- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
| 12-HH3C-TWAMP-MIB | 152.59 KB |
hh3cTwamplightSenderEnable (1.3.6.1.4.1.25506.2.184.2.1.2)
hh3cTwamplightRespondeEnable(1.3.6.1.4.1.25506.2.184.2.2.1)
hh3cTwamplightSenderAdminTable
hh3cTwamplightSenderStatusTable
hh3cTwamplightTwoWayDelayTable
hh3cTwamplightSenderLossSeqTable
hh3cTwamplightSendDelaySeqTable
hh3cTwampSenderSessionNumLimit
HH3C-TWAMP-MIB
About this MIB
● Use HH3C-TWAMP-MIB to implement NQA TWAMP Light as follows:
● Enable the TWAMP Light client and the TWAMP Light sender.
● Configure and obtain information about test sessions on the TWAMP Light client.
● Configure and obtain packet sending intervals, timeout time of the reflected packet, and statistics collection interval for TWAMP Light tests on the TWAMP Light sender.
● Obtain the TWAMP Light sender status.
● Obtain two-way delay and two-way jitter statistics for TWAMP Light tests on the TWAMP Light sender.
● Obtain two-way packet loss statistics for TWAMP Light tests on the TWAMP Light sender.
● Obtain the largest index value in TWAMP loss results and TWAMP delay results.
● Clear statistics about TWAMP Light tests.
● Enable the TWAMP Light responder.
● Configure and obtain information about test sessions on the TWAMP Light responder.
MIB file name
hh3c-twamp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTwamp(184)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderEnable (1.3.6.1.4.1.25506.2.184.2.1.2) |
read-write |
TruthValue |
Standard MIB values. |
Enabling status of the TWAMP Light sender. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightRespondeEnable(1.3.6.1.4.1.25506.2.184.2.2.1) |
read- write |
TruthValue |
Enabling status of the TWAMP Light responder. |
As per the MIB. |
Tabular objects
hh3cTwamplightClientTable
About this table
Use this table to configure and obtain information about test sessions on the TWAMP Light client.
Support for operations
Create:Supported
Edit/Modify:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cTwamplightControllerID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightControllerID(1.3.6.1.4.1.25506.2.184.2.1.3.1.1) |
accessible-for-notify |
Integer32 |
Integer32(1..512) |
Test session ID. |
Implementation varies by product. |
hh3cTwamplightClientSrcAddrType(1.3.6.1.4.1.25506.2.184.2.1.3.1.2) |
read-create |
InetAddressType |
Type of the source address. |
As per the MIB. |
hh3cTwamplightClientSrcAddr(1.3.6.1.4.1.25506.2.184.2.1.3.1.3) |
read-create |
InetAddress |
Source IP address. |
As per the MIB. |
hh3cTwamplightClientTrgtAddrType(1.3.6.1.4.1.25506.2.184.2.1.3.1.4) |
read-create |
InetAddressType |
Type of the destination IP address. |
As per the MIB. |
hh3cTwamplightClientTrgtAddr(1.3.6.1.4.1.25506.2.184.2.1.3.1.5) |
read-create |
InetAddress |
Destination IP address. |
As per the MIB. |
hh3cTwamplightClientSrcPort(1.3.6.1.4.1.25506.2.184.2.1.3.1.6) |
read-create |
Integer32 |
Integer32(0..65535) |
Source port number. |
As per the MIB. |
hh3cTwamplightClientTrgtPort(1.3.6.1.4.1.25506.2.184.2.1.3.1.7) |
read-create |
Integer32 |
Destination port number. |
As per the MIB. |
hh3cTwamplightClientVPN(1.3.6.1.4.1.25506.2.184.2.1.3.1.8) |
read-create |
DisplayString |
OCTET STRING(0..31) |
MPLS L3VPN instance name. |
As per the MIB. |
hh3cTwamplightClientDscp (1.3.6.1.4.1.25506.2.184.2.1.3.1.9) |
read-create |
Integer32 |
integer32(0..63) |
Differentiated services code point (DSCP) value. |
As per the MIB. |
hh3cTwamplightClientDataSize(1.3.6.1.4.1.25506.2.184.2.1.3.1.10) |
read-create |
Integer32 |
Integer32(44..1518) |
Probe packet size. |
As per the MIB. |
hh3cTwamplightClientDescription(1.3.6.1.4.1.25506.2.184.2.1.3.1.11) |
read-create |
DisplayString |
OCTET STRING(0..200) |
Description for the test session. |
As per the MIB. |
hh3cTwamplightClientRowStatus(1.3.6.1.4.1.25506.2.184.2.1.3.1.12) |
read-create |
RowStatus |
Manages the creation and deletion of the conceptual row. |
Supports only active(1), createAndGo(2), and destroy(6). |
hh3cTwamplightClientSrcIfName(1.3.6.1.4.1.25506.2.184.2.1.3.1.13) |
read-create |
DisplayString |
OCTET STRING(0..47) |
Source interface type and number. |
As per the MIB. |
hh3cTwamplightClientServiceID(1.3.6.1.4.1.25506.2.184.2.1.3.1.14) |
read-create |
Unsigned32 |
Unsigned32(1.. 4096) |
Ethernet service instance ID. |
As per the MIB. |
hh3cTwamplightClientDesMac(1.3.6.1.4.1.25506.2.184.2.1.3.1.15) |
read-create |
MacAddress |
Destination MAC address of the probe packets. |
As per the MIB. |
hh3cTwamplightClientSrcMac(1.3.6.1.4.1.25506.2.184.2.1.3.1.16) |
read-create |
MacAddress |
Source MAC address of the probe packets. |
As per the MIB. |
hh3cTwamplightClientTimeFormat(1.3.6.1.4.1.25506.2.184.2.1.3.1.17) |
read-create |
INTEGER |
ntp (1), ptp (2) |
Timestamp format of the probe packets. |
As per the MIB. |
hh3cTwamplightClientDataFill(1.3.6.1.4.1.25506.2.184.2.1.3.1.18) |
read-create |
DisplayString |
OCTET STRING(1..200) |
Payload fill string. |
As per the MIB. |
hh3cTwamplightClientDataFillType(1.3.6.1.4.1.25506.2.184.2.1.3.1.19) |
read-create |
INTEGER |
string (1), hex (2) |
Type of the payload fill string. |
As per the MIB. |
hh3cTwamplightClientSVlanID(1.3.6.1.4.1.25506.2.184.2.1.3.1.20) |
read-create |
Unsigned32 |
Unsigned32(1..4094) |
Outer VLAN ID of the probe packets. |
As per the MIB. |
hh3cTwamplightClientCVlanID(1.3.6.1.4.1.25506.2.184.2.1.3.1.21) |
read-create |
Unsigned32 |
Inner VLAN ID of the probe packets. |
As per the MIB. |
hh3cTwamplightClientVlanPriority(1.3.6.1.4.1.25506.2.184.2.1.3.1.22) |
read-create |
Unsigned32 |
Unsigned32(0..7) |
802.1p priority of the probe packets. |
As per the MIB. |
hh3cTwamplightClientBindIfName(1.3.6.1.4.1.25506.2.184.2.1.3.1.23) |
read-create |
DisplayString |
Name of the interface to which the session binds. |
As per the MIB. |
About this table
Use this table to configure and obtain information about TWAMP light tests.
Create:Supported
Delete:Supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSendAdminContinual(1.3.6.1.4.1.25506.2.184.2.1.4.1.1) |
read-create |
Integer32 |
TWAMP test type. |
As per the MIB. |
hh3cTwamplightSendAdminDuration(1.3.6.1.4.1.25506.2.184.2.1.4.1.2) |
read-create |
Integer32 |
Integer32(60..3600) |
TWAMP test duration. |
As per the MIB. |
hh3cTwamplightSendAdminPktCount (1.3.6.1.4.1.25506.2.184.2.1.4.1.3) |
read-create |
Integer32 |
Integer32(100..30000) |
Number of packets to send for the TWAMP test. |
As per the MIB. |
hh3cTwamplightSendAdminTxPeriod (1.3.6.1.4.1.25506.2.184.2.1.4.1.4) |
read-create |
INTEGER |
interval10ms(1), interval100ms(2), interval1s(3), interval30s(4), interval10s(5) |
Interval at which probe packets are sent for the TWAMP test. |
Supports only interval10ms(1), interval100ms(2), interval1s(3), interval30s(4), and interval10s(5). |
hh3cTwamplightSendAdminTimeOut (1.3.6.1.4.1.25506.2.184.2.1.4.1.5) |
read-create |
Integer32 |
Integer32(1..60) |
Timeout time for TWAMP response packets. |
hh3cTwamplightSendAdminRowStatus(1.3.6.1.4.1.25506.2.184.2.1.4.1.6) |
read-create |
RowStatus |
Supports only createAndGo(4) and destroy(6). |
About this table
Use this MIB to obtain the TWAMP Light sender status.
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderStatus(1.3.6.1.4.1.25506.2.184.2.1.5.1.1) |
read-only |
INTEGER |
inactive(1), active(2) |
Operational state of a TWAMP test. |
Supports only inactive(1) and active(2). |
hh3cTwamplightSenderStatusType(1.3.6.1.4.1.25506.2.184.2.1.5.1.2) |
read-only |
INTEGER |
init(0), continual(1), onDemand(2) |
Operational type of a TWAMP test. |
Supports only init(0), continual(1), and onDemand(2). |
hh3cTwamplightLastStartTime(1.3.6.1.4.1.25506.2.184.2.1.5.1.4) |
read-only |
DateAndTime |
Date and time when the most recent test started. |
As per the MIB. |
hh3cTwamplightLastStopTime(1.3.6.1.4.1.25506.2.184.2.1.5.1.5) |
read-only |
DateAndTime |
Date and time when the most recent test stopped. |
As per the MIB. |
About this table
Use this table to obtain statistics result about TWAMP Light tests.
Read:Supported
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightTWDelaySeq.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightTWDelaySeq(1.3.6.1.4.1.25506.2.184.2.1.6.1.1) |
read-only |
Gauge32 |
Sequence number. |
As per the MIB. |
hh3cTwamplightTWDelayAvgDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.2) |
read-only |
Integer32 |
Average delay. |
As per the MIB. |
hh3cTwamplightTWDelayMaxDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.3) |
read-only |
Integer32 |
Maximum delay. |
As per the MIB. |
hh3cTwamplightTWDelayMinDelay (1.3.6.1.4.1.25506.2.184.2.1.6.1.4) |
read-only |
Integer32 |
Minimum delay. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.5) |
read-only |
Integer32 |
Average jitter. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.6) |
read-only |
Integer32 |
Maximum jitter. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitter(1.3.6.1.4.1.25506.2.184.2.1.6.1.7) |
read-only |
Integer32 |
Minimum jitter. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.8) |
read-only |
Integer32 |
Average jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.9) |
read-only |
Integer32 |
Maximum jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitterSD (1.3.6.1.4.1.25506.2.184.2.1.6.1.10) |
read-only |
Integer32 |
Minimum jitter from source to destination. |
As per the MIB. |
hh3cTwamplightTWDelayAvgJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.11) |
read-only |
Integer32 |
Average jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTWDelayMaxJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.12) |
read-only |
Integer32 |
Maximum jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTWDelayMinJitterDS (1.3.6.1.4.1.25506.2.184.2.1.6.1.13) |
read-only |
Integer32 |
Minimum jitter from destination to source. |
As per the MIB. |
hh3cTwamplightTwoWayLossTable
About this table
Use this table to obtain packet loss statistics for TWAMP Light tests.
Read:Supported
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightTWLossSeq.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightTWLossSeq(1.3.6.1.4.1.25506.2.184.2.1.7.1.1) |
read-only |
Gauge32 |
Sequence number. |
As per the MIB. |
hh3cTwamplightTWLossValue(1.3.6.1.4.1.25506.2.184.2.1.7.1.2) |
read-only |
Integer32 |
Number of lost packets in a statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWSentCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.3) |
read-only |
Integer32 |
Number of sent packets in a statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWTotalLossValue(1.3.6.1.4.1.25506.2.184.2.1.7.1.4) |
read-only |
Integer32 |
Number of lost packets in the most recent 30 statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWTotalSentCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.5) |
read-only |
Integer32 |
Number of sent packets in the most recent 30 statistical cycle of a TWAMP test. |
As per the MIB. |
hh3cTwamplightTWErrorCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.6) |
read-only |
Unsigned32 |
Number of error packets received in a statistical cycle of a TWAMP-light test. |
As per the MIB. |
hh3cTwamplightTWTotalErrorCount(1.3.6.1.4.1.25506.2.184.2.1.7.1.7) |
read-only |
Unsigned32 |
Number of error packets received in last 30 statistical cycles of a TWAMP-light test. |
As per the MIB. |
About this table
Use this table to obtain the largest index value in TWAMP loss results.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightLossSeqNumValue(1.3.6.1.4.1.25506.2.184.2.1.8.1.1) |
read-only |
Gauge32 |
Largest index value in TWAMP loss results. |
As per the MIB. |
About this table
Use this table to obtain the largest index value in TWAMP delay results.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightSenderDelaySeqNum(1.3.6.1.4.1.25506.2.184.2.1.9.1.1) |
read-only |
Gauge32 |
Largest index value in TWAMP delay results. |
As per the MIB. |
hh3cTwamplightResetStatTable
About this table
Use this table to clear TWAMP Light test statistics.
Read:Not supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightResetStatistics(1.3.6.1.4.1.25506.2.184.2.1.10.1.1) |
read-create |
INTEGER |
single(1), all(2) |
Clears statistics for one or all TWAMP Light tests. |
Supports only set operations. Supports only single(1) and all(2). |
hh3cTwamplightReactionTable
About this table
Use this table to configure and obtain information about a reaction entry.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cTwamplightControllerID and hh3cTwamplightReactItemIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightReactItemIndex(1.3.6.1.4.1.25506.2.184.2.1.11.1.1) |
Unsigned32 |
Integer32(1..10) |
ID of a reaction entry |
As per the MIB. |
hh3cTwamplightReactCheckElement(1.3.6.1.4.1.25506.2.184.2.1.11.1.2) |
read-create |
INTEGER |
twoWayDelay(1), twoWayJitter(2), twoWayLoss(3) |
Monitored performance metric. |
As per the MIB. |
hh3cTwamplightReactUpperLimit(1.3.6.1.4.1.25506.2.184.2.1.11.1.3) |
read-create |
Unsigned32 |
Unsigned32(2..1000000) |
Lower threshold limit. |
As per the MIB. |
hh3cTwamplightReactLowerLimit (1.3.6.1.4.1.25506.2.184.2.1.11.1.4) |
read-create |
Integer32 |
Unsigned32(1..999999) |
Upper threshold limit. |
As per the MIB. |
hh3cTwamplightReactActionType(1.3.6.1.4.1.25506.2.184.2.1.11.1.5) |
read-create |
INTEGER |
none(0), trapOnly(1) |
Action for the threshold violation event. |
As per the MIB. |
hh3cTwamplightReactRowStatus(1.3.6.1.4.1.25506.2.184.2.1.11.1.6) |
read-create |
RowStatus |
Controls the creation and deletion of the conceptual row. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cTwamplightReactValue(1.3.6.1.4.1.25506.2.184.2.1.11.1.7) |
Unsigned32 |
Unsigned32(1..1000000) |
Threshold. |
As per the MIB. |
hh3cTwamplightResponderTable
About this table
Use this table to configure and obtain information about test sessions on the TWAMP Light responder.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cTwamplightRespID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cTwamplightRespID(1.3.6.1.4.1.25506.2.184.2.2.2.1.1) |
not-accessible |
Integer32 |
Integer32(1..512) |
Test session ID. |
hh3cTwamplightRespSrcAddrType(1.3.6.1.4.1.25506.2.184.2.2.2.1.2) |
read-create |
InetAddressType |
As per the MIB. |
hh3cTwamplightRespSrcAddr(1.3.6.1.4.1.25506.2.184.2.2.2.1.3) |
read-create |
InetAddress |
As per the MIB. |
hh3cTwamplightRespTrgtAddrType(1.3.6.1.4.1.25506.2.184.2.2.2.1.4) |
read-create |
Integer32 |
As per the MIB. |
hh3cTwamplightRespTrgtAddr(1.3.6.1.4.1.25506.2.184.2.2.2.1.5) |
read-create |
OCTET STRING |
As per the MIB. |
hh3cTwamplightRespSrcPort(1.3.6.1.4.1.25506.2.184.2.2.2.1.6) |
read-create |
Integer32 |
Integer32(1..65535) |
As per the MIB. |
hh3cTwamplightRespTrgtPort(1.3.6.1.4.1.25506.2.184.2.2.2.1.7) |
read-create |
Integer32 |
As per the MIB. |
hh3cTwamplightRespVPN(1.3.6.1.4.1.25506.2.184.2.2.2.1.8) |
read-create |
DisplayString |
OCTET STRING(1..31) |
As per the MIB. |
hh3cTwamplightRespDescription(1.3.6.1.4.1.25506.2.184.2.2.2.1.9) |
read-create |
DisplayString |
Description about the test session. |
As per the MIB. |
hh3cTwamplightRespRowStatus(1.3.6.1.4.1.25506.2.184.2.2.2.1.10) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
hh3cTwamplightRespSrcIfName(1.3.6.1.4.1.25506.2.184.2.2.2.1.11) |
read-create |
DisplayString |
Source interface of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespServiceID(1.3.6.1.4.1.25506.2.184.2.2.2.1.12) |
read-create |
Unsigned32 |
Unsigned32(1..4096) |
Ethernet service instance ID for the session. |
As per the MIB. |
hh3cTwamplightRespDesMac(1.3.6.1.4.1.25506.2.184.2.2.2.1.13) |
read-create |
MacAddress |
Destination MAC address of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespSrcMac(1.3.6.1.4.1.25506.2.184.2.2.2.1.14) |
read-create |
MacAddress |
Source MAC address of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespTimeFormat(1.3.6.1.4.1.25506.2.184.2.2.2.1.15) |
read-create |
INTEGER |
auto(0) ntp(1) ptp(2) |
Timestamp format of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespSVlanID(1.3.6.1.4.1.25506.2.184.2.2.2.1.16) |
read-create |
Unsigned32 |
Outer VLAN ID of the reflected packets. |
As per the MIB. |
hh3cTwamplightRespCVlanID(1.3.6.1.4.1.25506.2.184.2.2.2.1.17) |
read-create |
Unsigned32 |
Inner VLAN ID of the reflected packets. |
As per the MIB. |
Notifications
hh3cTwampTwoWayLossExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.1 |
The two-way packet loss ratio exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.2 (hh3cTwampTwoWayLossRecover) |
OFF |
Notification triggers
This notification is generated when the two-way packet loss ratio exceeds the upper threshold in the TWAMP test. Possible causes might include the following:
Cause 1: Network congestion due to abnormal traffic.
Cause 2: Unstable link state.
System impact
The packet loss rate is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the undo reaction item-number command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.184.2.1.3.1.1 (hh3cTwamplightControllerID) |
Session ID. |
hh3cTwamplightControllerID hh3cTwamplightReactItemIndex |
Integer32 |
Integer32(1..512) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.1 (hh3cTwamplightReactItemIndex) |
Threshold alarm group ID. |
Unsigned32 |
Integer32(1..10) |
1.3.6.1.4.1.25506.2.184.2.1.11.1.7 (hh3cTwamplightReactValue) |
Threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.2.184.2.1.11.1.3 (hh3cTwamplightReactUpperLimit) |
Upper threshold. |
Unsigned32 |
1.3.6.1.4.1.25506.2.184.2.1.11.1.4 (hh3cTwamplightReactLowerLimit) |
Lower threshold. |
Integer32 |
Recommended action
To resolve this issue:
1.Identify whether abnormal traffic exists in the network during the alarm time.
2.Identify whether the link state is stable in the network during the alarm time, and troubleshoot link instability issues.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.2 |
The two-way packet loss ratio drops below the lower threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the two-way packet loss ratio drops below the lower threshold in the TWAMP test.
System impact
No negative impact on services.
Status control
ON
OFF
CLI: Use the reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold action-type trap-only none command.
Object
OID (object name) |
Index |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Integer32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Integer32 |
Recommended action
No action is required.
hh3cTwampTwoWayDelayExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.3 |
The two-way delay exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.4 (hh3cTwampTwoWayDelayRecover) |
OFF |
This notification is generated when the two-way delay exceeds the upper threshold in the TWAMP test.
System impact
The delay is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-delay threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Integer32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.4 |
The two-way delay drops below the lower threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the two-way delay drops below the lower threshold in the TWAMP test.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Integer32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Integer32 |
Recommended action
hh3cTwampTwoWayJitterExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.5 |
The two-way jitter exceeds the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.184.1.0.6 (hh3cTwampTwoWayJitterRecover) |
OFF |
This notification is generated when the two-way jitter exceeds the upper threshold in the TWAMP test.
System impact
The jitter is too high and might not meet the service requirements. Services are affected.
Status control
ON
CLI: Use the reaction item-number checked-element two-way-jitter threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Integer32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.6 |
The two-way jitter drops below the lower threshold. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the two-way jitter drops below the lower threshold in the TWAMP test.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Session ID. |
Integer32 |
Integer32(1..512) |
Unsigned32 |
Integer32(1..10) |
Threshold. |
Unsigned32 |
Upper threshold. |
Unsigned32 |
Lower threshold. |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.184.1.0.7 |
The number of TAWMP test sessions reaches the upper limit. |
Informational |
Major |
N/A (N/A) |
OFF |
This notification is generated when the number of TAWMP test sessions reaches the upper limit.
System impact
The TAWMP test sessions that exceed the system capacity cannot operate correctly.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
N/A (N/A) |
N/A |
N/A |
N/A |
N/A |
Recommended action
1.Execute the display nqa twamp-light client verbose command to check for inactive sessions.
- If inactive sessions exist, delete the sessions.
- If no inactive sessions exist, as a best practice, arrange services appropriately.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
