06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10006-Layer 2 - LAN Switching
25-LLDP-V2-MIB
25-LLDP-V2-MIB 126.04 KB
LLDP-V2-MIB
About this MIB
This MIB is compliant with IEEE 802.1AB-2009. It defines MIB objects for the following LLDP information:
·     LLDP configuration.
·     LLDP statistics.
·     LLDP local system information.
·     LLDP neighbor system information.
·     802.1 extension.
·     DCBX extension.
·     802.3 extension.
MIB file name
lldp-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13)
Scalar objects
lldpV2MessageTxInterval
Object (OID)
Access
Value range
Implementation
lldpV2MessageTxInterval (1.3.111.2.802.1.1.13.1.1.1)
read-write
Unsigned32
Unsigned32 (5..32768)
LLDP frame transmission interval.
As per the MIB.
lldpV2MessageTxHoldMultiplier
Object (OID)
Access
Value range
Implementation
lldpV2MessageTxHoldMultiplier (1.3.111.2.802.1.1.13.1.1.2)
read-write
Unsigned32
Unsigned32 (2..10)
TTL multiplier.
As per the MIB.
lldpV2ReinitDelay
Object (OID)
Access
Value range
Implementation
lldpV2ReinitDelay (1.3.111.2.802.1.1.13.1.1.3)
read-write
Unsigned32
Unsigned32 (1..10)
LLDP reinitialization delay.
As per the MIB.
lldpV2NotificationInterval
Object (OID)
Access
Value range
Implementation
lldpV2NotificationInterval (1.3.111.2.802.1.1.13.1.1.4)
read-write
Unsigned32
Unsigned32 (5..3600)
Trap transmission interval.
As per the MIB.
lldpV2TxCreditMax
Object (OID)
Access
Value range
Implementation
lldpV2TxCreditMax (1.3.111.2.802.1.1.13.1.1.5)
read-write
Unsigned32
Unsigned32 (1..100)
Token bucket size for sending LLDP frames.
As per the MIB.
lldpV2MessageFastTx
Object (OID)
Access
Value range
Implementation
lldpV2MessageFastTx (1.3.111.2.802.1.1.13.1.1.6)
read-write
Unsigned32
Unsigned32 (1..3600)
Fast LLDP frame transmission interval.
As per the MIB.
lldpV2TxFastInit
Object (OID)
Access
Value range
Implementation
lldpV2TxFastInit (1.3.111.2.802.1.1.13.1.1.7)
read-write
Unsigned32
Unsigned32 (1..8)
Number of LLDP frames sent each time fast LLDP frame transmission is triggered.
As per the MIB.
lldpV2StatsRemTablesLastChangeTime
Object (OID)
Access
Value range
Implementation
lldpV2StatsRemTablesLastChangeTime (1.3.111.2.802.1.1.13.1.2.1)
read-only
TimeStamp
Standard MIB values.
Time when LLDP information about a neighboring device was last updated.
As per the MIB.
lldpV2StatsRemTablesInserts
Object (OID)
Access
Value range
Implementation
lldpV2StatsRemTablesInserts (1.3.111.2.802.1.1.13.1.2.2)
read-only
ZeroBasedCounter32
Number of neighbors added by LLDP.
As per the MIB.
lldpV2StatsRemTablesDeletes
Object (OID)
Access
Value range
Implementation
lldpV2StatsRemTablesDeletes (1.3.111.2.802.1.1.13.1.2.3)
read-only
ZeroBasedCounter32
Number of neighbors deleted by LLDP.
As per the MIB.
lldpV2StatsRemTablesDrops
Object (OID)
Access
Value range
Implementation
lldpV2StatsRemTablesDrops (1.3.111.2.802.1.1.13.1.2.4)
read-only
ZeroBasedCounter32
Number of neighbors discarded by LLDP.
As per the MIB.
lldpV2StatsRemTablesAgeouts
Object (OID)
Access
Value range
Implementation
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5)
read-only
ZeroBasedCounter32
Neighbor ageout count.
As per the MIB.
lldpV2LocChassisIdSubtype
Object (OID)
Access
Value range
Implementation
lldpV2LocChassisIdSubtype (1.3.111.2.802.1.1.13.1.3.1)
read-only
LldpV2ChassisIdSubtype
Local chassis ID subtype.
As per the MIB.
lldpV2LocChassisId
Object (OID)
Access
Value range
Implementation
lldpV2LocChassisId (1.3.111.2.802.1.1.13.1.3.2)
read-only
LldpV2ChassisId
Local chassis ID.
As per the MIB.
lldpV2LocSysName
Object (OID)
Access
Value range
Implementation
lldpV2LocSysName (1.3.111.2.802.1.1.13.1.3.3)
read-only
SnmpAdminString
OCTET STRING (0..255)
Local system name.
As per the MIB.
lldpV2LocSysDesc
Object (OID)
Access
Value range
Implementation
lldpV2LocSysDesc (1.3.111.2.802.1.1.13.1.3.4)
read-only
SnmpAdminString
Local system description.
As per the MIB.
lldpV2LocSysCapSupported
Object (OID)
Access
Value range
Implementation
lldpV2LocSysCapSupported (1.3.111.2.802.1.1.13.1.3.5)
read-only
LldpV2SystemCapabilitiesMap
Capabilities supported by the local system.
As per the MIB.
lldpV2LocSysCapEnabled
Object (OID)
Access
Value range
Implementation
lldpV2LocSysCapEnabled (1.3.111.2.802.1.1.13.1.3.6)
read-only
Capabilities enabled on the local system.
As per the MIB.
Tabular objects
lldpV2PortConfigTable
About this table
Use this table to configure LLDP on a port.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The table OID is 1.3.111.2.802.1.1.13.1.1.8.
Object (OID)
Access
Value range
Implementation
lldpV2PortConfigIfIndex (1.3.111.2.802.1.1.13.1.1.8.1.1)
not-accessible
InterfaceIndex
Port number.
As per the MIB.
lldpV2PortConfigDestAddressIndex  (1.3.111.2.802.1.1.13.1.1.8.1.2)
not-accessible
LldpV2DestAddressTableIndex
Agent index.
As per the MIB.
lldpV2PortConfigAdminStatus (1.3.111.2.802.1.1.13.1.1.8.1.3)
read-write
INTEGER
txOnly(1)
rxOnly(2)
txAndRx(3)
disabled(4)
LLDP operating mode.
Default: Disabled for the following agents:
·     The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 Ethernet interface.
·     The nearest customer bridge agent and nearest non-TPMR bridge agent on a Layer 2 or Layer 3 aggregate interface.
·     The nearest non-TPMR bridge agent on a Layer 3 Ethernet interface.
lldpV2PortConfigNotificationEnable (1.3.111.2.802.1.1.13.1.1.8.1.4)
read-write
TruthValue
Trapping status.
As per the MIB.
lldpV2PortConfigTLVsTxEnable (1.3.111.2.802.1.1.13.1.1.8.1.5)
read-write
BITS
BITS {
portDesc(0),
sysName(1),
sysDesc(2),
sysCap(3)
Optional TLVs that the port can send.
Default: 0xf0 for the following agents:
·     The nearest bridge agent and nearest customer bridge agent on a Layer 2 or Layer 3 Ethernet interface.
·     The nearest customer bridge agent on a Layer 2 aggregate interface.
The default is 0x40 for the nearest customer bridge agent on a Layer 3 aggregate interface or S-channel interface.
lldpV2DestAddressTable
About this table
Use this table to obtain the destination MAC address of LLDP frames.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpV2AddressTableIndex.
The table OID is 1.3.111.2.802.1.1.13.1.1.9.
Object (OID)
Access
Value range
Implementation
lldpV2AddressTableIndex (1.3.111.2.802.1.1.13.1.1.9.1.1)
not-accessible
Index used to identify the destination MAC address associated with this entry.
As per the MIB.
lldpV2DestMacAddress (1.3.111.2.802.1.1.13.1.1.9.1.2)
read-only
MacAddress
Destination MAC address.
As per the MIB.
lldpV2ManAddrConfigTxPortsTable
About this table
Use this table to configure a management address for agents on interfaces.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are lldpV2ManAddrConfigIfIndex, lldpV2ManAddrConfigDestAddressIndex, lldpV2ManAddrConfigLocManAddrSubtype, lldpV2ManAddrConfigLocManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.1.10.
Object (OID)
Access
Value range
Implementation
lldpV2ManAddrConfigIfIndex (1.3.111.2.802.1.1.13.1.1.10.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
lldpV2ManAddrConfigDestAddressIndex (1.3.111.2.802.1.1.13.1.1.10.1.2)
not-accessible
Agent ID.
As per the MIB.
lldpV2ManAddrConfigLocManAddrSubtype (1.3.111.2.802.1.1.13.1.1.10.1.3)
not-accessible
AddressFamilyNumbers
Management address subtype.
As per the MIB.
lldpV2ManAddrConfigLocManAddr (1.3.111.2.802.1.1.13.1.1.10.1.4)
not-accessible
LldpV2ManAddress
Management address string.
The subtypes of the management address TLV are IPv4 and IPv6.
lldpV2ManAddrConfigTxEnable (1.3.111.2.802.1.1.13.1.1.10.1.5)
read-create
TruthValue
Whether the management address TLV is enabled.
·     The nearest customer bridge agent on a Layer 2 or Layer 3 aggregate interface.
lldpV2ManAddrConfigRowStatus (1.3.111.2.802.1.1.13.1.1.10.1.6)
read-create
RowStatus
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
lldpV2StatsTxPortTable
About this table
Use this table to obtain outgoing LLDP packet statistics about agents.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2StatsTxIfIndex and lldpV2StatsTxDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.2.6.
Object (OID)
Access
Value range
Implementation
lldpV2StatsTxIfIndex (1.3.111.2.802.1.1.13.1.2.6.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
lldpV2StatsTxDestMACAddress (1.3.111.2.802.1.1.13.1.2.6.1.2)
not-accessible
Agent ID.
As per the MIB.
lldpV2StatsTxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.6.1.3)
read-only
Counter32
Total outgoing frame count.
As per the MIB.
lldpV2StatsTxLLDPDULengthErrors (1.3.111.2.802.1.1.13.1.2.6.1.4)
read-only
Counter32
Frame length error count.
As per the MIB.
lldpV2StatsRxPortTable
About this table
Use this table to obtain incoming LLDP packet statistics about agents.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2StatsRxDestIfIndex and lldpV2StatsRxDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.2.7.
Object (OID)
Access
Value range
Implementation
lldpV2StatsRxDestIfIndex (1.3.111.2.802.1.1.13.1.2.7.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
lldpV2StatsRxDestMACAddress(1.3.111.2.802.1.1.13.1.2.7.1.2)
not-accessible
Agent ID.
As per the MIB.
lldpV2StatsRxPortFramesDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.3)
read-only
Counter32
Discarded incoming frame count.
As per the MIB.
lldpV2StatsRxPortFramesErrors(1.3.111.2.802.1.1.13.1.2.7.1.4)
read-only
Counter32
Error incoming frame count.
As per the MIB.
lldpV2StatsRxPortFramesTotal (1.3.111.2.802.1.1.13.1.2.7.1.5)
read-only
Counter32
Total incoming frame count.
As per the MIB.
lldpV2StatsRxPortTLVsDiscardedTotal (1.3.111.2.802.1.1.13.1.2.7.1.6)
read-only
Counter32
Discarded incoming TLV count.
As per the MIB.
lldpV2StatsRxPortTLVsUnrecognizedTotal (1.3.111.2.802.1.1.13.1.2.7.1.7)
read-only
Counter32
Unrecognized incoming TLV count.
As per the MIB.
lldpV2StatsRxPortAgeoutsTotal (1.3.111.2.802.1.1.13.1.2.7.1.8)
read-only
ZeroBasedCounter32
As per the MIB.
lldpV2LocPortTable
About this table
Use this table to obtain LLDP information about local ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.3.7.
Object (OID)
Access
Value range
Implementation
lldpV2LocPortIfIndex (1.3.111.2.802.1.1.13.1.3.7.1.1)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
lldpV2LocPortIdSubtype (1.3.111.2.802.1.1.13.1.3.7.1.2)
read-only
LldpV2PortIdSubtype
Port ID subtype.
As per the MIB.
lldpV2LocPortId (1.3.111.2.802.1.1.13.1.3.7.1.3)
read-only
LldpV2PortId
Port ID.
As per the MIB.
lldpV2LocPortDesc (1.3.111.2.802.1.1.13.1.3.7.1.4)
read-only
SnmpAdminString
Port description.
As per the MIB.
lldpV2LocManAddrTable
About this table
Use this table to obtain local management address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocManAddrSubtype and lldpV2LocManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.3.8.
Object (OID)
Access
Value range
Implementation
lldpV2LocManAddrSubtype (1.3.111.2.802.1.1.13.1.3.8.1.1)
not-accessible
As per the MIB.
lldpV2LocManAddr (1.3.111.2.802.1.1.13.1.3.8.1.2)
not-accessible
LldpV2ManAddress
Management address.
lldpV2LocManAddrLen (1.3.111.2.802.1.1.13.1.3.8.1.3)
read-only
Unsigned32
Management address length.
As per the MIB.
lldpV2LocManAddrIfSubtype (1.3.111.2.802.1.1.13.1.3.8.1.4)
read-only
LldpV2ManAddrIfSubtype
The enumeration value that identifies the port numbering method used for defining the port number associated with the local system.
As per the MIB.
lldpV2LocManAddrIfId (1.3.111.2.802.1.1.13.1.3.8.1.5)
read-only
Unsigned32
Interface index.
As per the MIB.
lldpV2LocManAddrOID (1.3.111.2.802.1.1.13.1.3.8.1.6)
read-only
OBJECT IDENTIFIER
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the local system agent.
Not supported
lldpV2RemTable
About this table
Use this table to obtain neighbor configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.4.1
Object (OID)
Access
Value range
Implementation
lldpV2RemTimeMark (1.3.111.2.802.1.1.13.1.4.1.1.1)
not-accessible
TimeFilter
Time mark for a neighbor.
The time mark is the time when this object is created or the remote system is updated.
You can use the time mark to search for remote system records.
lldpV2RemLocalIfIndex (1.3.111.2.802.1.1.13.1.4.1.1.2)
not-accessible
InterfaceIndex
Local interface receiving the neighbor information.
As per the MIB.
lldpV2RemLocalDestMACAddress (1.3.111.2.802.1.1.13.1.4.1.1.3)
not-accessible
Neighbor agent ID.
As per the MIB.
lldpV2RemIndex (1.3.111.2.802.1.1.13.1.4.1.1.4)
not-accessible
Unsigned32
Unsigned32 (1..2147483647)
Neighbor index.
As per the MIB.
lldpV2RemChassisIdSubtype (1.3.111.2.802.1.1.13.1.4.1.1.5)
read-only
Neighbor chassis ID subtype.
As per the MIB.
lldpV2RemChassisId (1.3.111.2.802.1.1.13.1.4.1.1.6)
read-only
LldpV2ChassisId
Neighbor chassis ID.
As per the MIB.
lldpV2RemPortIdSubtype (1.3.111.2.802.1.1.13.1.4.1.1.7)
read-only
LldpV2PortIdSubtype
Neighbor port ID subtype.
As per the MIB.
lldpV2RemPortId (1.3.111.2.802.1.1.13.1.4.1.1.8)
read-only
LldpV2PortId
Neighbor port ID.
As per the MIB.
lldpV2RemPortDesc (1.3.111.2.802.1.1.13.1.4.1.1.9)
read-only
SnmpAdminString
Neighbor port description.
As per the MIB.
lldpV2RemSysName (1.3.111.2.802.1.1.13.1.4.1.1.10)
read-only
SnmpAdminString
Neighbor system name.
As per the MIB.
lldpV2RemSysDesc (1.3.111.2.802.1.1.13.1.4.1.1.11)
read-only
SnmpAdminString
Neighbor system description.
As per the MIB.
lldpV2RemSysCapSupported (1.3.111.2.802.1.1.13.1.4.1.1.12)
read-only
Capabilities supported by the neighbor system.
As per the MIB.
lldpV2RemSysCapEnabled (1.3.111.2.802.1.1.13.1.4.1.1.13)
read-only
Capabilities enabled on the neighbor system.
As per the MIB.
lldpV2RemRemoteChanges (1.3.111.2.802.1.1.13.1.4.1.1.14)
read-only
TruthValue
Whether there are changes in the remote system's MIB.
As per the MIB.
lldpV2RemTooManyNeighbors (1.3.111.2.802.1.1.13.1.4.1.1.15)
read-only
TruthValue
Whether there are too many neighbors.
As per the MIB.
lldpV2RemManAddrTable
About this table
Use this table to obtain neighbor management address information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpV2RemManAddrSubtype, and lldpV2RemManAddr.
The table OID is 1.3.111.2.802.1.1.13.1.4.2.
Object (OID)
Access
Value range
Implementation
lldpV2RemManAddrSubtype (1.3.111.2.802.1.1.13.1.4.2.1.1)
not-accessible
As per the MIB.
lldpV2RemManAddr (1.3.111.2.802.1.1.13.1.4.2.1.2)
not-accessible
LldpV2ManAddress
OCTET STRING (1..31)
Management address.
As per the MIB.
lldpV2RemManAddrIfSubtype (1.3.111.2.802.1.1.13.1.4.2.1.3)
read-only
The enumeration value that identifies the interface numbering method used for defining the interface number associated with the remote system.
As per the MIB.
lldpV2RemManAddrIfId (1.3.111.2.802.1.1.13.1.4.2.1.4)
read-only
Unsigned32
Index of the interface associated with the management address.
As per the MIB.
lldpV2RemManAddrOID (1.3.111.2.802.1.1.13.1.4.2.1.5)
read-only
OBJECT IDENTIFIER
The OID value used to identify the type of hardware component or protocol entity associated with the management address advertised by the remote system agent.
Not supported
lldpV2RemUnknownTLVTable
About this table
Use this table to display the unrecognized TLVs received from neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2RemUnknownTLVType.
The table OID is 1.3.111.2.802.1.1.13.1.4.3.
Object (OID)
Access
Value range
Implementation
lldpV2RemUnknownTLVType (1.3.111.2.802.1.1.13.1.4.3.1.1)
not-accessible
Unsigned32
Unsigned32 (9..126)
TLV type.
As per the MIB.
lldpV2RemUnknownTLVInfo (1.3.111.2.802.1.1.13.1.4.3.1.2)
read-only
OCTET STRING
OCTET STRING (0..511)
TLV string.
As per the MIB.
lldpV2RemOrgDefInfoTable
About this table
Use this table to display the neighbor organizationally defined information not recognized by the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpV2RemOrgDefInfoOUI, lldpV2RemOrgDefInfoSubtype, and lldpV2RemOrgDefInfoIndex.
The table OID is 1.3.111.2.802.1.1.13.1.4.4.
Object (OID)
Access
Value range
Implementation
lldpV2RemOrgDefInfoOUI (1.3.111.2.802.1.1.13.1.4.4.1.1)
not-accessible
OCTET STRING
OCTET STRING (3)
Organizationally Unique Identifier (OUI).
As per the MIB.
lldpV2RemOrgDefInfoSubtype (1.3.111.2.802.1.1.13.1.4.4.1.2)
not-accessible
Unsigned32
Unsigned32 (1..255)
Subtype of the organizationally defined information.
As per the MIB.
lldpV2RemOrgDefInfoIndex (1.3.111.2.802.1.1.13.1.4.4.1.3)
not-accessible
Unsigned32
Index of the organizationally defined information.
As per the MIB.
lldpV2RemOrgDefInfo (1.3.111.2.802.1.1.13.1.4.4.1.4)
read-only
OCTET STRING
OCTET STRING (0..507)
Organizationally defined information.
As per the MIB.
Notifications
lldpV2RemTablesChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.111.2.802.1.1.13.0.0.1
Neighbor events.
Informational
OFF
This notification is generated when the value of the lldpV2StatsRemTableLastChangeTime object changes.
You can set the notification transmission interval by configuring the lldpV2NotificationInterval object.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to false(2).
Objects
OID (object name)
Index
Value range
Neighbor creation.
No
ZeroBasedCounter32
Neighbor deletion.
No
ZeroBasedCounter32
Neighbor discard.
No
ZeroBasedCounter32
Neighbor ageout.
No
ZeroBasedCounter32
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Verify that the topology changes are as expected.
If you cannot resolve the issue, contact H3C Support.
