03-Layer 2—LAN Switching Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500G-AF&S12500CR&S10500X-G&S7500X-G Switch Series Configuration Examples-R7753Pxx[R8053Pxx]-6W10003-Layer 2—LAN Switching Configuration Examples
09-VLAN Tagging Configuration Examples
09-VLAN Tagging Configuration Examples 1.02 MB
Introduction· 1
Prerequisites· 1
General configuration restrictions and guidelines· 1
Example: Configuring QinQ·· 2
Network configuration· 2
Applicable hardware and software versions· 2
Restrictions and guidelines· 3
Procedures· 3
Configuring PE A· 3
Configuring PE B· 4
Configuring devices between PE A and PE B· 4
Verifying the configuration· 5
Configuration files· 5
Example: Configuring one-to-two VLAN mapping· 6
Network configuration· 6
Analysis· 8
Applicable hardware and software versions· 8
Restrictions and guidelines· 9
Procedures· 9
Configuring PE A· 9
Configuring PE B· 10
Configuring devices between PE A and PE B· 11
Verifying the configuration· 11
Configuration files· 12
Example: Configuring QoS policies for SVLAN tagging and 802.1p priority marking  14
Network configuration· 14
Analysis· 15
Software versions used· 16
Restrictions and guidelines· 16
Procedures· 16
Configuring PE A· 16
Configuring PE B· 19
Configuring devices between PE A and PE B· 21
Verifying the configuration· 21
Configuration files· 22
Example: Configuring QoS policies for SVLAN tagging· 26
Network configuration· 26
Analysis· 28
Software versions used· 28
Restrictions and guidelines· 29
Procedures· 29
Configuring PE A· 29
Configuring PE B· 31
Configuring devices between PE A and PE B· 33
Verifying the configuration· 33
Configuration files· 34
Example: Configuring one-to-one VLAN mapping· 37
Network configuration· 37
Applicable hardware and software versions· 38
Procedures· 39
Configuring Switch A· 39
Configuring Switch B· 40
Verifying the configuration· 40
Configuration files· 40
Example: Configuring two-to-two VLAN mapping· 41
Network configuration· 41
Applicable hardware and software versions· 42
Restrictions and guidelines· 42
Procedures· 43
Configuring Switch A· 43
Configuring Switch B· 43
Configuring Switch C· 44
Configuring Switch D·· 45
Verifying the configuration· 45
Configuration files· 46
Example: Modifying the CVLAN ID through QoS marking· 47
Network configuration· 47
Analysis· 48
Software versions used· 48
Procedures· 48
Configuring PE A· 48
Configuring PE B· 50
Configuring devices between PE A and PE B· 52
Verifying the configuration· 52
Configuration files· 54
Introduction
This document provides examples for using VLAN tagging features to extend customer VLANs (CVLANs) across an Ethernet service provider network.
VLAN tagging features enable service providers to separate or aggregate customer traffic in the service provider network. The following are available VLAN tagging operations:
·     Adding a layer of service provider VLAN (SVLAN) tag.
·     Modifying the SVLAN tag, CVLAN tag, or both.
To add an SVLAN tag, use one of the following VLAN tagging features:
·     QinQ—Tags all incoming frames (tagged or untagged) on the customer-side port with the PVID of the port.
·     One-to-two VLAN mapping—Adds different SVLANs for traffic with different CVLAN tags.
·     Zero-to-two VLAN mapping—Adds double VLAN tags to untagged packets.
·     Two-to-three VLAN mapping—Adds an outermost VLAN tag to double-tagged packets.
·     Policy-based VLAN manipulation—Uses QoS nest actions in a QoS policy to tag different classes of frames with different SVLAN tags. Traffic classifiers include CVLAN ID, IP address, and MAC address. In addition, you can use QoS priority marking to set the 802.1p priority in SVLAN tags.
To modify VLAN tags, use one of the following VLAN tagging features:
·     VLAN mapping—Includes the following features:
¡     One-to-one VLAN mapping—Replaces one VLAN tag with another.
¡     Many-to-one VLAN mapping—Replaces multiple VLAN tags with the same VLAN tag.
¡     Two-to-two VLAN mapping—Replaces the SVLAN ID, CVLAN ID, or both IDs for an incoming double-tagged frame.
·     Policy-based VLAN manipulation—Uses a QoS policy to modify the CVLAN or SVLAN ID by using the remark customer-vlan-id or remark service-vlan-id action.
The devices in the service provider network learn MAC addresses of CVLANs into the MAC address table of the SVLAN.
This document assumes that you have basic knowledge of QinQ, VLAN mapping, QoS nesting, and QoS priority and CVLAN marking.
EVB and the VLAN tagging features are mutually exclusive. Do not use EVB with any VLAN tagging features on a port.
As shown in Figure 1:
·     The service provider assigns VLAN 1000 to Company A's VLANs 100 through 150.
·     The service provider assigns VLAN 2000 to Company B's VLANs 120 through 200.
Configure QinQ on PE A and PE B to transmit traffic in VLANs 1000 and 2000 for Company A and Company B, respectively.
Figure 1 Network diagram
Hardware
Software version
S12500G-AF
Release 8053P05 and later
S12500CR
S10500X-G
Release 7753P05 and later
S7500X-G
When you configure QinQ, follow these restrictions and guidelines:
·     You only need to configure QinQ on customer-side ports of PEs.
·     The link type of the customer-side port can be access, hybrid, or trunk.
¡     If the link type is access, you must assign the port to the SVLAN.
¡     If the link type is trunk, you must assign the port to the SVLAN, and set the SVLAN ID as the PVID of the port.
¡     If the link type is hybrid, you must assign the port to the SVLAN as an untagged VLAN member, and set the SVLAN ID as the PVID of the port. The settings ensure that the port can forward traffic to the customer site with the SVLAN tag removed.
·     For QinQ frames to travel across the service provider network, you must perform the following tasks:
¡     Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
¡     Configure all the ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1.     Create VLANs 1000 and 2000.
<PE_A> system-view
[PE_A] vlan 1000
[PE_A-vlan1000] quit
[PE_A] vlan 2000
[PE_A-vlan2000] quit
2.     Configure Ten-GigabitEthernet 3/0/1:
# Configure the port as an access port, and assign the port to VLAN 1000.
[PE_A] interface ten-gigabitethernet 3/0/1
[PE_A-Ten-GigabitEthernet3/0/1] port access vlan 1000
# Enable QinQ on the port.
[PE_A-Ten-GigabitEthernet3/0/1] qinq enable
[PE_A-Ten-GigabitEthernet3/0/1] quit
3.     Configure Ten-GigabitEthernet 3/0/2:
# Configure the port as an access port, and assign the port to VLAN 2000.
[PE_A] interface ten-gigabitethernet 3/0/2
[PE_A-Ten-GigabitEthernet3/0/2] port access vlan 2000
[PE_A-Ten-GigabitEthernet3/0/2] qinq enable
[PE_A-Ten-GigabitEthernet3/0/2] quit
4.     Configure Ten-GigabitEthernet 3/0/3:
# Configure the port as a trunk port.
[PE_A] interface ten-gigabitethernet 3/0/3
[PE_A-Ten-GigabitEthernet3/0/3] port link-type trunk
# Assign the port to VLANs 1000 and 2000.
[PE_A-Ten-GigabitEthernet3/0/3] port trunk permit vlan 1000 2000
# Remove the port from VLAN 1.
[PE_A-Ten-GigabitEthernet3/0/3] undo port trunk permit vlan 1
[PE_A-Ten-GigabitEthernet3/0/3] quit
Configuring PE B
<PE_B> system-view
[PE_B] vlan 1000
[PE_B-vlan1000] quit
[PE_B] vlan 2000
[PE_B-vlan2000] quit
[PE_B] interface ten-gigabitethernet 3/0/1
[PE_B-Ten-GigabitEthernet3/0/1] port access vlan 2000
[PE_B-Ten-GigabitEthernet3/0/1] qinq enable
[PE_B-Ten-GigabitEthernet3/0/1] quit
[PE_B] interface ten-gigabitethernet 3/0/2
[PE_B-Ten-GigabitEthernet3/0/2] port access vlan 1000
[PE_B-Ten-GigabitEthernet3/0/2] qinq enable
[PE_B-Ten-GigabitEthernet3/0/2] quit
[PE_B] interface ten-gigabitethernet 3/0/3
[PE_B-Ten-GigabitEthernet3/0/3] port link-type trunk
[PE_B-Ten-GigabitEthernet3/0/3] port trunk permit vlan 1000 2000
[PE_B-Ten-GigabitEthernet3/0/3] undo port trunk permit vlan 1
[PE_B-Ten-GigabitEthernet3/0/3] quit
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 1000 and 2000 to pass through without removing the VLAN tag. (Details not shown.)
# Verify that each company's PCs can ping each other in the same CVLAN across the service provider network. (Details not shown.)
# Verify that the two companies' PCs cannot communicate at Layer 2 even if their CVLAN IDs are the same. The ARP tables on one company's PCs do not contain entries for MAC addresses of the other company's PCs. (Details not shown.)
Configuration files
·     PE A:
vlan 1000
vlan 2000
interface Ten-GigabitEthernet3/0/1
 port link-mode bridge
 qinq enable
interface Ten-GigabitEthernet3/0/2
 qinq enable
interface Ten-GigabitEthernet3/0/3
·     PE B:
vlan 1000
vlan 2000
 qinq enable
 qinq enable
As shown in Figure 2:
·     Customer A and Customer B each have two branches that require Layer 2 connectivity over the service provider network.
·     Both customers have three types of traffic. For each customer, the service provider assigns one SVLAN by traffic type.
Configure one-to-two VLAN mapping on each customer-side port of PE A and PE B to meet the following requirements:
·     The service provider adds an SVLAN tag to packets from customer networks based on the traffic type, as described in Table 1 and Figure 3.
·     The SVLAN tag uses the same 802.1p priority as the CVLAN tag.
Figure 2 Network diagram
Table 1 VLAN mapping table
Traffic type
CVLANs
SVLAN
Customer A
Video
20 to 24
1003
Voice
15 to 19
1002
Data
10 to 14
1001
Customer B
Storage
25 to 29
2003
Voice
20 to 24
2002
Data
15 to 19
2001
Figure 3 Required traffic pattern in the service provider network
Analysis
To support multiple SVLANs and send traffic to the customer networks with the SVLAN tag removed, perform the following tasks on the customer-side ports:
1.     Configure the link type of the ports as hybrid.
2.     Assign the ports to the SVLANs as untagged VLAN members.
For the SVLAN tag to use the same 802.1p priority as the CVLAN tag, configure the customer-side port to use the 802.1p priority in incoming packets for priority mapping.
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
When you configure ports on the forwarding path of double-tagged packets across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port.
·     Configure all ports to allow double-tagged packets to pass through without removing the SVLAN tag.
Procedures
Configuring PE A
1.     Create CVLANs and SVLANs:
# Create CVLANs 10 to 29.
<PE_A> system-view
[PE_A] vlan 10 to 29
# Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A] vlan 1001 to 1003
[PE_A] vlan 2001 to 2003
2.     Configure the customer-side port Ten-GigabitEthernet 3/0/1:
# Configure the port as a hybrid port.
[PE_A-Ten-GigabitEthernet3/0/1] port link-type hybrid
# Assign the port to CVLANs 10 through 29 as a tagged VLAN member.
[PE_A-Ten-GigabitEthernet3/0/1] port hybrid vlan 10 to 29 tagged
# Assign the port to SVLANs 1001 through 1003 as an untagged VLAN member.
[PE_A-Ten-GigabitEthernet3/0/1] port hybrid vlan 1001 to 1003 untagged
[PE_A-Ten-GigabitEthernet3/0/1] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 1001 to traffic from VLANs 10 through 14.
[PE_A-Ten-GigabitEthernet3/0/1] vlan mapping nest single 10 11 12 13 14 nested-vlan 1001
# Configure one-to-two VLAN mapping to add SVLAN tag 1002 to traffic from VLANs 15 through 19.
[PE_A-Ten-GigabitEthernet3/0/1] vlan mapping nest single 15 16 17 18 19 nested-vlan 1002
# Configure one-to-two VLAN mapping to add SVLAN tag 1003 to traffic from VLANs 20 through 24.
[PE_A-Ten-GigabitEthernet3/0/1] vlan mapping nest single 20 21 22 23 24 nested-vlan 1003
# Configure the port to use the 802.1p priority in incoming packets for priority mapping.
[PE_A-Ten-GigabitEthernet3/0/1] qos trust dot1p
3.     Configure the service provider-side port Ten-GigabitEthernet 3/0/3:
# Assign the port to SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
[PE_A-Ten-GigabitEthernet3/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
Configuring PE B
<PE_B> system-view
[PE_B] vlan 10 to 29
[PE_B] vlan 1001 to 1003
[PE_B] vlan 2001 to 2003
[PE_B-Ten-GigabitEthernet3/0/1] port link-type hybrid
# Assign the port to CVLANs 15 through 29 as a tagged VLAN member.
[PE_B-Ten-GigabitEthernet3/0/1] port hybrid vlan 15 to 29 tagged
# Assign the port to SVLANs 2001 through 2003 as an untagged VLAN member.
[PE_B-Ten-GigabitEthernet3/0/1] port hybrid vlan 2001 to 2003 untagged
[PE_B-Ten-GigabitEthernet3/0/1] undo port hybrid vlan 1
# Configure one-to-two VLAN mapping to add SVLAN tag 2001 to traffic from VLANs 15 through 19.
[PE_B-Ten-GigabitEthernet3/0/1] vlan mapping nest single 15 16 17 18 19 nested-vlan 2001
# Configure one-to-two VLAN mapping to add SVLAN tag 2002 to traffic from VLANs 20 through 24.
[PE_B-Ten-GigabitEthernet3/0/1] vlan mapping nest single 20 21 22 23 24 nested-vlan 2002
# Configure one-to-two VLAN mapping to add SVLAN tag 2003 to traffic from VLANs 25 through 29.
[PE_B-Ten-GigabitEthernet3/0/1] vlan mapping nest single 25 26 27 28 29 nested-vlan 2003
[PE_B-Ten-GigabitEthernet3/0/1] qos trust dot1p
3.     Configure the customer-side port Ten-GigabitEthernet 3/0/2:
[PE_B-Ten-GigabitEthernet3/0/2] port link-type hybrid
# Assign the port to CVLANs 10 through 40 as a tagged VLAN member.
[PE_B-Ten-GigabitEthernet3/0/2] port hybrid vlan 10 to 40 tagged
[PE_B-Ten-GigabitEthernet3/0/2] port hybrid vlan 1001 to 1003 untagged
[PE_B-Ten-GigabitEthernet3/0/2] undo port hybrid vlan 1
[PE_B-Ten-GigabitEthernet3/0/2] vlan mapping nest single 10 11 12 13 14 nested-vlan 1001
[PE_B-Ten-GigabitEthernet3/0/2] vlan mapping nest single 15 16 17 18 19 nested-vlan 1002
[PE_B-Ten-GigabitEthernet3/0/2] vlan mapping nest single 20 21 22 23 24 nested-vlan 1003
[PE_B-Ten-GigabitEthernet3/0/2] qos trust dot1p
4.     Configure the service provider-side port Ten-GigabitEthernet 3/0/3:
[PE_B-Ten-GigabitEthernet3/0/3] port trunk permit vlan 1001 to 1003 2001 to 2003
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged packets. (Details not shown.)
# Configure all ports on the forwarding path to allow packets from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the SVLAN tag. (Details not shown.)
1.     Verify VLAN mapping information:
# Verify VLAN mapping information on PE A.
[PE_A] display vlan mapping
Interface Ten-GigabitEthernet3/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10-14         N/A           1001                     10-24
  15-19         N/A           1002                     15-19
  20-24         N/A           1003                     20-24
Interface Ten-GigabitEthernet3/0/2:
  15-19         N/A           2001                     15-19
  20-24         N/A           2002                     20-24
  25-29         N/A           2003                     25-29
# Verify VLAN mapping information on PE B.
[PE_B] display vlan mapping
2.     Verify that PCs of the same customer in a CVLAN can ping each other across the service provider network. (Details not shown.)
3.     Verify that PCs of different customers in a CVLAN cannot communicate at Layer 2. The ARP tables on one customer's PCs do not contain entries for MAC addresses of the other customer's PCs. (Details not shown.)
Configuration files
·     PE A:
vlan 10 to 29
vlan 1001 to 1003
vlan 2001 to 2003
 port hybrid vlan 10 to 24 tagged
 qos trust dot1p
 vlan mapping nest single 15 single nested-vlan 2001
 qos trust dot1p
·     PE B:
vlan 10 to 29
vlan 1001 to 1003
vlan 2001 to 2003
 vlan mapping nest single 16 17 18 19 nested-vlan 2001
 qos trust dot1p
 qos trust dot1p
As shown in Figure 4:
·     Both customers have three types of traffic and require different transmission priorities for the three types of traffic.
Apply a QoS policy to each customer-side port on PE A and PE B to meet the following requirements:
·     Separate the traffic by customer and traffic type.
·     Assign different 802.1p priority values to the traffic flows.
Figure 4 Network diagram
Table 2 shows the VLAN and 802.1p priority assignment scheme. For each customer, the service provider assigns one SVLAN by traffic type. Figure 5 shows the expected traffic transmission pattern after the QoS policies are applied to customer-side ports.
Table 2 VLAN and traffic priority assignment
Traffic type
CVLANs
SVLAN
Traffic priority
Customer A:
Video
31 to 40
1003
High
Voice
21 to 30
1002
Medium
Data
10 to 20
1001
Low
Customer B:
Storage
36 to 40
2003
High
Voice
26 to 35
2002
Medium
Data
15 to 25
2001
Low
Figure 5 Expected traffic pattern in the service provider network
Analysis
For the customer-side ports to support multiple SVLANs and send traffic to the customer site with the SVLAN tag removed, you must perform the following tasks:
1.     Configure the link type as hybrid on the customer-side ports.
To change the 802.1p priority for a class of traffic, use the remark dot1p action. By default, the 802.1p priority in the SVLAN tag added by a QinQ-enabled port depends on the priority trust mode on the port.
·     If the 802.1p priority in frames is trusted, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
·     If port priority is trusted, the port priority is used as the 802.1p priority in the SVLAN tag. For untagged incoming frames, the port encapsulates the port priority as the 802.1p priority in the SVLAN tag.
This configuration example was created and verified on xxxx.
When you configure an SVLAN tagging QoS policy, follow these restrictions and guidelines:
·     Use the nest action for SVLAN tagging. You can configure only one nest action in the traffic behavior for a traffic class.
·     You must apply the QoS policy to the inbound direction of customer-side ports.
·     For the nest action to take effect, you must enable QinQ on the customer-side ports.
·     If an incoming frame does not match the QoS policy, the port adds the PVID tag to the frame as the SVLAN tag.
For QinQ frames to travel across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of QinQ frames is treated as part of the payload during transmission.
·     Configure all the ports on the forwarding path to allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag.
Procedures
Configuring PE A
1.     Create SVLANs 1001 through 1003 and SVLANs 2001 through 2003.
<PE_A> system-view
# Configure the port to trust the 802.1p priority of frames.
[PE_A-Ten-GigabitEthernet3/0/2] port link-type hybrid
[PE_A-Ten-GigabitEthernet3/0/2] undo port hybrid vlan 1
[PE_A-Ten-GigabitEthernet3/0/2] port hybrid vlan 2001 to 2003 untagged
[PE_A-Ten-GigabitEthernet3/0/2] qos trust dot1p
4.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create the class customer_A_pc to match traffic from CVLANs 10 through 20 (data traffic) for Customer A.
[PE_A] traffic classifier customer_A_pc
[PE_A-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_A-classifier-customer_A_pc] quit
# Create the classes customer_A_voice and customer_A_video to match Customer A's voice traffic and video traffic, respectively.
[PE_A] traffic classifier customer_A_voice
[PE_A-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_A-classifier-customer_A_voice] quit
[PE_A] traffic classifier customer_A_video
[PE_A-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_A-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking actions for Customer A's three traffic types.
[PE_A] traffic behavior customer_A_pc
[PE_A-behavior-customer_A_pc] nest top-most vlan 1001
[PE_A-behavior-customer_A_pc] remark dot1p 3
[PE_A-behavior-customer_A_pc] quit
[PE_A] traffic behavior customer_A_voice
[PE_A-behavior-customer_A_voice] nest top-most vlan 1002
[PE_A-behavior-customer_A_voice] remark dot1p 5
[PE_A-behavior-customer_A_voice] quit
[PE_A] traffic behavior customer_A_video
[PE_A-behavior-customer_A_video] nest top-most vlan 1003
[PE_A-behavior-customer_A_video] remark dot1p 7
[PE_A-behavior-customer_A_video] quit
# Create the QoS policy customer_A for Customer A, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_A
[PE_A-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_A-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_A-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_A-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of Ten-GigabitEthernet 3/0/1.
[PE_A-Ten-GigabitEthernet3/0/1] qos apply policy customer_A inbound
# Create traffic classes for matching Customer B's three traffic types.
[PE_A] traffic classifier customer_B_pc
[PE_A-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_A-classifier-customer_B_pc] quit
[PE_A] traffic classifier customer_B_voice
[PE_A-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_A-classifier-customer_B_voice] quit
[PE_A] traffic classifier customer_B_storage
[PE_A-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_A-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's traffic types.
[PE_A] traffic behavior customer_B_pc
[PE_A-behavior-customer_B_pc] nest top-most vlan 2001
[PE_A-behavior-customer_B_pc] remark dot1p 3
[PE_A-behavior-customer_B_pc] quit
[PE_A] traffic behavior customer_B_voice
[PE_A-behavior-customer_B_voice] nest top-most vlan 2002
[PE_A-behavior-customer_B_voice] remark dot1p 5
[PE_A-behavior-customer_B_voice] quit
[PE_A] traffic behavior customer_B_storage
[PE_A-behavior-customer_B_storage] nest top-most vlan 2003
[PE_A-behavior-customer_B_storage] remark dot1p 7
[PE_A-behavior-customer_B_storage] quit
# Create the QoS policy customer_B for Customer B, and associate the classes with their respective behaviors in the QoS policy.
[PE_A] qos policy customer_B
[PE_A-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_A-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_A-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_A-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of Ten-GigabitEthernet 3/0/2.
[PE_A-Ten-GigabitEthernet3/0/2] qos apply policy customer_B inbound
Configuring PE B
<PE_B> system-view
5.     Configure QoS policies for SVLAN tagging and 802.1p priority marking:
# Create traffic classes for matching Customer A's traffic types.
[PE_B] traffic classifier customer_A_pc
[PE_B-classifier-customer_A_pc] if-match customer-vlan-id 10 to 20
[PE_B-classifier-customer_A_pc] quit
[PE_B] traffic classifier customer_A_voice
[PE_B-classifier-customer_A_voice] if-match customer-vlan-id 21 to 30
[PE_B-classifier-customer_A_voice] quit
[PE_B] traffic classifier customer_A_video
[PE_B-classifier-customer_A_video] if-match customer-vlan-id 31 to 40
[PE_B-classifier-customer_A_video] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer A's three traffic types.
[PE_B] traffic behavior customer_A_pc
[PE_B-behavior-customer_A_pc] nest top-most vlan 1001
[PE_B-behavior-customer_A_pc] remark dot1p 3
[PE_B-behavior-customer_A_pc] quit
[PE_B] traffic behavior customer_A_voice
[PE_B-behavior-customer_A_voice] nest top-most vlan 1002
[PE_B-behavior-customer_A_voice] remark dot1p 5
[PE_B-behavior-customer_A_voice] quit
[PE_B] traffic behavior customer_A_video
[PE_B-behavior-customer_A_video] nest top-most vlan 1003
[PE_B-behavior-customer_A_video] remark dot1p 7
[PE_B-behavior-customer_A_video] quit
[PE_B] qos policy customer_A
[PE_B-qospolicy-customer_A] classifier customer_A_pc behavior customer_A_pc
[PE_B-qospolicy-customer_A] classifier customer_A_voice behavior customer_A_voice
[PE_B-qospolicy-customer_A] classifier customer_A_video behavior customer_A_video
[PE_B-qospolicy-customer_A] quit
# Apply the QoS policy customer_A to the inbound direction of Ten-GigabitEthernet 3/0/2.
[PE_B-Ten-GigabitEthernet3/0/2] qos apply policy customer_A inbound
[PE_B] traffic classifier customer_B_pc
[PE_B-classifier-customer_B_pc] if-match customer-vlan-id 15 to 25
[PE_B-classifier-customer_B_pc] quit
[PE_B] traffic classifier customer_B_voice
[PE_B-classifier-customer_B_voice] if-match customer-vlan-id 26 to 35
[PE_B-classifier-customer_B_voice] quit
[PE_B] traffic classifier customer_B_storage
[PE_B-classifier-customer_B_storage] if-match customer-vlan-id 36 to 40
[PE_B-classifier-customer_B_storage] quit
# Configure SVLAN tagging and 802.1p priority marking behaviors for Customer B's three traffic types.
[PE_B] traffic behavior customer_B_pc
[PE_B-behavior-customer_B_pc] nest top-most vlan 2001
[PE_B-behavior-customer_B_pc] remark dot1p 3
[PE_B-behavior-customer_B_pc] quit
[PE_B] traffic behavior customer_B_voice
[PE_B-behavior-customer_B_voice] nest top-most vlan 2002
[PE_B-behavior-customer_B_voice] remark dot1p 5
[PE_B-behavior-customer_B_voice] quit
[PE_B] traffic behavior customer_B_storage
[PE_B-behavior-customer_B_storage] nest top-most vlan 2003
[PE_B-behavior-customer_B_storage] remark dot1p 7
[PE_B-behavior-customer_B_storage] quit
[PE_B] qos policy customer_B
[PE_B-qospolicy-customer_B] classifier customer_B_pc behavior customer_B_pc
[PE_B-qospolicy-customer_B] classifier customer_B_voice behavior customer_B_voice
[PE_B-qospolicy-customer_B] classifier customer_B_storage behavior customer_B_storage
[PE_B-qospolicy-customer_B] quit
# Apply the QoS policy customer_B to the inbound direction of Ten-GigabitEthernet 3/0/1.
[PE_B-Ten-GigabitEthernet3/0/1] qos apply policy customer_B inbound
# Configure all ports on the path between PE A and PE B allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without removing the VLAN tag. (Details not shown.)
# Verify the configuration on each port. This example uses Ten-GigabitEthernet 3/0/1 of PE A.
[PE_A-Ten-GigabitEthernet3/0/1] display this
 qinq enable
 qos trust dot1p
Return
# Verify the QoS configuration on each port. This example uses Ten-GigabitEthernet 3/0/1 of PE A.
[PE_A] display qos policy interface ten-gigabitethernet 3/0/1
Interface: Ten-GigabitEthernet3/0/1
  Direction: Inbound
  Policy: customer_A
   Classifier: customer_A_pc
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 10 to 20
     Behavior: customer_A_pc
      Nesting:
        Nest top-most vlan-id 1001
      Marking:
        Remark dot1p 3
   Classifier: customer_A_voice
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 21 to 30
     Behavior: customer_A_voice
      Nesting:
        Nest top-most vlan-id 1002
      Marking:
        Remark dot1p 5
   Classifier: customer_A_video
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 31 to 40
     Behavior: customer_A_video
      Nesting:
        Nest top-most vlan-id 1003
      Marking:
        Remark dot1p 7
Configuration files
·     PE A:
vlan 1001 to 1003
vlan 2001 to 2003
traffic classifier customer_A_pc operator and
traffic classifier customer_A_voice operator and
traffic classifier customer_A_video operator and
traffic classifier customer_B_pc operator and
traffic classifier customer_B_voice operator and
traffic classifier customer_B_storage operator and
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 qinq enable
 qos trust dot1p
 qinq enable
 qos trust dot1p
·     PE B:
vlan 1001 to 1003
vlan 2001 to 2003
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 remark dot1p 3
 remark dot1p 5
 remark dot1p 7
 qinq enable
 qos trust dot1p
 qinq enable
 qos trust dot1p
As shown in Figure 6:
·     The three types of traffic require separate transmission through three VLANs provided by the service provider. The service provider network configures different transmission policies for each type of traffic.
Apply a QoS policy to each customer-side port on PE A and PE B to separate the traffic by customer and traffic type.
Figure 6 Network diagram
Table 3 shows the VLAN assignment. For each customer, the service provider assigns one SVLAN by traffic type. Figure 7 shows the expected traffic transmission pattern after the QoS policies are applied to customer-side ports.
Table 3 VLAN assignment
Traffic type
CVLANs
SVLAN
Customer A:
Video
31 to 40
1003
Voice
21 to 30
1002
Data
10 to 20
1001
Customer B:
Storage
36 to 40
2003
Voice
26 to 35
2002
Data
15 to 25
2001
Figure 7 Expected traffic pattern in the service provider network
Analysis
By default, the 802.1p priority in the SVLAN tag added by a port depends on the priority trust mode on the port.
To add SVLAN tags for traffic of different types, you can perform one of the following tasks on the customer-side ports:
·     Configure an SVLAN tagging QoS policy.
·     Configure one-to-two VLAN mapping.
For frames to travel across the service provider network, follow these restrictions and guidelines:
·     Set the MTU to a minimum of 1504 bytes for each port on the path of frames. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a CVLAN tag. The CVLAN tag of frames is treated as part of the payload during transmission.
·     Configure all the ports on the forwarding path to allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without modifying or removing the VLAN tag.
Procedures
Configuring PE A
<PE_A> system-view
# Configure SVLAN tagging actions for Customer A's three traffic types.
# Configure SVLAN tagging behaviors for Customer B's traffic types.
Configuring PE B
<PE_B> system-view
# Configure SVLAN tagging behaviors for Customer A's three traffic types.
# Configure SVLAN tagging behaviors for Customer B's three traffic types.
# Set the MTU to a minimum of 1504 bytes for each port on the path of frames. (Details not shown.)
# Configure all ports on the path between PE A and PE B allow frames from VLANs 1001 through 1003 and VLANs 2001 through 2003 to pass through without modifying or removing the VLAN tag. (Details not shown.)
 qos trust dot1p
Return
  Direction: Inbound
  Policy: customer_A
     Operator: AND
     Rule(s) :
      Nesting:
     Operator: AND
     Rule(s) :
      Nesting:
     Operator: AND
     Rule(s) :
      Nesting:
Configuration files
·     PE A:
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
·     PE B:
vlan 1001 to 1003
vlan 2001 to 2003
 qos trust dot1p
 qos trust dot1p
As shown in Figure 8:
·     Each household subscribes to PC, VoD, and VoIP services, and obtains the IP address through DHCP.
·     On the home gateways, PC, VoD, and VoIP service traffic is assigned to VLANs 1, 2, and 3, respectively.
This feature assigns one VLAN to each type of traffic from each household to isolate traffic of the same service type from different households,.
Figure 8 Network diagram
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
Procedures
# Create the original VLANs 2 and 3. (VLAN 1 is the system default VLAN and already exists.)
[SwitchA] vlan 2 to 3
# Create the translated VLANs 101 through 102, 201 through 202, and 301 through 302.
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
# Configure the customer-side port Ten-GigabitEthernet 3/0/1 as a trunk port.
[SwitchA] interface ten-gigabitethernet 3/0/1
[SwitchA-Ten-GigabitEthernet3/0/1] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/1 to the original VLANs and translated VLANs.
[SwitchA-Ten-GigabitEthernet3/0/1] port trunk permit vlan 1 2 3 101 201 301
# Configure one-to-one VLAN mapping on Ten-GigabitEthernet 3/0/1 to map VLANs 1, 2, and 3 to VLANs 101, 201, and 301, respectively.
[SwitchA-Ten-GigabitEthernet3/0/1] vlan mapping 1 translated-vlan 101
[SwitchA-Ten-GigabitEthernet3/0/1] vlan mapping 2 translated-vlan 201
[SwitchA-Ten-GigabitEthernet3/0/1] vlan mapping 3 translated-vlan 301
[SwitchA-Ten-GigabitEthernet3/0/1] quit
# Configure the customer-side port Ten-GigabitEthernet 3/0/2 as a trunk port.
[SwitchA] interface ten-gigabitethernet 3/0/2
[SwitchA-Ten-GigabitEthernet3/0/2] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/2 to the original VLANs and translated VLANs.
[SwitchA-Ten-GigabitEthernet3/0/2] port trunk permit vlan 1 2 3 102 202 302
# Configure one-to-one VLAN mapping on Ten-GigabitEthernet 3/0/2 to map VLANs 1, 2, and 3 to VLANs 102, 202, and 302, respectively.
[SwitchA-Ten-GigabitEthernet3/0/2] vlan mapping 1 translated-vlan 102
[SwitchA-Ten-GigabitEthernet3/0/2] vlan mapping 2 translated-vlan 202
[SwitchA-Ten-GigabitEthernet3/0/2] vlan mapping 3 translated-vlan 302
[SwitchA-Ten-GigabitEthernet3/0/2] quit
# Configure the network-side port Ten-GigabitEthernet 3/0/3 as a trunk port.
[SwitchA] interface ten-gigabitethernet 3/0/3
[SwitchA-Ten-GigabitEthernet3/0/3] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/3 to the translated VLANs.
[SwitchA-Ten-GigabitEthernet3/0/3] undo port trunk permit vlan 1
[SwitchA-Ten-GigabitEthernet3/0/3] port trunk permit vlan 101 201 301 102 202 302
[SwitchA-Ten-GigabitEthernet3/0/3] quit
# Configure Switch B in the same way Switch A is configured. (Details not shown.)
# Verify VLAN mapping information on the wiring-closet switches, for example, Switch A.
[SwitchA] display vlan mapping
  1             N/A           101                      N/A
  2             N/A           201                      N/A
  3             N/A           301                      N/A
  1             N/A           102                      N/A
  2             N/A           202                      N/A
  3             N/A           302                      N/A
Configuration files
·     Switch A:
vlan 1
vlan 2 to 3
vlan 101 to 102
vlan 201 to 202
vlan 301 to 302
 port trunk permit vlan 1 to 3 101 201 301
 port trunk permit vlan 1 to 3 102 202 302
 port trunk permit vlan 1 101 to 102 201 to 202 301 to 302
·     Switch B:
vlan 1
vlan 2 to 3
vlan 103 to 104
vlan 203 to 204
vlan 303 to 304
 port trunk permit vlan 1 to 3 103 203 303
 vlan mapping 1 translated-vlan 103
 vlan mapping 2 translated-vlan 203
 vlan mapping 3 translated-vlan 303
 port trunk permit vlan 1 to 3 104 204 304
 vlan mapping 1 translated-vlan 104
 vlan mapping 2 translated-vlan 204
 vlan mapping 3 translated-vlan 304
 port trunk permit vlan 1 103 to 104 203 to 204 303 to 304
As shown in Figure 9:
·     A company assigns its branch sites (Site 1 and Site 2) to VLAN 10, and the headquarters provides services in VLAN 30.
·     Service provider A uses SVLAN 100 to transmit VLAN 10 traffic for the branch sites.
·     Service provider B uses SVLAN 200 to transmit VLAN 30 traffic for the headquarters.
Configure two-to-two VLAN mapping to permit the two branch sites to access VLAN 30 of the headquarters without changing their VLAN assignment.
Figure 9 Network diagram
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
Configure two-to-two VLAN mapping on one of the edge devices between the two service provider networks. This example uses Switch C.
Procedures
# Create CVLAN 10 and SVLAN 100.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (Ten-GigabitEthernet 3/0/1) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchA-Ten-GigabitEthernet3/0/1] vlan mapping nest single 10 nested-vlan 100
# Configure Ten-GigabitEthernet 3/0/1 as a hybrid port.
[SwitchA-Ten-GigabitEthernet3/0/1] port link-type hybrid
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 10 as a tagged member.
[SwitchA-Ten-GigabitEthernet3/0/1] port hybrid vlan 10 tagged
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 100 as an untagged member.
[SwitchA-Ten-GigabitEthernet3/0/1] port hybrid vlan 100 untagged
# Remove Ten-GigabitEthernet 3/0/1 from VLAN 1.
[SwitchA-Ten-GigabitEthernet3/0/1] undo port hybrid vlan 1
# Configure the network-side port Ten-GigabitEthernet 3/0/2 as a trunk port.
# Assign Ten-GigabitEthernet 3/0/2 to VLAN 100.
[SwitchA-Ten-GigabitEthernet3/0/2] port trunk permit vlan 100
# Remove Ten-GigabitEthernet 3/0/2 from VLAN 1.
[SwitchA-Ten-GigabitEthernet3/0/2] undo port trunk permit vlan 1
[SwitchB] vlan 10
[SwitchB-vlan10] quit
[SwitchB] vlan 100
[SwitchB-vlan100] quit
# Configure a one-to-two VLAN mapping on the customer-side port (Ten-GigabitEthernet 3/0/3) to add SVLAN tag 100 to packets from VLAN 10.
[SwitchB] interface ten-gigabitethernet 3/0/3
[SwitchB-Ten-GigabitEthernet3/0/3] vlan mapping nest single 10 nested-vlan 100
# Configure Ten-GigabitEthernet 3/0/3 as a hybrid port.
[SwitchB-Ten-GigabitEthernet3/0/3] port link-type hybrid
# Assign Ten-GigabitEthernet 3/0/3 to VLAN 10 as a tagged member.
[SwitchB-Ten-GigabitEthernet3/0/3] port hybrid vlan 10 tagged
# Assign Ten-GigabitEthernet 3/0/3 to VLAN 100 as an untagged member.
[SwitchB-Ten-GigabitEthernet3/0/3] port hybrid vlan 100 untagged
# Remove Ten-GigabitEthernet 3/0/3 from VLAN 1.
[SwitchB-Ten-GigabitEthernet3/0/3] undo port hybrid vlan 1
[SwitchB-Ten-GigabitEthernet3/0/3] quit
# Configure Ten-GigabitEthernet 3/0/1 as a trunk port.
[SwitchB] interface ten-gigabitethernet 3/0/1
[SwitchB-Ten-GigabitEthernet3/0/1] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 100.
[SwitchB-Ten-GigabitEthernet3/0/1] port trunk permit vlan 100
[SwitchB-Ten-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SwitchB-Ten-GigabitEthernet3/0/1] quit
# Configure Ten-GigabitEthernet 3/0/2 as a trunk port.
[SwitchB] interface ten-gigabitethernet 3/0/2
[SwitchB-Ten-GigabitEthernet3/0/2] port link-type trunk
[SwitchB-Ten-GigabitEthernet3/0/2] port trunk permit vlan 100
[SwitchB-Ten-GigabitEthernet3/0/2] undo port trunk permit vlan 1
[SwitchB-Ten-GigabitEthernet3/0/2] quit
# Create SVLANs 100 and 200.
[SwitchC] vlan 100
[SwitchC-vlan100] quit
[SwitchC] vlan 200
[SwitchC-vlan200] quit
[SwitchC] interface ten-gigabitethernet 3/0/1
[SwitchC-Ten-GigabitEthernet3/0/1] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/1 to VLANs 100 to 200.
[SwitchC-Ten-GigabitEthernet3/0/1] port trunk permit vlan 100 200
[SwitchC-Ten-GigabitEthernet3/0/1] undo port trunk permit vlan 1
# Configure a two-to-two VLAN mapping on Ten-GigabitEthernet 3/0/1 to map SVLAN 100 and CVLAN 10 to SVLAN 200 and CVLAN 30.
[SwitchC-Ten-GigabitEthernet3/0/1] vlan mapping tunnel 100 10 translated-vlan 200 30
[SwitchC-Ten-GigabitEthernet3/0/1] quit
[SwitchC] interface ten-gigabitethernet 3/0/2
[SwitchC-Ten-GigabitEthernet3/0/2] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/2 to VLAN 200.
[SwitchC-Ten-GigabitEthernet3/0/2] port trunk permit vlan 200
[SwitchC-Ten-GigabitEthernet3/0/2] undo port trunk permit vlan 1
[SwitchC-Ten-GigabitEthernet3/0/2] quit
# Create CVLAN 30 and SVLAN 200.
<SwitchD> system-view
[SwitchD] vlan 30
[SwitchD-vlan30] quit
[SwitchD] vlan 200
[SwitchD-vlan200] quit
# Configure the link type of Ten-GigabitEthernet 3/0/1 as trunk.
[SwitchD] interface ten-gigabitethernet 3/0/1
[SwitchD-Ten-GigabitEthernet3/0/1] port link-type trunk
# Assign Ten-GigabitEthernet 3/0/1 to VLAN 200.
[SwitchD-Ten-GigabitEthernet3/0/1] port trunk permit vlan 200
[SwitchD-Ten-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[SwitchD-Ten-GigabitEthernet3/0/1] quit
# Configure Ten-GigabitEthernet 3/0/2 as a hybrid port.
[SwitchD] interface ten-gigabitethernet 3/0/2
[SwitchD-Ten-GigabitEthernet3/0/2] port link-type hybrid
# Assign Ten-GigabitEthernet 3/0/2 to VLAN 30 as a tagged member.
[SwitchD-Ten-GigabitEthernet3/0/2] port hybrid vlan 30 tagged
# Assign Ten-GigabitEthernet 3/0/2 to VLAN 200 as an untagged member.
[SwitchD-Ten-GigabitEthernet3/0/2] port hybrid vlan 200 untagged
[SwitchD-Ten-GigabitEthernet3/0/2] undo port hybrid vlan 1
[SwitchD-Ten-GigabitEthernet3/0/2] quit
# Configure a one-to-two VLAN mapping on the customer-side port (Ten-GigabitEthernet 3/0/2) to add SVLAN tag 200 to packets from VLAN 30.
[SwitchD-Ten-GigabitEthernet3/0/2] vlan mapping nest single 30 nested-vlan 200
# Verify VLAN mapping information on Switch C.
[SwitchC] display vlan mapping
  100           10            200                      30
Configuration files
·     Switch A:
vlan 10
vlan 100
·     Switch B:
vlan 10
vlan 100
·     Switch C:
vlan 100
vlan 200
·     Switch D:
vlan 30
vlan 200
As shown in Figure 10:
·     Company A uses CVLANs 10 and 20 to transmit voice traffic and data traffic, respectively.
·     Company B uses CVLANs 30 and 40 to transmit voice traffic and data traffic, respectively.
·     The service provider uses SVLANs 100 and 200 to transmit these two companies' voice and data traffic, respectively.
To provide Layer 2 connectivity for the voice and data traffic between the two companies, configure QoS CVLAN marking on PE A and PE B.
Figure 10 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To add different SVLAN tags to voice and data traffic, use the nest action for SVLAN tagging on the customer-side ports of PE A and PE B.
·     To provide Layer 2 connectivity for the traffic from different CVLANs, configure QoS CVLAN marking on the service provider-side ports of PE A and PE B.
Procedures
Configuring PE A
1.     Create the CVLANs and SVLANs.
<PE_A> system-view
[PE_A] vlan 10
[PE_A-vlan10] quit
[PE_A] vlan 20
[PE_A-vlan20] quit
[PE_A] vlan 100
[PE_A-vlan100] quit
[PE_A] vlan 200
[PE_A-vlan200] quit
[PE_A] vlan 30
[PE_A-vlan30] quit
[PE_A] vlan 40
[PE_A-vlan40] quit
# Configure the port as an untagged VLAN member of VLANs 100 and 200.
[PE_A-Ten-GigabitEthernet3/0/1] port hybrid vlan 100 200 untagged
# Create the class A10 to match frames with CVLAN 10.
[PE_A] traffic classifier A10
[PE_A-classifier-A10] if-match customer-vlan-id 10
[PE_A-classifier-A10] quit
# Configure the traffic behavior P100 to tag packets with SVLAN 100.
[PE_A] traffic behavior P100
[PE_A-behavior-P100] nest top-most vlan 100
[PE_A-behavior-P100] quit
# Create the class A20 to match frames with CVLAN 20.
[PE_A] traffic classifier A20
[PE_A-classifier-A20] if-match customer-vlan-id 20
[PE_A-classifier-A20] quit
# Configure the traffic behavior P200 to tag packets with SVLAN 200.
[PE_A] traffic behavior P200
[PE_A-behavior-P200] nest top-most vlan 200
[PE_A-behavior-P200] quit
# Create the QoS policy qinq to associate the traffic classes A10 and A20 with the traffic behaviors P100 and P200, respectively.
[PE_A] qos policy qinq
[PE_A-qospolicy-qinq] classifier A10 behavior P100
[PE_A-qospolicy-qinq] classifier A20 behavior P200
[PE_A-qospolicy-qinq] quit
# Enable QinQ in the port.
# Apply the QoS policy to the inbound direction of the port.
[PE_A-Ten-GigabitEthernet3/0/1] qos apply policy qinq inbound
3.     Configure the service network-side port Ten-GigabitEthernet 3/0/2:
[PE_A-Ten-GigabitEthernet3/0/2] port link-type trunk
# Assign the port to VLANs 100 and 200.
[PE_A-Ten-GigabitEthernet3/0/2] port trunk permit vlan 100 200
[PE_A-Ten-GigabitEthernet3/0/2] undo port trunk permit vlan 1
# Create the class A100 to match frames with CVLAN 10 and SVLAN 100.
[PE_A] traffic classifier A100
[PE_A-classifier-A100] if-match customer-vlan-id 10
[PE_A-classifier-A100] if-match service-vlan-id 100
[PE_A-classifier-A100] quit
# Configure the traffic behavior T100 to mark matching traffic with CVLAN 30.
[PE_A] traffic behavior T100
[PE_A-behavior-T100] remark customer-vlan-id 30
[PE_A-behavior-T100] quit
# Create the class A200 to match frames with CVLAN 20 and SVLAN 200.
[PE_A] traffic classifier A200
[PE_A-classifier-A200] if-match customer-vlan-id 20
[PE_A-classifier-A200] if-match service-vlan-id 200
[PE_A-classifier-A200] quit
# Configure the traffic behavior T200 to mark matching traffic with CVLAN 40.
[PE_A] traffic behavior T200
[PE_A-behavior-T200] remark customer-vlan-id 40
[PE_A-behavior-T200] quit
# Create the QoS policy vlanmapping to associate the traffic classes A100 and A200 with the traffic behaviors T100 and T200, respectively.
[PE_A] qos policy vlanmapping
[PE_A-qospolicy-vlanmapping] classifier A100 behavior T100
[PE_A-qospolicy-vlanmapping] classifier A200 behavior T200
[PE_A-qospolicy-vlanmapping] quit
# Apply the QoS policy to the outbound direction of the port.
[PE_A-Ten-GigabitEthernet3/0/2] qos apply policy vlanmapping outbound
Configuring PE B
<PE_B> system-view
[PE_B] vlan 30
[PE_B-vlan30] quit
[PE_B] vlan 40
[PE_B-vlan40] quit
[PE_B] vlan 100
[PE_B-vlan100] quit
[PE_B] vlan 200
[PE_B-vlan200] quit
[PE_B] vlan 10
[PE_B-vlan10] quit
[PE_B] vlan 20
[PE_B-vlan20] quit
# Assign the port to VLANs 100 and 200 as an untagged VLAN member.
[PE_B-Ten-GigabitEthernet3/0/1] port hybrid vlan 100 200 untagged
# Create the class A30 to match frames with CVLAN 30.
[PE_B] traffic classifier A30
[PE_B-classifier-A30] if-match customer-vlan-id 30
[PE_B-classifier-A30] quit
[PE_B] traffic behavior P100
[PE_B-behavior-P100] nest top-most vlan 100
[PE_B-behavior-P100] quit
# Create the class A40 to match frames with CVLAN 40.
[PE_B] traffic classifier A40
[PE_B-classifier-A40] if-match customer-vlan-id 40
[PE_B-classifier-A40] quit
[PE_B] traffic behavior P200
[PE_B-behavior-P200] nest top-most vlan 200
[PE_B-behavior-P200] quit
# Create the QoS policy qinq to associate the traffic classes A30 and A40 with the traffic behaviors P100 and P200, respectively.
[PE_B] qos policy qinq
[PE_B-qospolicy-qinq] classifier A30 behavior P100
[PE_B-qospolicy-qinq] classifier A40 behavior P200
[PE_B-qospolicy-qinq] quit
[PE_B-Ten-GigabitEthernet3/0/1] qos apply policy qinq inbound
3.     Configure the service provider-side port Ten-GigabitEthernet 3/0/2:
[PE_B-Ten-GigabitEthernet3/0/2] port link-type trunk
[PE_B-Ten-GigabitEthernet3/0/2] port trunk permit vlan 100 200
[PE_B-Ten-GigabitEthernet3/0/2] undo port trunk permit vlan 1
# Create the class A100 to match frames with CVLAN 30 and SVLAN 100.
[PE_B] traffic classifier A100
[PE_B-classifier-A100] if-match customer-vlan-id 30
[PE_B-classifier-A100] if-match service-vlan-id 100
[PE_B-classifier-A100] quit
# Configure the traffic behavior T100 to mark matching traffic with CVLAN 10.
[PE_B] traffic behavior T100
[PE_B-behavior-T100] remark customer-vlan-id 10
[PE_B-behavior-T100] quit
# Create the class A200 to match frames with CVLAN 40 and SVLAN 200.
[PE_B] traffic classifier A200
[PE_B-classifier-A200] if-match customer-vlan-id 40
[PE_B-classifier-A200] if-match service-vlan-id 200
[PE_B-classifier-A200] quit
# Configure the traffic behavior T200 to mark matching traffic with CVLAN 20.
[PE_B] traffic behavior T200
[PE_B-behavior-T200] remark customer-vlan-id 20
[PE_B-behavior-T200] quit
[PE_B] qos policy vlanmapping
[PE_B-qospolicy-vlanmapping] classifier A100 behavior T100
[PE_B-qospolicy-vlanmapping] classifier A200 behavior T200
[PE_B-qospolicy-vlanmapping] quit
[PE_B-Ten-GigabitEthernet3/0/2] qos apply policy vlanmapping outbound
# Set the MTU to a minimum of 1504 bytes for each port on the path of double-tagged frames. (Details not shown.)
# Configure the ports between PE A and PE B to allow frames from VLANs 100 and 200 to pass through tagged. (Details not shown.)
# Verify configuration on the customer-side ports on PE A and PE B. This example uses Ten-GigabitEthernet 3/0/1 of PE A.
 qinq enable
return
# Verify the QoS nesting configuration on the customer-side ports on PE A and PE B. This example uses Ten-GigabitEthernet 3/0/1 of PE A.
  Direction: Inbound
  Policy: qinq
   Classifier: A10
     Operator: AND
     Rule(s) :
     Behavior: P100
      Nesting:
   Classifier: A20
     Operator: AND
     Rule(s) :
      If-match customer-vlan-id 20
     Behavior: P200
      Nesting:
        Nest top-most vlan-id 200
# Verify the QoS marking configuration on the service provider-side ports on PE A and PE B. This example uses Ten-GigabitEthernet 3/0/2 of PE A.
[PE_A] display qos policy interface ten-gigabitethernet 3/0/2
Interface: Ten-GigabitEthernet3/0/2
  Direction: Outbound
  Policy: vlanmapping
   Classifier: A100
     Operator: AND
     Rule(s) :
      If-match service-vlan-id 100
     Behavior: T100
      Marking:
        Remark Customer VLAN ID 30
   Classifier: A200
     Operator: AND
     Rule(s) :
      If-match service-vlan-id 200
     Behavior: T200
      Marking:
        Remark Customer VLAN ID 40
Configuration files
·     PE A:
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
vlan 200
traffic classifier A10 operator and
traffic classifier A20 operator and
traffic classifier A100 operator and
traffic classifier A200 operator and
qos policy qinq
 qinq enable
·     PE B:
vlan 10
vlan 20
vlan 30
vlan 40
vlan 100
vlan 200
traffic classifier A30 operator and
traffic classifier A40 operator and
qos policy qinq
 qinq enable
