- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
| 11-HH3C-SNMP-EXT-MIB | 69.29 KB |
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4) |
read-only |
Integer32 |
Integer32 (1..65535) |
Maximum number of SNMP contexts supported by the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5) |
read-write |
BITS |
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) } |
SNMP version. |
As per the MIB. |
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1) |
not-accessible |
SnmpSecurityModel |
INTEGER (0..3) |
Security model of a community or user. |
As per the MIB. |
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2) |
not-accessible |
SnmpAdminString |
OCTET STRING (1..32) |
Security name of the community or user. |
As per the MIB. |
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3) |
read-only |
OCTET STRING |
Community name or username. |
As per the MIB. |
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4) |
read-write |
Integer32 |
Integer32 (0 | 2000..3999) |
IPv4 ACL number used by the community or the user. |
As per the MIB. |
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5) |
read-write |
Integer32 |
IPv6 ACL number used by the community or the user. |
As per the MIB. |
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP context extended properties.
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1) |
not-accessible |
SnmpAdminString |
Context name. |
As per the MIB. |
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Status of this entry. |
Supports only action, createAndGo, and destroy. |
