08-MPLS
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10008-MPLS
07-MPLS-LDP-STD-MIB
07-MPLS-LDP-STD-MIB 146.61 KB
MPLS-LDP-STD-MIB
About this MIB
LDP is the core of MPLS and defines the messages and processing procedures involved in the label distribution process.
The Label Distribution Protocol (LDP) dynamically distributes FEC-label mapping information between LSRs to establish LSPs. LSPs can be established between two adjacent LSRs or terminate at the egress node of the network, so that all intermediate nodes in the network use label switching.
MPLS-LDP-STD-MIB is a public MIB defined by RFC 3815.
MIB file name
rfc3815-mpls-ldp-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsLdpStdMIB(4)
Scalar objects
mplsLdpLsrId
Object (OID)
Access
Value range
Implementation
mplsLdpLsrId (1.3.6.1.2.1.10.166.4.1.1.1)
read-only
Octet string
Octet string
(0..65535)
LDP LSR ID.
As per the MIB.
mplsLdpLsrLoopDetectionCapable
Object (OID)
Access
Value range
Implementation
mplsLdpLsrLoopDetectionCapable (1.3.6.1.2.1.10.166.4.1.1.2)
read-only
Integer
1:none(1)
2:other(2)
3:hopCount(3)
4:pathVector(4)
5:hopCountAndPathVector(5)
Whether the LSR supports loop detection.
The value of this object is fixed at hopCountAndPathVector(5).
mplsLdpEntityLastChange
Object (OID)
Access
Value range
Implementation
mplsLdpEntityLastChange (1.3.6.1.2.1.10.166.4.1.2.1)
read-only
TimeTicks
Standard MIB values.
System time when an entry in the mplsLdpEntityTable  table was most recently added, deleted, or modified.
As per the MIB.
mplsLdpEntityIndexNext
Object (OID)
Access
Value range
Implementation
mplsLdpEntityIndexNext (1.3.6.1.2.1.10.166.4.1.2.2)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Next LDP entity index.
This object returns 0, which indicates that the network administrator cannot create mplsLdpEntityTable.
mplsLdpPeerLastChange
Object (OID)
Access
Value range
Implementation
mplsLdpPeerLastChange (1.3.6.1.2.1.10.166.4.1.3.1)
read-only
TimeStamp
INTEGER
(0..4294967295)
Time when the entry was edited.
As per the MIB.
mplsFecLastChange
Object (OID)
Access
Value range
Implementation
mplsFecLastChange (1.3.6.1.2.1.10.166.4.1.3.8.1)
read-only
TimeStamp
INTEGER
(0..4294967295)
System time when the LDP FEC entry was most recently modified.
Not supported
mplsFecIndexNext
Object (OID)
Access
Value range
Implementation
mplsFecIndexNext (1.3.6.1.2.1.10.166.4.1.3.8.2)
read-only
IndexIntegerNextFree
Gauge32
(1..4294967295)
Next LDP FEC index.
This object returns 0, which indicates that the network administrator cannot create mplsFecTable.
Tabular objects
mplsLdpEntityTable
About this table
This table contains LDP entity information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsLdpEntityLdpId and mplsLdpEntityIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpEntityLdpId (1.3.6.1.2.1.10.166.4.1.2.3.1.1)
not-accessible
MplsLdpIdentifier
OCTET STRING
(6,6)
LDP entity ID.
As per the MIB.
mplsLdpEntityIndex (1.3.6.1.2.1.10.166.4.1.2.3.1.2)
not-accessible
Unsigned32
Unsigned32
(1,4294967295)
LDP entity index.
As per the MIB.
mplsLdpEntityProtocolVersion (1.3.6.1.2.1.10.166.4.1.2.3.1.3)
read-create
Unsigned32
Unsigned32
(1~65535)
Version number of the LDP protocol which will be used in the session initialization message.
As per the MIB.
mplsLdpEntityAdminStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.4)
read-create
INTEGER
enable(1)
disable(2)
Administrative state of the LDP entity.
As per the MIB.
mplsLdpEntityOperStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.5)
read-only
INTEGER
1:unknown(1)
2:enabled(2)
3:disabled(3)
Operational state of the LDP entity.
As per the MIB.
Default: enabled.
mplsLdpEntityTcpPort (1.3.6.1.2.1.10.166.4.1.2.3.1.6)
read-create
Unsigned32
Unsigned32
(0..65535)
TCP port number of the LDP entity.
As per the MIB.
Default: 646.
mplsLdpEntityUdpDscPort (1.3.6.1.2.1.10.166.4.1.2.3.1.7)
read-create
Unsigned32
Unsigned32
(0..65535)
UDP port number of the LDP entity.
As per the MIB.
Default: 646.
mplsLdpEntityMaxPduLength (1.3.6.1.2.1.10.166.4.1.2.3.1.8)
read-create
Unsigned32
Unsigned32
(256..65535)
Maximum PDU length of the LDP entity.
As per the MIB.
Default: 4096.
mplsLdpEntityKeepAliveHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.9)
read-create
Unsigned32
Unsigned32
(1..65535)
Keepalive interval of the LDP entity.
As per the MIB.
Default: 40.
mplsLdpEntityHelloHoldTimer (1.3.6.1.2.1.10.166.4.1.2.3.1.10)
read-create
Unsigned32
Unsigned32
(0..65535)
Hello interval of the LDP entity.
As per the MIB.
Default: 0.
If mplsLdpEntityTargetPeer is set to false, the actual default value is 15. If mplsLdpEntityTargetPeer is set to true, the actual default value is 45.
mplsLdpEntityInitSessionThreshold (1.3.6.1.2.1.10.166.4.1.2.3.1.11)
read-create
Integer32
Integer32
(0..100)
LDP entity session initialization threshold.
As per the MIB.
Default: 8.
mplsLdpEntityLabelDistMethod (1.3.6.1.2.1.10.166.4.1.2.3.1.12)
read-create
INTEGER
downstreamOnDemand(1)
downstreamUnsolicited(2)
LDP entity label distribution method.
As per the MIB.
mplsLdpEntityLabelRetentionMode (1.3.6.1.2.1.10.166.4.1.2.3.1.13)
read-create
INTEGER
conservative(1)
liberal(2)
Label retention mode used by the LDP entity.
As per the MIB.
mplsLdpEntityPathVectorLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.14)
read-create
Integer32
Integer32
(0..255)
LDP entity path vector limit.
As per the MIB.
0 indicates that loop detection is not enabled.
mplsLdpEntityHopCountLimit (1.3.6.1.2.1.10.166.4.1.2.3.1.15)
read-create
Integer32
Integer32
(0..255)
LDP entity hop limit.
As per the MIB.
mplsLdpEntityTransportAddrKind (1.3.6.1.2.1.10.166.4.1.2.3.1.16)
read-create
INTEGER
1:Interface(1)
2:loopback(2)
LDP entity transport address type.
As per the MIB.
Default: loopback(2).
mplsLdpEntityTargetPeer (1.3.6.1.2.1.10.166.4.1.2.3.1.17)
read-create
INTEGER
true(1)
false(2)
If this LDP entity uses targeted peer, set this to true.
As per the MIB.
Default: false.
mplsLdpEntityTargetPeerAddrType (1.3.6.1.2.1.10.166.4.1.2.3.1.18)
read-create
InetAddressType
INTEGER
unknown (0) ,
ipv4(1) ,
ipv6 (2) ,
ipv4z (3) ,
ipv6z (4),
dns(16)
Type of the internetwork layer address used for the Extended Discovery.
As per the MIB.
Supports only ipv4.
mplsLdpEntityTargetPeerAddr (1.3.6.1.2.1.10.166.4.1.2.3.1.19)
read-create
OCTET STRING
OCTET STRING
(0..255)
The value of the internetwork layer address used for the Extended Discovery.
As per the MIB.
mplsLdpEntityLabelType (1.3.6.1.2.1.10.166.4.1.2.3.1.20)
read-create
INTEGER
generic(1),
atmParameters(2),
frameRelayParameters(3)
LDP entity label type.
As per the MIB.
mplsLdpEntityDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.2.3.1.21)
read-only
TimeTicks
System time when any one or more of this entity's counters suffered a discontinuity most recently.
As per the MIB.
mplsLdpEntityStorageType (1.3.6.1.2.1.10.166.4.1.2.3.1.22)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
 permanent(4),
readOnly(5)
Storage type for the LDP entity.
As per the MIB.
mplsLdpEntityRowStatus (1.3.6.1.2.1.10.166.4.1.2.3.1.23)
read-create
INTEGER
 active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsLdpEntityStatsTable
About this table
This table contains LDP entity statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
mplsLdpEntityStatsSessionAttempts (1.3.6.1.2.1.10.166.4.1.2.4.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Session initialization messages sent or received by this LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedNoHelloErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (No Hello Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedAdErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.3)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Advertisement Mode Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedMaxPduErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.4)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Max Pdu Length Error) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsSessionRejectedLRErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.5)
read-only
Counter32
Counter32
(0..4294967295)
Session Rejected (Parameters Label Range) notifications sent or received by the LDP entity.
As per the MIB.
mplsLdpEntityStatsBadLdpIdentifierErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.6)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad LDP Identifier Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadPduLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.7)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad PDU Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadMessageLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.8)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad Message Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsBadTlvLengthErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.9)
read-only
Counter32
Counter32
(0..4294967295)
Number of Bad TLV Length Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsMalformedTlvValueErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.10)
read-only
Counter32
Counter32
(0..4294967295)
Number of Malformed TLV Value Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsKeepAliveTimerExpErrors (1.3.6.1.2.1.10.166.4.1.2.4.1.11)
read-only
Counter32
Counter32
(0..4294967295)
Number of Session Keep Alive Timer Expired Fatal Errors detected by the sessions associated with this LDP entity.
As per the MIB.
mplsLdpEntityStatsShutdownReceivedNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.12)
read-only
Counter32
Counter32
(0..4294967295)
Number of shutdown notifications received by sessions associated with the LDP entity.
As per the MIB.
mplsLdpEntityStatsShutdownSentNotifications (1.3.6.1.2.1.10.166.4.1.2.4.1.13)
read-only
Counter32
Counter32
(0..4294967295)
Number of shutdown notifications sent by sessions associated with the LDP entity.
As per the MIB.
mplsLdpPeerTable
About this table
This table contains LDP peer information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsLdpPeerLdpId.
Object (OID)
Access
Value range
Implementation
mplsLdpPeerLdpId (1.3.6.1.2.1.10.166.4.1.3.2.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP ID of the LDP peer.
As per the MIB.
mplsLdpPeerLabelDistMethod (1.3.6.1.2.1.10.166.4.1.3.2.1.2)
read-only
INTEGER
downstreamOnDemand(1),
Label distribution method of the LDP peer.
As per the MIB.
mplsLdpPeerPathVectorLimit (1.3.6.1.2.1.10.166.4.1.3.2.1.3)
read-only
Integer32
Integer32
(0..255)
Path vector limit information about the LDP peer.
As per the MIB.
mplsLdpPeerTransportAddrType (1.3.6.1.2.1.10.166.4.1.3.2.1.4)
read-only
INTEGER
unknown(0),
ipv4(1),
 ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
LDP peer address type.
As per the MIB.
mplsLdpPeerTransportAddr (1.3.6.1.2.1.10.166.4.1.3.2.1.5)
read-only
OCTET STRING
OCTET STRING
( 0..255)
LDP peer address.
As per the MIB.
mplsLdpSessionTable
About this table
This table contains LDP session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
mplsLdpSessionStateLastChange (1.3.6.1.2.1.10.166.4.1.3.3.1.1)
read-only
TimeTicks
Time when the LDP session state changed.
As per the MIB.
mplsLdpSessionState (1.3.6.1.2.1.10.166.4.1.3.3.1.2)
read-only
INTEGER
nonexistent(1),
initialized(2),
openrec(3),
opensent(4),
operational(5)
LDP session state.
As per the MIB.
mplsLdpSessionRole (1.3.6.1.2.1.10.166.4.1.3.3.1.3)
read-only
INTEGER
unknown(1),
active(2),
passive(3)
LDP session role.
As per the MIB.
mplsLdpSessionProtocolVersion (1.3.6.1.2.1.10.166.4.1.3.3.1.4)
read-only
Unsigned32
Unsigned32
(1..65535)
LDP session protocol version.
As per the MIB.
mplsLdpSessionKeepAliveHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.3.1.5)
read-only
INTEGER
INTEGER (0..2147483647)
Remaining keepalive time.
As per the MIB.
mplsLdpSessionKeepAliveTime (1.3.6.1.2.1.10.166.4.1.3.3.1.6)
read-only
Unsigned32
Unsigned32
(1..65535)
Keepalive interval.
As per the MIB.
mplsLdpSessionMaxPduLength (1.3.6.1.2.1.10.166.4.1.3.3.1.7)
read-only
Unsigned32
Unsigned32
(1..65535)
Maximum PDU length.
As per the MIB.
mplsLdpSessionDiscontinuityTime (1.3.6.1.2.1.10.166.4.1.3.3.1.8)
read-only
TimeTicks
System time when a counter of the LDP session suffered a discontinuity.
As per the MIB.
mplsLdpSessionStatsTable
About this table
This table contains LDP session statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
mplsLdpSessionStatsUnknownMesTypeErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.1)
read-only
Counter32
Counter32
(0..4294967295)
Number of unknown messages detected by the LSR during the session.
As per the MIB.
mplsLdpSessionStatsUnknownTlvErrors (1.3.6.1.2.1.10.166.4.1.3.4.1.2)
read-only
Counter32
Counter32
(0..4294967295)
Number of unknown TLVs detected by the LSR during the session.
As per the MIB.
mplsLdpHelloAdjacencyTable
About this table
This table contains LDP hello adjacency information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsLdpHelloAdjacencyIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpHelloAdjacencyIndex (1.3.6.1.2.1.10.166.4.1.3.5.1.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP hello adjacency index.
As per the MIB.
mplsLdpHelloAdjacencyHoldTimeRem (1.3.6.1.2.1.10.166.4.1.3.5.1.1.2)
read-only
INTEGER
INTEGER
(0..2147483647)
Time remaining for the hello adjacency.
As per the MIB.
mplsLdpHelloAdjacencyHoldTime (1.3.6.1.2.1.10.166.4.1.3.5.1.1.3)
read-only
Unsigned32
Unsigned32
(0..65535)
Hold time for the hello adjacency.
As per the MIB.
Default: 0.
The actual default value is 15 for the Link Hello mode and 45 for the Targeted Hello mode.
mplsLdpHelloAdjacencyType (1.3.6.1.2.1.10.166.4.1.3.5.1.1.4)
read-only
INTEGER
link(1),
targeted(2)
LDP hello adjacency type.
As per the MIB.
mplsInSegmentLdpLspTable
About this table
This table contains LDP incoming label configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsInSegmentLdpLspIndex.
Object (OID)
Access
Value range
Implementation
mplsInSegmentLdpLspIndex (1.3.6.1.2.1.10.166.4.1.3.6.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP incoming label index.
0x00 is invalid.
mplsInSegmentLdpLspLabelType (1.3.6.1.2.1.10.166.4.1.3.6.1.2)
read-only
INTEGER
generic(1),
atmParameters(2),
LDP LSP incoming label type.
Supports only the read operation.
Supports only generic.
mplsInSegmentLdpLspType (1.3.6.1.2.1.10.166.4.1.3.6.1.2)
read-only
INTEGER
unknown(1),
terminatingLsp(2),
originatingLsp(3),
crossConnectingLsp(4)
LDP LSP type.
As per the MIB.
mplsOutSegmentLdpLspTable
About this table
This table contains LDP outgoing label table information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsOutSegmentLdpLspIndex.
Object (OID)
Access
Value range
Implementation
mplsOutSegmentLdpLspIndex (1.3.6.1.2.1.10.166.4.1.3.7.1.1)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP outgoing label index.
0x00 is invalid.
mplsOutSegmentLdpLspLabelType (1.3.6.1.2.1.10.166.4.1.3.7.1.2)
read-only
INTEGER
generic(1),
atmParameters(2),
LDP LSP outgoing label type.
mplsOutSegmentLdpLspType (1.3.6.1.2.1.10.166.4.1.3.7.1.3)
read-only
INTEGER
unknown(1),
terminatingLsp(2),
originatingLsp(3),
LDP LSP type.
As per the MIB.
mplsFecTable
About this table
This table contains LDP FEC information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsFecIndex.
Object (OID)
Access
Value range
Implementation
mplsFecIndex (1.3.6.1.2.1.10.166.4.1.3.8.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP FEC index.
As per the MIB.
MplsFecType
(1.3.6.1.2.1.10.166.4.1.3.8.3.1.2)
read-create
INTEGER
prefix(1),
hostAddress(2)
LDP FEC type.
As per the MIB.
mplsFecAddrPrefixLength (1.3.6.1.2.1.10.166.4.1.3.8.3.1.3)
read-create
Unsigned32
Unsigned32
 (0..2040)
This node will not be defined if the mplsFecType is hostAddress(2).
The value for this node is 0 or the IP prefix range defined by mplsFecAddr if the mplsFecType is prefix(1).
If the value for this node is 0, it means that the IP prefix matches all IP addresses.
As per the MIB.
mplsFecAddrType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.4)
read-create
INTEGER
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
LDP FEC address type.
As per the MIB.
mplsFecAddr (1.3.6.1.2.1.10.166.4.1.3.8.3.1.5)
read-create
OCTET STRING
OCTET STRING
 (0..65535)
LDP FEC address.
As per the MIB.
mplsFecStorageType (1.3.6.1.2.1.10.166.4.1.3.8.3.1.6)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
LDP FEC storage type.
As per the MIB.
mplsFecRowStatus (1.3.6.1.2.1.10.166.4.1.3.8.3.1.7)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
mplsLdpLspFecTable
About this table
This table contains the relationship between LDP LSPs and FECs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are mplsLdpLspFecSegment, mplsLdpLspFecSegmentIndex, and mplsLdpLspFecIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpLspFecSegment (1.3.6.1.2.1.10.166.4.1.3.10.1.1)
not-accessible
INTEGER
INTEGER
inSegment (1),
outSegment (2)
LDP LSP label type.
If the value of this object is inSegment, mplsLdpLspFecSegmentIndex must be consistent with mplsInSegmentLdpLspIndex. If the value of this object is set to outSegment, mplsLdpLspFecSegmentIndex must be consistent with mplsOutSegmentLdpLspIndex.
mplsLdpLspFecSegmentIndex (1.3.6.1.2.1.10.166.4.1.3.10.1.2)
not-accessible
OCTET STRING
OCTET STRING
(0..65535)
LDP LSP label index.
0x00 is invalid.
mplsLdpLspFecIndex (1.3.6.1.2.1.10.166.4.1.3.10.1.3)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
LDP FEC index.
As per the MIB.
mplsLdpLspFecStorageType
(1.3.6.1.2.1.10.166.4.1.3.10.1.4)
read-create
INTEGER
other(1),
 volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
The value of this object is fixed at volatile.
mplsLdpLspFecRowStatus
(1.3.6.1.2.1.10.166.4.1.3.10.1.5)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
The row status is fixed at active(1).
mplsLdpSessionPeerAddrTable
About this table
This table contains LDP session peer address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is mplsLdpSessionPeerAddrIndex.
Object (OID)
Access
Value range
Implementation
mplsLdpSessionPeerAddrIndex (1.3.6.1.2.1.10.166.4.1.3.11.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Peer address index.
As per the MIB.
mplsLdpSessionPeerNextHopAddrType (1.3.6.1.2.1.10.166.4.1.3.11.1.2)
read-only
INTEGER
unknown(0),
ipv4(1),
ipv6(2),
ipv4z(3),
ipv6z(4),
dns(16)
Next hop address type.
As per the MIB.
mplsLdpSessionPeerNextHopAddr (1.3.6.1.2.1.10.166.4.1.3.11.1.3)
read-only
OCTET STRING
OCTET STRING
(0..65535)
Next hop address.
As per the MIB.
Notifications
mplsLdpInitSessionThresholdExceeded
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.10.166.4.0.1
The number of session initialization messages exceeds the limit.
Error
Major
1.3.6.1.2.1.10.166.4.1.2.3.1.11 (mplsLdpEntityInitSessionThreshold)
ON
A notification sent when the value of the mplsLdpEntityInitSessionThreshold object is not zero and the number of session initialization messages exceeds the value of the mplsLdpEntityInitSessionThreshold object.
Status control
ON
CLI: Use the snmp-agent trap enable ldp command.
OFF
CLI: Use the undo snmp-agent trap enable ldp command.
Objects
OID (object name)
Index
Value range
During the session establishment with an LDP peer, if the number of session initialization messages sent by the LDP entity exceeds the maximum value defined by the mplsLdpInitSessionThresholdExceeded object, the LDP entity will send notifications.
No
Integer32
0..100
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve this issue:
1.     Check LDP session initialization message parameters.
2.     If the issue persists, contact H3C Support.
mplsLdpSessionUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.4.0.3
The session state changes to operational.
Recovery
Warning
ON
A notification sent when the value of the mplsLdpSessionState object changes to operational(5).
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.10.166.4.1.3.3.1.2 (mplsLdpSessionState)
LDP session state.
No
INTEGER
nonexistent(1)
initialized(2)
openrec(3)
opensent(4)
operational(5))
1.3.6.1.2.1.10.166.4.1.3.3.1.8 (mplsLdpSessionDiscontinuityTime)
Time when the LDP session is up.
No
Timeticks
1.3.6.1.2.1.10.166.4.1.3.4.1.1 (mplsLdpSessionStatsUnknownMesTypeErrors)
No
Counter32
1.3.6.1.2.1.10.166.4.1.3.4.1.2 (mplsLdpSessionStatsUnknownTlvErrors)
No
Counter32
Recommended action
No action is required.
mplsLdpSessionDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.10.166.4.0.4
The session state is not operational.
Error
Major
ON
A notification sent when the value of the mplsLdpSessionState object is not operational.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Session state.
No
INTEGER
nonexistent(1)
initialized(2)
openrec(3)
opensent(4)
operational(5))
No
Timeticks
No
Counter32
No
Counter32
Recommended action
  • Become a Partner
  • Partner Resources
