issxj6Rmja5gMQA
mesh-profile enable
vlan 1
vlan 100
interface Vlan-interface1
ip address 192.168.0.1 255.255.255.0
interface Vlan-interface100
port access vlan 100
interface WLAN-Radio1/0/1
mesh-profile 1
type dot11ax
channel 149
ip route-static 192.168.2.0 24 192.168.0.2
return
· AP 2:
sysname AP2
wlan mesh-profile 1
mesh-id 1
akm mode sae
mesh-profile enable
vlan 1
vlan 200
ip address 192.168.0.2 255.255.255.0
interface Vlan-interface200
ip address 192.168.2.1 255.255.255.0
port access vlan 200
mesh-profile 1
type dot11ax
channel 149
ip route-static 192.168.1.0 24 192.168.0.1
return
As shown in Figure 2, the MPP connects to the AC through a switch, and a server is attached to the switch. Deploy a point-to-point WDS of a fat AP and a fit AP to provide Layer 2 wireless connectivity between two LANs. Configure the APs to use 802.11ax to establish a WDS link on channel 149.
Procedures
Configuring the AC
1. Configure the DHCP service:
# Enable DHCP.
<AC> system-view
[AC] dhcp enable
# Create DHCP address pool 1, specify subnet 192.168.0.0/24, and specify gateway address 192.168.0.1. The AC will use this address pool to assign IP addresses to the fit AP and the server.
[AC] dhcp server ip-pool 1
[AC-dhcp-pool-1] network 192.168.0.0 mask 255.255.255.0
[AC-dhcp-pool-1] gateway-list 192.168.0.1
[AC-dhcp-pool-1] quit
2. Create VLAN-interface 1, and assign an IP address to the VLAN interface.
[AC] interface vlan-interface 1
[AC-Vlan-interface1] ip address 192.168.0.1 255.255.255.0
[AC-Vlan-interface1] quit
3. Configure a mesh profile:
<AC> system-view
[AC] wlan mesh-profile 1
[AC-wlan-mesh-profile-1] mesh-id 1
[AC-wlan-mesh-profile-1] akm mode sae
[AC-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
[AC-wlan-mesh-profile-1] mesh-profile enable
[AC-wlan-mesh-profile-1] quit
4. Configure the MPP:
# Create AP mpp, and specify the AP model and serial ID.
[AC] wlan ap mpp model WA6620
[AC-wlan-ap-mpp] serial-id 219801A2BQ8207E0000S
# Bind mesh profile 1 to radio 1.
[AC-wlan-ap-mpp] radio 1
[AC-wlan-ap-mpp-radio-1] mesh-profile 1
# Set the radio mode to 802.11ax.
[AC-wlan-ap-mpp-radio-1] type dot11ax
[AC-wlan-ap-mpp-radio-1] channel 149
# Enable the radio.
[AC-wlan-ap-mpp-radio-1] radio enable
[AC-wlan-ap-mpp-radio-1] quit
# Disable an MPP from sending probe requests.
[AC-wlan-ap-mpp] portal-service enable
[AC-wlan-ap-mpp] quit
5. Configure a static route.
[AC]ip route-static 192.168.1.0 255.255.255.0 192.168.0.2
Configuring the fat AP
1. Configure a mesh profile:
<MAP> system-view
[MAP] wlan mesh-profile 1
[MAP1-wlan-mesh-profile-1] mesh-id 1
[MAP-wlan-mesh-profile-1] akm mode sae
[MAP-wlan-mesh-profile-1] preshared-key pass-phrase simple 12345678
[MAP-wlan-mesh-profile-1] mesh-profile enable
[MAP-wlan-mesh-profile-1] quit
2. Create service template service1, set the SSID to mesh-network, and enable the service template.
[MAP] wlan service-template service1
[MAP-wlan-st-service1] ssid mesh-network
[MAP-wlan-st-service1] service-template enable
[MAP-wlan-st-service1] quit
[MAP] interface wlan-radio 1/0/1
[MAP-WLAN-Radio1/0/1] mesh-profile 1
# Bind service template service1 to interface WLAN-Radio 1/0/1.
[MAP-WLAN-Radio1/0/1] service-template service1
[MAP-WLAN-Radio1/0/1] type dot11ax
[MAP-WLAN-Radio1/0/1] channel 149
# Add the MAC address of the MPP to the mesh peer whitelist. This enables the MAP to establish a mesh link only with the MPP to avoid loops.
[MAP-WLAN-Radio1/0/1] mesh peer-mac-address ac74-090a-6420
[MAP-WLAN-Radio1/0/1] undo shutdown
[MAP-WLAN-Radio1/0/1] quit
[MAP] quit
4. Configure the DHCP service:
# Enable DHCP.
[MAP] dhcp enable
# Create a DHCP address pool named vlan100, specify subnet 192.168.1.0/24, and specify gateway address 192.168.1.1.
[MAP] dhcp server ip-pool vlan100
[MAP-dhcp-pool-vlan100] network 192.168.1.0 mask 255.255.255.0
[MAP-dhcp-pool-vlan100] gateway-list 192.168.1.1
[MAP-dhcp-pool-vlan100] quit
# Execute the display wlan mesh-link ap command on the AC to verify that the MPP and the MAP have established a mesh link.
<AC>display wlan mesh-link ap
AP name: mpp
Peer Local Status RSSI Packets(Rx/Tx)
d461-fe59-4d20 ac74-090a-6420 Forwarding 84 75/206
# Execute the display wlan mesh-link command on the MAP to verify that the MAP and the MPP have established a mesh link.
<MAP> display wlan mesh-link
ac74-090a-6420 82 d461-fe59-4d20 WLAN-MeshLink231 Active 00h 46m 53s
# Verify that the client and the server can ping each other successfully.
Configuration files
· MAP:
sysname MAP
dhcp enable
wlan mesh-profile 1
mesh-id 1
akm mode sae
preshared-key pass-phrase cipher $c$3$MA+IbbyMk2HFZPOGPZtCOu/7tC0zlT4/9HuX
mesh-profile enable
vlan 1
vlan 100
ssid mesh-network
vlan 100
interface NULL0
mesh-profile 1
type dot11ax
channel 149
return
· AC:
sysname AC
telnet server enable
dhcp enable
wlan mesh-profile 1
mesh-id 1
akm mode sae
preshared-key pass-phrase cipher $c$3$L7PLM5cfBX+LuA9AXhbmYQgz0yU1pcc0y26/
mesh-profile enable
vlan 1
ip route-static 192.168.1.0 24 192.168.0.2
radio 1
type dot11ax
channel 149
radio enable
mesh-profile 1
return
Related documentation
· WLAN Mesh Command Reference in H3C Access Points Command References
· WLAN Mesh Configuration Guide in H3C Access Points Configuration Guides
