- 08-MPLS
- 01-HH3C-VPN-PEER-MIB
- 02-HH3C-VSI-MIB
- 03-MPLS-FRR-FACILITY-STD-MIB
- 04-MPLS-FRR-GENERAL-STD-MIB
- 05-MPLS-FTN-STD-MIB
- 06-MPLS-L3VPN-STD-MIB
- 07-MPLS-LDP-STD-MIB
- 08-MPLS-LSR-STD-MIB
- 09-MPLS-TE-STD-MIB
- 10-TE-MIB
- 11-HH3C-EVC-MIB
- 12-HH3C-L3VPN-MIB
- 13-HH3C-MPLSEXT-MIB
- 14-HH3C-MPLSTE-MIB
- 15-HH3C-MPLS-VPN-BGP-MIB
02-HH3C-VSI-MIB | 70.25 KB |
HH3C-VSI-MIB
About this MIB
Use this MIB to configure VSI.
MIB file name
hh3c-vsi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVsi(105)
Tabular objects
hh3cVsiScalarGroup
About this table
This table describes the global configuration for VSI.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiNextAvailableVsiIndex (1.3.6.1.4.1.25506.2.105.1.1.1) |
read-only |
Unsigned32 |
Next available VSI entry index. |
As per the MIB. |
hh3cVsiL2vpnStatus (1.3.6.1.4.1.25506.2.105.1.1.2) |
read-write |
TruthValue |
true(1) false(2) |
Global enabling status of L2VPN. |
As per the MIB. |
hh3cVsiTable
About this table
Use this table to configure VSI parameters.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVsiIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiIndex (1.3.6.1.4.1.25506.2.105.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
Index of a VSI. |
As per the MIB. |
hh3cVsiName (1.3.6.1.4.1.25506.2.105.1.2.1.2) |
read-create |
OCTET STRING |
OCTET STRING (1..31) |
Name of a VSI. |
Not editable after creation. |
hh3cVsiMode (1.3.6.1.4.1.25506.2.105.1.2.1.3) |
read-create |
INTEGER |
default(0), martini(1), minm(2) martiniAndMinm(3), kompella(4), kompellaAndMinm(5), minmpxp(6), martiniAndMinmpxp(7), kompellaAndMinmpxp(8), vxlan(9) |
Mode of the VSI. |
Supports only default(0) and vxlan(9). The set operation on other variables will be ignored. The default value is default(0). |
hh3cVsiId (1.3.6.1.4.1.25506.2.105.1.2.1.5) |
read-create |
Unsigned32 |
Default PW ID. |
hh3cVsiTransMode (1.3.6.1.4.1.25506.2.105.1.2.1.6) |
read-create |
vlan(1), ethernet(2) |
Transmit mode of the VSI. |
Supports only the read operation. The value is always vlan(1). |
hh3cVsiAdminState (1.3.6.1.4.1.25506.2.105.1.2.1.8) |
read-create |
INTEGER |
adminUp(1), adminDown(2) |
Administrative state of the VSI. |
Default value: adminUp(1). |
hh3cVsiRowStatus (1.3.6.1.4.1.25506.2.105.1.2.1.9) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). Active(1) is only used to change the value for hh3cVsiAdminState, hh3cVsiArpSuppression, hh3cVsiFlooding, and hh3cVsiStatistics. |
hh3cVsiVxlanID (1.3.6.1.4.1.25506.2.105.1.2.1.11) |
read-only |
Unsigned32 |
VXLAN ID. |
As per the MIB. |
hh3cVsiArpSuppression (1.3.6.1.4.1.25506.2.105.1.2.1.12) |
read-create |
TruthValue |
true(1) false(2) |
The capability of ARP suppression. |
Implementation varies by product. |
hh3cVsiFlooding (1.3.6.1.4.1.25506.2.105.1.2.1.13) |
read-create |
TruthValue |
true(1) false(2) |
The capability of MAC flooding. |
hh3cVsiLocalMacCount (1.3.6.1.4.1.25506.2.105.1.2.1.14) |
read-only |
Unsigned32 |
Number of local MAC addresses of the VSI. |
This value is 0 if hh3cVsiVxlanID uses an invalid value. This value cannot be 0 if hh3cVsiVxlanID uses a valid value. |
hh3cVsiInterfaceID (1.3.6.1.4.1.25506.2.105.1.2.1.15) |
read-create |
Unsigned32 |
VSI interface number. |
hh3cVsiStatistics (1.3.6.1.4.1.25506.2.105.1.2.1.16) |
read-create |
TruthValue |
true(1) false(2) |
VSI traffic statistics capability. |
hh3cVsiNvgreID (1.3.6.1.4.1.25506.2.105.1.2.1.17) |
read-only |
Unsigned32 |
NVGRE ID |
As per the MIB. |
hh3cVsiXconnectTable
About this table
Use this table to configure AC-VSI bindings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsiXconnectIfIndex and hh3cVsiXconnectEvcSrvInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
(1.3.6.1.4.1.25506.2.105.1.3.1.1) |
not-accessible |
Unsigned32 |
Index of an interface. |
As per the MIB. |
hh3cVsiXconnectEvcSrvInstId (1.3.6.1.4.1.25506.2.105.1.3.1.2) |
not-accessible |
Unsigned32 |
Service instance ID. |
As per the MIB. |
hh3cVsiXconnectVsiName (1.3.6.1.4.1.25506.2.105.1.3.1.3) |
read-create |
OCTET STRING |
Name of the VSI. |
hh3cVsiXconnectAccessMode (1.3.6.1.4.1.25506.2.105.1.3.1.4) |
read-create |
INTEGER |
Access mode. |
hh3cVsiXconnectHubSpoke (1.3.6.1.4.1.25506.2.105.1.3.1.5) |
read-create |
INTEGER |
none(1), hub(2), spoke(3) |
The hub-spoke capability of the service instance. |
hh3cVsiXconnectRowStatus (1.3.6.1.4.1.25506.2.105.1.3.1.6) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cVsiFloodMacTable
About this table
This table contains MAC addresses enabled with selective flooding in a VSI.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsiIndex and hh3cVsiFloodMac.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiFloodMac (1.3.6.1.4.1.25506.2.105.1.5.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
hh3cVsiFloodMacRowStatus (1.3.6.1.4.1.25506.2.105.1.5.1.2) |
read-create |
RowStatus |
Row status. |
hh3cVsiLocalMacTable
About this table
This table contains information about local MAC addresses of a VSI.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVsiIndex and hh3cVsiLocalMacAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiLocalMacAddr (1.3.6.1.4.1.25506.2.105.1.6.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
hh3cVsiLocalMacIfIndex (1.3.6.1.4.1.25506.2.105.1.6.1.2) |
read-only |
InterfaceIndex |
InterfaceIndex (1..2147483647) |
Outgoing interface of the MAC addresses. |
As per the MIB. |
hh3cVsiLocalMacSrvID (1.3.6.1.4.1.25506.2.105.1.6.1.3) |
read-only |
Unsigned32 |
ID of the service instance on the outgoing interface. |
As per the MIB. |
hh3cVsiPerfTable
About this table
This table contains performance statistics for VSIs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiPerfInOctets (1.3.6.1.4.1.25506.2.105.1.7.1.1) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Total number of octets received by the VSI. |
As per the MIB. |
hh3cVsiPerfInPackets (1.3.6.1.4.1.25506.2.105.1.7.1.2) |
read-only |
Counter64 |
Total number of packets received by the VSI. |
As per the MIB. |
hh3cVsiPerfInErrors (1.3.6.1.4.1.25506.2.105.1.7.1.3) |
read-only |
Counter64 |
Number of error packets received by the VSI. |
As per the MIB. |
hh3cVsiPerfInDiscards (1.3.6.1.4.1.25506.2.105.1.7.1.4) |
read-only |
Counter64 |
Number of incoming packets discarded by the VSI. |
As per the MIB. |
hh3cVsiPerfOutOctets (1.3.6.1.4.1.25506.2.105.1.7.1.5) |
read-only |
Counter64 |
Total number of octets sent by the VSI. |
As per the MIB. |
hh3cVsiPerfOutPackets (1.3.6.1.4.1.25506.2.105.1.7.1.6) |
read-only |
Counter64 |
Total number of packets sent by the VSI. |
As per the MIB. |
hh3cVsiPerfOutErrors (1.3.6.1.4.1.25506.2.105.1.7.1.7) |
read-only |
Counter64 |
Number of packets that failed to be sent because of a VSI error. |
As per the MIB. |
hh3cVsiPerfOutDiscards (1.3.6.1.4.1.25506.2.105.1.7.1.8) |
read-only |
Counter64 |
Number of outgoing packets discarded by the VSI because of transmission failure. |
As per the MIB. |
hh3cVsiNextAvailableVsiIfID
About this table
This table contains information about next available VSI interface numbers.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiNextAvailableVsiIfID (1.3.6.1.4.1.25506.2.105.1.8) |
read-only |
Unsigned32 |
hh3cVsiIfTable
About this table
Use this table to configure VSI interface parameters.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVsiIfID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsiIfID (1.3.6.1.4.1.25506.2.105.1.9.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cVsiIfIndex (1.3.6.1.4.1.25506.2.105.1.9.1.2) |
read-only |
InterfaceIndex |
Integer32 (1..2147483647) |
VSI interface index. |
As per the MIB. |
hh3cVsiIfRowStatus (1.3.6.1.4.1.25506.2.105.1.9.1.3) |
read-create |
RowStatus |
Row status. |
