- 03-Layer 2—LAN Switching Configuration Examples
- 01-Ethernet Link Aggregation Configuration Examples
- 02-M-LAG Configuration Examples
- 03-MAC Address Table Configuration Examples
- 04-MVRP Configuration Examples
- 05-Port Isolation Configuration Examples
- 06-S-MLAG Configuration Examples
- 07-Spanning Tree Configuration Examples
- 08-VLAN Configuration Examples
- 09-VLAN Tagging Configuration Examples
| 03-MAC Address Table Configuration Examples | 86.73 KB |
Example: Configuring static MAC address entries
Example: Configuring MAC address move suppression
Configuring Device B and Device C
Introduction
This document provides MAC address table configuration examples.
This document assumes that you have basic knowledge of the MAC address table.
As shown in Figure 1, for secure communication between users in VLAN 100 and the server, perform the following tasks:
· Assign Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3 to VLAN 100.
· Add a static MAC address entry on Device to bind the server MAC address to Ten-GigabitEthernet 3/0/2.
Hardware |
Software version |
S12500G-AF |
Release 7753P05 and later |
S12500CR |
S10500X-G |
S7500X-G |
Procedures
# Create VLAN 100, and assign Ten-GigabitEthernet 3/0/2 to VLAN 100.
[Device] vlan 100
[Device-vlan100] quit
[Device] interface ten-gigabitethernet 3/0/2
[Device-Ten-GigabitEthernet3/0/2] port access vlan 100
[Device-Ten-GigabitEthernet3/0/2] quit
# Configure Ten-GigabitEthernet 3/0/3 (port connected to the LAN switch) as a trunk port, and assign the port to VLAN 100.
[Device] interface ten-gigabitethernet 3/0/3
[Device-Ten-GigabitEthernet3/0/3] port link-type trunk
[Device-Ten-GigabitEthernet3/0/3] port trunk permit vlan 100
[Device-Ten-GigabitEthernet3/0/3] quit
# Add a static entry for MAC address 0000-fc00-a249 on Ten-GigabitEthernet 3/0/2 that belongs to VLAN 100.
[Device] mac-address static 0000-fc00-a249 interface ten-gigabitethernet 3/0/2 vlan 100
# Verify that any 10.0.0.0/24 host in VLAN 100 can communicate with the server. (Details not shown.)
# Verify that the static MAC address entry has been added.
[Device] display mac-address
MAC Address VLAN ID State Port/NickName Aging
0000-fc00-a249 100 Static XGE3/0/2 N
7425-8a02-4d00 100 Learned XGE3/0/3 Y
Configuration files
sysname Device
vlan 1
vlan 100
interface Ten-GigabitEthernet3/0/2
port link-mode bridge
mac-address static 0000-fc00-a249 vlan 100
interface Ten-GigabitEthernet3/0/3
port trunk permit vlan 1 100
As shown in Figure 2, Devices A, B, and C form a loop because of cable misconnection, and spanning tree protocols are not enabled on the devices. As a result, MAC addresses are frequently moves among Devices A, B, and C. To deal with loop-triggered MAC flapping, perform the following tasks:
· Display MAC address move records to locate the Layer 2 loop.
· Configure MAC address move suppression on Device A to eliminate the Layer 2 loop.
Analysis
To meet the network requirements, you must perform the following tasks:
· For Devices A, B, and C to communicate with each other, assign all inter-connected ports to VLAN 100.
· Configure MAC address move suppression on one or more ports of Device A.
· To monitor the port status change of Device A, enable the log monitoring of the current terminal feature.
· For loop detection, create VLAN-interface 100 and assign an IP address to the interface on each device.
· To display MAC address move records, ping Device B from Device A.
Hardware |
Software version |
S12500G-AF |
Release 8053P05 and later |
S12500CR |
S10500X-G |
S7500X-G |
Procedures
Configuring Device A
# Enable the monitoring of logs on the current terminal.
<DeviceA> terminal monitor
<DeviceA> terminal debugging
# Create VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
# Configure Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 as trunk ports, and assign the ports to VLAN 100.
[DeviceA] interface range ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 100
[DeviceA-if-range] quit
# Set the suppression interval to 300 seconds. A suppressed port will automatically come up after 300 seconds.
[DeviceA] mac-address notification mac-move suppression interval 300
# Set the suppression threshold to 0. A port will be shut down when the system detects a MAC address move on the port within a MAC move detection interval (1 minute by default).
[DeviceA] mac-address notification mac-move suppression threshold 0
# Enable MAC address move suppression on Ten-GigabitEthernet 3/0/1.
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] mac-address notification mac-move suppression
[DeviceA-Ten-GigabitEthernet3/0/1] quit
# Create VLAN-interface 100, and assign an IP address to the interface.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] ip address 10.0.0.1 24
[DeviceA-Vlan-interface100] quit
1. Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB-vlan100] quit
[DeviceB] interface range ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 100
[DeviceB-if-range] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] ip address 10.0.0.2 24
[DeviceB-Vlan-interface100] quit
2. Configure Device C in the same way Device B was configured. (Details not shown.)
# Ping Device B from Device A. (Details not shown.)
# Verify that Ten-GigabitEthernet 3/0/1 on Device A is shut down.
[DeviceA] %Dec 11 09:51:06:309 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the Ten-GigabitEthernet3/0/1 changed to down.
%Dec 11 09:51:06:323 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface Ten-GigabitEthernet3/0/1 changed to down.
# Verify that Ten-GigabitEthernet 3/0/1 is shut down because a MAC address move is detected.
[DeviceA] display interface ten-gigabitethernet 3/0/1
Current state: mac-address moving down
Line protocol state: DOWN
# Verify that Ten-GigabitEthernet 3/0/1 comes up automatically after 300 seconds.
[DeviceA] %Dec 11 09:56:07:002 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the Ten-GigabitEthernet3/0/1 changed to up.
%Dec 11 09:56:07:004 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface Ten-GigabitEthernet3/0/1 changed to up.
# Verify that the MAC address of Device B's VLAN-interface 100 moves between Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2. You can manually shut down either port to eliminate the loop.
[DeviceA] display mac-address mac-move
MAC address VLAN Current port Source port Last time Times
0000-fc00-6506 100 XGE3/0/2 XGE3/0/1 2014-12-11 09:29:48 3
0000-fc00-6506 100 XGE3/0/1 XGE3/0/2 2014-12-11 09:51:03 4
--- 2 MAC address moving records found ---
Configuration files
· Device A:
sysname DeviceA
vlan 1
vlan 100
interface Vlan-interface100
ip address 10.0.0.1 255.255.255.0
· Device B:
sysname DeviceB
vlan 1
vlan 100
ip address 10.0.0.2 255.255.255.0
· Device C:
sysname DeviceC
vlan 1
vlan 100
ip address 10.0.0.3 255.255.255.0
