08-MPLS
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10008-MPLS
10-TE-MIB
10-TE-MIB 90.04 KB
TE-MIB
About this MIB
Use this MIB to manage TE tunnel interface and explicit path settings.
MIB file name
rfc3970-te.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).teMIB(122)
Scalar objects
teDistProtocol
Object (OID)
Access
Value range
Implementation
teDistProtocol
(1.3.6.1.2.1.122.1.1.1)
read-only
BITS
other(0),
isis(1),
ospf(2)
TE distribution protocol type.
As per the MIB.
teSignalingProto
Object (OID)
Access
Value range
Implementation
teSignalingProto
(1.3.6.1.2.1.122.1.1.2)
read-only
BITS
other(0),
rsvpte(1),
crldp(2),
static(3)
TE signaling protocol type.
As per the MIB.
teNotificationEnable
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.122.1.1.3)
read-write
TruthValue
true(1),
false(2)
Enable notifications.
As per the MIB.
teNextTunnelIndex
Object (OID)
Access
Value range
Implementation
teNextTunnelIndex
(1.3.6.1.2.1.122.1.1.4)
read-only
Unsigned32
Unsigned32
(1..4294967295)
Next tunnel index.
As per the MIB.
teNextPathHopIndex
Object (OID)
Access
Value range
Implementation
teNextPathHopIndex
(1.3.6.1.2.1.122.1.1.5)
read-only
Unsigned32
Unsigned32
(1..4294967295)
Next path index.
As per the MIB.
teConfiguredTunnels
Object (OID)
Access
Value range
Implementation
teConfiguredTunnels
(1.3.6.1.2.1.122.1.1.6)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of configured tunnels.
As per the MIB.
teActiveTunnels
Object (OID)
Access
Value range
Implementation
teActiveTunnels
(1.3.6.1.2.1.122.1.1.7)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of active tunnels.
As per the MIB.
tePrimaryTunnels
Object (OID)
Access
Value range
Implementation
tePrimaryTunnels
(1.3.6.1.2.1.122.1.1.8)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of tunnels running on their primary paths.
As per the MIB.
Tabular objects
teTunnelTable
About this table
This table is used to query, create, and delete the configuration, traffic, and status information of a tunnel interface.
Support for operations
Create
Edit/Modify
Delete
Read
Supported.
When you create a tunnel interface, you can leave teTunnelDestinationAddress empty.
If you need to assign a tunnel interface an IP address, you need to specify teTunnelDestinationAddress when you create the tunnel interface.
Not supported
Not supported
Supported
Columns
The table index is teTunnelIndex.
Object (OID)
Access
Value range
Implementation
teTunnelIndex
(1.3.6.1.2.1.122.1.2.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of a tunnel.
As per the MIB.
teTunnelName
(1.3.6.1.2.1.122.1.2.1.2)
read-create
SnmpAdminString
OCTET STRING
(1..32)
Name of the tunnel.
As per the MIB.
teTunnelNextPathIndex
(1.3.6.1.2.1.122.1.2.1.3)
read-only
Unsigned32
Unsigned32
(1..2147483647)
Next path index.
As per the MIB.
teTunnelRowStatus
(1.3.6.1.2.1.122.1.2.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4), createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
teTunnelStorageType
(1.3.6.1.2.1.122.1.2.1.5)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
Not supported. The value is always nonvolatile(3).
teTunnelSourceAddressType
(1.3.6.1.2.1.122.1.2.1.6)
read-only
TeHopAddressType
unknown(0),
ipv4(1),
ipv6(2),
asnumber(3),
unnum(4),
lspid(5)
Type of the source address.
Supports only ipv4(1).
(1.3.6.1.2.1.122.1.2.1.7)
read-create
TeHopAddress
0..32
Source address.
Supports only the read operation.
teTunnelDestinationAddressType
(1.3.6.1.2.1.122.1.2.1.8)
read-create
TeHopAddressType
unknown(0),
ipv4(1),
ipv6(2),
asnumber(3),
unnum(4),
lspid(5)
Type of the destination address.
(1.3.6.1.2.1.122.1.2.1.9)
read-create
TeHopAddress
OCTET STRING
(0..32)
Destination address.
As per the MIB.
teTunnelState
(1.3.6.1.2.1.122.1.2.1.10)
read-only
INTEGER
unknown(1),
up(2),
down(3),
testing(4)
Tunnel status.
Supports only up(2) and down(3).
teTunnelDiscontinuityTimer
(1.3.6.1.2.1.122.1.2.1.11)
read-only
TimeStamp
Standard MIB values.
Time when traffic was interrupted.
Not supported. The value is always 0.
teTunnelOctets
(1.3.6.1.2.1.122.1.2.1.12)
read-only
Counter64
Counter64
(0..18446744073709551615)
Number of octets that have been forwarded over the tunnel.
teTunnelPackets
(1.3.6.1.2.1.122.1.2.1.13)
read-only
Counter64
Counter64
Number of packets that have been forwarded over the tunnel.
teTunnelLPOctets
(1.3.6.1.2.1.122.1.2.1.14)
read-only
Counter32
Counter32
(0..4294967295)
teTunnelLPPackets
(1.3.6.1.2.1.122.1.2.1.15)
read-only
Counter32
Counter32
(0..4294967295)
teTunnelAge
(1.3.6.1.2.1.122.1.2.1.16)
read-only
TimeTicks
The age of this tunnel in hundredths of a second.
As per the MIB.
teTunnelTimeUp
(1.3.6.1.2.1.122.1.2.1.17)
read-only
TimeTicks
Total time in hundredths of a second that this tunnel has been operational (in up state).
As per the MIB.
teTunnelPrimaryTimeUp
(1.3.6.1.2.1.122.1.2.1.18)
read-only
TimeTicks
Total time in hundredths of a second that this tunnel's primary path has been operational.
As per the MIB.
teTunnelTransitions
(1.3.6.1.2.1.122.1.2.1.19)
read-only
Counter32
Counter32
(0..4294967295)
Number of operational state transitions (up-to-down or down-to-up) this tunnel has undergone.
As per the MIB.
teTunnelLastTransition
(1.3.6.1.2.1.122.1.2.1.20)
read-only
TimeTicks
The time in hundredths of a second since the last operational state transition occurred on this tunnel.
As per the MIB.
teTunnelPathChanges
(1.3.6.1.2.1.122.1.2.1.21)
read-only
Counter32
Counter32
(0..4294967295)
Number of path changes this tunnel has had.
As per the MIB.
teTunnelLastPathChange
(1.3.6.1.2.1.122.1.2.1.22)
read-only
TimeTicks
The time in hundredths of a second since the last path change occurred on this tunnel.
As per the MIB.
teTunnelConfiguredPaths
(1.3.6.1.2.1.122.1.2.1.23)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of paths configured for this tunnel.
As per the MIB.
teTunnelStandbyPaths
(1.3.6.1.2.1.122.1.2.1.24)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of standby paths configured for this tunnel.
As per the MIB.
teTunnelOperationalPaths
(1.3.6.1.2.1.122.1.2.1.25)
read-only
Gauge32
Gauge32
(0..4294967295)
Number of operational paths for this tunnel.
As per the MIB.
tePathTable
About this table
This table is used to create and delete the explicit paths on a tunnel interface.
Create
Edit/Modify
Delete
Read
You must specify tePathName, tePathConfiguredRoute, or both. An error will be returned if you specify both objects but the values conflict, for example, the explicit path name specified by tePathConfiguredRoute is not consistent with the path name specified by tePathName.
If you set the value of tePathConfiguredRoute to 0, the tunnel will use a dynamically calculated path. If you set tePathConfiguredRoute to a non-zero value, you must also specify tePathName and the value of tePathName cannot be null. If you set tePathIndex to a value between 101 and 110, you must specify the tePathType and set its value to standby(3).
Not supported
Supported
The value of NULL for tePathName indicates that the explicit path is dynamically calculated. In this case, the value for tePathConfiguredRoute is also 0.
Columns
The table index is tePathIndex.
Object (OID)
Access
Value range
Implementation
tePathIndex
(1.3.6.1.2.1.122.1.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Preference value of an explicit path, an index that uniquely identifies the path within a tunnel.
As per the MIB.
tePathName
(1.3.6.1.2.1.122.1.3.1.2)
read-create
SnmpAdminString
OCTET STRING
(0..32)
Name of the path.
tePathRowStatus
(1.3.6.1.2.1.122.1.3.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
destroy(6)
Row status.
tePathStorageType
(1.3.6.1.2.1.122.1.3.1.4)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
tePathType
(1.3.6.1.2.1.122.1.3.1.5)
read-create
INTEGER
other(1),
primary(2),
standby(3),
secondary(4)
Type of the path.
Supports only primary(2) and standby(3).
(1.3.6.1.2.1.122.1.3.1.6)
read-create
Unsigned32
Unsigned32
(1..4294967295)
Index of the route that the path is configured to follow.
As per the MIB.
tePathBandwidth
(1.3.6.1.2.1.122.1.3.1.7)
read-create
MplsBitRate
Unsigned32
(0..2147483647)
Bandwidth for the path.
tePathOperStatus
(1.3.6.1.2.1.122.1.3.1.14)
read-only
INTEGER
unknown(0),
down(1),
testing(2),
dormant(3),
ready(4),
operational(5)
Operational state of the path.
Supports only down(1), dormant(3), and operational(5).
tePathAdminStatus
(1.3.6.1.2.1.122.1.3.1.15)
read-create
INTEGER
normal(1),
testing(2)
Administrative state of the path.
Not supported. The value is always normal(1).
tePathComputedRoute
(1.3.6.1.2.1.122.1.3.1.16)
read-only
Unsigned32
Unsigned32
(1..4294967295)
Index of the route computed for the path.
As per the MIB.
tePathRecordedRoute
(1.3.6.1.2.1.122.1.3.1.17)
read-only
Unsigned32
Unsigned32
(1..4294967295)
Index of the route actually used for the path.
As per the MIB.
tePathHopTable
About this table
This table contains information about the path hop table, path computed route table, and path recorded route table.
Create
Edit/Modify
Delete
Read
The tePathHopAddress object must be specified, and the value for teHopListIndex must be in the range of 0x1 to 0xfffff.
Not supported
Supported
If the value for teHopListIndex is between 1 and 1048575, the information is about a path hop table.
If the value for teHopListIndex is between 1048577 and 2097151, the information is about a path computed route table.
If the value for teHopListIndex is between 2097153 and 3145727, the information is about a path recorded route table.
The computed route table and the recorded route table do not contain tePathHopStorageType and tePathHopType.
Columns
The table indexes are teHopListIndex and tePathHopIndex.
Object (OID)
Access
Value range
Implementation
teHopListIndex
(1.3.6.1.2.1.122.1.4.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index that identifies a list of hops.
As per the MIB.
tePathHopIndex
(1.3.6.1.2.1.122.1.4.1.2)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index that identifies a particular hop among the list of hops for a path.
As per the MIB.
tePathHopRowStatus
(1.3.6.1.2.1.122.1.4.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
destroy(6)
Row status.
(1.3.6.1.2.1.122.1.4.1.4)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type.
tePathHopAddrType
(1.3.6.1.2.1.122.1.4.1.5)
read-create
TeHopAddressType
unknown(0),
ipv4(1),
ipv6(2),
asnumber(3),
unnum(4),
lspid(5)
Address type of the hop.
tePathHopAddress
(1.3.6.1.2.1.122.1.4.1.6)
read-create
TeHopAddress
OCTET STRING
(0..32)
Address of the hop.
As per the MIB.
tePathHopType
(1.3.6.1.2.1.122.1.4.1.7)
read-only
INTEGER
unknown(0),
loose(1),
strict(2)
Type of the hop.
As per the MIB.
Notifications
teTunnelUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.122.0.1
TE tunnel up
Recovery
Warning
ON
This notification is generated when the tunnel specified by teTunnelName transitions to the up state.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name)
Index
Value range
(teTunnelName)
TE tunnel name
No
SnmpAdminString
OCTET STRING (SIZE (1..32))
(tePathName)
Name of the TE tunnel's path
No
SnmpAdminString
OCTET STRING (SIZE (0..32))
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
teTunnelDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.2
TE tunnel down
Error
Major
ON
This notification is generated when the tunnel specified by teTunnelName transitions to the down state.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
(teTunnelName)
TE tunnel name
No
SnmpAdminString
(tePathName)
No
SnmpAdminString
Recommended action
teTunnelChanged
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.122.0.3
TE tunnel path change
Informational
Warning
ON
This notification is generated when the active path on the tunnel specified by teTunnelName changes or a new path becomes active. The value of tePathName is the new active path.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
 (teTunnelName)
TE tunnel name
No
SnmpAdminString
(tePathName)
No
SnmpAdminString
Recommended action
  • Become a Partner
  • Partner Resources
