06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10006-Layer 2 - LAN Switching
16-IEEE8021-CFM-V2-MIB
16-IEEE8021-CFM-V2-MIB 59.04 KB
IEEE8021-CFM-V2-MIB
About this MIB
This document describes the IEEE8021-CFM-V2-MIB. This document includes the MIB tree structure description, non-table child object description, tabular object description, leaf object description, and trap definitions. This document is for the use of network administrators, device developers, testers, documentation staff, and maintenance staff.
MIB file name
Ieee8021-cfm-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbered-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021CfmV2Mib(7)
Tabular objects
ieee8021CfmMaCompTable
About this table
Use this table to configure the MA component table.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ieee8021CfmMaComponentId, dot1CfmMdIndex, and dot1CfmMaIndex.
OID of this table is: 1.3.111.2.802.1.1.8.1.6.4
Object (OID)
Access
Value range
Implementation
ieee8021CfmMaComponentId (1.3.111.2.802.1.1.8.1.6.4.1.1)
not-accessible
IEEE8021PbbComponentIdentifier
Standard MIB values.
MA component ID.
The value is fixed at 1.
ieee8021CfmMaCompPrimarySelectorType (1.3.111.2.802.1.1.8.1.6.4.1.2)
read-create
IEEE8021ServiceSelectorValueOrNone
vlanId(1),
isid(2),
tesid(3),
segid(4)
Service selector type.
In the current software version, only the value vlanId(1) is supported.
ieee8021CfmMaCompPrimarySelectorOrNone (1.3.111.2.802.1.1.8.1.6.4.1.3)
read-create
SelectorOrNone
Service Selector identifier to which the MP is attached.
This object cannot be modified after being created.
ieee8021CfmMaCompMhfCreation (1.3.111.2.802.1.1.8.1.6.4.1.4)
read-create
INTEGER
defMHFnone (1),
defMHFdefault (2),
defMHFexplicit (3),
defMHFdefer (4)
Indicates whether the management entity can create MHFs (MIP Half Function) for this MA.
As per the MIB.
ieee8021CfmMaCompIdPermission (1.3.111.2.802.1.1.8.1.6.4.1.5)
read-create
Dot1agCfmIdPermission
sendIdNone (1),
sendIdChassis (2),
sendIdManage (3),
sendIdChassisManage (4),
sendIdDefer (5)
Enumerated value indicating what, if anything, is to be included in the Sender ID TLV.
In the current software version, only sendIdNone (1) and sendIdDefer (5) are supported.
ieee8021CfmMaCompNumberOfVids (1.3.111.2.802.1.1.8.1.6.4.1.6)
read-only
Unsigned32
Number of VIDs associated with the MA.
The object can only be read and the value is fixed at 1.
ieee8021CfmMaCompRowStatus (1.3.111.2.802.1.1.8.1.6.4.1.7)
read-create
RowStatus
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6)
Row status.
Available values are active(1), createAndGo(4), and destroy(6).
