- 06-Comware 7 CLI-based configuration examples (AP standalone deployment)
- 01-WPA2-PSK Encryption Configuration Examples
- 02-Client Rate Limiting Configuration Examples
- 03-NAT Configuration Examples
- 04-PPPoE Configuration Examples
- 05-Mesh WDS Configuration Examples
- 06-Local MAC Authentication (IPv6) Configuration Examples
- 07-IPv6 Configuration Examples
- 08-Layer 2 IPv6 Multicast Configuration Examples
- 09-Interoperation of Fat APs and Switch for WLAN Access and Roaming Configuration Examples
- 10-Remote 802.1X Authentication Configuration Examples
- 11-Remote MAC Authentication Configuration Examples
- 12-Anchor AC Mode Local Forwarding Configuration Examples
- 13-Anchor AC Mode Dual-Link Backup Configuration Examples
- 14-Anchor AC Mode Internal-to-External Access Through NAT Configuration Examples
- 15-Anchor AC Mode Remote Portal Auth in Local Forwarding Configuration Examples
- 16-Anchor AC Mode Remote Portal Auth in Centralized Forwarding Configuration Examples
- 17-Anchor AC Mode Remote 802.1X Auth in Local Forwarding Configuration Examples
- 18-Anchor AC Mode Remote 802.1X Auth in Centralized Forwarding Configuration Examples
- 19-Anchor AC Mode Remote AP Configuration Examples
| 01-WPA2-PSK Encryption Configuration Examples | 81.78 KB |
H3C Access Points |
Comware 7 WPA2-PSK Encryption |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring WPA2-PSK encryption.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of WLAN access and WLAN security.
Example: Configuring WPA2-PSK encryption
As shown in Figure 1, the clients access the WLAN provided by the AP. The AP obtains IP addresses from a DHCP server in the IP network.
· Configure the AP to act as a DHCP server to assign IP addresses to the clients.
· Configure WPA2-PSK encryption on the AP.
· Configure open-system authentication and bypass authentication.
· Set the AKM mode to PSK to protect client data transmission.
· Set the CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
Procedures
1. Configure AP interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will use this IP address to communicate with clients.
[AP] vlan 100
[AP -vlan100] quit
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 192.1.1.1 24
[AP-Vlan-interface100] quit
# Configure uplink interface VLAN-interface 1 to obtain IP addresses through DHCP.
[AP-Vlan-interface1] undo ip address
[AP-Vlan-interface1] ip address dhcp-alloc
[AP-Vlan-interface1] quit
2. Configure wireless services:
# Create service template service and enter its view.
[AP] wlan service-template service
# Configure the SSID as service.
[AP-wlan-st-service] ssid service
# Specify VLAN 100 for clients to access the WLAN defined by the service template.
[AP-wlan-st-service] vlan 100
# Set the AKM mode to PSK and configure simple character string 12345678 as the PSK.
[AP-wlan-st-service] akm mode psk
[AP-wlan-st-service] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
[AP-wlan-st-service] cipher-suite ccmp
[AP-wlan-st-service] security-ie rsn
# Enable the service template.
[AP-wlan-st-service] service-template enable
[AP-wlan-st-service] quit
3. Bind the service template to interface WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
[AP-WLAN-Radio1/0/1] service-template service
[AP-WLAN-Radio1/0/1] quit
4. Configure the DHCP service:
# Enable DHCP.
[AP] dhcp enable
# Create a DHCP address pool named vlan100, specify subnet 192.1.1.0/24, and specify gateway address 192.1.1.1.
[AP] dhcp server ip-pool vlan100
[AP-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
[AP-dhcp-pool-vlan100] gateway-list 192.1.1.1
[AP-dhcp-pool-vlan100] quit
# Verify that the clients can access the WLAN through PSK authentication.
[AP] display wlan client verbose
Total number of clients: 1
MAC address : 502b-73dc-603a
IPv4 address : 192.1.1.2
IPv6 address : N/A
Username : N/A
AID : 1
Radio ID : 1
Channel : 36
SSID : service
BSSID : 743a-2013-6ba4
VLAN ID : 100
Service VLAN ID : N/A
Sleep count : 3
Wireless mode : 802.11ac
Channel bandwidth : 80MHz
SM power save : Disabled
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160/80+80MHz : Not supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
Beamformee STS capability : N/A
Number of Sounding Dimensions : N/A
SU beamformee capability : Not supported
MU beamformee capability : Not supported
Block Ack : TID 0 Both
TID 6 Out
Supported VHT-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7
Supported rates : 6, 9, 12, 18, 24, 36,
48, 54 Mbps
QoS mode : WMM
Listen interval : 1
RSSI : 8
Rx/Tx rate : 6.5/21.7 Mbps
Speed : 0.544/0.216Kbps
Authentication method : Open system
Security mode : RSN
AKM mode : PSK
Cipher suite : CCMP
User authentication mode : Bypass
WPA3 status : Disabled
Authorization CAR : N/A
Authorization user group name : N/A
Authorization ACL ID : N/A
Authorization user profile : N/A
Roam status : N/A
Key derivation : SHA1
PMF status : N/A
Forwarding policy name : Not configured
Online time : 0days 0hours 4minutes 26seconds
FT status : Inactive
BTM mode : Inactive
Configuration files
dhcp enable
vlan 1
vlan 100
ssid service
vlan 100
akm mode psk
preshared-key pass-phrase cipher $c$3$7hZ2DNiI+h/ajPE7DhZbD6Y7py9vqf4721sp
cipher-suite ccmp
security-ie rsn
interface NULL0
interface Vlan-interface1
interface Vlan-interface100
ip address 192.1.1.1 255.255.255.0
interface WLAN-Radio1/0/1
return
Related documentation
· WLAN Access Command Reference in H3C Access Points Command References
· WLAN Access Configuration Guide in H3C Access Points Configuration Guides
· WLAN Security Command Reference in H3C Access Points Command References
· WLAN Security Configuration Guide in H3C Access Points Configuration Guides
