04-HH3C-IPRAN-DCN-MIB | 100.16 KB |
HH3C-IPRAN-DCN-MIB
About this MIB
HH3C-IPRAN-DCN-MIB is used for the Network Management System (NMS) to perform remote management and control of network elements in the Data Communication Network (DCN), and obtain the running status and receive association and disassociation notifications.
MIB file name
hh3c-ipran-dcn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpRanDcn(152)
Tabular objects
hh3cIpRanDcnInfoObject
About this table
This table contains network element information about the local device.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeId (1.3.6.1.4.1.25506.2.152.1.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
NE ID of the local device. |
As per the MIB. |
hh3cIpRanDcnNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2) |
read-only |
InetAddressType |
ipv4(1) |
NE IP address type of the local device. |
As per the MIB. |
hh3cIpRanDcnNeIp (1.3.6.1.4.1.25506.2.152.1.1.3) |
read-only |
InetAddress |
OCTET STRING (0..255) |
NE IP address of the local device. |
As per the MIB. |
hh3cIpRanDcnMask (1.3.6.1.4.1.25506.2.152.1.1.4) |
read-only |
InetAddress |
Subnet mask of the NE IP address of the local device. |
As per the MIB. |
hh3cIpRanDcnMAC (1.3.6.1.4.1.25506.2.152.1.1.5) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC of the local device. |
As per the MIB. |
hh3cIpRanDcnVendor (1.3.6.1.4.1.25506.2.152.1.1.6) |
read-only |
DisplayString |
SIZE (0..255) |
Vendor of the local device. |
As per the MIB. |
hh3cIpRanDcnNeInfoTable
About this table
This table contains information about all network elements in the DCN network.
Read:Supported
Columns
The table index is hh3cIpRanDcnNeInfoNeId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeInfoNeId (1.3.6.1.4.1.25506.2.152.1.1.2.1.1) |
read-only |
Hh3cIpRanNeId |
OCTET STRING (4) |
ID of the network element. |
As per the MIB. |
hh3cIpRanDcnNeInfoNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2.1.2) |
read-only |
InetAddressType |
ipv4(1) |
IP address type of the network element |
As per the MIB. |
hh3cIpRanDcnNeInfoNeIp (1.3.6.1.4.1.25506.2.152.1.1.2.1.3) |
read-only |
InetAddress |
IP address of the network element |
As per the MIB. |
hh3cIpRanDcnNeInfoMetric (1.3.6.1.4.1.25506.2.152.1.1.2.1.4) |
read-only |
Integer32 |
Standard MIB values. |
Distance between the local network element to the remote network element. |
As per the MIB. |
hh3cIpRanDcnNeInfoDeviceType (1.3.6.1.4.1.25506.2.152.1.1.2.1.5) |
read-only |
DisplayString |
Device model of the network element. |
As per the MIB. |
hh3cIpRanDcnNeInfoMAC (1.3.6.1.4.1.25506.2.152.1.1.2.1.6) |
read-only |
MacAddress |
OCTET STRING (6) |
Bridge MAC address of the network element. |
As per the MIB. |
hh3cIpRanDcnNeInfoVendor (1.3.6.1.4.1.25506.2.152.1.1.2.1.7) |
read-only |
DisplayString |
Vendor ID of the network element. |
As per the MIB. |
hh3cIpRanDcnTrapObjects
About this table
This table contains information about the network element that changed most recently.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpRanDcnNeNumber (1.3.6.1.4.1.25506.2.152.1.2.1) |
read-only |
Integer32 |
Total number of online network elements in the current DCN network. |
As per the MIB. |
hh3cIpRanDcnNeChangeMode (1.3.6.1.4.1.25506.2.152.1.2.2) |
read-only |
INTEGER |
online (1), offline (2) |
Current state of the network element that changed most recently. |
As per the MIB. |
hh3cIpRanDcnCompanyName (1.3.6.1.4.1.25506.2.152.1.2.3) |
read-only |
DisplayString |
Vendor of the network element that changed most recently. |
As per the MIB. |
hh3cIpRanDcnDeviceType (1.3.6.1.4.1.25506.2.152.1.2.4) |
read-only |
DisplayString |
Model of the network element that changed most recently. |
As per the MIB. |
hh3cIpRanDcnDeviceMac (1.3.6.1.4.1.25506.2.152.1.2.5) |
read-only |
MacAddress |
OCTET STRING(6) |
Bridge MAC address of the network element that changed most recently. |
As per the MIB. |
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.1 |
A network element comes online. |
Recovery |
Informational |
N/A (N/A) |
OFF |
Notification triggers
This notification is sent when a network element comes online from the DCN network.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId) |
hh3cIpRanDcnNeInfoNeId |
Hh3cIpRanNeId |
OCTET STRING (4) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType) |
IP address type of the network element. |
InetAddressType |
ipv4(1) |
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp) |
IP address of the network element. |
InetAddress |
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName) |
Device vendor name. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType) |
Device type. |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac) |
Bridge MAC of the device. |
N/A |
MacAddress |
OCTET STRING (6) |
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.2 |
A network element goes offline. |
Error |
Informational |
1.3.6.1.4.1.25506.2.152.1.3.0.1 (hh3cIpRanDcnNeOnline) |
OFF |
This notification is sent when a network element goes offline from the DCN network.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Network element ID. |
Hh3cIpRanNeId |
OCTET STRING (4) |
InetAddressType |
ipv4(1) |
InetAddress |
Recommended action
hh3cIpRanDcnNeIdConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.3 |
A network element ID conflict occurs. |
Error |
Warning |
1.3.6.1.4.1.25506.2.152.1.3.0.4 (hh3cIpRanDcnNeIdConflictClear) |
ON |
This notification is sent when two or more devices have the same NE ID in the DCN network.
System impact
After this notification is generated, NMS cannot manage the device correctly, configuration cannot be deployed to the device, and errors might occur on newly added services.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict command
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict command
Object
OID (object name) |
Index |
Type |
Value range |
Hh3cIpRanNeId |
OCTET STRING (4) |
Recommended action
1.Modify the ID of the alarming network element to a unique value in the DCN network, and wait for the NE ID conflict notification to be removed.
2.If the issue persists, collect alarm information and configuration information, and contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.4 |
The network element ID conflict is cleared. |
Recovery |
Informational |
N/A (N/A) |
ON |
This notification is sent when the network element ID conflict is removed in the DCN network.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neid-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neid-conflict-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
Hh3cIpRanNeId |
OCTET STRING (4) |
Recommended action
hh3cIpRanDcnNeIpConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.5 |
A network element IP address conflict occurs. |
Error |
Warning |
1.3.6.1.4.1.25506.2.152.1.3.0.6 (hh3cIpRanDcnNeIpConflictClear) |
ON |
This notification is sent when two or more devices have the same NE IP address in the DCN network.
System impact
The conflicting network element may be placed under management, resulting in NMS being unable to manage the device correctly.
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict command.
Object
OID (object name) |
Index |
Type |
Value range |
Network element IP address. |
InetAddress |
Recommended action
1.Modify the IP address of the alarming network element to a unique value in the DCN network, and wait for the NE IP conflict notification to be removed.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.152.1.3.0.6 |
The network element IP address conflict is cleared. |
Recovery |
Informational |
N/A (N/A) |
ON |
This notification is sent when the network element IP address conflict is removed in the DCN network.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dcn neip-conflict-clear command.
OFF
CLI: Use the undo snmp-agent trap enable dcn neip-conflict-clear command.
Object
OID (object name) |
Index |
Type |
Value range |
InetAddress |
Recommended action
