- 20-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-HTTP-MIB
- 04-HH3C-INQA-MIB
- 05-HH3C-MIRRORGROUP-MIB
- 06-HH3C-NETCONF-MIB
- 07-HH3C-NQA-MIB
- 08-HH3C-NTP-MIB
- 09-HH3C-PTP-MIB
- 10-HH3C-RMON-EXT2-MIB
- 11-HH3C-SNMP-EXT-MIB
- 12-HH3C-TWAMP-MIB
- 13-RMON-MIB
- 14-RMON2-MIB
- 15-SNMP-FRAMEWORK-MIB
- 16-SNMP-MPD-MIB
- 17-SNMP-NOTIFICATION-MIB
- 18-SNMP-TARGET-MIB
- 19-SNMP-USER-BASED-SM-MIB
- 20-SNMP-VIEW-BASED-ACM-MIB
- 21-SNMPv2-MIB
| 13-RMON-MIB | 106.38 KB |
RMON-MIB
About this MIB
Use this MIB to monitor data traffic on a network segment or the entire network.
MIB file name
rfc2819-rmon.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rmon(16)
Tabular objects
etherStatsTable
About this table
Use this table to obtain statistics about Ethernet interfaces.
Support for operations
Create:You must specify etherStatsDataSource and etherStatsStatus in pairs when creating a row of instances.
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is etherStatsIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
etherStatsIndex (1.3.6.1.2.1.16.1.1.1.1) |
read-only |
Integer32 |
Integer32 (1..65535) |
Index of an etherStats entry. |
As per the MIB. |
etherStatsDataSource (1.3.6.1.2.1.16.1.1.1.2) |
read-create |
OBJECT IDENTIFIER |
Standard MIB values. |
Interface on which statistics are gathered. |
As per the MIB. |
etherStatsDropEvents (1.3.6.1.2.1.16.1.1.1.3) |
read-only |
Counter32 |
Total number of events in which packets were dropped. |
Implementation varies by product.. |
etherStatsOctets (1.3.6.1.2.1.16.1.1.1.4) |
read-only |
Counter32 |
Total number of octets received on the interface. |
Implementation varies by product. |
etherStatsPkts (1.3.6.1.2.1.16.1.1.1.5) |
read-only |
Counter32 |
Total number of packets received on the interface. |
etherStatsBroadcastPkts (1.3.6.1.2.1.16.1.1.1.6) |
read-only |
Counter32 |
Total number of broadcast packets received on the interface. |
etherStatsMulticastPkts (1.3.6.1.2.1.16.1.1.1.7) |
read-only |
Counter32 |
Total number of multicast packets received on the interface. |
etherStatsCRCAlignErrors (1.3.6.1.2.1.16.1.1.1.8) |
read-only |
Counter32 |
Total number of packets with CRC errors received on the interface. |
etherStatsUndersizePkts (1.3.6.1.2.1.16.1.1.1.9) |
read-only |
Counter32 |
Total number of undersize packets received on the interface. |
etherStatsOversizePkts (1.3.6.1.2.1.16.1.1.1.10) |
read-only |
Counter32 |
Total number of oversize packets received on the interface. |
etherStatsFragments (1.3.6.1.2.1.16.1.1.1.11) |
read-only |
Counter32 |
Total number of undersize packets with FCS errors received on the interface. |
etherStatsJabbers (1.3.6.1.2.1.16.1.1.1.12) |
read-only |
Counter32 |
Total number of oversize packets with FCS errors received on the interface. |
etherStatsCollisions (1.3.6.1.2.1.16.1.1.1.13) |
read-only |
Counter32 |
Total number of colliding packets received on the interface. |
etherStatsPkts64Octets (1.3.6.1.2.1.16.1.1.1.14) |
read-only |
Counter32 |
Total number of packets with a length smaller than or equal to 64 octets received on the interface |
etherStatsPkts65to127Octets (1.3.6.1.2.1.16.1.1.1.15) |
read-only |
Counter32 |
Total number of 65- to 127-octet packets received on the interface. |
etherStatsPkts128to255Octets (1.3.6.1.2.1.16.1.1.1.16) |
read-only |
Counter32 |
Total number of 128- to 255-octet packets received on the interface |
etherStatsPkts256to511Octets (1.3.6.1.2.1.16.1.1.1.17) |
read-only |
Counter32 |
Total number of 256- to 511-octet packets received on the interface. |
etherStatsPkts512to1023Octets (1.3.6.1.2.1.16.1.1.1.18) |
read-only |
Counter32 |
Total number of 512- to 1023-octet packets received on the interface |
etherStatsPkts1024to1518Octets (1.3.6.1.2.1.16.1.1.1.19) |
read-only |
Counter32 |
Total number of 1024- to 1518-octet packets received on the interface |
etherStatsOwner (1.3.6.1.2.1.16.1.1.1.20) |
read-create |
OwnerString |
OCTET STRING (0..127) |
Owner of the etherStats entry. |
Not-displayable characters or question marks are not allowed. The default value is a zero-length string. |
etherStatsStatus (1.3.6.1.2.1.16.1.1.1.21) |
read-create |
EntryStatus |
valid(1), |
Status of the etherStats entry. |
As per the MIB. |
historyControlTable
About this table
Use this table to configure history control entries.
Create:You must specify historyControlDataSource and historyControlStatus in pairs when creating an instance.
Delete:Supported
Read:Supported
Columns
The table index is historyControlIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
historyControlIndex (1.3.6.1.2.1.16.2.1.1.1) |
read-only |
Integer32 |
Index of a historyControl entry. |
As per the MIB. |
historyControlDataSource (1.3.6.1.2.1.16.2.1.1.2) |
read-create |
OBJECT IDENTIFIER |
Interface on which historical data was collected. |
As per the MIB. |
historyControlBucketsRequested (1.3.6.1.2.1.16.2.1.1.3) |
read-create |
Integer32 |
Requested number of samples to be retained for the entry. |
A maximum of 50 samples are supported. You can set a value larger than 50 for this object, but only 50 samples are supported. |
historyControlBucketsGranted (1.3.6.1.2.1.16.2.1.1.4) |
read-only |
Integer32 |
Granted number of samples to be retained for the entry. |
As per the MIB. |
historyControlInterval (1.3.6.1.2.1.16.2.1.1.5) |
read-create |
Integer32 |
Integer32 (1..3600) |
Sampling interval in seconds. |
Value range: 5 to 3600 Default: 1800 |
historyControlOwner (1.3.6.1.2.1.16.2.1.1.6) |
read-create |
OwnerString |
Owner of this entry. |
historyControlStatus (1.3.6.1.2.1.16.2.1.1.7) |
read-create |
EntryStatus |
valid(1), |
Statistics about this entry. |
As per the MIB. |
etherHistoryTable
About this table
Use this table to obtain information about RMON history control entries and history samples of Ethernet statistics for Ethernet interfaces.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are etherHistoryIndex and etherHistorySampleIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
etherHistoryIndex (1.3.6.1.2.1.16.2.2.1.1) |
read-only |
Integer32 |
Index of an etherHistory entry. |
As per the MIB. |
etherHistorySampleIndex (1.3.6.1.2.1.16.2.2.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Index of a sample. |
As per the MIB. |
etherHistoryIntervalStart (1.3.6.1.2.1.16.2.2.1.3) |
read-only |
TimeTicks |
Sampling start time. |
As per the MIB. |
etherHistoryDropEvents (1.3.6.1.2.1.16.2.2.1.4) |
read-only |
Counter32 |
Total number of events in which packets were dropped during this sampling interval. |
etherHistoryOctets (1.3.6.1.2.1.16.2.2.1.5) |
read-only |
Counter32 |
Total number of octets received on the interface during this sampling interval. |
etherHistoryPkts (1.3.6.1.2.1.16.2.2.1.6) |
read-only |
Counter32 |
Total number of packets received during this sampling interval. |
etherHistoryBroadcastPkts (1.3.6.1.2.1.16.2.2.1.7) |
read-only |
Counter32 |
Total number of broadcast packets received during this sampling interval. |
etherHistoryMulticastPkts (1.3.6.1.2.1.16.2.2.1.8) |
read-only |
Counter32 |
Total number of multicast packets received during this sampling interval. |
etherHistoryCRCAlignErrors (1.3.6.1.2.1.16.2.2.1.9) |
read-only |
Counter32 |
Total number of packets with CRC alignment errors received during the sampling interval. |
etherHistoryUndersizePkts (1.3.6.1.2.1.16.2.2.1.10) |
read-only |
Counter32 |
Total number of undersize packets received during the sampling interval. |
etherHistoryOversizePkts (1.3.6.1.2.1.16.2.2.1.11) |
read-only |
Counter32 |
Total number of oversize packets received during the sampling interval. |
etherHistoryFragments (1.3.6.1.2.1.16.2.2.1.12) |
read-only |
Counter32 |
Total number of undersize packets with FCS errors received during the sampling interval. |
etherHistoryJabbers (1.3.6.1.2.1.16.2.2.1.13) |
read-only |
Counter32 |
Total number of oversize packets with FCS errors received during the sampling interval. |
etherHistoryCollisions (1.3.6.1.2.1.16.2.2.1.14) |
read-only |
Counter32 |
Total number of colliding packets received during the sampling interval. |
etherHistoryUtilization (1.3.6.1.2.1.16.2.2.1.15) |
read-only |
Integer32 |
Integer32 (0..10000) |
Bandwidth utilization during the sampling period. |
alarmTable
About this table
Use this table to configure alarm entries.
Create:You must specify alarmVariable and alarmStatus in pairs when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails.
Delete:Supported
Read:Supported
Columns
The table index is alarmIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
alarmIndex (1.3.6.1.2.1.16.3.1.1.1) |
read-only |
Integer32 |
Index of an RMON alarm entry. |
As per the MIB. |
alarmInterval (1.3.6.1.2.1.16.3.1.1.2) |
read-create |
Integer32 |
Value range: 5 to 3600. Default value: 1800. |
alarmVariable (1.3.6.1.2.1.16.3.1.1.3) |
read-create |
OBJECT IDENTIFIER |
OID of the variable to be sampled. |
As per the MIB. |
alarmSampleType (1.3.6.1.2.1.16.3.1.1.4) |
read-create |
INTEGER |
absoluteValue(1), |
Sampling type. |
Default value: absoluteValue(1). |
alarmValue (1.3.6.1.2.1.16.3.1.1.5) |
read-only |
Integer32 |
Value of the sampled variable. |
If the object value exceeds the maximum positive value, the negation of the object value is returned when read. |
alarmStartupAlarm (1.3.6.1.2.1.16.3.1.1.6) |
read-create |
INTEGER |
risingAlarm(1), |
Alarms that can be generated at the first sampling. |
Default value: risingOrFallingAlarm(3). |
alarmRisingThreshold (1.3.6.1.2.1.16.3.1.1.7) |
read-create |
Integer32 |
Rising threshold. |
Default value: 1. |
alarmFallingThreshold (1.3.6.1.2.1.16.3.1.1.8) |
read-create |
Integer32 |
Falling threshold. |
Default value: 0. |
alarmRisingEventIndex (1.3.6.1.2.1.16.3.1.1.9) |
read-create |
Integer32 |
Integer32 (0..65535) |
Index of the event that is triggered when the rising threshold is crossed. |
Default value: 0. |
alarmFallingEventIndex (1.3.6.1.2.1.16.3.1.1.10) |
read-create |
Integer32 |
Index of the event that is triggered when the falling threshold is crossed. |
Default value: 0. |
alarmOwner (1.3.6.1.2.1.16.3.1.1.11) |
read-create |
OwnerString |
Owner of the alarm entry. |
Not-displayable characters or question marks are not allowed. Default value: zero-length string. |
alarmStatus (1.3.6.1.2.1.16.3.1.1.12) |
read-create |
EntryStatus |
valid(1), createRequest(2), underCreation(3), invalid(4) |
Status of the alarm entry. |
As per the MIB. |
eventTable
About this table
Use this table to configure event entries.
Create:Supported.
You must specify eventStatus when creating a row of instances. If the buildruns of the instances exceed the maximum specification, the creation fails.
Delete:Supported
Read:Supported
Columns
The table index is eventIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
eventIndex (1.3.6.1.2.1.16.9.1.1.1) |
read-only |
Integer32 |
Event entry index. |
As per the MIB. |
eventDescription (1.3.6.1.2.1.16.9.1.1.2) |
read-create |
DisplayString |
Event description. |
Default value: Zero-length string. |
eventType (1.3.6.1.2.1.16.9.1.1.3) |
read-create |
INTEGER |
none(1), log(2), snmptrap(3), logandtrap(4) |
Event type. |
Default value: none(1) |
eventCommunity (1.3.6.1.2.1.16.9.1.1.4) |
read-create |
OCTET STRING |
SNMP community to which an SNMP trap is sent. |
Not supported. |
eventLastTimeSent (1.3.6.1.2.1.16.9.1.1.5) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Time at which the most recent event occurs. |
As per the MIB. |
eventOwner (1.3.6.1.2.1.16.9.1.1.6) |
read-create |
OwnerString |
Event owner. |
Not-displayable characters or question marks are not allowed. Default value: Zero-length string. |
eventStatus (1.3.6.1.2.1.16.9.1.1.7) |
read-create |
EntryStatus |
Event status. |
As per the MIB. |
logTable
About this table
Use this table to obtain event logs.
Read:Supported
Columns
The table indexes are logEventIndex and logIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
logEventIndex (1.3.6.1.2.1.16.9.2.1.1) |
read-only |
Integer32 |
Index of the event entry that generated this log entry. |
As per the MIB. |
logIndex (1.3.6.1.2.1.16.9.2.1.2) |
read-only |
Integer32 |
Index of the log entry. |
As per the MIB. |
logTime (1.3.6.1.2.1.16.9.2.1.3) |
read-only |
TimeTicks |
Time when the log entry was created. |
As per the MIB. |
logDescription (1.3.6.1.2.1.16.9.2.1.4) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Description of the event that activated this log entry. |
As per the MIB. |
Notifications
risingAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.16.0.1 |
A variable of an alarm entry crossed its rising threshold. |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a variable of an alarm entry crosses its rising threshold and the triggered event is to send SNMP notifications.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the rmon event entry-number [ description string ] { log-trap security-string | trap security-string } [ owner text ] command.
OFF
CLI: Use the rmon event entry-number [ description string ] { log | none } [ owner text ] command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.16.3.1.1.1 (alarmIndex) |
Index of the alarm entry |
alarmIndex |
Integer32 |
1..65535 |
1.3.6.1.2.1.16.3.1.1.3 (alarmVariable) |
Variable to be sampled |
alarmIndex |
OBJECT IDENTIFIER |
1.3.6.1.2.1.16.3.1.1.4 (alarmSampleType) |
Sampling type |
alarmIndex |
INTEGER |
absoluteValue(1), deltaValue(2) |
1.3.6.1.2.1.16.3.1.1.5 (alarmValue) |
Sampled value |
alarmIndex |
Integer32 |
1.3.6.1.2.1.16.3.1.1.7 (alarmRisingThreshold) |
Rising threshold |
alarmIndex |
Integer32 |
Recommended action
To resolve the issue:
1.Execute the display rmon alarm command in any view to check information about the monitored variable and rising threshold. Locate and remove the reason causing the notification.
If the rising threshold is inappropriate, execute the rmon alarm command in system view to change the rising threshold.
2.If the issue persists, collect alarm information and configuration data and then contact H3C Support for help.
fallingAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.16.0.2 |
A variable of an alarm entry fell to or below its falling threshold. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a variable of an alarm entry falls to or below its falling threshold and the triggered event is to send SNMP notifications.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
alarmIndex |
Integer32 |
1..65535 |
alarmIndex |
OBJECT IDENTIFIER |
Sampling type |
alarmIndex |
INTEGER |
Sampled value |
alarmIndex |
Integer32 |
1.3.6.1.2.1.16.3.1.1.8 (alarmFallingThreshold) |
Falling threshold |
alarmIndex |
Integer32 |
Recommended action
1.Execute the display rmon alarm command in any view to check information about the monitored variable and falling threshold. Locate and remove the reason causing the notification.
If the falling threshold is inappropriate, execute the rmon alarm command in system view to change the falling threshold.
