- H3C WA7539 Access Point Installation Guide-5W100
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
| 03-Appendix A AP views and technical specifications | 151.76 KB |
3 Appendix A AP views and technical specifications
AP views
WA7539
Figure3-1 WA7539
Ports
Figure3-2 Ports on the WA7539 AP
(1) Power port |
(2) 10GE1/PoE++ port |
(3) GE/PSE port |
(4) USB port |
(5) 10GE2/P++SFP port |
(6) Console port |
(7) Reset button |
(8) Security slot |
Technical specifications
Table3-1 Technical specifications
Item |
Dimensions (H × W × D) (without the mounting bracket) |
42 × 225 × 225 mm (1.65 × 8.86 × 8.86 in) |
Weight |
1.5 kg (3.31 lb) |
Power consumption |
≤ 54 W |
Antenna |
Built-in antenna |
Standard compliance |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3at/bt |
Powering option |
IEEE802.3at/bt powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
Console port |
Control port, used for debugging by the maintenance personnel |
10GE2/P++SFP port |
1000M/2.5G/5G/10G photoelectric hybrid port |
10GE1/PoE++ port |
100M/1000M/2.5G/5G/10G Ethernet copper port When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and Ten-GigabitEthernet 1 for configuration on the AC. |
GE/PSE port |
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
USB port |
USB-compliant USB port. NOTE: By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view. |
Power port (54VDC) |
Used for receiving power from a local power source. |
Reset button |
For more information, see "Appendix B LEDs and buttons." |
