- H3C WA7539 Access Point Installation Guide-5W100
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
| 04-Appendix B LEDs and buttons | 36.85 KB |
4 Appendix B LEDs and buttons
LEDs and buttons
The LED status varies by AP operating mode. For information about the supported operating modes, see the release notes for the AP.
Table 4-1 LED descriptions (fit mode)
LED status |
Off |
No power is present or the LED has been turned off. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing (twice per second) |
The Ethernet interfaces are down and no mesh links are established. |
Green |
Steady on |
The AP has registered to an AC, but does not have any associated clients. |
Flashing (once per two seconds) |
The AP has started up but has not registered to any AC. |
The AP is upgrading the image. |
Blue |
Flashing (once per second) |
The radios have associated clients. |
Table 4-2 LED descriptions (cloud mode)
LED status |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state and has connected to the Cloudnet platform, but does not have any associated clients. |
The AP has connected to the Cloudnet platform and has associated clients. |
Blue |
Steady on |
The AP is in standby state, but has not connected to the Cloudnet platform and does not have associated clients. |
The AP has not connected to the Cloudnet platform, but has associated clients. |
Table 4-3 RESET button descriptions
Press and hold duration (sec) |
Button LED status |
0 to 5 |
Steady green |
Reset the AP. |
5 to 20 |
Flashing green (twice per second) |
Restore to the factory defaults. |
20 to 30 |
Yellow |
The AP is operating in fit mode. |
Flashing (four times per second) |
The AP is operating in cloud mode. |
> 30 |
Yellow |
Green |
Change the AP operating mode to cloud. NOTE: If you release the button, the AP will restart for the new mode to take effect. |
