09-Layer 3 - IP Routing
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10009-Layer 3 - IP Routing
12-OSPF-TRAP-MIB
12-OSPF-TRAP-MIB 184.95 KB
OSPF-TRAP-MIB
About this MIB
Use this MIB to set, edit, and view OSPF protocol and notification information about network devices.
MIB file name
rfc4750-ospf-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ospf(14)
Scalar objects
ospfSetTrap (1.3.6.1.2.1.14.16.1.1)
Object (OID)
Access
Value range
Implementation
read-write
OCTET STRING
OCTET STRING (4)
Whether OSPF notification is enabled.
As per the MIB.
ospfConfigErrorType (1.3.6.1.2.1.14.16.1.2)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
badVersion (1), areaMismatch (2), unknownNbmaNbr (3), unknownVirtualNbr (4),       authTypeMismatch(5),        authFailure (6),        netMaskMismatch (7),       helloIntervalMismatch (8), deadIntervalMismatch (9),       optionMismatch (10),        mtuMismatch (11),       duplicateRouterId (12),        noError (13)
Possible configuration error type.
As per the MIB.
ospfPacketType (1.3.6.1.2.1.14.16.1.3)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
hello (1),       dbDescript (2),        lsReq (3),        lsUpdate (4),       lsAck (5),       nullPacket (6)
OSPF packet type.
As per the MIB.
ospfPacketSrc (1.3.6.1.2.1.14.16.1.4)
Object (OID)
Access
Value range
Implementation
read-only
IpAddress
OCTET STRING (4)
IP address that cannot be identified by a neighbor.
As per the MIB.
Notifications
ospfVirtIfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.14.16.2.1
Virtual interface state changes.
Informational
Informational
N/A (N/A)
ON
Notification triggers
This notification is generated when the state of a virtual interface changes. This issue occurs when one of the following conditions exists:
The state of a virtual interface changes from P2P to Down, or from Down to P2P.
The router ID of a virtual link neighbor changes.
System impact
If the state of a virtual interface changes from Down to P2P, it has no negative impact on services.
If the state of a virtual interface changes from P2P to Down, the virtual interface will be disconnected and OSPF route calculation will fail. Services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtif-state-change command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.14.1.1 (ospfRouterId)
Unique identifier of a router in an AS.
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.9.1.1 (ospfVirtIfAreaId)
ID of the area to which the virtual link belongs.
ospfVirtIfAreaId
ospfVirtIfNeighbor
AreaID
IpAddress
1.3.6.1.2.1.14.9.1.2 (ospfVirtIfNeighbor)
Router ID of the virtual neighbor.
ospfVirtIfAreaId
ospfVirtIfNeighbor
RouterID
IpAddress
1.3.6.1.2.1.14.9.1.7 (ospfVirtIfState)
Virtual interface state.
ospfVirtIfAreaId
ospfVirtIfNeighbor
INTEGER
down (1), pointToPoint (4)
Recommended action
To resolve this issue:
1.Use the display ospf vlink command to view the state of the virtual interface.
  - If the state of the virtual interface changes from Down to P2P, no action is required.
  - If the state of the virtual interface changes from P2P to Down, proceed to step 2.
2.Use the display ospf spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. The flag indicates that the neighbor is reachable.
  - If yes, check whether the virtual interface settings are configured correctly on both the local end and the remote end.
  - If no, check for the cause of the unreachability.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.2
Neighbor state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the state of a neighbor changes. This issue occurs when one of the following conditions exists:
The state of a neighbor changes from Attempt or any other state to 1-Way or Down, or from Down or any other state to 2-Way or Full.
The local and remote ends have different interface settings (such as the hello timer, dead timer, and authentication settings).
OSPF is restarted by the reset ospf process command.
The state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full.
System impact
The process of OSPF neighbor establishment involves a series of neighbor state changes, including Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, and Full.
If the state of a neighbor progresses, it has no negative impact on services.
If the state of a neighbor regresses, services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospf neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf neighbor-state-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.1 (ospfNbrIpAddr)
IP address of the neighbor.
ospfNbrIpAddr
ospfNbrAddressLessIndex
IpAddress
Standard MIB values.
1.3.6.1.2.1.14.10.1.2 (ospfNbrAddressLessIndex)
Set to 0 on an interface having an IP address, and set to the value of interface index in the Internet Standard MIB on an interface having no IP address.
ospfNbrIpAddr
InterfaceIndexOrZero
Integer32 (0..2147483647)
1.3.6.1.2.1.14.10.1.3 (ospfNbrRtrId)
Router ID of the neighbor.
ospfNbrIpAddr
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.6 (ospfNbrState)
Neighbor state.
ospfNbrIpAddr
INTEGER
down (1), attempt (2), init (3), twoWay (4), exchangeStart (5), exchange (6), loading (7), full (8)
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name
ifIndex
DisplayString
OCTET STRING (0..255)
Recommended action
1.Use the display ospf peer command to view the state of the neighbor. You can view the State field in the command output.
  - If the neighbor state is Full, no action is required.
  - If the neighbor state is not Full, proceed to step 2.
2.Use the display interface interface-type interface-number command to view the state of the neighbor-facing interface on the local end.
  - If the interface is up, proceed to step 3.
  - If the neighbor interface is down, check whether the shutdown command is executed on the interface.
If yes, execute the undo shutdown command on the interface, and then proceed to step 3.
If no, proceed to step 3.
3.Use the ping command to identify whether the IP address of the remote interface is reachable.
  - If yes, proceed to step 4.
  - If no, proceed to step 6.
4.Use the display ospf interface command to view the state of the OSPF interface. You can view the State field in the command output.
  - If the neighbor-facing interface is down, proceed to step 6.
  - If the neighbor-facing interface is not down, proceed to step 5.
5.Use the display ospf interface verbose command to check whether the local and remote ends use the same interface settings, including the hello timer, dead timer, poll timer, OSPFv3 network type, and authentication settings.
  - If yes, proceed to step 6.
  - If no, use the following commands to modify inconsistent interface settings and make sure that the local and remote ends use the same interface settings.
ospf timer hello
ospf timer dead
ospf timer poll
ospf network-type
ospf authentication-mode
6.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfVirtNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.3
Virtual neighbor state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the state of a virtual neighbor changes. This issue occurs when one of the following conditions exists:
The state of a virtual neighbor regresses (for example, changing from Attempt or Full to 1-Way or Down) or progresses to the final state (for example, Full).
The state of the physical interface on which the virtual link is established changes.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtneighbor-state-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.1 (ospfVirtNbrArea)
ID of the area to which the virtual neighbor belongs.
ospfVirtNbrArea
ospfVirtNbrRtrId
AreaID
IpAddress
1.3.6.1.2.1.14.11.1.2 (ospfVirtNbrRtrId)
A 32-bit integer that uniquely identifies the neighboring router in the AS.
ospfVirtNbrArea
ospfVirtNbrRtrId
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.5 (ospfVirtNbrState)
Neighbor state.
ospfVirtNbrArea
ospfVirtNbrRtrId
INTEGER
Recommended action
1.Use the display ospf interface and display ip interface brief commands to view the state of the physical interface on which the virtual link is established.
  - If the physical state of the interface is down, check whether the interface has been shut down.
If yes, execute the undo shutdown command on the interface, and then proceed to step 2.
If no, proceed to step 2.
  - If the link layer protocol state of the interface is down, check whether the interface has been configured with an IP address.
If yes, proceed to step 2.
If no, use the ip address command to configure an IP address for the interface.
2.Use the display ospf peer command to view the state of the neighbor.
  - If the State field displays Full, proceed to step 3.
  - If the State field does not display Full, proceed to step 5.
3.Use the display ospf spf-tree command to whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
  - If no, proceed to step 5.
4.Use the display ospf vlink and display current-configuration configuration ospf commands to identify whether the local and remote ends use the same settings, such as the hello timer, dead timer, and poll timer.
  - If yes, proceed to step 5.
  - If no, use the vlink-peer command to configure the same settings for both the local and remote ends, and then check whether the notification is cleared.
If yes, the troubleshooting is complete.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.4
Interface configuration error.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents an adjacency from establishing.
The local interface and the remote interface use different interface settings.
On a broadcast or NBMA network, the IP addresses of the local interface and the remote interface use different masks.
MTU check is enabled and the MTUs of the local interface and the remote interface are different.
A router ID conflict exists.
System impact
This issue typically has no impact on services as long as you reconfigure the local interface and the remote interface correctly.
Status control
ON
CLI: Use the snmp-agent trap enable ospf config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf config-error command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.7.1.1 (ospfIfIpAddress)
IP address of the interface.
ospfIfIpAddress
ospfAddressLessIf
IpAddress
1.3.6.1.2.1.14.7.1.2 (ospfAddressLessIf)
Used to distinguish interface instances with addresses configured and those without addresses configured.
ospfIfIpAddress
ospfAddressLessIf
1.3.6.1.2.1.14.16.1.4 (ospfPacketSrc)
N/A
IpAddress
1.3.6.1.2.1.14.16.1.2 (ospfConfigErrorType)
Configuration error type.
N/A
INTEGER
1.3.6.1.2.1.14.16.1.3 (ospfPacketType)
OSPF packet type.
N/A
INTEGER
Recommended action
1.Use the display ospf interface interface-type interface-number command to identify whether the local OSPF interface and the remote OSPF interface use the same settings.
  - If yes, proceed to step 3.
  - If no, proceed to step 2.
2.Perform the following tasks to clear the notification:
Use the following commands to reconfigure the local or remote OSPFv3 interface, ensuring that the two interfaces use the same settings:
ospf timer hello
ospf timer dead
ospf timer poll
Identify whether the notification is cleared:
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfVirtIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.5
Virtual interface configuration error.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an OSPF virtual interface on a router receives a packet from another router with mismatched configuration. The optionMismatch event causes a notification only if it prevents establishment of an adjacency.
This issue occurs when the interface settings on the ends of a virtual link are not the same.
System impact
This issue typically has no negative impact on services as long as the local interface and the remote interface use the same settings after configuration correction.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-config-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-config-error command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
AreaID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
RouterID
IpAddress
N/A
INTEGER
OSPF packet type.
N/A
INTEGER
Recommended action
1.Use the display ospf vlink and display current-configuration configuration ospf commands to identify whether the two ends of the virtual link use the same interface settings.
2.Use the vlink-peer command to reconfigure an end of the virtual link, ensuring that the two ends of the virtual link use the same settings. Then, identify whether the notification is cleared:
  - If yes, the troubleshooting is complete.
  - If no, proceed to step 3.
ospfIfAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.6
Interface authentication failure.
Informational
Warning
N/A (N/A)
ON
This notification is generated when OSPF interface authentication fails. This issue occurs if an OSPF interface on a router receives a packet from another router with mismatched authentication settings.
System impact
This issue typically has no negative impact on services as long as you reconfigure the same authentication settings for interfaces on both ends.
Status control
ON
CLI: Use the snmp-agent trap enable ospf authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf authentication-failure command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfIfIpAddress
ospfAddressLessIf
IpAddress
ospfIfIpAddress
ospfAddressLessIf
IP address that cannot be identified by a neighbor instance.
N/A
IpAddress
N/A
INTEGER
OSPF packet type.
N/A
INTEGER
Recommended action
1.Use the display current-configuration configuration ospf command to identify whether the local end and the remote end use the same area authentication settings.
2.Use the display current-configuration interface interface-type interface-number command to identify whether the local interface and the remote interface use the same interface authentication settings. The comparison result of interface-level authentication settings takes precedence over that of area-level authentication settings.
3.Perform the following tasks to clear the notification:
Use the ospf authentication-mode command to reconfigure the interface authentication settings on the local or remote interface, ensuring that the two interfaces use the same settings.
Use the authentication-mode command to reconfigure the area authentication settings for the local or remote device, ensuring that the two devices use the same settings.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfVirtIfAuthFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.7
Virtual interface authentication failure.
Informational
Warning
N/A (N/A)
ON
This notification is generated when OSPF virtual interface authentication fails. This issue occurs when an OSPF virtual interface on a router receives a packet from another router with mismatched authentication settings.
System impact
This issue typically has no negative impact on services as long as you reconfigure the same authentication settings for virtual interfaces on both ends.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-authentication-failure command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-authentication-failure command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
AreaID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
RouterID
IpAddress
N/A
INTEGER
OSPF packet type.
N/A
INTEGER
Recommended action
1.Use the display current-configuration configuration ospf command to identify whether the local end and the remote end use the same virtual link authentication settings and the same backbone area authentication settings. The comparison result of virtual link authentication settings takes precedence over that of backbone area authentication settings.
Use the vlink-peer command to reconfigure the virtual link authentication settings for the local or remote device, ensuring that the two devices use the same settings.
Use the authentication-mode command to reconfigure the backbone area authentication settings for the local or remote device, ensuring that the two devices use the same settings.
ospfIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.8
An interface receives an error packet.
Informational
Informational
N/A (N/A)
ON
This notification is generated when an interface receives an OSPF packet that cannot be parsed. This issue occurs when one of the following conditions exists:
The length of the OSPF packet is incorrect.
The OSPF packet has content errors.
System impact
When a normal interface receives an OSPF packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospf bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf bad-packet command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfIfIpAddress
ospfAddressLessIf
IpAddress
ospfIfIpAddress
ospfAddressLessIf
N/A
IpAddress
OSPF packet type.
N/A
INTEGER
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
ospfVirtIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.9
A virtual interface receives an error packet.
Informational
Informational
N/A (N/A)
ON
This notification is generated when a virtual interface receives an OSPF packet that cannot be parsed. This issue occurs when one of the following conditions exists:
System impact
When a virtual interface receives an OSPF packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-bad-packet command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-bad-packet command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
AreaID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
RouterID
IpAddress
OSPF packet type.
N/A
INTEGER
Recommended action
ospfTxRetransmit
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.10
An interface retransmits an OSPF packet.
Informational
Informational
N/A (N/A)
ON
This notification is generated when an interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
The neighbor considers packets from the local device illegal.
The neighbor is not reachable
System impact
This notification is generated typically due to heavy traffic load. Route synchronization and convergence might slow down.
Status control
ON
CLI: Use the snmp-agent trap enable ospf retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf retransmit command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfIfIpAddress
ospfAddressLessIf
IpAddress
ospfIfIpAddress
ospfAddressLessIf
ospfNbrIpAddr
RouterID
IpAddress
OSPF packet type.
N/A
INTEGER
1.3.6.1.2.1.14.4.1.2 (ospfLsdbType)
LSA type.
Type-5 LSAs are not displayed.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
INTEGER
routerLink (1), networkLink (2), summaryLink (3), asSummaryLink (4), asExternalLink (5), multicastLink (6), nssaExternalLink (7), areaOpaqueLink (10)
1.3.6.1.2.1.14.4.1.3 (ospfLsdbLsid)
LS ID.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
IpAddress
1.3.6.1.2.1.14.4.1.4 (ospfLsdbRouterId)
Router ID of the device that generates the LSA.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
RouterID
IpAddress
Recommended action
ospfVirtIfTxRetransmit
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.11
A virtual interface retransmits an OSPF packet.
Informational
Informational
N/A (N/A)
ON
This notification is generated when a virtual interface retransmits an OSPF packet. All packets that might be retransmitted are associated with an LSDB entry, which is identified by the LS type, LS ID, and Router ID.
This issue occurs when the neighbor considers packets from the local device illegal.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospf virt-retransmit command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virt-retransmit command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
AreaID
IpAddress
ospfVirtIfAreaId
ospfVirtIfNeighbor
RouterID
IpAddress
OSPF packet type.
N/A
INTEGER
LSA type.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
INTEGER
LS ID
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
IpAddress
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
RouterID
IpAddress
Recommended action
1.Use the display ospf vlink command on the remote device to view the state of the virtual link.
  - If the virtual interface state or neighbor state is Down, perform the recommended actions for the ospfVirtIfStateChange and ospfVirtNbrStateChange notifications.
  - If the neighbor state is Full, proceed to step 2.
2.Check whether the ospfVirtIfRxBadPacket notification is generated on the local and remote devices.
  - If yes, perform the recommended actions for the ospfVirtIfRxBadPacket notification.
ospfOriginateLsa
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.12
The local device generates a new LSA.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the local device generates a new LSA. This notification is generated only when an LSA is originated because of a topology change. Flushing of aged LSAs and refreshes of LSAs will not trigger this notification.
An interface comes up or down.
The state of a neighbor changes.
A route redistributed by OSPF changes.
System impact
If the ospfNbrStateChange and ospfIfStateChange notifications are generated together with this notification, services might be affected.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-originate command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-originate command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.4.1.1 (ospfLsdbAreaId)
ID of the area from which the LSA was received.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
AreaID
IpAddress
LSA type.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
INTEGER
LS ID.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
IpAddress
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
RouterID
IpAddress
Recommended action
1.View the 1.3.6.1.2.1.14.4.1.2 (ospfLsdbType) object in the notification to identify the LSA type.
  - If the LSA is a Type-1 or Type-2 LSA, check whether the ospfNbrStateChange or ospfIfStateChange notification is generated.
If yes, perform the recommended actions for the corresponding notification.
  - If the LSA is a Type-3 or Type-7 LSA, proceed to step 2.
2.Use the display ip routing-table link-state-id command to identify whether the routing table has changed.
  - If yes, determine the cause of the change, or proceed to step 3.
ospfMaxAgeLsa
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.13
An LSA in the LSDB ages.
Informational
Informational
N/A (N/A)
ON
This notification is generated when an LSA in the LSDB ages (becomes a MaxAge LSA). This issue occurs when one of the following conditions exists:
System impact
This issue might affect route calculation. If the 1.3.6.1.2.1.14.4.1.3 (ospfLsdbLsid) object is in the service network segment, services will be affected.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsa-maxage command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsa-maxage command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
AreaID
IpAddress
LSA type.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
INTEGER
LS ID.
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
IpAddress
ospfLsdbAreaId
ospfLsdbType
ospfLsdbLsid
ospfLsdbRouterId
RouterID
IpAddress
Recommended action
1.View the 1.3.6.1.2.1.14.4.1.4 (ospfLsdbRouterId) object in the notification to identify whether the LSA is generated by the local device.
  - If yes, proceed to step 2.
2.View the 1.3.6.1.2.1.14.4.1.2 (ospfLsdbType) object in the notification to identify the LSA type.
  - If the LSA is a Type-3 or Type-7 LSA, use the display ip routing-table link-state-id command to identify whether the routing table has changed.
ospfLsdbOverflow
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.14
The number of LSAs in the LSDB of a device exceeds the upper limit.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of LSAs in the LSDB of a device exceeds the upper limit. This issue occurs when too many Type-5 and Type-7 LSAs exist in the LSDB.
System impact
This issue might cause network flapping if it affects route calculation.
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-overflow command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.1.11 (ospfExtLsdbLimit)
Maximum number of non-default ASEs in the LSDB. A value of -1 indicates no limit.
N/A
Integer32
-1..'7FFFFFFF'h
Recommended action
1.If the upper limit of external LSAs in the LSDB can be changed, use the lsdb-overflow-limit command to increase the value and make sure all OSPF devices use the same value throughout the network. If this notification is still generated after the new upper limit takes effect, proceed to step 2.
If the upper limit of external LSAs in the LSDB cannot be changed, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfLsdbApproachingOverflow
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.15
The number of LSAs in the LSDB of a device reaches 90% the upper limit.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of LSAs in the LSDB of a device reaches 90% of the upper limit. This issue occurs when too many Type-5 and Type-7 LSAs exist in the LSDB.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospf lsdb-approaching-overflow command.
OFF
CLI: Use the undo snmp-agent trap enable ospf lsdb-approaching-overflow command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
N/A
Integer32
-1..'7FFFFFFF'h
Recommended action
1.Use the display ospf lsdb brief command to identify whether the number of Type-5 and Type-7 LSAs reaches 90% the upper limit set by the lsdb-overflow-limit command.
2.If the upper limit of external LSAs in the LSDB can be changed, use the lsdb-overflow-limit command to increase the value and make sure all OSPF devices use the same value throughout the network. If this notification is still generated after the new upper limit takes effect, proceed to step 3.
If the upper limit of external LSAs in the LSDB cannot be changed, proceed to step 3.
ospfIfStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.16
Interface state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the state of an OSPF interface regresses (for example, changing from DR to Down) or progresses to a terminal state (for example, Point-to-Point, DRother, DR, or Backup). This issue occurs when one of the following conditions exists:
The physical interface comes up or goes down.
The router priority for the interface changes and DR/BDR election is performed.
System impact
This issue might affect the state of neighbors. If the state of an OSPF interface regresses (for example, changing to Down), it will be disconnected from its neighbors.
Status control
ON
CLI: Use the snmp-agent trap enable ospf if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf if-state-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfIfIpAddress
ospfAddressLessIf
IpAddress
ospfIfIpAddress
ospfAddressLessIf
1.3.6.1.2.1.14.7.1.12 (ospfIfState)
Interface state.
ospfIfIpAddress
ospfAddressLessIf
INTEGER
down (1), loopback (2), waiting (3), pointToPoint (4), designatedRouter (5), backupDesignatedRouter (6), otherDesignatedRouter (7)
Recommended action
1.Use the display ospf interface command to view the interface state.
  - If the interface state is Down, proceed to step 2.
  - If the interface state is not Down, no action is required.
2.Use the display interface interface-type interface-number command to view the state of the interface.
  - If the interface is not up, check whether the interface has been shut down.
ospfNssaTranslatorStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.17
A router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when a router's ability to translate OSPF type-7 LSAs into OSPF type-5 LSAs changes. This issue occurs when one of the following conditions exists:
The translate-always keyword of the nssa command is configured or canceled on an NSSA ABR.
An NSSA ABR has been configured with a new router ID and the change is already in effect.
The device becomes an ABR or its role changes from ABR to another.
System impact
When the translator in an NSSA area changes, the former translator must flush the Type-5 LSAs translated from Type-7 LSAs and the new translator translates new OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs. This might cause temporary AES route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable ospf nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf nssatranslator-status-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.2.1.1 (ospfAreaId)
Area ID, a 32-bit integer that uniquely identifies an area.
ospfAreaId
AreaID
IpAddress
1.3.6.1.2.1.14.2.1.12 (ospfAreaNssaTranslatorState)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
ospfAreaId
INTEGER
enabled (1), elected (2), disabled (3)
Recommended action
1.If the nssa translate-always command is configured on the local device, use the display ospf command to identify whether the 7/5 translator state field displays Enabled.
  - If yes, no action is required.
  - If no, proceed to step 7.
If the nssa translate-always command is canceled on the local device, use the display ospf command to identify whether the 7/5 translator state field displays Disabled.
  - If the 7/5 translator state field displays Disabled, proceed to step 2.
  - If the 7/5 translator state field displays Elected, no action is required.
2.Use the display ospf lsdb router command to identify whether the Options field in the router LSA of an NSSA ABR contains the Nt bit.
3.If the local device has been configured with a new router ID and the change is already in effect, identify whether the NSSA translator role is correct after the network topology is stable.
  - If no, proceed to step 4.
4.Identify whether other NSSA ABRs have been configured with new router IDs. After the network topology is stable, identify whether one of the new router IDs is larger than the local router ID.
5.If a new NSSA ABR has been added in the area, identify whether the router ID of the new NSSA ABR is larger than the local router ID after the network topology is stable,.
  - If no, proceed to step 0.
If the new device is not an ABR, proceed to step 0.
6.Check whether the ospfNbrStateChange or ospfIfStateChange notification is generated on the local and neighbor devices.
  - If yes, perform the recommended actions to clear the notification.
7.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfRestartStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.18
GR restarter state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the state of the GR restarter changes. This issue occurs when one of the following conditions exists:
The device stops GR.
The device starts GR.
System impact
If the state of the GR restarter changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grrestarter-status-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
1.3.6.1.2.1.14.1.21 (ospfRestartStatus)
GR restarter state.
N/A
INTEGER
notRestarting (1), plannedRestart (2), unplannedRestart (3)
1.3.6.1.2.1.14.1.19 (ospfRestartInterval)
Graceful restart timeout interval.
N/A
Integer32
1..1800
1.3.6.1.2.1.14.1.23 (ospfRestartExitReason)
Reason why the GR restarter exited.
N/A
INTEGER
none (1), inProgress (2), completed (3), timedOut (4), topologyChanged (5)
Recommended action
1.If you are manually performing an active/standby switchover or restarting the OSPF process with GR, no action is required. Otherwise, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.19
GR helper state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the GR helper state of a neighbor changes. This issue occurs when one of the following conditions exists:
The neighbor becomes the GR helper.
The neighbor stops being the GR helper.
System impact
If the GR helper state of a neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospf grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf grhelper-status-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfNbrIpAddr
IpAddress
ospfNbrIpAddr
ospfNbrIpAddr
RouterID
IpAddress
1.3.6.1.2.1.14.10.1.12 (ospfNbrRestartHelperStatus)
GR helper state.
ospfNbrIpAddr
INTEGER
notHelping (1), helping (2)
1.3.6.1.2.1.14.10.1.13 (ospfNbrRestartHelperAge)
Remaining time of the GR interval when the router is acting as a GR helper for the neighbor.
ospfNbrIpAddr
Unsigned32
1.3.6.1.2.1.14.10.1.14 (ospfNbrRestartHelperExitReason)
Reason why the GR helper exited.
ospfNbrIpAddr
INTEGER
Recommended action
ospfVirtNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.14.16.2.20
The GR helper state of a virtual neighbor changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the GR helper state of a virtual neighbor changes. This issue occurs when one of the following conditions exists:
The virtual neighbor becomes the GR helper.
The virtual neighbor stops being the GR helper.
System impact
If the GR helper state of a virtual neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospf virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospf virtgrhelper-status-change command.
Object
OID (object name)
Index
Value range
N/A
RouterID
IpAddress
ospfVirtNbrArea
ospfVirtNbrRtrId
AreaID
IpAddress
ospfVirtNbrArea
ospfVirtNbrRtrId
RouterID
IpAddress
1.3.6.1.2.1.14.11.1.9 (ospfVirtNbrRestartHelperStatus)
Whether the router is acting as a GR helper for the virtual neighbor.
ospfVirtNbrArea
ospfVirtNbrRtrId
INTEGER
1.3.6.1.2.1.14.11.1.10 (ospfVirtNbrRestartHelperAge)
ospfVirtNbrArea
ospfVirtNbrRtrId
Unsigned32
1.3.6.1.2.1.14.11.1.11 (ospfVirtNbrRestartHelperExitReason)
ospfVirtNbrArea
ospfVirtNbrRtrId
INTEGER
none (1), inProgress (2), completed (3), timedOu t 4), topologyChanged (5)
Recommended action
