20-Network Management and Monitoring
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10020-Network Management and Monitoring
09-HH3C-PTP-MIB
09-HH3C-PTP-MIB 205.32 KB
HH3C-PTP-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cPTPOldPortName (1.3.6.1.4.1.25506.2.235.1.1.2) 1
hh3cPTPPortState (1.3.6.1.4.1.25506.2.235.1.1.3) 1
hh3cPTPOldPortState (1.3.6.1.4.1.25506.2.235.1.1.4) 1
hh3cPTPMasterClockId (1.3.6.1.4.1.25506.2.235.1.1.5) 2
hh3cPTPOldMasterClockId (1.3.6.1.4.1.25506.2.235.1.1.6) 2
hh3cPTPSourcePortNum (1.3.6.1.4.1.25506.2.235.1.1.7) 2
hh3cPTPOldSourcePortNum (1.3.6.1.4.1.25506.2.235.1.1.8) 2
hh3cPTPTimeSyncStatus (1.3.6.1.4.1.25506.2.235.1.1.9) 2
hh3cPTPTimeLockStatus (1.3.6.1.4.1.25506.2.235.1.1.10) 3
hh3cPTPExtTimePortStatus (1.3.6.1.4.1.25506.2.235.1.1.11) 3
hh3cPTPExtTimePortType (1.3.6.1.4.1.25506.2.235.1.1.12) 3
hh3cPTPSourcePortClockId (1.3.6.1.4.1.25506.2.235.1.1.13) 3
hh3cPTPSourceStepsRemoved (1.3.6.1.4.1.25506.2.235.1.1.14) 3
hh3cPTPPacketType (1.3.6.1.4.1.25506.2.235.1.1.15) 4
hh3cPTPTimeOffset (1.3.6.1.4.1.25506.2.235.1.1.16) 4
hh3cPTPTimeOffsetThreshold (1.3.6.1.4.1.25506.2.235.1.1.17) 4
hh3cPTPTimeOffsetSum (1.3.6.1.4.1.25506.2.235.1.1.18) 4
hh3cPTPTimeOffsetSumThrehold (1.3.6.1.4.1.25506.2.235.1.1.19) 4
hh3cPTPFreqLockStatus (1.3.6.1.4.1.25506.2.235.1.1.20) 5
hh3cPTPTimeOffsetSumSec (1.3.6.1.4.1.25506.2.235.1.1.21) 5
hh3cPTPChassisID (1.3.6.1.4.1.25506.2.235.1.1.23) 5
hh3cPTPPortAttrMismatchReason (1.3.6.1.4.1.25506.2.235.1.1.24) 5
Notifications· 5
hh3cPTPPortStateChange· 5
hh3cPTPClockSourceChange· 7
hh3cPTPTimeSyncFaulty· 8
hh3cPTPTimeSyncFaultyRecover 9
hh3cPTPTimeLockFail 9
hh3cPTPTimeLockFailRecover 10
hh3cPTPExtTimePortLost 11
hh3cPTPExtTimePortLostRecover 12
hh3cPTPPortBmcInfoChange· 13
hh3cPTPSourceClockClassDecline· 14
hh3cPTPSourceClockClassRecover 15
hh3cPTPPacketLoss· 15
hh3cPTPPacketLossRecover 16
hh3cPTPTimeOffsetExceed· 17
hh3cPTPTimeOffsetRecover 18
hh3cPTPTimeOffsetSumExceed· 19
hh3cPTPTimeOffsetSumRecover 20
hh3cPTPFrequencyLockFail 20
hh3cPTPFrequencyLockRecover 21
hh3cPTPPortAttrMismatch· 22
hh3cPTPPortAttrMismatchRecover 23
HH3C-PTP-MIB
About this MIB
Use this MIB to implement PTP notifications.
MIB file name
hh3c-ptp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPTP(235)
Scalar objects
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
Standard MIB values.
Old PTP port name.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
initializing(1),
faulty(2),
disabled(3),
listening(4),
premaster(5),
master(6),
passive(7),
uncalibrated(8),
slave(9)
PTP port status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
initializing(1),
faulty(2),
disabled(3),
listening(4),
premaster(5),
master(6),
passive(7),
uncalibrated(8),
slave(9)
Old PTP port status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Current master clock ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Old master clock ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
PTP source port number.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Old PTP source port number.
As per the MIB.
Object (OID)
Access
Value range
Implementation
TruthValue
PTP clock synchronization status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
TruthValue
PTP clock locking status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
up(1),
down(2)
External clock port status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
tod0(1),
tod1(2)
External clock port type.
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Clock ID information from the PTP source port.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Steps removed from the grandmaster.
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
sync(1),
pDelayResp(3),
delayResp(9),
announce(11)
PTP message type.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
PTP standard time offset.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
PTP standard time offset threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Nanosecond part of the PTP standard time-offset-sum peak-to-peak value.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
PTP standard time offset sum threshold.
As per the MIB.
Object (OID)
Access
Value range
Implementation
TruthValue
PTP clock frequency locking status.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Second part of the PTP standard time-offset-sum peak-to-peak value.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Chassis number.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Reason for PTP attribute inconsistency between two ends.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.235.1.0.1
PTP port status changed.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification might be generated when the PTP port status changes in the following situations:
The clock device attributes in a PTP domain have changes, for example, the clock priority, time class, time accuracy, and interface NotSlave attribute.
The PTP port is connected to a clock source with higher priority.
The PTP port encounters a link failure or the PTP port goes down.
System impact
The clock source might be changed.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.1 (hh3cPTPPortName)
PTP port name.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.3 (hh3cPTPPortState)
PTP port status.
N/A
INTEGER
initializing(1),, faulty(2),, disabled(3),, listening(4),, premaster(5),, master(6),, passive(7),, uncalibrated(8),, slave(9)
1.3.6.1.4.1.25506.2.235.1.1.4 (hh3cPTPOldPortState)
N/A
INTEGER
PTP instance number.
N/A
Unsigned32
Recommended action
To resolve this issue:
1.Execute the display ptp interface command to identify whether the port is in faulty state.
  - If the port is in faulty state, it has a link failure or goes down. Execute the display interface command to view the port down reason, and locate and resolve the port down issue according to the reason.
  - If the port is not in faulty state, go to step 2.
2.Execute the display current-configuration | include ptp command to identify whether a command has been used to change clock attributes.
  - If a command has been used to change clock attributes, no action is required.
  - If no command has been used to change clock attributes, go to the next step.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.2
Clock source attribute changed.
Informational
Warning
N/A (N/A)
ON
This notification might be generated when the PTP clock source attribute changes in the following situations:
Clock source attributes are changed at the CLI.
Packets of an external clock source with higher time accuracy are received.
System impact
The PTP clock source changes.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.6 (hh3cPTPOldMasterClockId)
Old PTP master clock ID.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.5 (hh3cPTPMasterClockId)
Current PTP master clock ID.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.8 (hh3cPTPOldSourcePortNum)
N/A
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.235.1.1.7 (hh3cPTPSourcePortNum)
Current PTP source port number.
N/A
Unsigned32
Unsigned32
Current PTP port name.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.2 (hh3cPTPOldPortName)
Old PTP port name.
N/A
OCTET STRING
OCTET STRING
N/A
Unsigned32
Recommended action
If clock source attributes are changed at the CLI, no action is required.
If packets of an external clock source with higher time accuracy are received, you need to identify whether the PTP clock source change is correct.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.3
PTP clock unsynchronized.
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.4 (hh3cPTPTimeSyncFaultyRecover)
ON
This notification is generated when the PTP clock status becomes unsynchronized.
System impact
The device time cannot be synchronized.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1. 9 (hh3cPTPTimeSyncStatus)
N/A
TruthValue
N/A
Unsigned32
Recommended action
1.Execute the display ptp clock command to identify whether the device is in local state.
  - If the device is in local state, go to step 2.
  - If the device is not in local state, go to step 4.
2.Execute the display ptp clock command to identify whether the state of the external clock source is correct.
  - If the state is correct, go to step 3.
  - If the state is not correct, go to step 4.
3.Execute the ptp priority clock-source command to correctly configure the clock parameter attributes on the device. After that, use the display ptp clock command to identify whether the device remains in local state. If the device remains in local state, go to step 4.
  - If the device remains in local state, go to step 4.
  - If the device does not remain in local state, the issue is resolved.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
PTP clock synchronized.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP clock status becomes synchronized from unsynchronized.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.9 (hh3cPTPTimeSyncStatus)
N/A
INTEGER
N/A
Unsigned32
Recommended action
No action is required.
hh3cPTPTimeLockFail
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.5
PTP clock loss of lock.
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.6 (hh3cPTPTimeLockFailRecover)
ON
This notification might be generated when the PTP clock loses lock with the reference clock in the following situations:
Frequency loss of lock.
Subcard or clock daughter card fails.
The timestamps received by DSP does not change or have an error.
System impact
The system time cannot be synchronized.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.10 (hh3cPTPTimeLockStatus)
N/A
TruthValue
Recommended action
1.Execute the display ptp interface brief and display interface brief commands to identify whether the PTP subordinate port encounters a link failure or has gone down.
  - If the PTP subordinate port encounters a link failure or has gone down, recover the link or bring up the interface.
  - If the PTP subordinate port is normal, go to step 2.
2.Execute the display current-configuration | include ptp and display ptp interface commands to identify whether the PTP configuration has changed.
  - If the PTP configuration has changed, restore the original configuration.
  - If the PTP configuration has not changed, go to step 3.
Basic information
OID
Event
Severity
Default status
PTP clock returned to locked state.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP clock returns to the locked state.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
TruthValue
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.7
Loss of synchronization with the external clock source.
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.8 (hh3cPTPExtTimePortLostRecover)
ON
This notification is generated when the device loses synchronization with the external clock source.
System impact
The system cannot synchronize frequency or time from the external clock source.
Status control
Object
OID (object name)
Index
Value range
 (hh3cPTPExtTimePortStatus)
N/A
INTEGER
up(1), down(2)
1.3.6.1.4.1.25506.2.235.1.1.12 (hh3cPTPExtTimePortType)
N/A
INTEGER
tod0(1),, tod1(2)
Recommended action
1.Execute the display ptp clock command to identify whether the external clock source is active.
  - If the external clock source is not active, activate the external clock source.
  - If the external clock source is active, go to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
External clock port active.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the external clock port comes active.
System impact
Status control
Object
OID (object name)
Index
Value range
N/A
INTEGER
up(1),, down(2)
N/A
INTEGER
tod0(1),, tod1(2)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.9
Clock source information of a PTP port changed.
Informational
Warning
N/A (N/A)
ON
This notification is generated when clock source information such as follows received on a PTP port has changed:
Clock source ID.
Clock source port number.
Removed steps of the clock source from the grandmaster clock.
System impact
Status control
Object
OID (object name)
Index
Value range
PTP port name.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.13 (hh3cPTPSourcePortClockId)
Clock source ID information received on the port.
N/A
OCTET STRING
OCTET STRING
N/A
Unsigned32
1.3.6.1.4.1.25506.2.235.1.1.14 (hh3cPTPSourceStepsRemoved)
Information received on the port about steps removed from the grandmaster
N/A
Unsigned32
N/A
OCTET STRING
OCTET STRING
PTP instance ID.
N/A
Unsigned32
Recommended action
1.Execute the display ptp parent command to view master node information.
  - If master node information meets the requirements, no action is required.
  - If master node information meets the requirements, go to step 2.
2.Execute the display ptp interface command to identify whether the port is in faulty state.
  - If the port is in faulty state, a link failure is present or the port has gone down. You need to locate and resolve the port issue.
  - If the port is not in faulty state, go to step 3.
3.Execute the dis current-configuration interface and display ptp interface commands to check if commands have been configured to change the clock properties of the port.
  - If such commands have been configured, no action is required.
  - If such commands have not been configured, go to step 4.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.10
Clock source class fell below threshold.
Error
Minor
1.3.6.1.4.1.25506.2.235.1.0.11 (hh3cPTPSourceClockClassRecover)
ON
This notification is generated when the class of the clock source falls below the threshold in the following situations:
The device selects the local clock as the clock source, and the class of the local clock is below the threshold and the number of removed steps from the grandmaster clock to the local clock is 0.
The device selects the external clock source input from the ToD port as the clock source, and the class of the external clock is below the threshold.
System impact
The clock source class degrades.
Status control
Object
OID (object name)
Index
Value range
PTP instance ID.
N/A
Unsigned32
Recommended action
1.Execute the display ptp parent command to check if the grandmaster clock class is lower than the threshold.
  - If it is lower than the threshold, execute the ptp priority clock-source command on the clock source device to increase the clock class or specify another clock source with a higher class.
  - If it is higher than the threshold, go to step 2.
Basic information
OID
Event
Severity
Default status
Clock source class increased above the threshold.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the clock source class increases above the threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
PTP instance ID.
N/A
Unsigned32
Recommended action
hh3cPTPPacketLoss
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.12
PTP message lost
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.13 (hh3cPTPPacketLossRecover)
ON
This notification is generated when the PTP subordinate port fails to receive Announce, Delay_Resp, or Sync messages within the timeout timer.
System impact
The clock source might be changed if Announce message are not received in the timeout timer. PTP loss of lock might occur if Sync or Delay_Resp messages are not received in the timeout timer.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.15 (hh3cPTPPacketType)
PTP message type
No
INTEGER
sync(1),, pDelayResp(3),, delayResp(9),, announce(11)
PTP instance ID.
N/A
Unsigned32
Recommended action
1.Execute the display ptp statistics command on the PTP member device for which this notification is generated to identify whether the number of the received messages is increasing.
  - If the number is increasing, the timeout is caused by a long link delay. Locate the reason causing the long link delay.
  - If the number is not increasing, execute the display ptp statistics command on the master device to identify whether the number of sent messages is increasing.
If the number is increasing, a link failure caused the packet loss. You need to fix the issue to recover the link.
If the number is not increasing, go to step 2.
Basic information
OID
Event
Severity
Default status
PTP message loss issue removed.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP message loss issue is removed:
The subordinate port receives Announce or Delay_Resp messages after the timeout.
The device role changes from member device to master device after a long timeout.
System impact
Status control
Object
OID (object name)
Index
Value range
PTP message type.
N/A
INTEGER
PTP instance ID.
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.14
PTP absolute time offset exceeded the threshold.
Error
Minor
1.3.6.1.4.1.25506.2.235.1.0.15 (hh3cPTPTimeOffsetRecover)
ON
This notification is generated when the PTP source absolute time offset exceeds the threshold. The PTP source absolute time offset is the time difference between the external reference time and the PTP time.
System impact
The absolute time offset of the clock source is large and the clock accuracy is not high.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.16 (hh3cPTPTimeOffset)
No
Unsigned32
1.3.6.1.4.1.25506.2.235.1.1.17 (hh3cPTPTimeOffsetThreshold)
No
Unsigned32
Recommended action
1.Execute the ptp asymmetry-correction command to set the asymmetric delay correction time for the PTP time to be consistent with that of the external reference time. Then, check if an hh3cPTPTimeOffsetRecover notification is generated.
  - If an hh3cPTPTimeOffsetRecover notification is generated, the issue is resolved.
  - If the hh3cPTPTimeOffsetRecover notification is not generated, go to step 2.
Basic information
OID
Event
Severity
Default status
PTP standard time offset returned to the normal range.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP source absolute time offset returns to the normal range.
System impact
Status control
Object
OID (object name)
Index
Value range
No
Unsigned32
No
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.16
PTP time-offset-sum peak-to-peak value exceeded the threshold.
Error
Minor
1.3.6.1.4.1.25506.2.235.1.0.17 (hh3cPTPTimeOffsetSumRecover)
ON
This notification is generated when the PTP time-offset-sum peak-to-peak value exceeds the threshold.
System impact
The device might fail to get locked with the clock reference.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.18 (hh3cPTPTimeOffsetSum)
Nanosecond part of the PTP time-offset-sum peak-to-peak value.
No
Unsigned32
1.3.6.1.4.1.25506.2.235.1.1.19 (hh3cPTPTimeOffsetSumThrehold)
PTP time-offset-sum peak-to-peak threshold.
No
Unsigned32
1.3.6.1.4.1.25506.2.235.1.1.21 (hh3cPTPTimeOffsetSumSec)
Second part of the PTP time-offset-sum peak-to-peak value.
No
Unsigned32
Recommended action
1.Identify whether the PTP clock is in locked state.
  - If the PTP clock is in locked state, go to step 3.
  - If the PTP clock is not in locked state, go to step 2.
2.Wait for 15 minutes and then identify whether the PTP clock is in locked state.
  - If the PTP clock is not in locked state, go to step 4.
3.Wait for 15 minutes and then determine whether the issue is fixed (whether a PTP_TIMOFFSUM_RECOVER message is generated).
Basic information
OID
Event
Severity
Default status
PTP time-offset-sum peak-to-peak value returned to the normal range.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP time-offset-sum peak-to-peak value returns to the normal range.
System impact
Status control
Object
OID (object name)
Index
Value range
No
Unsigned32
No
Unsigned32
No
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.18
PTP clock frequency loss of lock
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.19 (hh3cPTPFrequencyLockRecover)
ON
This notification is generated when the PTP clock frequency loses lock with the clock reference.
In Ethernet frequency synchronization mode, the frequency offset of the reference source is too large.
In 1588v2 frequency synchronization mode, the timestamps are abnormal.
The output frequency offset of the system clock exceeds +/–10 ppm.
System impact
The device fails to synchronize the clock frequency with the clock reference.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.20 (hh3cPTPFreqLockStatus)
N/A
TruthValue
Recommended action
1.Identify whether an hh3cPTPFrequencyLockRecover notification is printed after this notification is printed.
  - If an hh3cPTPFrequencyLockRecover notification is printed, the device just started up or the PTP clock frequency flapped. No action is required.
  - If the hh3cPTPFrequencyLockRecover notification is not printed, go to step 2
2.Execute the display current-configuration | include ptp command to identify whether the PTP configuration has changed.
Basic information
OID
Event
Severity
Default status
PTP clock frequency returned to the locked state.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP clock frequency returns to the locked state.
System impact
Status control
Object
OID (object name)
Index
Value range
No
TruthValue
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.235.1.0.20
Error
Major
1.3.6.1.4.1.25506.2.235.1.0.21 (hh3cPTPPortAttrMismatchRecover)
ON
This notification is generated in the following situations:
Inconsistent delay measurement mechanisms at the two PTP ends.
Inconsistent encapsulation types at the two PTP ends.
Inconsistent domain numbers at the two PTP ends.
Inconsistent SourcePortID field values in the packets received on the PTP port.
System impact
PTP time tracking might fail.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.235.1.1.23 (hh3cPTPChassisID)
Chassis number.
N/A
Unsigned32
PTP port name.
N/A
OCTET STRING
OCTET STRING
1.3.6.1.4.1.25506.2.235.1.1.24 (hh3cPTPPortAttrMismatchReason)
Reasons for PTP attribute inconsistency between two ends.
N/A
Unsigned32
PTP instance ID.
N/A
Unsigned32
Recommended action
1.Execute the display ptp interface command to identify whether the two ends are consistent in the delay measurement mechanism.
  - If not consistent, modify the PTP configuration at the two ends to ensure that they are consistent in the delay measurement mechanism.
  - If consistent, go to step 2.
2.Execute the display ptp interface command to identify whether the two ends are consistent in the encapsulation type.
  - If not consistent, modify the PTP configuration at the two ends to ensure that they are consistent in the encapsulation type.
  - If consistent, go to step 3.
3.Execute the dis current-configuration | include ptp command to identify whether the two ends are in the same domain.
  - If they are not in the same domain, modify the PTP configuration to ensure that the two ends are in the same domain.
  - If they are in the same domain, go to step 4.
4.Identify whether a loop is present on the link, causing inconsistency of the value of the SourcePortId field in the received PTP packets.
  - If the value of SourcePortId field is inconsistent, fix the link issue.
  - If the value of SourcePortId field is inconsistent, go to step 5.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
PTP attribute inconsistency issue removed.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the PTP attribute inconsistency issue is removed.
System impact
Status control
Object
OID (object name)
Index
Value range
Chassis ID.
N/A
Unsigned32
PTP port name.
N/A
OCTET STRING
OCTET STRING
N/A
Unsigned32
PTP instance ID.
N/A
Unsigned32
Recommended action
