09-Layer 3 - IP Routing
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10009-Layer 3 - IP Routing
07-HH3C-OSPFv3-MIB
07-HH3C-OSPFv3-MIB 39.03 KB
HH3C-OSPFv3-MIB
About this MIB
Use this MIB to display OSPFv3 information.
MIB file name
hh3c-ospfv3.mib
Notifications
hh3cOspfv3LastAuthKeyExpiry
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.239.0.1
The last active send key in the keychain used by OSPFv3 became inactive or no active key ID exists.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the last active send key in the keychain used by OSPFv3 becomes inactive.
System impact
When no active send keys exist in the keychain used by OSPFv3, the neighbors cannot send OSPFv3 packets and will go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 last-auth-key-expiry command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 last-auth-key-expiry command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.239.2.1 (hh3cOspfv3ProcessIdForNotify)
OSPFv3 process ID.
N/A
Integer32
Integer32 (1..65535)
1.3.6.1.4.1.25506.2.239.2.2 (hh3cOspfv3AreaIdForNotify)
OSPFv3 area ID. Each area has a unique ID.
N/A
IpAddress
OCTET STRING(4)
1.3.6.1.4.1.25506.2.239.2.3 (hh3cOspfv3IfName)
Name of the packet incoming interface.
N/A
DisplayString
OCTET STRING(1..255)
1.3.6.1.4.1.25506.2.239.2.4 (hh3cOspfv3RouterID)
Local router ID.
N/A
IpAddress
OCTET STRING(4)
Recommended action
To resolve this issue:
1.Use the display ospfv3 interface command to view the keychain enabled on the interface.
2.Use the display keychain command to identify whether the Default send key ID field is displayed. This field indicates whether a default send key exists and displays its status.
  - If no default send keys exist, proceed to step 3.
  - If the Default send key ID field displays an existing key ID and the status is Active, proceed to step 4.
  - If the Default send key ID field displays an existing key ID and the status is Inactive, proceed to step 3.
  - If the Default send key ID field displays None, proceed to step 3.
3.Use the display keychain command to view the Active send key ID field. This field displays the send key ID which is currently active.
  - If the Active send key ID field displays the key ID which currently exists, proceed to step 4.
  - If the Active send key ID field displays None, all send keys are inactive. Check whether the key configuration is complete and the system time is within the sending lifetime of the send key.
If yes, proceed to step 4.
If no, complete key configuration and update the send lifetime of the send key.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
