- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
| 19-SNMP-USER-BASED-SM-MIB | 84.65 KB |
usmStatsUnsupportedSecLevels (1.3.6.1.6.3.15.1.1.1)
usmStatsNotInTimeWindows (1.3.6.1.6.3.15.1.1.2)
usmStatsUnknownUserNames (1.3.6.1.6.3.15.1.1.3)
usmStatsUnknownEngineIDs (1.3.6.1.6.3.15.1.1.4)
usmStatsWrongDigests (1.3.6.1.6.3.15.1.1.5)
usmStatsDecryptionErrors (1.3.6.1.6.3.15.1.1.6)
usmUserSpinLock (1.3.6.1.6.3.15.1.2.1)
About this MIB
Use this MIB to implement the SNMP user-based security model.
MIB file name
rfc3414-snmp-usm.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpUsmMIB(15)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsUnsupportedSecLevels (1.3.6.1.6.3.15.1.1.1) |
read-only |
Counter32 |
Standard MIB values |
Total number of packets received but dropped by the SNMP engine because they requested a security level unknown to the SNMP engine or not available. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsNotInTimeWindows (1.3.6.1.6.3.15.1.1.2) |
read-only |
Counter32 |
Total number of packets received but dropped by the SNMP engine because they appeared outside of the authoritative SNMP engine's window. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsUnknownUserNames (1.3.6.1.6.3.15.1.1.3) |
read-only |
Counter32 |
Total number of packets received but dropped by the SNMP engine because they referenced a user unknown to the SNMP engine. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsUnknownEngineIDs (1.3.6.1.6.3.15.1.1.4) |
read-only |
Counter32 |
Total number of packets received but dropped by the SNMP engine because they referenced an SNMP Engine ID unknown to the SNMP engine. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsWrongDigests (1.3.6.1.6.3.15.1.1.5) |
read-only |
Counter32 |
Total number of packets received but dropped by the SNMP engine because they did not contain the expected digest value. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmStatsDecryptionErrors (1.3.6.1.6.3.15.1.1.6) |
read-only |
Counter32 |
Total number of packets received but dropped by the SNMP engine because they could not be decrypted. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmUserSpinLock (1.3.6.1.6.3.15.1.2.1) |
read-write |
TestAndIncr |
An advisory lock used to allow several cooperating command generator applications to coordinate their use of facilities to alter secrets in the usmUserTable. |
As per the MIB. |
Tabular objects
usmUserTable
About this table
Use this table to create users.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are usmUserEngineID and usmUserName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
usmUserEngineID (1.3.6.1.6.3.15.1.2.2.1.1) |
not-accessible |
SnmpEngineID |
OCTET STRING (5..32) |
Administratively unique identifier for the SNMP engine. |
As per the MIB. |
usmUserName (1.3.6.1.6.3.15.1.2.2.1.2) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Use name. It is the (user-based security) model dependent security ID. |
The value can contain only displayable characters except question marks. |
usmUserSecurityName (1.3.6.1.6.3.15.1.2.2.1.3) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
A human readable string representing the user in security model independent format. The default transformation of the user-based security model dependent security ID to the security name and vice versa is the identity function so that the security name is the same as the user name. |
As per the MIB. |
usmUserCloneFrom (1.3.6.1.6.3.15.1.2.2.1.4) |
read-create |
RowPointer |
A pointer to another conceptual row in this usmUserTable. The user in this other conceptual row is called the clone-from user. |
This object must be specified for creating an instance. If the object corresponds to a user created by the command line, this operation succeeds but does not take effect. When a new user is created (a new conceptual row is instantiated in this table), the privacy and authentication parameters of the new user must be cloned from its clone-from user. These parameters are: authentication protocol (usmUserAuthProtocol) privacy protocol (usmUserPrivProtocol) They will be copied regardless of what the current value is. Cloning also causes the initial values of the secret authentication key (authKey) and the secret encryption key (privKey) of the new user to be set to the same values as the corresponding secrets of the clone-from user to allow the KeyChange process to occur as required during user creation. The first time an instance of this object is set by a management operation (either at or after its instantiation), the cloning process is invoked. Subsequent writes are successful but invoke no action to be taken by the receiver. The cloning process fails with an inconsistentName error if the conceptual row representing the clone-from user does not exist or is not in an active state when the cloning process is invoked. When this object is read, the ZeroDotZero OID is returned. |
usmUserAuthProtocol (1.3.6.1.6.3.15.1.2.2.1.5) |
read-create |
AutonomousType |
Indicates whether messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID can be authenticated and the authentication protocol to be used. |
As per the MIB. |
usmUserAuthKeyChange (1.3.6.1.6.3.15.1.2.2.1.6) |
read-create |
KeyChange |
-- typically (SIZE (0 | 32)) for HMACMD5 -- typically (SIZE (0 | 40)) for HMACSHA |
An object, which when modified, causes the secret authentication key used for messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID, to be modified via a one-way function. |
When read, this object returns a zero-length string. |
usmUserOwnAuthKeyChange (1.3.6.1.6.3.15.1.2.2.1.7) |
read-create |
KeyChange |
Functions exactly as usmUserAuthKeyChange, with one notable difference: in order for the set operation to succeed, the usmUserName of the operation requester must match the usmUserName that indexes the row which is targeted by this operation. |
usmUserPrivProtocol (1.3.6.1.6.3.15.1.2.2.1.8) |
read-create |
AutonomousType |
An indication of whether messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID can be protected from disclosure, and the type of privacy protocol to be used. |
As per the MIB. |
usmUserPrivKeyChange (1.3.6.1.6.3.15.1.2.2.1.9) |
read-create |
KeyChange |
-- typically (SIZE (0 | 32)) for DES |
An object, which when modified, causes the secret encryption key used for messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID, to be modified via a one-way function. |
usmUserOwnPrivKeyChange (1.3.6.1.6.3.15.1.2.2.1.10) |
read-create |
KeyChange |
Functions exactly as usmUserPrivKeyChange, with one notable difference: in order for the Set operation to succeed, the usmUserName of the operation requester must match the usmUserName that indexes the row which is targeted by this operation. |
usmUserPublic (1.3.6.1.6.3.15.1.2.2.1.11) |
read-create |
OCTET STRING |
OCTET STRING (0..32) |
A publicly-readable value that can be written as part of the procedure for changing a user's secret authentication and/or privacy key, and later read to determine whether the change of the secret was effected. |
As per the MIB. |
usmUserStorageType (1.3.6.1.6.3.15.1.2.2.1.12) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for this conceptual row. |
Supports only nonVolatile(3). |
usmUserStatus (1.3.6.1.6.3.15.1.2.2.1.13) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
