09-Layer 3 - IP Routing
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10009-Layer 3 - IP Routing
08-HH3C-PBR-MIB
08-HH3C-PBR-MIB 103.75 KB
HH3C-PBR-MIB
About this MIB
Use this MIB to obtain and configure PBR information.
MIB file name
hh3c-pbr.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPBR(113)
Scalar objects
hh3cPBRNexthopTrapEnabled
(1.3.6.1.4.1.25506.2.113.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
Standard MIB values.
Enable notifications when the next hop becomes unreachable.
As per the MIB.
hh3cPBRLocalPolicy
(1.3.6.1.4.1.25506.2.113.1.1.2)
Object (OID)
Access
Value range
Implementation
hh3cPBRLocalPolicy
read-write
DisplayString
DisplayString(SIZE (0..19))
Apply the PBR policy to locally generated packets.
As per the MIB.
hh3cPBRIPv6NexthopTrapEnabled
(1.3.6.1.4.1.25506.2.113.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
Enable notifications when the IPv6 next hop becomes unreachable.
As per the MIB.
Tabular objects
hh3cPBRMibPolicyNodeTable
About this table
This table is used to create a policy node and configure match criteria and actions for the policy.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, and hh3cPBRMibPolicyNodeId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.113.2.1.1.1)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
Address type of the policy node.
Supports IPv4, IPv6, and Dual-stack.
(1.3.6.1.4.1.25506.2.113.2.1.1.2)
not-accessible
DisplayString
DisplayString (SIZE (1..19))
PBR policy name.
As per the MIB.
(1.3.6.1.4.1.25506.2.113.2.1.1.3)
not-accessible
Integer32
Integer32(0..65535)
Policy node ID.
As per the MIB.
hh3cPBRMibPolicyNodeMode
(1.3.6.1.4.1.25506.2.113.2.1.1.4)
read-create
TruthValue
Match mode of the policy node.
As per the MIB.
hh3cPBRMibPolicyNodeRowStatus
(1.3.6.1.4.1.25506.2.113.2.1.1.5)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Operation type of the policy node.
As per the MIB.
hh3cPBRMibMinPktLen
(1.3.6.1.4.1.25506.2.113.2.1.1.6)
read-write
Integer32
Integer32(1..65535)
Minimum IP packet length of the packet length match criterion on the policy node.
As per the MIB.
hh3cPBRMibMaxPktLen
(1.3.6.1.4.1.25506.2.113.2.1.1.7)
read-write
Integer32
Integer32(1..65535)
Maximum IP packet length of the packet length match criterion on the policy node.
As per the MIB.
hh3cPBRMibQosId
(1.3.6.1.4.1.25506.2.113.2.1.1.8)
read-write
Integer32
Integer32(1..4095)
Local QoS ID match criterion of the policy node.
As per the MIB.
hh3cPBRMibQosIdMode
(1.3.6.1.4.1.25506.2.113.2.1.1.9)
read-write
INTEGER
invalid(1)
normal(2),
qppb(3)
Local QoS ID mode of the policy node.
As per the MIB.
hh3cPBRMibVxlanId
(1.3.6.1.4.1.25506.2.113.2.1.1.10)
read-write
Integer32
Integer32(0.. 16777215)
VXLAN ID match criterion of the policy mode.
As per the MIB.
hh3cPBRMibDescription
(1.3.6.1.4.1.25506.2.113.2.1.1.11)
read-write
DisplayString
DisplayString(SIZE (0..127))
Policy node description.
As per the MIB.
hh3cPBRMibApplyContinue
(1.3.6.1.4.1.25506.2.113.2.1.1.12)
read-write
TruthValue
Action that compares packets with the next policy node upon failure on the current node.
As per the MIB.
hh3cPBRMibApplyFailDropNextHop
(1.3.6.1.4.1.25506.2.113.2.1.1.13)
read-write
TruthValue
Action that drops matching packets when all next hops on a policy node are invalid
As per the MIB.
hh3cPBRMibApplyIpDf
(1.3.6.1.4.1.25506.2.113.2.1.1.14)
read-write
Integer32
0 or 1
Action that sets the Don't Fragment (DF) bit in the IP header of matching packets.
As per the MIB.
hh3cPBRMibApplyLoadShareNextHop
(1.3.6.1.4.1.25506.2.113.2.1.1.15)
read-write
TruthValue
Action that enables load sharing among multiple next hops.
As per the MIB.
hh3cPBRMibApplyLoadShareOutIf
(1.3.6.1.4.1.25506.2.113.2.1.1.16)
read-write
TruthValue
Action that enables load sharing among multiple output interfaces.
As per the MIB.
hh3cPBRMibApplyLSDefaultNextHop
(1.3.6.1.4.1.25506.2.113.2.1.1.17)
read-write
TruthValue
Action that enables load sharing among multiple default next hops.
As per the MIB.
hh3cPBRMibApplyLSDefaultOutIf
(1.3.6.1.4.1.25506.2.113.2.1.1.18)
read-write
TruthValue
Action that enables load sharing among multiple default output interfaces.
As per the MIB.
hh3cPBRMibApplyStatisticsValue
(1.3.6.1.4.1.25506.2.113.2.1.1.19)
read-write
TruthValue
Action that enables match counting on a policy node.
As per the MIB.
hh3cPBRMibIfPolicyTable
About this table
This table is used to implement interface PBR.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPBRMibPolicyAddressType and ifIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.113.2.2.1.1)
not-accessible
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
Address type of interface PBR.
hh3cPBRMibAppliedPolicyName
(1.3.6.1.4.1.25506.2.113.2.2.1.2)
read-create
DisplayString
Policy name of interface PBR.
As per the MIB.
hh3cPBRMibIfPolicyRowStatus
(1.3.6.1.4.1.25506.2.113.2.2.1.3)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Operation type of interface PBR.
As per the MIB.
hh3cPBRMibIfPolicyShareMode
(1.3.6.1.4.1.25506.2.113.2.2.1.4)
read-create
TruthValue
Resource sharing mode of interface PBR.
As per the MIB.
hh3cPBRMibMatchAclTable
About this table
This table is used to set ACL match criterions for a policy node.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cPBRMibAclGroupId
(1.3.6.1.4.1.25506.2.113.2.3.1.1)
read-write
Integer32
ACL number.
As per the MIB.
hh3cPBRMibAclGroupName
(1.3.6.1.4.1.25506.2.113.2.3.1.2)
read-write
STRING
STRING(SIZE (0..63))
ACL name.
As per the MIB.
hh3cPBRMibAclGroupVersion
(1.3.6.1.4.1.25506.2.113.2.3.1.3)
read-write
INTEGER
invalid(1)
ipv4(2),
ipv6(3),
userdefined (4)
ACL rule version
As per the MIB.
hh3cPBRMibApplyPrecedenceTable
About this table
This table is used to set an IP precedence.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cPBRMibApplyPrecedenceValue
(1.3.6.1.4.1.25506.2.113.2.4.1.1)
read-write
Integer32
0 to 7
Precedence for IP packets.
routine (0)
priority (1)
immediate (2)
flash (3)
flash-override (4)
critical (5)
internet (6)
network (7)
hh3cPBRMibApplyNexthopTable
About this table
This table is used to set next hops for matching packets on a policy node.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, hh3cPBRMibPolicyNodeId, and hh3cPBRMibApplyNexthopIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.113.2.5.1.1)
not-accessible
Integer32
Integer32(0..2147483647)
Index of the default next hop.
As per the MIB.
hh3cPBRMibApplyNexthopVpnName
(1.3.6.1.4.1.25506.2.113.2.5.1.2)
read-create
DisplayString
DisplayString (SIZE (0..31))
VPN instance name of the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopAddressType
(1.3.6.1.4.1.25506.2.113.2.5.1.3)
read-create
InetAddressType
ipv4(1),
ipv6(2),
Next hop address type.
Supports IPv4 and IPv6.
(1.3.6.1.4.1.25506.2.113.2.5.1.4)
read-create
InetAddress
Next hop address.
As per the MIB.
hh3cPBRMibApplyNexthopTrackId
(1.3.6.1.4.1.25506.2.113.2.5.1.5)
read-create
Integer32
ID of the track entry associated with the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopDirect
(1.3.6.1.4.1.25506.2.113.2.5.1.6)
read-create
TruthValue
Effective condition of the next hop that it must be directly connected.
As per the MIB.
hh3cPBRMibApplyNexthopRowStatus
(1.3.6.1.4.1.25506.2.113.2.5.1.7)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Operation type of the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopInboundVpn
(1.3.6.1.4.1.25506.2.113.2.5.1.8)
read-create
TruthValue
VPN instance of the inbound interface associated with the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopWeight
(1.3.6.1.4.1.25506.2.113.2.5.1.9)
read-create
Integer32
Integer32(1..100)
Load sharing weight for the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopPathId
(1.3.6.1.4.1.25506.2.113.2.5.1.10)
read-create
Integer32
Integer32(1..16777215)
Service chain path ID of the next hop.
As per the MIB.
hh3cPBRMibApplyNexthopPathIndex
(1.3.6.1.4.1.25506.2.113.2.5.1.11)
read-create
Integer32
Integer32(1..255)
Service chain node index of the next hop.
As per the MIB.
hh3cPBRMibApplyDefaultNexthopTable
About this table
This table is used to set default next hops for matching packets on a policy node.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cPBRMibPolicyNodeAddrType, hh3cPBRMibPolicyName, hh3cPBRMibPolicyNodeId, and hh3cPBRMibApplyDefaultNexthopIndex.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.113.2.6.1.1)
not-accessible
Integer32
As per the MIB.
hh3cPBRMibApplyDefaultNexthopVpnName
(1.3.6.1.4.1.25506.2.113.2.6.1.2)
read-create
DisplayString
VPN instance name of the default next hop.
As per the MIB.
hh3cPBRMibApplyDefaultNexthopAddressType
(1.3.6.1.4.1.25506.2.113.2.6.1.3)
read-create
InetAddressType
ipv4(1),
ipv6(2),
Default next hop address type.
(1.3.6.1.4.1.25506.2.113.2.6.1.4)
read-create
InetAddress
Default next hop address.
As per the MIB.
hh3cPBRMibApplyDefaultNexthopTrackId
(1.3.6.1.4.1.25506.2.113.2.6.1.5)
read-create
Integer32
ID of the track entry associated with the default next hop.
As per the MIB.
hh3cPBRMibApplyDefaultNexthopDirect
(1.3.6.1.4.1.25506.2.113.2.6.1.6)
read-create
TruthValue
Effective condition of the default next hop that it must be directly connected.
As per the MIB.
hh3cPBRMibApplyDefaultNexthopRowStatus
(1.3.6.1.4.1.25506.2.113.2.6.1.7)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Operation type of the default next hop.
As per the MIB.
hh3cPBRMibApplyDefNexthopInbVpn
(1.3.6.1.4.1.25506.2.113.2.6.1.8)
read-create
TruthValue
VPN instance of the inbound interface associated with the default next hop.
As per the MIB.
hh3cPBRMibApplyDefNexthopPathId
(1.3.6.1.4.1.25506.2.113.2.6.1.9)
read-create
Integer32
Service chain path ID of the default next hop.
As per the MIB.
hh3cPBRMibApplyDefNexthopPathInd
(1.3.6.1.4.1.25506.2.113.2.6.1.10)
read-create
Integer32
Integer32(1..255)
Service chain node index of the default next hop.
As per the MIB.
Notifications
hh3cPBRNexthopFailedTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.113.1.2.2.0.1
The next hop in a PBR policy becomes unreachable.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the next hop in a PBR policy becomes unreachable.
System impact
A PBR policy cannot use an invalid next hop to forward packets.
Status control
ON
CLI: Use the snmp-agent trap enable policy-based-route command.
OFF
CLI: Use the undo snmp-agent trap enable policy-based-route command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.113.1.2.1.1 (hh3cPBRNexthopAddrType)
N/A
INTEGER
ipv4(1), , ipv6(2),
1.3.6.1.4.1.25506.2.113.1.2.1.2 (hh3cPBRNexthopAddr)
Next hop address.
N/A
OCTET STRING
OCTET STRING (0..255)
Recommended action
Check the network status, locate the reason that the next hop route becomes unreachable, and resolve the route reachability issue.
1.Identify whether the output interface of the next hop is up. Execute the display interface  interface-type interface-number brief command to view the physical layer state of the interface. If the physical layer state or data link layer state of the interface is not up, resolve the interface or link failure. If the output interface is up, proceed to step 2.
2.Identify whether the route is correctly issued. Execute the display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] verbose or display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] command to view route information about the specified destination address. If the routing table does not contain the route with the specified next hop and output interface, check the route configuration. If the route configuration is correct, proceed to step 3.
3.Identify whether the IP addresses at both ends are on the same network segment. Execute the display ip interface  interface-type interface-number brief or display ipv6 interface interface-type interface-number brief command on both the local and next hop devices to view the IP addresses of the interfaces on both ends.
If the IP addresses of the interfaces on both ends are not on the same network segment, execute the ip address or ipv6 address command in interface view to edit the IP addresses on both ends to make sure they are on the same network segment.
If the IP addresses of the interfaces on both ends are not on the same network segment, proceed to step 4.
4.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
