- 16-Security Command Reference
- 01-ACL commands
- 02-Packet filter commands
- 03-Time range commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-IKE commands
- 11-IKEv2 commands
- 12-SSH commands
- 13-SSL commands
- 14-SSL VPN commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Attack detection and prevention commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-Protocol packet rate limit commands
- 23-Object group commands
- 24-Security policy commands
| 04-User profile commands | 57.94 KB |
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ session-group ] [ name profile-name ]
session-group: Specifies a session group profile.
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, underscores (_), minus signs (–), and dots (.). The name can start with an English letter or digit, and cannot contain only digits. The name must be unique globally. If you do not specify this option, the command displays configuration and online user information for all user profiles.
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
User-Profile: aaa
Direction: Inbound
Committed Access Rate:
CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Policy: p1
Packet-filter ipv6 2222
Direction: Outbound
Line Rate:
Priority queuing: pql 1
General Traffic Shaping:
CIR 200 (kbps), CBS 12500 (Bytes), EBS 0 (Bytes)
Policy: p2
Packet-filter 2222
Connection-limit amount: 1000
Connection-limit rate: 100
Authentication-free rule:
acl 3000
acl name flow1
acl ipv6 3000
acl ipv6 name flow2
User user_1:
Authentication type: 802.1X
Network attributes:
Interface : GigabitEthernet1/0/1
MAC address : 0000-1111-2222
Failed action list:
Direction: Inbound
Policy: p1
User user_2:
Authentication type: Portal
Network attributes:
Interface : GigabitEthernet1/0/3
IP address : 172.16.187.16
VPN : N/A
Service VLAN : 100
# Display configuration and online user information for all session group profiles.
<Sysname> display user-profile session-group
Session-Group-Profile: aaa
Direction: Outbound
QMProfile: a
User user_1:
Network attributes:
Failed action list:
Direction Outbound
QMProfile: a
User user_2:
Network attributes:
VPN : N/A
Service VLAN : 100
Session-Group-Profile: bbb
Direction: Outbound
CIR 512 (kbps), CBS 1024 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
QMProfile: a
User user_4:
Network attributes:
Interface : GigabitEthernet1/0/2
IP address : 172.16.187.166
VPN : N/A
Service VLAN : 100
User-Profile |
User profile name. |
Inbound |
Policy applied to incoming traffic. |
Outbound |
Policy applied to outgoing traffic. |
Session-Group-Profile |
Session group profile name. |
CIR |
Committed information rate, in kbps. |
CBS |
Committed burst size, in bytes. |
EBS |
Excess burst size, in bytes. |
PIR |
Peak information rate, in kbps. |
Connection-limit amount |
Maximum number of user connections set by the connection limits. |
Connection-limit rate |
Maximum connection establishment rate set by the connection limits. |
Authentication-free rule |
User profile free rule. |
Policy |
Policy name. |
Packet-filter |
Packet filter that uses an IPv4 ACL. |
Packet-filter ipv6 |
Packet filter that uses an IPv6 ACL. |
QMProfile |
Queue scheduling profile. |
User user_1 |
Username of a user account with which a user profile or session group profile is associated. |
Authentication type |
Authentication type: Portal—Portal authentication. |
Network attributes |
Online user information. |
Failed action list |
Actions that failed to be applied to the user. |
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name [ type session-group ]
undo user-profile profile-name
No user profiles exist.
type session-group: Specifies a session group profile.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
# Create session group profile a123 and enter the view of a123.
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123]
