20-Network Management and Monitoring
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10020-Network Management and Monitoring
14-RMON2-MIB
14-RMON2-MIB 77.29 KB
RMON2-MIB
About this MIB
Use this MIB to monitor the data traffic on a network segment or the entire network. RMON2-MIB is an extended version of RMON to support multi-dimensional monitoring and statistics.
MIB file name
rfc4502-rmon2.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Scalar objects
probeCapabilities (1.3.6.1.2.1.16.19.1)
Object (OID)
Access
Value range
Implementation
read-only
BITS
BITS { etherStats(0), historyControl(1), etherHistory(2), alarm(3), hosts(4), hostTopN(5), matrix(6), filter(7), capture(8), event(9), tokenRingMLStats(10), tokenRingPStats(11), tokenRingMLHistory(12), tokenRingPHistory(13), ringStation(14), ringStationOrder(15), ringStationConfig(16), sourceRouting(17), protocolDirectory(18), protocolDistribution(19), addressMapping(20), nlHost(21), nlMatrix(22), alHost(23), alMatrix(24), usrHistory(25), probeConfig(26) }
An indication of the RMON MIB groups supported on a minimum of one interface by this probe.
As per the MIB.
probeSoftwareRev (1.3.6.1.2.1.16.19.2)
Object (OID)
Access
Value range
Implementation
read-only
OCTET STRING
OCTET STRING (0..15)
Software revision of this device.
As per the MIB.
probeHardwareRev (1.3.6.1.2.1.16.19.3)
Object (OID)
Access
Value range
Implementation
read-only
DisplayString
OCTET STRING (0..31)
Hardware revision of this device.
Not supported.
Tabular objects
usrHistoryControlTable
About this table
Use this table to configure user-defined history control entries.
Support for operations
CreateTo create a row of instances, you must specify usrHistoryControlIndex and usrHistoryControlStatus in pairs.
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is usrHistoryControlIndex.
Object (OID)
Access
Value range
Implementation
usrHistoryControlIndex (1.3.6.1.2.1.16.18.1.1.1)
not-accessible
Integer32
Integer32 (1..65535)
Index of a usrHistoryControl entry.
As per the MIB.
usrHistoryControlObjects (1.3.6.1.2.1.16.18.1.1.2)
read-create
Integer32
Number of MIB objects on which historical data is collected.
Value range: 1 to 30.
Default value: 1.
usrHistoryControlBucketsRequested (1.3.6.1.2.1.16.18.1.1.3)
read-create
Integer32
Requested number of samples to be retained for the entry.
A maximum of 50 samples are supported.
You can set a value larger than 50 for this object, but only 50 samples are supported.
usrHistoryControlBucketsGranted (1.3.6.1.2.1.16.18.1.1.4)
read-only
Integer32
Granted number of samples to be retained for the entry.
As per the MIB.
usrHistoryControlInterval (1.3.6.1.2.1.16.18.1.1.5)
read-create
Integer32
Integer32 (1..2147483647)
Sampling interval, in seconds.
Value range: 1 to 4294967.
usrHistoryControlOwner (1.3.6.1.2.1.16.18.1.1.6)
read-create
OwnerString
OCTET STRING (0..127)
Owner of the entry.
Not-displayable characters or question marks are not allowed.
Default: Zero-length string.
usrHistoryControlStatus (1.3.6.1.2.1.16.18.1.1.7)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of the entry.
Supports only createAndWait(5) after the entry is created.
usrHistoryObjectTable
About this table
Use this table to configure user-defined data-collection entries.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are usrHistoryControlIndex and usrHistoryObjectIndex.
Object (OID)
Access
Value range
Implementation
usrHistoryObjectIndex (1.3.6.1.2.1.16.18.2.1.1)
not-accessible
Integer32
Index of a usrHistoryObject entry.
As per the MIB.
usrHistoryObjectVariable (1.3.6.1.2.1.16.18.2.1.2)
read-create
OBJECT IDENTIFIER
Standard MIB values.
OID of the variable to be sampled.
As per the MIB.
usrHistoryObjectSampleType (1.3.6.1.2.1.16.18.2.1.3)
read-create
INTEGER
absoluteValue(1), deltaValue(2)
Method of sampling the selected variable for storage in the usrHistoryTable.
As per the MIB.
usrHistoryTable
About this table
Use this table to obtain information about history samples.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are usrHistoryControlIndex, usrHistorySampleIndex, and usrHistoryObjectIndex.
Object (OID)
Access
Value range
Implementation
usrHistorySampleIndex (1.3.6.1.2.1.16.18.3.1.1)
not-accessible
Integer32
Index of a sample of this entry.
As per the MIB.
usrHistoryIntervalStart (1.3.6.1.2.1.16.18.3.1.2)
read-only
TimeTicks
Standard MIB values
Sampling start time.
As per the MIB.
usrHistoryIntervalEnd (1.3.6.1.2.1.16.18.3.1.3)
read-only
TimeStamp
Standard MIB values
Sampling end time.
As per the MIB.
usrHistoryAbsValue (1.3.6.1.2.1.16.18.3.1.4)
read-only
Gauge32
Standard MIB values
Absolute value of the monitored object.
As per the MIB.
usrHistoryValStatus
(1.3.6.1.2.1.16.18.3.1.5)
read-only
INTEGER
valueNotAvailable(1), valuePositive(2), valueNegative(3)
Indicates the validity and sign of the data in the associated instance of usrHistoryAbsValue.
As per the MIB.
