- 16-Security Command Reference
- 01-ACL commands
- 02-Packet filter commands
- 03-Time range commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-IKE commands
- 11-IKEv2 commands
- 12-SSH commands
- 13-SSL commands
- 14-SSL VPN commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Attack detection and prevention commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-Protocol packet rate limit commands
- 23-Object group commands
- 24-Security policy commands
| 14-SSL VPN commands | 194.77 KB |
SSL VPN commands
aaa domain
Use aaa domain to specify an ISP domain for authentication, authorization, and accounting of SSL VPN users for an SSL VPN gateway.
Use undo aaa domain to restore the default.
aaa domain domain-name
undo aaa domain
The default ISP domain is used for authentication, authorization, and accounting of SSL VPN users for an SSL VPN gateway.
SSL VPN gateway view
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters. The name must meet the following requirements:
· The name cannot contain a forward slash (/), backslash (\), vertical bar (|), quotation marks ("), colon (:), asterisk (*), question mark (?), left angle bracket (<), right angle bracket (>), or at sign (@).
· The name cannot be d, de, def, defa, defau, defaul, default, i, if, if-, if-u, if-un, if-unk, if-unkn, if-unkno, if-unknow, or if-unknown.
An SSL VPN username cannot carry ISP domain information. After this command is executed, an SSL VPN gateway uses the specified ISP domain for authentication, authorization, and accounting of SSL VPN users.
# Specify ISP domain myserver for authentication, authorization, and accounting of SSL VPN users in SSL VPN gateway gw1.
[Sysname] sslvpn gateway gw1
[Sysname-sslvpn-gateway-gw1] aaa domain myserver
display interface sslvpn-ac
Use display interface sslvpn-ac to display SSL VPN AC interface information.
display interface [ sslvpn-ac [ interface-number ] ] [ brief [ description | down ] ]
sslvpn-ac [ interface-number ]: Specifies an SSL VPN AC interface by its number in the range of 0 to 4095. If you do not specify the sslvpn-ac keyword, this command displays information about all interfaces. If you specify the sslvpn-ac keyword without the interface-number argument, this command displays information about all SSL VPN AC interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about SSL VPN AC 1000.
<Sysname> display interface sslvpn-ac 1000
SSLVPN-AC1000
Current state: UP
Line protocol state: DOWN
Description: SSLVPN-AC1000 Interface
Bandwidth: 64kbps
Link layer protocol is SSLVPN
SSLVPN-AC1000 |
Information about interface SSL VPN AC 1000. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Network Connectivity Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Network Connectivity Configuration Guide. |
Last clearing of counters |
Most recent time the counters were cleared by using the reset counters interface command. If the reset counters interface command has never been executed since the device starts up, this field displays Never. |
Last 300 seconds input rate |
Average input rate in the last 300 seconds. |
Last 300 seconds output rate |
Average output rate in the last 300 seconds. |
# Display brief information about all SSL VPN AC interfaces.
<Sysname> display interface sslvpn-ac brief
Brief information of interfaces in route mode:
Protocol: (s) - spoofing
SSLVPN-AC1000 UP DOWN --
# Display brief information about SSL VPN AC 1000, including the complete interface description.
<Sysname> display interface sslvpn-ac 1000 brief description
SSLVPN-AC1000 UP UP 1.1.1.1 SSLVPN-AC1000 Interface
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface sslvpn-ac brief down
Interface Link Cause
SSLVPN-AC1000 ADM
SSLVPN-AC1001 ADM
Brief information of interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol of the interface is down. |
Primary IP |
Primary IP address of the interface. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). |
display sslvpn gateway
Use display sslvpn gateway to display SSL VPN gateway information.
display sslvpn gateway [ brief | name gateway-name ]
brief: Displays brief SSL VPN gateway information. If you do not specify this keyword, the command displays detailed SSL VPN gateway information.
name gateway-name: Specifies an SSL VPN gateway by its name. An SSL VPN gateway name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN gateway, this command displays information about all SSL VPN gateways.
# Display detailed information about all SSL VPN gateways.
<Sysname> display sslvpn gateway
Gateway name: gw
Operation state: Down
Down reason: Administratively down
AAA domain: Not specified
Code verification: Disabled
Associated SSL VPN Interface: GigabitEthernet0/0/1
SSL server policy configured: a
HTTPS port: 443
Maximum users allowed: 1048575
Idle timeout: 30 min
Gateway name |
Name of the SSL VPN gateway. |
Operation state |
Operation state of the SSL VPN gateway: · Up—The gateway is running. · Down—The gateway is not running. |
Down reason |
Causes for the Down operation status: · Administratively down—The SSL VPN gateway is disabled. To enable the gateway, use the service enable command. · Applying SSL server-policy failed—Failed to apply the SSL server policy to the SSL VPN gateway. |
AAA domain |
ISP domain used by the SSL VPN gateway. |
Code verification |
Whether code verification is enabled for the SSL VPN gateway. |
Associated SSL VPN Interface |
Interface associated with the SSL VPN gateway. |
SSL server policy configured |
SSL server policy configured for the SSL VPN gateway. A newly configured SSL server policy takes effect only after the SSL VPN gateway restarts. |
HTTPS port |
HTTPS port number of the SSL VPN gateway. |
Maximum users allowed |
Maximum number of online users allowed for the SSL VPN gateway. |
Idle timeout |
Maximum idle time of an online SSL VPN user, in minutes. |
# Display brief information about all SSL VPN gateways.
<Sysname> display sslvpn gateway brief
Gateway name Admin Operation
gw1 Up Up
gw2 Down Down (Administratively down)
gw3 Up Up
Gateway name |
Admin |
Administrative status of the SSL VPN gateway: · Up—The gateway has been enabled by using the service enable command. · Down—The gateway is disabled. |
Operation |
Operation state of the SSL VPN gateway: · Up—The gateway is running. · Down (Administratively down)—The gateway is disabled. To enable the gateway, use the service enable command. · Down (Applying SSL server-policy failed)—The gateway is down because the SSL server policy failed to be applied to the gateway. |
display sslvpn online-users
display sslvpn online-users to display online SSL VPN user information.
display sslvpn online-users [ gateway gateway-name ] [ user user-name | verbose ]
gateway gateway-name: Specifies an SSL VPN gateway by its name. An SSL VPN gateway name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SSL VPN gateway, this command displays online SSL VPN user information for all SSL VPN gateways.
user user-name: Specifies an SSL VPN user by the username, a case-insensitive string of 1 to 80 characters. If you specify a user, this command displays detailed online SSL VPN user information for the user. If you do not specify a user, this command displays brief online SSL VPN user information for all users.
verbose: Displays detailed online SSL VPN user information for all SSL VPN users. If you do not specify this keyword, the command displays brief online SSL VPN user information for the specified or all SSL VPN users.
# Display brief information about online SSL VPN users in the SSL VPN gateway.
<Sysname> display sslvpn online-users
Total online-users: 2
SSL VPN gateway: gw1
Online-users: 2
Username Connections Idle time Created User IP
user1 5 0/00:00:23 0/04:47:16 192.0.2.1
user2 5 0/00:00:46 0/04:48:36 192.0.2.2
Table 5 Command output
Total online-users |
Total number of users in all SSL VPN gateways. |
SSL VPN gateway |
SSL VPN gateway name. |
Online-users |
Number of users in the current SSL VPN gateway. |
Username |
Login name of the online user. |
Connections |
Number of connections for the online user. |
Idle time |
Duration that the online user has been idle, in the format of days/hh:mm:ss. |
Created |
Time elapsed since the online user was created, in the format of days/hh:mm:ss. |
User IP |
IP address used by the online user. |
# Display detailed information about online SSL VPN user user1.
<Sysname> display sslvpn online-users user user1
User : user1
Authentication method : Username/password authentication
Gateway : gw1
Idle timeout : 30 min
Created at : 13:49:27 UTC Wed 05/14/2021
Lastest : 17:50:58 UTC Wed 05/14/2021
Allocated client IPv4 : 2.2.2.1
User IPv4 address : 192.0.2.1
User ID : 1
Endpoint information : Internet Explorer
# Display detailed information about all online SSL VPN users.
<Sysname> display sslvpn online-users verbose
User : user1
Gateway : gw1
User ID : 1
User : user2
Gateway : gw1
Idle timeout : 2100 sec
Created at : 14:15:12 UTC Wed 05/14/2021
Lastest : 18:56:58 UTC Wed 05/14/2021
Allocated client IPv4 : 2.2.2.2
User IPv4 address : 192.0.2.2
User ID : 5
Table 6 Command output
User |
SSL VPN username. |
Authentication method |
Authentication methods required for logging in to the SSL VPN gateway. Options include: · Username/password authentication. · Certificate authentication. · Code verification. · SMS authentication. · Custom authentication. The use of authentication methods must meet the following requirements: · You can enable one or multiple authentication methods. · Username/password authentication, certificate authentication, or both must be enabled. · Custom authentication and SMS authentication cannot both be enabled at the same time. · All authentication methods can be used independently except for code verification. |
Gateway |
SSL VPN gateway to which the user belongs. |
Idle timeout |
Idle timeout timer of the SSL VPN user, in seconds. |
Created at |
Time at which the SSL VPN user was created |
Lastest |
Most recent time when the SSL VPN user accessed resources through the SSL VPN gateway. |
Allocated client IPv4 |
IPv4 address allocated to the iNode client of the SSL VPN user. This field is displayed only for iNode users. |
User IPv4 address |
IPv4 address used by the online SSL VPN user. |
User ID |
ID of the online SSL VPN user. |
Endpoint information |
Web browser or operating system used by the SSL VPN user. |
force-logout
Use force-logout to force online users to log out.
force-logout [ all | user-id user-id | user user-name ]
all: Logs out all users.
user-id user-id: Specifies a user by the user ID, in the range of 1 to 4294967295. You can obtain user IDs of online users by using display sslvpn online-users.
user user-name: Specifies a user by the username. The username is a case-sensitive string of 1 to 80 characters.
# Log out the user with user ID 1.
[Sysname-sslvpn-gateway-gw1] force-logout user-id 1
https-port
Use https-port to specify an HTTPS port number for an SSL VPN gateway.
Use undo https-port to restore the default.
https-port port-number
undo https-port
The HTTPS port number used by an SSL VPN gateway is 443.
port-number: Specifies an HTTPS port number. The value range is 443 and 1025 to 65535. The default is 443.
# Specify HTTPS port number as 10443 for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] https-port 10443
interface
Use interface to specify an interface for an SSL VPN gateway.
Use undo interface to restore the default.
undo interface interface-type interface-number
Non interface is specified for an SSL VPN gateway.
The SSL VPN gateway uses the specified interface to communicate with SSL VPN users in IP access mode. It uses the interface to forward packets sent by the user to remote servers and to forward the servers' replies back to the user.
# Access SSL VPN gateway gw1 and specify the interface for the gateway as GigabitEthernet 1/0/1.
[Sysname-sslvpn-gateway-gw1] interface gigabitEthernet 1/0/1
interface sslvpn-ac
Use interface sslvpn-ac to create an SSL VPN AC interface and enter its view, or enter the view of an existing SSL VPN AC interface.
Use undo interface sslvpn-ac to delete an SSL VPN AC interface.
interface sslvpn-ac interface-number
undo interface sslvpn-ac interface-number
No SSL VPN AC interfaces exist.
interface-number: Specifies an SSL VPN AC interface number, in the range of 0 to 4095.
# Create SSL VPN AC 1000 and enter its view.
<Sysname>system-view
[Sysname]interface SSLVPN-AC 1000
[Sysname-SSLVPN-AC1000]
ip-tunnel access-route
Use ip-tunnel access-route to specify the IPv4 routes to be issued to clients.
Use undo ip-tunnel access-route to remove the IPv4 routes to be issued to clients.
ip-tunnel access-route ipv4-address { mask | mask-length }
undo ip-tunnel access-route ipv4-address { mask | mask-length }
No IPv4 routes to be issued to clients are specified.
ip-address: Specifies the destination address of the IPv4 route. It cannot be a multicast, broadcast, or loopback address.
mask: Specifies the mask for the destination address of the IPv4 route.
mask-length: Specifies the mask length for the destination address of the IPv4 route, in the range of 0 to 32.
When a client accesses an SSL VPN gateway in IP access mode, the SSL VPN gateway issues the configured IPv4 route or the specified IPv4 routes to the client. The client adds the IPv4 routes, using the VNIC as the output interface. Packets from the client to the internal servers match the IPv4 routes, and therefore are sent to the SSL VPN gateway through the VNIC.
Repeat this command to specify multiple IPv4 routes to be issued to clients.
# In SSL VPN gateway gw1, specify the destination address of the IPv4 route to be issued to clients as 10.0.0.0 and specify the mask length as 8.
[Sysname-sslvpn-gateway-gw1] ip-tunnel access-route 10.0.0.0 8
ip-tunnel address-pool
Use ip-tunnel address-pool to create an IPv4 address pool.
Use undo ip-tunnel address-pool to delete an IPv4 address pool.
ip-tunnel address-pool start-ipv4-address end-ipv4-address mask { mask | mask-length }
undo ip-tunnel address-pool start-ipv4-address end-ipv4-address
No IPv4 address pool is configured.
start-ip-address end-ip-address: Specifies the start IP address and end IP address for the pool. The end IP address must be greater than the start IP address. The start IP address and end IP address cannot be a multicast, broadcast, or loopback address.
mask { mask-length | mask }: Specifies the mask length or mask of the IPv4 address pool. The value range for the mask length is 1 to 30.
The created IPv4 address pools are used for an SSL VPN gateway to allocate addresses to SSL VPN IP access clients.
You can execute this command multiple times to configure multiple IPv4 address pools, but no overlapping address ranges are allowed for different address pools.
If an SSL VPN gateway is configured with multiple IPv4 address pools of different network segments, the IPv4 address allocated to a client might not be in the same network segment as the IPv4 address of an SSL VPN AC interface. In this case, you must add a route on the SSL VPN gateway for the SSL VPN AC interface to reach the client.
# In SSL VPN gateway gw1, create an IPv4 address pool named pool1 and specify the address range as 10.1.1.1 to 10.1.1.254.
[Sysname-sslvpn-gateway-gw1] ip-tunnel address-pool 10.1.1.1 10.1.1.254 mask 24
ip-tunnel dns-server
Use ip-tunnel dns-server to specify an IPv4 DNS server for IP access.
Use undo ip-tunnel dns-server to restore the default.
ip-tunnel dns-server { primary | secondary } ip-address
undo ip-tunnel dns-server { primary | secondary }
No IPv4 DNS servers are specified for IP access.
primary: Specifies the primary DNS server.
secondary: Specifies the secondary DNS server.
ip-address: Specifies the IPv4 address of the DNS server. It cannot be a multicast, broadcast, or loopback address.
# Specify the primary DNS server 1.1.1.1 for IP access in SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel dns-server primary 1.1.1.1
ip-tunnel emo-server
Use ip-tunnel emo-server to specify an Endpoint Mobile Office (EMO) server for mobile clients.
Use undo ip-tunnel emo-server to restore the default.
ip-tunnel emo-server address { host-name | ipv4-address } port port-number
No EMO server is specified for mobile clients.
address: Specifies the host name or IPv4 address of the EMO server.
host-name: Specifies the host name of the EMO server, a case-insensitive string of 1 to 127 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.).
ipv4-address: Specifies the IPv4 address of the EMO server, in dotted decimal notation. The IP address cannot be a multicast, broadcast, or loopback address.
port port-number: Specifies the port number of the EMO server, in the range of 1025 to 65535.
An EMO server provides services for mobile clients. The SSL VPN gateway issues the EMO server information to the clients, and the clients can access available service resources through the EMO server.
# Specify the IP address of the EMO server as 10.10.1.1 and the port number as 9058 for SSL VPN gate gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel emo-server address 10.10.1.1 port 9058
ip-tunnel interface
Use ip-tunnel interface to specify an SSL VPN AC interface for IP access.
Use undo ip-tunnel interface to restore the default.
ip-tunnel interface sslvpn-ac interface-number
No SSL VPN AC interface is specified for IP access.
sslvpn-ac interface-number: Specifies the number of an SSL VPN AC interface. The interface must have been created.
The SSL VPN gateway uses the specified SSL VPN AC interface to communicate with SSL VPN users in IP access mode. It uses the SSL VPN AC interface to forward packets sent by the user to remote servers and to forward the servers' replies back to the user.
# Specify SSL VPN AC 100 for IP access in the view of SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel interface sslvpn-ac 100
interface sslvpn-ac
ip-tunnel keepalive
Use ip-tunnel keepalive to set the keepalive interval for IP access.
Use undo ip-tunnel keepalive to restore the default.
ip-tunnel keepalive seconds
The keepalive interval is 30 seconds for IP access.
seconds: Specifies the keepalive interval in the range of 0 to 600 seconds. If the interval is set to 0 seconds, a client does not send keepalive messages to the SSL VPN gateway.
A client sends keepalive messages to the SSL VPN gateway to maintain connections between them.
If an SSL VPN gateway does not receive any data or keepalive messages from a client during the online user idle timeout timer, it terminates the connection with the client.
Set the keepalive interval to be shorter than the user idle timeout timer configured by the timeout idle command.
# Set the keepalive interval to 50 seconds for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel keepalive 50
ip-tunnel message-server
Use message-server to specify a message server for mobile clients.
Use undo message-server to restore the default.
ip-tunnel message-server address { host-name | ipv4-address } port port-number
undo ip-tunnel message-server
No message server is specified for mobile clients.
address: Specifies the host name or IPv4 address of the message server.
host-name: Specifies the host name of the message server, a case-insensitive string of 1 to 127 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.).
ipv4-address: Specifies the IPv4 address of the message server, in dotted decimal notation. The IP address cannot be a multicast, broadcast, or loopback address.
port port-number: Specifies the port number of the message server, in the range of 1025 to 65535.
A message server provides services for mobile clients. The SSL VPN gateway issues the message server information to the clients, and the clients can access the message server.
# Specify the IP address of the message server as 10.10.1.1 and the port number as 8000 for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel message-server address 10.10.1.1 port 8000
ip-tunnel wins-server
Use ip-tunnel wins-server to specify an IPv4 WINS server for IP access.
Use undo ip-tunnel wins-server to restore the default.
ip-tunnel wins-server { primary | secondary } ip-address
undo ip-tunnel wins-server { primary | secondary }
No IPv4 WINS servers are specified for IP access.
primary: Specifies the primary WINS server.
secondary: Specifies the secondary WINS server.
ip-address: Specifies the IPv4 address of the WINS server. It cannot be a multicast, broadcast, or loopback address.
# Specify the primary WINS server 1.1.1.1 for IP access in SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ip-tunnel wins-server primary 1.1.1.1
log ip-tunnel
Use ip-tunnel log to enable logging for IP address allocations and releases, IP access connection close events, or IP access packet drop events.
Use undo ip-tunnel log to disable logging for IP address allocations and releases, IP access connection close events, or IP access packet drop events.
log ip-tunnel { address-alloc-release | connection-close | packet-drop }
undo log ip-tunnel { address-alloc-release | connection-close | packet-drop }
Logging is disabled for IP access connection close events or IP access packet drop events.
address-alloc-release: Enables logging for IP address allocations and releases for the VNIC of the IP access client.
connection-close: Enables logging for IP access connection close events.
packet-drop: Enables logging for IP access packet drop events.
If logging is enabled for IP address allocations and releases for the VNIC of the IP access client, the SSL VPN gateway generates logs when the VNIC's IP address is allocated or released.
If logging for IP access connection close events is enabled, the SSL VPN gateway generates logs when the connections established for SSL VPN IP access users are closed.
If logging for IP access packet drop events is enabled, the SSL VPN gateway generates logs when packets for SSL VPN IP access users are dropped.
The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about the information center, see Device Management Configuration Guide.
# Enable logging for IP access connection close events for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] log ip-tunnel connection-close
log resource-access enable
Use log resource-access enable to enable resource access logging.
Use undo log resource-access enable to disable resource access logging.
log resource-access enable [ brief | filtering ] *
Resource access logging is disabled.
brief: Records brief resource access information. If you specify this keyword, only the address and port number of the accessed resource will be recorded. If you do not specify this keyword, a large amount of information including webpage formatting information will be recorded.
filtering: Enables resource access log filtering. With this keyword specified, the device generates only one log for accesses of the same user to the same resource in a minute. If this keyword is not specified, the device generates a log for each resource access.
This feature logs resource accesses of SSL VPN users. The logs are sent to the information center of the device.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output SSL VPN resource access logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view SSL VPN resource access logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see System Management Configuration Guide.
If you execute the log resource-access enable command multiple times, the most recent configuration takes effect.
# Enable resource access logging.
[Sysname-sslvpn-gateway-gw1] log resource-access enable
log user-login enable
Use log user-login enable to enable logging for user login and logoff events.
Use undo log user-login enable to disable logging for user login and logoff events.
Logging for user login and logoff events is disabled.
This feature logs user login and logoff events. The logs are sent to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about the information center, see System Management Configuration Guide.
# Enable logging for user logins and logouts.
[Sysname-sslvpn-gateway-gw1] log user-login enable
max-online-users per-gateway
Use max-online-users per-gateway to specify the maximum number of online users for an SSL VPN gateway.
Use undo max-online-users per-gateway to restore the default.
max-online-users per-gateway max-number
A maximum of 1048575 online users are allowed for an SSL VPN gateway.
per-gateway max-number: Specifies the maximum number of online users for an SSL VPN gateway, in the range of 1 to 1048575.
If the specified limit is reached, new users cannot access the SSL VPN gateway.
# Set the maximum number of online users to 500 for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] max-online-users per-gateway 500
reset counters interface sslvpn-ac
Use reset counters interface sslvpn-ac to clear SSL VPN AC interface statistics.
reset counters interface [ sslvpn-ac [ interface-number ] ]
sslvpn-ac [ interface-number ]: Specifies an SSL VPN AC interface by its number in the range of 0 to 4095. If you do not specify this option, the command clears statistics for all interfaces. If you specify the sslvpn-ac keyword without the interface-number argument, this command clears statistics for all existing SSL VPN AC interfaces.
Use this command to clear old statistics so you can observe new traffic statistics on an SSL VPN AC interface.
# Clear statistics for SSL VPN AC 1000.
<Sysname> reset counters interface sslvpn-ac 1000
service ipv4 enable
Use service ipv4 enable to enable the IPV4 service for an SSL VPN gateway.
Use undo service ipv4 enable to disable the IPv4 service for an SSL VPN gateway.
service ipv4 enable
The IPv4 service is disabled for an SSL VPN gateway.
The IPv4 service enables an SSL VPN gateway to establish SSL connections with remote access users and forward IPv4 traffic between remote users and internal servers.
# Enable the IPv4 service for SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] service ipv4 enable
ssl server-policy
Use ssl server-policy to apply an SSL server policy to an SSL VPN gateway.
Use undo ssl server-policy to remove the application.
ssl server-policy policy-name
An SSL VPN gateway uses the SSL server policy of its self-signed certificate.
policy-name: Specifies the name of an SSL server policy, a case-insensitive string of 1 to 31 characters.
You can apply only one SSL server policy to an SSL VPN gateway. The SSL VPN gateway will use the parameters defined by the policy to establish SSL connections to remote users.
# Apply SSL server policy CA_CERT to SSL VPN gateway gw1.
[Sysname-sslvpn-gateway-gw1] ssl server-policy CA_CERT
sslvpn gateway
Use sslvpn gateway to create an SSL VPN gateway and enter its view, or enter the view of an existing SSL VPN gateway.
Use undo sslvpn gateway to delete an SSL VPN gateway.
sslvpn gateway gateway-name
undo sslvpn gateway gateway-name
No SSL VPN gateways exist.
gateway-name: Specifies an SSL VPN gateway name, a case-insensitive string of 1 to 31 characters. Valid characters are letters, digits, and underscores (_).
An SSL VPN gateway resides between remote users and the enterprise network to ensure secure access of remote users to the enterprise internal network. The SSL VPN gateway establishes an SSL connection to a remote user, and then authenticates the user before allowing the user to access an internal server.
# Create an SSL VPN gateway named gw1 and enter its view.
timeout idle
Use timeout idle to set the idle timeout timer for online SSL VPN users.
Use undo timeout idle to restore the default.
timeout idle minutes
undo timeout idle
The idle timeout timer is 30 minutes for online SSL VPN users.
seconds: Specifies the idle timeout timer, in the range of 1 to 1440 minutes.
If the idle time of an online SSL VPN user exceeds the specified idle timeout timer, the connection to the user is terminated.
# Set the idle timeout timer to 50 minutes for online SSL VPN users.
[Sysname-sslvpn-gateway-gw1] timeout idle 50
display sslvpn policy-group
verify-code
Use verify-code enable to enable code verification.
Use undo verify-code enable to disable code verification.
verify-code enable
Code verification is disabled.
After code verification is enabled, a user must enter a correct verification code to log in to the SSL VPN webpage.
# Enable code verification.
[Sysname-sslvpn-gateway-gw1] verify-code enable
