- 06-Layer 2 - LAN Switching
- 01-EtherLike-MIB
- 02-HH3C-LAG-MIB
- 03-HH3C-LLDP-EXT-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-LswVLAN-MIB
- 08-HH3C-MAC-INFORMATION-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-PVST-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-IEEE8021-CFM-MIB
- 16-IEEE8021-CFM-V2-MIB
- 17-IEEE8023-LAG-MIB
- 18-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 19-LLDP-EXT-DOT1-MIB
- 20-LLDP-EXT-DOT1-V2-MIB
- 21-LLDP-EXT-DOT3-MIB
- 22-LLDP-EXT-DOT3-V2-MIB
- 23-LLDP-EXT-MED-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-P-BRIDGE-MIB
- 28-Q-BRIDGE-MIB
27-P-BRIDGE-MIB | 38.65 KB |
P-BRIDGE-MIB
About this MIB
Use this table to manage the priorities and multicast filtering defined in IEEE 802.1D-1998.
MIB file name
Rfc4363-pbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2().dod1dBridge(17).pBridgeMIB(6)
Scalar objects
OID of this table is: 1.3.6.1.2.1.17.6.1.1
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1dDeviceCapabilities (1.3.6.1.2.1.17.6.1.1.1) |
read-only |
BITS |
dot1dExtendedFilteringServices(0), dot1dTrafficClasses(1), dot1qStaticEntryIndividualPort(2), dot1qIVLCapable(3), dot1qSVLCapable(4), dot1qHybridCapable(5), dot1qConfigurablePvidTagging(6), dot1dLocalVlanCapable(7) |
Device capabilities. |
As per the MIB. |
dot1dTrafficClassesEnabled (1.3.6.1.2.1.17.6.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Whether traffic classification is supported. |
Read-only. |
dot1dGmrpStatus (1.3.6.1.2.1.17.6.1.1.3) |
read-write |
EnabledStatus |
enabled(1), disabled(2) |
GMRP enabling state. |
Not supported |
Tabular objects
dot1dPortCapabilitiesTable
OID of this table is: 1.3.6.1.2.1.17.6.1.1.4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
(1.3.6.1.2.1.17.6.1.1.4.1.1) |
read-only |
BITS |
dot1qDot1qTagging(0) , dot1qConfigurableAcceptableFrameTypes(1) , dot1qIngressFiltering(2) |
Port capabilities. |
As per the MIB. |
