- 16-Security Command Reference
- 01-ACL commands
- 02-Packet filter commands
- 03-Time range commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-IKE commands
- 11-IKEv2 commands
- 12-SSH commands
- 13-SSL commands
- 14-SSL VPN commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Attack detection and prevention commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-Protocol packet rate limit commands
- 23-Object group commands
- 24-Security policy commands
| 24-Security policy commands | 216.69 KB |
description (security policy rule view)
description (security policy view)
display security-policy statistics
reset security-policy statistics
accelerate enhanced enable
Use accelerate enhanced enable to manually activate rule matching acceleration.
IPv4 security policy view
IPv6 security policy view
Rule matching acceleration enhances connection establishment and packet forwarding performance, especially for a device using multiple rules to match packets from multiple users.
Rule matching acceleration does not take effect on newly added, modified, and moved rules unless the feature is activated for the rules. By default, the system automatically activates rule matching acceleration for such rules at specific intervals. The interval is 2 seconds if 100 or fewer rules exist and 20 seconds if over 100 rules exist.
To activate rule matching acceleration immediately after a rule change, you can execute this command.
If no rule change is detected, the system does not perform an activation operation.
Insufficient memory can cause rule matching acceleration failures. Unaccelerated rules do not take effect, and rules that have been accelerated are not affected.
# Activate rule matching acceleration.
[Sysname] security-policy ip
[Sysname-security-policy-ip] accelerate enhanced enable
action
Use action to set the action for a security policy rule.
Use undo action to restore the default.
action { drop | pass }
undo action pass
The action for a security policy rule is drop.
Security policy rule view
drop: Discards matched packets.
pass: Allows matched packets to pass.
# Set the action for security policy rule rule1 to drop.
[Sysname-security-policy-ip] rule 0 name rule1
[Sysname-security-policy-ip-0-rule1] action drop
app-group
Use app-group to specify an application group as a filtering criterion of a security policy rule.
Use undo app-group to remove the specified application group filtering criterion from a security policy rule.
app-group app-group-name
undo app-group [ app-group-name ]
No application group is specified as a filtering criterion for a security policy rule.
app-group-name: Specifies the name of an application policy, a case-insensitive string of 1 to 63 characters. The name cannot be invalid or other. If you do not specify this argument when executing the undo app-group command, the command removes all application groups from the rule. For more information about application groups, see APR in DPI Configuration Guide.
You can execute the command multiple times to specify multiple application groups as the filtering criteria.
# Specify application groups app1 and app2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] app-group app1
[Sysname-security-policy-ip-0-rule1] app-group app2
app-group
application
Use application to specify an application as a filtering criterion of a security policy rule.
Use undo application to remove the specified application filtering criterion from a security policy rule.
application application-name
undo application [ application-name ]
No application is specified as a filtering criterion for a security policy rule.
application-name: Specifies the name of an application, a case-insensitive string of 1 to 63 characters. The name cannot be invalid or other. If you do not specify this argument when executing the undo application command, the command removes all applications from the rule. For more information about applications, see APR in DPI Configuration Guide.
You can execute the command multiple times to specify multiple applications as the filtering criteria.
For the application filtering criteria to be identified, you must permit the packets of the protocols on which the applications depend to pass through. If port-based packet filtering is configured and a dependent protocol uses a non-default port, you must permit the packets from the port to pass.
# Specify applications 139Mail and 51job as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] application 139Mail
[Sysname-security-policy-ip-0-rule1] application 51job
nbar application
port-mapping
counting enable
Use counting enable to enable statistics collection for matched packets.
Use undo counting enable to disable statistics collection for matched packets.
counting enable
Statistics collection for matched packets is disabled.
This feature enables the device to collect statistics about matched packets. The collected statistics can be viewed by executing the display security-policy statistics command.
# Enable matched packet statistics collection for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] counting enable
default rule action
Use default rule action to configure the action of the default security policy rule.
default rule action { drop | pass }
The action for the default security policy rule is drop.
Security policy view
# Set the action for the default security policy rule to drop.
[Sysname-security-policy-ip] default rule action drop
default rule counting enable
Use default rule counting enable to enable statistics collection for the default security policy rule.
Use undo default rule counting enable to disable statistics collection for the default security policy rule.
Statistics collection is disabled for the default security policy rule.
This feature enables the device to collect statistics about packets matching the default security policy rule. To view the collected statistics, execute the display security-policy statistics command.
# Enable matched packet statistics collection for the default security policy rule.
[Sysname-security-policy-ip] default rule counting enable
default rule logging enable
Use default rule logging enable to enable logging for the default security policy rule.
Use undo default rule logging enable to disable logging for the default security policy rule.
Logging for is disabled for the default security policy rule.
This feature enables the security policy module to generate log messages for packet matching events of the default security policy rule and send the messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output packet matching logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view packet matching logs stored on the device, use the display logbuffer command or open the security policy log page from the Web interface of the device. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see System Management Configuration Guide.
# Enable matched packet logging for the default security policy rule.
[Sysname-security-policy-ip] default rule logging enable
Use description to configure a description for a security policy rule.
No description is configured for a security policy rule.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This rule is used for source-ip ip1 for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] description This rule is used for source-ip ip1
display object-policy ip
display object-policy ipv6
Use description to configure a description for the IPv4 or IPv6 security policy.
No description is configured for the IPv4 or IPv6 security policy.
# Configure the description as zone-pair security office to library for the IPv4 security policy.
[Sysname-security-policy-ip] description zone-pair security office to library
destination-ip
Use destination-ip to specify a destination IP address object group as a filtering criterion of a security policy rule.
Use undo destination-ip to remove the specified destination IP address object group from a security policy rule.
destination-ip object-group-name
undo destination-ip [ object-group-name ]
No destination IP address object group is specified as a filtering criterion for a security policy rule.
object-group-name: Specifies the name of a destination IP address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo destination-ip command, the command removes all destination IP address object groups from the rule. For more information about object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple destination IP address object groups as the filtering criteria.
If you specify a nonexistent object group, the device automatically creates the specified object group with empty configuration. A rule that contains an object group with empty configuration does not match any packets.
# Specify destination IP address object groups client1 and client2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] destination-ip client1
[Sysname-security-policy-ip-0-rule1] destination-ip client2
object-group
disable
Use disable to disable a security policy rule.
Use undo disable to enable a security policy rule.
disable
undo disable
A security policy rule is disabled.
# Disable security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] disable
Use display security-policy to display information about the specified security policy.
display security-policy { ip | ipv6 }
ip: Specifies the IPv4 security policy.
ipv6: Specifies the IPv6 security policy.
# Display information about the IPv4 security policy.
<Sysname> display security-policy ip
Security-policy ip
rule 0 name der (Inactive)
action pass
profile er
vrf re
logging enable
counting enable
counting enable TTL 1200
time-range dere
track positive 23
session aging-time 5000
session persistent aging-time 2400
source-ip erer
service ftp
app-group ere
application 110Wang
user der
user-group ere
undo disable
Rule ID and rule name. |
action pass |
Rule action: · pass—Allows matched packets to pass. · drop—Drops matched packets. |
profile app-profile-name |
DPI application profile applied to the rule. |
vrf vrf-name |
This field is not supported in the current software version. MPLS L3VPN instance whose packets can be filtered by the rule. |
logging enable |
Indicates that logging for matched packets is enabled. |
counting enable |
Indicates that statistics collection for matched packets is enabled. |
counting enable TTL time-value |
Indicates that statistics collection for matched packets is enabled. The time-value argument represents the remaining enabling period in seconds. |
time-range time-range-name |
Time range during which the rule is in effect. |
track negative 1 (Active) |
Track entry and track entry state associated with the security policy rule. |
session aging-time time-value |
Session aging time. |
session persistent aging-time time-value |
Persistent session aging time. |
source-ip object-group-name |
Source IP address object group that acts as a filtering criterion. |
destination-ip object-group-name |
Destination IP address object group that acts as a filtering criterion. |
service object-group-name |
Service object group that acts as a filtering criterion. |
app-group app-group-name |
Application group that acts as a filtering criterion. |
application application-name |
Application that acts as a filtering criterion. |
user user-name |
User that acts as a filtering criterion. |
user-group user-group-name |
User group that acts as a filtering criterion. |
undo disable |
The rule is enabled. |
security-policy ip
security-policy ipv6
Use display security-policy statistics to display security policy statistics.
display security-policy statistics { ip | ipv6 } [ rule rule-name ]
rule rule-name: Specifies a security policy rule by its name, a case-insensitive string of 1 to 127 characters. If you do not specify this option, the command displays statistics about all security policy rules of the specified IP version.
# Display statistics about IPv4 security policy rule abc.
<Sysname> display security-policy statistics ip rule abc
rule 0 name abc
action: pass (5 packets, 1000 bytes)
rule id name rule-name |
action |
x packets, y bytes |
The rule has matched x packets, a total of y bytes. This field is displayed only if the counting enable or the logging enable command has been executed for the rule. |
group move
Use group move to move a security policy rule group to change the match order of security policy rules.
group move group-name1 { after | before } { group group-name2 | rule rule-name }
group-name1: Specifies the name of the security policy rule group to be moved, a case-insensitive string of 1 to 63 characters.
after: Moves the security policy rule group to the place after the target security policy rule group or the target security policy rule.
before: Moves the security policy rule group to the place before the target security policy rule group or the target security policy rule.
group group-name2: Specifies the name of the target security policy rule group, a case-insensitive string of 1 to 63 characters.
rule rule-name: Specifies the name of the target security policy rule, a case-insensitive string of 1 to 127 characters.
If you specify a target security policy rule that belongs to a security policy rule group, follow these restrictions and guidelines:
· If the target rule is neither the start nor end rule of the group, you cannot move a security policy rule group to the place before or after the rule.
· If the target rule is the start rule of the group, you can only move a security policy rule group to the place before the rule.
· If the target rule is the end rule of the group, you can only move a security policy rule group to the place after the rule.
# Move security policy rule group group1 to the place before security policy rule group group2.
[Sysname-security-policy-ip] group move group1 before group group2
group name
Use group name to create a security policy rule group and add security policy rules to the group, or add security policy rules to an existing security policy rule group.
Use undo group name to delete a security policy rule group.
group name group-name [ from rule-name1 to rule-name2 ] [ description description-text ] [ disable | enable ]
undo group name group-name [ description | include-member ]
No security policy rule group exists.
group-name: Specifies a security policy rule group name, a case-insensitive string of 1 to 63 characters.
from rule-name1: Specifies the start rule of a rule list. The rule-name1 argument represents the security policy rule name, a case-insensitive string of 1 to 127 characters.
to rule-name2: Specifies the end rule of the rule list. The rule-name2 argument represents the security policy rule name, a case-insensitive string of 1 to 127 characters.
description description-text: Specifies the security policy description, a case-sensitive string of 1 to 127 characters. By default, no description is specified for a security policy rule group.
disable: Disables the security policy rule group.
enable: Enables the security policy rule group. By default, a security policy rule group is enabled.
include-member: Specifies security policy rules in the security policy rule group.
Security policy rule grouping allows users to enable, disable, delete, and move security policy rules in batches.
A security policy rule in a security policy rule group takes effect only when both the rule and the group are enabled.
To add a list of security policy rules, make sure the end rule is listed behind the start rule and the specified rules do not belong to any other security policy rule group.
When you execute the undo command, follow these restrictions and guidelines:
· The undo group name group-name command deletes only the specified security policy rule group.
· The undo group name group-name description command deletes only the description for the specified security policy rule group.
· The undo group name group-name include-member command deletes both the specified security policy rule group and all the security policy rules in the group.
# Create security policy rule group group1, add security policy rules rule-name1 through rule-name10 to the group, and specify the group description as marketing.
[Sysname-security-policy-ip] group name group1 from rule-name1 to rule-name10 enable description marketing
group rename
Use group rename to rename a security policy rule group.
group rename old-name new-name
old-name: Specifies the name of a security policy rule group, a case-insensitive string of 1 to 63 characters.
new-name: Specifies a new name for the security policy rule group, a case-insensitive string of 1 to 63 characters.
# Rename security policy rule group group1 to group2.
[Sysname-security-policy-ip] group rename group1 group2
logging enable
Use logging enable to enable logging for matched packets.
Use undo logging enable to disable logging for matched packets.
logging enable
undo logging enable
Logging for matched packets is disabled.
This feature enables the security policy module to send log messages to the information center when packets match a security policy.
# Enable matched packet logging for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] logging enable
move rule
Use move rule to move a security policy rule by rule ID.
move rule rule-id before insert-rule-id
rule-id: Specifies the ID of a rule, in the range of 0 to 65534.
insert-rule-id: Specifies the ID of the target rule before which a rule is inserted. The target rule ID is in the range of 0 to 65535. If you specify 65535 as the target rule ID, the rule is moved to the end of the list.
The system does not execute the command in the following situations:
· You specify the same value for the rule-id and insert-rule-id arguments.
· You specify a nonexistent rule.
# Insert rule 5 before rule 2 for the IPv4 security policy.
[Sysname-security-policy-ip] move rule 5 before 2
rule
security-policy ip
move rule name
Use move rule name to move a security policy rule by rule name.
move rule name rule-name1 { { after | before } name rule-name2 | bottom | down | top | up }
rule-name1: Specifies the name of the rule to move, a case-insensitive string of 1 to 127 characters.
after: Move the rule to the place after the destination rule.
before: Move the rule to the place before the destination rule.
name rule-name2: Specify the name of the destination rule, a case-insensitive string of 1 to 127 characters.
bottom: Move the rule to the end of the security policy.
down: Move the rule down one place.
top: Move the rule to the beginning of the security policy.
up: Move the rule up one place.
You can move a rule to change its packet matching priority.
# Move rule rule1 to the place before rule rule2.
[Sysname-security-policy-ip] move rule name rule1 before name rule2
rule
security-policy ip
parent-group
Use parent-group to specify a security policy rule group for a security policy rule.
Use undo parent-group to restore the default.
parent-group group-name
undo parent-group
A security policy rule does not belong to any security policy rule group.
group-name: Specifies the name of a security policy rule group, a case-insensitive string of 1 to 63 characters.
# Assign security policy rule rule1 to security policy rule group group1.
[Sysname-security-policy-ip] rule 1 name rule1
[Sysname-security-policy-ip-1-rule1] parent-group group1
profile
Use profile to apply a DPI application profile to a security policy rule.
Use undo profile to remove the DPI application profile applied to a security policy rule.
undo profile
No DPI application profile is applied to a security policy rule.
app-profile-name: Specifies the name of a DPI application profile, a case-insensitive string of 1 to 63 characters. For more information about DPI application profiles, see DPI engine in DPI Configuration Guide.
This feature enables the device to perform DPI on packets matching the specified rule. For more information about DPI, see DPI Configuration Guide.
This feature takes effect only when the rule action is pass.
# Apply DPI application profile p1 to IPv4 security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] action pass
[Sysname-security-policy-ip-0-rule1] profile p1
action pass
app-profile (DPI Command Reference)
Use reset security-policy statistics to clear security policy statistics.
reset security-policy statistics [ ip | ipv6 ] [ rule rule-name ]
If you do not specify any keyword or option, the command clears all security policy statistics.
# Clear the security policy statistics about IPv4 security policy rule abc.
<Sysname> reset security-policy statistics ip rule abc
rule
Use rule to create a security policy rule and enter its view, or enter the view of an existing security policy rule.
Use undo rule to delete the specified security policy rule.
rule { rule-id | [ rule-id ] name rule-name }
undo rule { rule-id | name rule-name } *
No security policy rules exist.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify an ID for the rule, the system automatically assigns the rule the integer next to the greatest ID being used. If the greatest ID is 65534, the system assigns the rule the smallest unused number in the range.
rule-name: Specifies a globally unique rule name, a case-insensitive string of 1 to 127 characters. The name cannot be default. You must specify a rule name when creating a rule.
# Create an IPv4 security policy rule with rule ID 0 and rule name rule1.
display security-policy ipv6
security-policy
Use security-policy to enter security policy view.
Use undo security-policy to delete all configurations in security policy view.
undo security-policy { ip | ipv6 }
No configurations exist in security policy view.
# Enter IPv4 security policy view.
security-policy log real-time-sending enable
Use security-policy log real-time-sending enable to enable real-time sending for security policy log messages.
Use undo security-policy log real-time-sending enable to disable real-time sending for security policy log messages.
The buffering mode is used to generate and send security policy log messages.
The device can send security policy log messages in the following ways:
· Buffering mode—After the device generates and sends the log message for the first packet of a flow, it buffers that log message and starts a 5-second timer, which is not configurable. If other packets of the same flow match are received before the timer expires, the buffered log message is sent. Otherwise, the buffered log message is deleted. After the number of log messages reaches the limit, no log messages can be generated for subsequent flows.
· Real-time mode—The device generates and sends a log message for the first packet of a flow but does not buffer it. For packets of a flow permitted by a security policy, the device generates and sends only one log message. For packets of a flow denied by a security policy, the device generates and sends one log message for each packet.
# Enable real-time sending for security policy log messages.
<Sysname>system-view
[Sysname] security-policy log real-time-sending enable
logging enable
service
Use service to specify a service object group as a filtering criterion of a security policy rule.
Use undo service to remove the specified service object group from a security policy rule.
service { object-group-name | any }
undo service [ object-group-name | any ]
No service object group is specified as a filtering criterion for a security policy rule.
object-group-name: Specifies the name of a service object group, a case-insensitive string of 1 to 31 characters.
any: Specifies all service object groups.
You can execute the command multiple times to specify multiple service object groups as the filtering criteria.
If you specify neither an object group nor the any keyword when executing the undo service command, the command removes all service object groups from the security policy rule.
# Specify service object groups http and ftp as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] service http
[Sysname-security-policy-ip-0-rule1] service ftp
object-group
session aging-time
Use session aging-time to set the session aging time for a security policy rule.
Use undo session aging-time to restore the default.
The session aging time is not configured for a security policy rule.
time-value: Specifies the aging time in the range of 1 to 2000000 seconds.
This command sets the aging time for stable sessions created for packets matching the specified security policy rule, and takes effect only on newly created sessions.
If the aging time is not configured for a rule, the stable sessions use the aging time set by using the session aging-time application or the session aging-time state command. For more information about session management, see Security Configuration Guide.
The session aging time for unstable sessions is one hour.
# Set the session aging time to 5000 seconds for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] session aging-time 5000
session persistent acl
Use session persistent aging-time to set the aging time for persistent sessions.
Use undo session persistent aging-time to restore the default.
The persistent session aging time is not configured for a security policy rule.
time-value: Specifies the aging time in the range of 0 to 24000 hours. If you set the aging time to 0, persistent sessions do not age out.
This command is effective only on TCP sessions in ESTABLISHED state.
It sets the aging time for persistent sessions created for packets matching the specified security policy rule, and takes effect only on newly created sessions.
The aging time configured by using this command takes precedence over the aging times configured by using the session aging-time and session persistent acl commands.
# Set the persistent session aging time to one hour for security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] session persistent aging-time 1
source-ip
Use source-ip to specify a source IP address object group as a filtering criterion of a security policy rule.
Use undo source-ip to remove the specified source IP address object group from a security policy rule.
undo source-ip [ object-group-name ]
No source IP address object group is specified as a filtering criterion for a security policy rule.
object-group-name: Specifies the name of a source IP address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo source-ip command, the command removes all source IP address object groups from the rule. For more information about object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple source IP address object groups as the filtering criteria.
# Specify source IP address object groups server1 and server2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-ip server1
[Sysname-security-policy-ip-0-rule1] source-ip server2
object-group
source-mac
Use source-mac to specify a source MAC address object group as a filtering criterion of a security policy rule.
Use undo source-mac to remove the specified source MAC address object group from a security policy rule.
source-mac object-group-name
undo source-mac [ object-group-name ]
No source MAC address object group is specified as a filtering criterion for a security policy rule.
IPv4 security policy rule view
object-group-name: Specifies the name of a source MAC address object group, a case-insensitive string of 1 to 31 characters. The name cannot be any. If you do not specify this argument when executing the undo source-mac command, the command removes all source MAC address object groups from the rule. For more information about MAC address object groups, see Security Configuration Guide.
You can execute the command multiple times to specify multiple source MAC address object groups as the filtering criteria.
# Specify source MAC address object groups mac1 and mac2 as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] source-mac mac1
[Sysname-security-policy-ip-0-rule1] source-mac mac2
object-group
time-range
Use time-range to specify the time range during which a security policy rule is in effect.
Use undo time-range to restore the default.
undo time-range
A security policy rule is in effect at any time.
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. For more information about time ranges, see "Configuring time ranges."
# Enable security policy rule rule1 to be in effect during time range work.
[Sysname-security-policy-ip-0-rule1] time-range work
track
Use track to associate a security policy rule with a track entry.
Use undo track to disassociate a security policy rule from the track entry.
track { negative | positive } track-entry-number
undo track
No track entry is associated with a security policy rule.
negative: Specifies the Negative state of a track entry.
positive: Specifies the Positive state of a track entry.
track-entry-number: Specifies the number of a track entry, in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
Use this command to enable the collaboration between the track module and a security policy rule. The collaboration operates as follows:
· If a rule is associated with the Negative state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Negative state.
¡ Sets the rule state to Inactive if the track entry is in Positive state.
· If a rule is associated with the Positive state of a track entry, the device:
¡ Sets the rule state to Active if the track entry is in Positive state.
¡ Sets the rule state to Inactive if the track entry is in Negative state.
# Associate security policy rule rule1 with the Positive state of track entry 10.
[Sysname-security-policy-ip-0-rule1] track positive 10
track bfd (High Availability Command Reference)
track interface (High Availability Command Reference)
track ip route reachability (High Availability Command Reference)
track nqa (High Availability Command Reference)
user
Use user to specify a user as a filtering criterion of a security policy rule.
Use undo user to remove the specified user filtering criterion from a security policy rule.
user username [ domain domain-name ]
undo user [ username [ domain domain-name ] ]
No user is specified as a filtering criterion for a security policy rule.
username: Specifies a username, a case-sensitive string of 1 to 55 characters. The name cannot be a, al, or all and cannot contain at signs (@). If you do not specify this argument when executing the undo user command, the command removes all users from the rule. For more information about users and identity domains, see user identification in User Access and Authentication Configuration Guide.
domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The string cannot contain forward slashes (/), backslashes (\), vertical bars (|), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), or at signs (@). If you do not specify this option, the command matches the user among users that do not belong to any identity domain.
You can execute the command multiple times to specify multiple users as the filtering criteria.
# Specify users usera and userb in identity domain test as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] user usera domain test
[Sysname-security-policy-ip-0-rule1] user userb domain test
user-identity enable (User Access and Authentication Command Reference)
user-identity static-user (User Access and Authentication Command Reference)
user-group
Use user-group to specify a user group as a filtering criterion of a security policy rule.
Use undo user-group to remove the specified user group filtering criterion from a security policy rule.
user-group user-group-name [ domain domain-name ]
undo user-group [ user-group-name [ domain domain-name ] ]
No user group is specified as a filtering criterion for a security policy rule.
user-group-name: Specifies the name of a user group, a case-insensitive string of 1 to 200 characters. If you do not specify this argument when executing the undo user-group command, the command removes all user groups from the rule. For more information about user groups and identity domains, see user identification in User Access and Authentication Configuration Guide.
domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters. The string cannot contain forward slashes (/), backslashes (\), vertical bars (|), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), or at signs (@). If you do not specify this option, the command matches the user group among user groups that do not belong to any identity domain.
You can execute the command multiple times to specify multiple user groups as the filtering criteria.
# Specify user groups groupa and groupb in identity domain test as the filtering criteria of security policy rule rule1.
[Sysname-security-policy-ip-0-rule1] user-group groupa domain test
[Sysname-security-policy-ip-0-rule1] user-group groupb domain test
user-group (User Access and Authentication Command Reference)
