03-Layer 2—LAN Switching Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C S12500G-AF&S12500CR&S10500X-G&S7500X-G Switch Series Configuration Examples-R7753Pxx[R8053Pxx]-6W10003-Layer 2—LAN Switching Configuration Examples
01-Ethernet Link Aggregation Configuration Examples
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 2 link aggregation
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
·     VLAN 10 on Device A can communicate with VLAN 10 on Device B.
·     VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Figure 1 Network diagram
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
·     Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
·     Assign the aggregate interface to VLAN 10 and VLAN 20.
Hardware
Software version
S12500G-AF
Release 8053P05 and later
S12500CR
S10500X-G
Release 7753P05 and later
S7500X-G
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
·     When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.     Use the display this command in interface view to check the following attribute configurations of the port:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
b.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.     Assign the port to the aggregation group.
·     In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, use dynamic aggregation.
·     You cannot assign a port to a Layer 2 aggregation group when forcible fiber port bringup, MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1.     Configure Device A:
# Create VLAN 10, and assign port Ten-GigabitEthernet 3/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 3/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port Ten-GigabitEthernet 3/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 3/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] undo shutdown
[DeviceA-Bridge-Aggregation1] quit
¡     Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/3 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 3/0/1 to ten-gigabitethernet 3/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring Ten-GigabitEthernet3/0/1 done.
 Configuring Ten-GigabitEthernet3/0/2 done.
 Configuring Ten-GigabitEthernet3/0/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
·     Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority  Oper-Key
  XGE3/0/1(R)      S       32768     1
  XGE3/0/2         S       32768     1
  XGE3/0/3         S       32768     1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
·     Link aggregation configuration information when the dynamic aggregation mode is used:
Creation Mode: Manual
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE3/0/1            S        32768    2        1                      {ACDEF}
  XGE3/0/2            S        32768    3        1                      {ACDEF}
  XGE3/0/3            S        32768    4        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE3/0/1(R)         32768    2        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE3/0/2            32768    3        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE3/0/3            32768    4        1        0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
·     Device A:
vlan 10
interface Ten-GigabitEthernet3/0/4
 port link-mode bridge
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet3/0/5
 port access vlan 20
¡     In the static aggregation mode:
interface Bridge-Aggregation1
¡     In the dynamic aggregation mode:
interface Ten-GigabitEthernet3/0/1
interface Ten-GigabitEthernet3/0/2
interface Ten-GigabitEthernet3/0/3
·     Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Example: Configuring Layer 2 link aggregation load sharing
As shown in Figure 2, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
·     VLAN 10 on Device A can communicate with VLAN 10 on Device B. VLAN 20 on Device A can communicate with VLAN 20 on Device B.
·     The packets from VLAN 10 and VLAN 20 are load shared across the Selected ports of link aggregation group 1 by source MAC addresses.
Figure 2 Network diagram
Analysis
To enable packets from VLAN 10 to pass through aggregate interface Bridge-aggregation 1, assign the aggregate interface to VLAN 10. To enable packets from VLAN 20 to pass through aggregate interface Bridge-aggregation 2, assign the aggregate interface to VLAN 20.
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
When you configure Layer 2 load sharing, follow these restrictions and guidelines:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
Procedures
# Create VLAN 10, and assign port Ten-GigabitEthernet 3/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 3/0/5
# Create VLAN 20, and assign port Ten-GigabitEthernet 3/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 3/0/6
# Assign ports Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to aggregation group 1.
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet3/0/1] quit
[DeviceA] interface ten-gigabitethernet 3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2] port link-aggregation group 1
[DeviceA-Ten-GigabitEthernet3/0/2] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 1 to VLAN 10.
[DeviceA-Bridge-Aggregation1] port access vlan 10
# Create Layer 2 aggregate interface Bridge-aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] quit
# Assign ports Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4 to aggregation group 2.
[DeviceA] interface ten-gigabitethernet 3/0/3
[DeviceA-Ten-GigabitEthernet3/0/3] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet3/0/3] quit
[DeviceA] interface ten-gigabitethernet 3/0/4
[DeviceA-Ten-GigabitEthernet3/0/4] port link-aggregation group 2
[DeviceA-Ten-GigabitEthernet3/0/4] quit
# Assign Layer 2 aggregate interface Bridge-aggregation 2 to VLAN 20.
[DeviceA-Bridge-Aggregation2] port access vlan 20
Configuring Ten-GigabitEthernet3/0/4 done.
# Set the global link-aggregation load share mode to source MAC address.
[DeviceA] link-aggregation global load-sharing mode source-mac
# Display the information about Selected ports in link aggregation groups on Device A.
Port Status: S -- Selected, U -- Unselected , I -- Individual
  XGE3/0/2         S       32768     1
Aggregation Interface: Bridge-Aggregation2
  XGE3/0/3(R)      S       32768     2
  XGE3/0/4         S       32768     2
·     Link aggregation groups 1 and 2 are both Layer 2 static aggregation groups.
·     Each aggregation group has two Selected ports for forwarding traffic.
# Display the link aggregation load sharing mode globally.
[DeviceA]display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:
0 (default)
Link-aggregation load-sharing offset:
0 (default)
Link-aggregation load-sharing seed:
0x0 (default)
Tunneled traffic load-sharing mode:
Link-aggregation load-sharing mode:
  source-mac address
The output shows that link aggregation load share packets based on source MAC addresses globally.
Configuration files
·     Device A:
vlan 10
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet3/0/6
 port access vlan 10
 port access vlan 10
 port access vlan 10
 port access vlan 10
interface Bridge-Aggregation2
 port access vlan 20
 port access vlan 20
 port access vlan 20
·     Device B:
Example: Configuring Layer 3 link aggregation
On the network as shown in Figure 3, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 3 Network diagram
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡     Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] undo shutdown
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
  XGE3/0/1         S       32768    1
  XGE3/0/2         S       32768    1
  XGE3/0/3         S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
  XGE3/0/1(R)         S        32768    2        1                      {ACDEF}
Remote:
  XGE3/0/1            32768    2        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE3/0/2            32768    3        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE3/0/3            32768    4        1        0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
·     Device A:
interface route-aggregation1
 Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation load sharing
On the network as shown in Figure 4, perform the following tasks:
·     Configure Layer 3 static aggregation groups 1 and 2 on Device A and Device B.
·     Set the global load sharing mode of link aggregation to source IP address.
Figure 4 Network diagram
Hardware
Software version
S12500G-AF
S12500CR
S10500X-G
S7500X-G
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2
# Assign Layer 3 Ethernet interfaces Ten-GigabitEthernet 3/0/3 and Ten-GigabitEthernet 3/0/4 to aggregation group 2.
[DeviceA] interface range ten-gigabitethernet 3/0/3 ten-gigabitethernet 3/0/4
[DeviceA-if-range] port link-aggregation group 2
# Set the global load sharing mode of link aggregation to source IP address.
[DeviceA] link-aggregation global load-sharing mode source-ip
# Display detailed information about all aggregation groups on Device A.
  XGE3/0/2         S       32768    1
Aggregate Interface: Route-Aggregation2
  XGE3/0/4         S       32768    2
The output shows that:
·     Link aggregation groups 1 and 2 are both load-shared Layer 3 static aggregation groups.
·     Each aggregation group contains two Selected ports.
# Display the global link aggregation load sharing mode.
[DeviceA] display link-aggregation load-sharing mode
0 (default)
0 (default)
0x0 (default)
  source-ip address
The output shows that link aggregation load shares packets based on source IP addresses globally.
Configuration files
·     Device A:
interface Route-Aggregation1
interface Route-Aggregation2
 ip address 192.168.2.1 255.255.255.0
·     Device B:
