06-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10006-Layer 2 - LAN Switching
09-HH3C-MLAG-MIB
09-HH3C-MLAG-MIB 175.69 KB
Table of Contents
HH3C-MLAG-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cMLagSystemMac· 1
hh3cMLagSystemPriority· 1
hh3cMLagSystemNumber 1
hh3cMLagRestoreDelay· 2
hh3cMLagAutoRecoveryReloadDelay· 2
hh3cMLagRoleLocalRolePriority· 2
hh3cMLagRolePeerRolePriority· 2
hh3cMLagRoleLocalBridgeMac· 2
hh3cMLagRolePeerBridgeMac· 3
hh3cMLagRoleLocalConfiguredRole· 3
hh3cMLagRolePeerConfiguredRole· 3
hh3cMLagRoleLocalEffectiveRole· 3
hh3cMLagRolePeerEffectiveRole· 3
hh3cMLagKeepaliveDestIpv4· 4
hh3cMLagKeepaliveSourceIpv4· 4
hh3cMLagKeepaliveDestIpv6· 4
hh3cMLagKeepaliveSourceIpv6· 4
hh3cMLagKeepaliveUdpPort 4
hh3cMLagKeepaliveInterval 5
hh3cMLagKeepaliveTimeout 5
hh3cMLagKeepaliveHoldTime· 5
hh3cMLagKeepaliveLinkStatus· 5
hh3cMLagVrf 5
hh3cMLagConsistencyType· 6
hh3cMLagGroupIdForNotify· 6
hh3cMLagNotSelectedReason· 6
hh3cMLagKeepAliveDownReason· 6
hh3cMLagMadDownReason· 6
hh3cMLagOldRole· 6
hh3cMLagNewRole· 7
hh3cMLagRoleChangeReason· 7
Tabular objects· 7
hh3cMLagPeerLinkTable· 7
hh3cMLagPortTable· 8
hh3cMLagAllPortTable· 8
Notifications· 9
hh3cMLagGlobalCheckConsistency· 9
hh3cMLagGlobalCheckInConsistency· 10
hh3cMLagIfCheckConsistency· 10
hh3cMLagIfCheckInConsistency· 11
hh3cMLagPortGlobalDown· 12
hh3cMLagPortGlobalUp· 12
hh3cMLagPortSelected· 13
hh3cMLagPortNoSelected· 13
hh3cMLagPortPeerNoSelected· 14
hh3cMLagPortPeerSelected· 15
hh3cMLagPeerLinkUp· 15
hh3cMLagPeerLinkDown· 16
hh3cMLagKeepaliveDown· 16
hh3cMLagKeepaliveUp· 17
hh3cMLagDeviceMadDown· 17
hh3cMLagDeviceMadRecovery· 18
hh3cMLagDeviceRoleChange· 18
HH3C-MLAG-MIB
About this MIB
Multichassis Link Aggregation Group (M-LAG) virtualizes two physical devices into one system through multichassis link aggregation to provide node redundancy in addition to link redundancy.
HH3C-MLAG-MIB is a private MIB for managing M-LAG from an NMS. This MIB offers following functions: 1. Obtain and modify M-LAG system settings such as the M-LAG system MAC address, priority, and number. 2. Obtain and modify M-LAG keepalive settings. 3. Obtain information about and configure peer-link interfaces and M-LAG interfaces.
MIB file name
hh3c-mlag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cMLag(176)
Scalar objects
hh3cMLagSystemMac
Object (OID)
Access
Value range
Implementation
hh3cMLagSystemMac (1.3.6.1.4.1.25506.2.176.1.1.1)
read-write
MacAddress
OCTET STRING(6)
M-LAG system MAC address.
Default value
0-0-0-0-0-0.
Object (OID)
Access
Value range
Implementation
hh3cMLagSystemPriority (1.3.6.1.4.1.25506.2.176.1.1.2)
read-write
Integer32
Integer32 (0..65535)
M-LAG system priority.
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system.
Object (OID)
Access
Value range
Implementation
hh3cMLagSystemNumber (1.3.6.1.4.1.25506.2.176.1.1.3)
read-write
Integer32
Integer32 (0..2)
M-LAG system number.
Default value:
0.
Object (OID)
Access
Value range
Implementation
hh3cMLagRestoreDelay (1.3.6.1.4.1.25506.2.176.1.1.4)
read-write
Integer32
Integer32 (1..3600)
Data restoration interval.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagAutoRecoveryReloadDelay (1.3.6.1.4.1.25506.2.176.1.1.5)
read-write
Integer32
Integer32 (0|240..3600)
Reload delay for M-LAG system auto-recovery.
A value of 0 indicates that M-LAG system auto-recovery is disabled.
Object (OID)
Access
Value range
Implementation
hh3cMLagRoleLocalRolePriority (1.3.6.1.4.1.25506.2.176.1.2.1)
read-write
Integer32
The role priority of the local M-LAG member device.
The smaller the priority value, the higher the priority.
Object (OID)
Access
Value range
Implementation
hh3cMLagRolePeerRolePriority (1.3.6.1.4.1.25506.2.176.1.2.2)
read-only
Integer32
Role priority of the peer M-LAG member device.
Object (OID)
Access
Value range
Implementation
hh3cMLagRoleLocalBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.3)
read-only
MacAddress
OCTET STRING(6)
Bridge MAC address of  the local M-LAG member device.
Default  value: 0-0-0-0-0-0
Object (OID)
Access
Value range
Implementation
hh3cMLagRolePeerBridgeMac (1.3.6.1.4.1.25506.2.176.1.2.4)
read-only
MacAddress
OCTET STRING(6)
Bridge MAC address of the peer M-LAG member device.
Object (OID)
Access
Value range
Implementation
hh3cMLagRoleLocalConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.5)
read-only
INTEGER
none(0),
primary(1),
secondary(2)
Specified role for the local M-LAG member device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagRolePeerConfiguredRole (1.3.6.1.4.1.25506.2.176.1.2.6)
read-only
INTEGER
none(0),
primary(1),
secondary(2)
Specified role for the peer M-LAG member device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagRoleLocalEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.7)
read-only
INTEGER
none(0),
primary(1),
secondary(2)
Effective role for the local M-LAG member device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagRolePeerEffectiveRole (1.3.6.1.4.1.25506.2.176.1.2.8)
read-only
INTEGER
none(0),
primary(1),
secondary(2)
Effective role for the peer M-LAG member device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveDestIpv4 (1.3.6.1.4.1.25506.2.176.1.3.1)
read-write
InetAddressIPv4
OCTET STRING(4)
Destination IP address of keepalive packets.
Default value:
0.0.0.0.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveSourceIpv4 (1.3.6.1.4.1.25506.2.176.1.3.2)
read-write
InetAddressIPv4
OCTET STRING(4)
Source IP address of keepalive packets.
Default value:
0.0.0.0. Configured with the destination IP address of keepalive packets.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveDestIpv6 (1.3.6.1.4.1.25506.2.176.1.3.3)
read-write
InetAddressIPv6
OCTET STRING(16)
Destination IPv6 address of keepalive packets.
Default value:
00::00.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveSourceIpv6 (1.3.6.1.4.1.25506.2.176.1.3.4)
read-write
InetAddressIPv6
OCTET STRING(16)
Source IPv6 address of keepalive packets.
Default value:
0.0:: 0.0.  Configured with the destination IPv6 address of keepalive packets.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveUdpPort (1.3.6.1.4.1.25506.2.176.1.3.5)
read-write
Integer32
Integer32 (1..65535)
Destination UDP port of keepalive packets.
The destination UDP port is also deleted when the keepalive source and destination IP addresses are deleted.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveInterval (1.3.6.1.4.1.25506.2.176.1.3.6)
read-write
Integer32
Integer32 (100..10000)
M-LAG keepalive interval.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveTimeout (1.3.6.1.4.1.25506.2.176.1.3.7)
read-write
Integer32
Integer32 (3..20)
M-LAG keepalive timeout timer.
The local M-LAG keepalive timeout timer must be at least two times the M-LAG keepalive interval of the peer.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveHoldTime (1.3.6.1.4.1.25506.2.176.1.3.8)
read-write
Integer32
Integer32 (3..10)
Keepalive hold timer.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepaliveLinkStatus (1.3.6.1.4.1.25506.2.176.1.3.9)
read-only
INTEGER
unknown(1),
up(2),
down(3)
Keepalive link status.
As per the MIB.
hh3cMLagVrf
Object (OID)
Access
Value range
Implementation
hh3cMLagVrf (1.3.6.1.4.1.25506.2.176.1.3.10)
read-write
OCTET STRING
OCTET STRING(0..31)
VPN instance name.
If the M-LAG member device exists in a public network, the VPN instance name length is 0.
Object (OID)
Access
Value range
Implementation
1.3.6.1.4.1.25506.2.176.2.1.1 (hh3cMLagConsistencyType)
accessible-for-notify
Integer32
type1(1)
type2(2)
Configuration consistency check.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagGroupIdForNotify(1.3.6.1.4.1.25506.2.176.2.1.2
Integer32
Integer32 (1..1024)
M-LAG group ID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagNotSelectedReason (1.3.6.1.4.1.25506.2.176.2.1.3)
OCTET STRING
OCTET STRING(0..255)
Reason why no selected member port exists for the M-LAG interface.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagKeepAliveDownReason(1.3.6.1.4.1.25506.2.176.2.1.4
OCTET STRING
Reason why the keepalive link goes down.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagMadDownReason(1.3.6.1.4.1.25506.2.176.2.1.5
OCTET STRING
Reason why the device is placed in M-LAG MAD DOWN state.
As per the MIB.
hh3cMLagOldRole
Object (OID)
Access
Value range
Implementation
hh3cMLagOldRole(1.3.6.1.4.1.25506.2.176.2.1.6
INTEGER
none(0),
primary(1),
secondary(2)
Previous role for the device.
As per the MIB.
hh3cMLagNewRole
Object (OID)
Access
Value range
Implementation
hh3cMLagNewRole(1.3.6.1.4.1.25506.2.176.2.1.7
INTEGER
none(0),
primary(1),
secondary(2)
New role for the device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cMLagRoleChangeReason(1.3.6.1.4.1.25506.2.176.2.1.8
OCTET STRING
Reason for the device role switching.
As per the MIB.
Tabular objects
About this table
Use this table to obtain and configure parameters for peer-link interfaces.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
Columns
The table index is hh3cMLagPeerLinkNumber.
Object (OID)
Access
Value range
Implementation
hh3cMLagPeerLinkNumber (1.3.6.1.4.1.25506.2.176.1.4.1.1.1)
not-accessible
Integer32
Integer32 (1..2)
Peer-link interface number.
The peer-link interface number can only be 1.
hh3cMLagPeerLinkIfIndex (1.3.6.1.4.1.25506.2.176.1.4.1.1.2)
read-write
InterfaceIndex
Integer32 (1..2147483647)
Index of the aggregate interface acting as the peer-link interface.
As per the MIB.
hh3cMLagPeerLinkRowStatus (1.3.6.1.4.1.25506.2.176.1.4.1.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only destroy(6).
hh3cMLagPortTable
About this table
Use this table to configure and obtain parameters for M-LAG interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
Columns
The table index is hh3cMLagGroupId.
Object (OID)
Access
Value range
Implementation
hh3cMLagGroupId (1.3.6.1.4.1.25506.2.176.1.4.2.1.1)
not-accessible
Integer32
Integer32 (1..1024)
M-LAG group ID.
As per the MIB.
hh3cMLagPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.2.1.2)
read-write
InterfaceIndex
Index of the aggregate interface acting as the M-LAG interface.
As per the MIB.
hh3cMLagPortRowStatus (1.3.6.1.4.1.25506.2.176.1.4.2.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
About this table
Use this table to obtain and configure selected member port information, DRCP state, and the short DRCP timeout timer for peer-link interfaces and M-LAG interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMLagAllPortIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cMLagAllPortIfIndex (1.3.6.1.4.1.25506.2.176.1.4.3.1.1)
not-accessible
InterfaceIndex
Interface index
As per the MIB.
hh3cMLagPortDrcpIsShortPeriod (1.3.6.1.4.1.25506.2.176.1.4.3.1.2)
read-write
TruthValue
true(1),
false(2)
Whether the short DRCP timeout timer is enabled.
As per the MIB.
hh3cMLagPortPortStatus (1.3.6.1.4.1.25506.2.176.1.4.3.1.3)
read-only
INTEGER
up(1), down(2)
Interface status
As per the MIB.
hh3cMLagPortLocalDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.4)
read-only
OCTET STRING
OCTET STRING(1)
DRCP status on the local end.
As per the MIB.
hh3cMLagPortPeerDRCPState (1.3.6.1.4.1.25506.2.176.1.4.3.1.5)
read-only
OCTET STRING
OCTET STRING(1)
DRCP status on the peer end.
As per the MIB.
hh3cMLagPortLocalMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.6)
read-only
PortList
Member list of the local aggregate interface.
As per the MIB.
hh3cMLagPortPeerMemberList (1.3.6.1.4.1.25506.2.176.1.4.3.1.7)
read-only
PortList
Member list of the peer aggregate interface.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.176.2.0.1
No inconsistency is detected during the global consistency check.
Informational
OFF
This notification is generated if the consistency check result for global M-LAG settings is consistent.
Status control
This notification cannot be disabled.
Objects
OID
Index
Value range
Consistency check type.
No
Integer32
type1(1)
type2(2)
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.2
Inconsistency is detected during the global consistency check.
Informational
OFF
This notification is generated if the consistency check result for global M-LAG settings is inconsistent.
Status control
Objects
OID
Index
Value range
No
Integer32
type1(1)
type2(2)
Recommended action
To resolve the issue: 1. If the global consistency check for the type 1 configuration is inconsistent, use the display m-lag consistency command to view configuration information on the M-LAG member devices, and modify their configuration to ensure consistency.
2. If the global consistency check for the type 2 configuration is inconsistent, modify the configuration on the M-LAG member devices to ensure consistency.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.3
Consistency is detected during the consistency check on M-LAG interfaces.
Informational
OFF
This notification is generated if the consistency check result for M-LAG interfaces is consistent.
Status control
Objects
OID
Index
Value range
No
Integer32
type1(1)
type2(2)
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.4
Inconsistency is detected during the consistency check on M-LAG interfaces.
Informational
OFF
This notification is generated if the consistency check result for M-LAG interfaces is inconsistent.
Status control
Objects
OID
Index
Value range
No
Integer32
type1(1)
type2(2)
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
Recommended action
To resolve the issue: 1. If the consistency check on M-LAG interfaces for the type 1 configuration is inconsistent, use the display m-lag consistency command to view configuration information on the M-LAG member devices, and modify their configuration to ensure consistency.
2. If the consistency check on M-LAG interfaces for the type 2 configuration is inconsistent, modify the configuration on the M-LAG member devices to ensure consistency.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.5
M-LAG group goes down.
Informational
OFF
This notification is generated when all member ports of the M-LAG interfaces in the same M-LAG group become unselected.
Status control
Objects
OID
Index
Value range
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
Recommended action
To resolve the issue, verify that the M-LAG system settings are configured and consistent, such as the M-LAG system MAC address, priority, and number.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.6
M-LAG group comes up.
Informational
OFF
 This notification is generated when member ports of the M-LAG interfaces in the same M-LAG group become selected.
Status control
Objects
OID
Index
Value range
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.7
A local M-LAG interface has selected member ports.
Informational
OFF
 This notification is generated when member ports of a local M-LAG interface become selected.
Status control
Objects
OID
Index
Value range
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.8
All member ports of a local M-LAG interface become unselected.
Informational
OFF
This notification is generated when all member ports of a local M-LAG interface become unselected.
Status control
Objects
OID
Index
Value range
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
(hh3cMLagPortNotSelectedReason)
No
OCTET STRING
Recommended action
To resolve the issue, check settings on member ports of the aggregation group and the cable connection status.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.9
All member ports of a peer M-LAG interface become unselected.
Informational
OFF
This notification is generated when all member ports of a peer M-LAG interface become unselected.
Status control
Objects
OID
Index
Value range
1.3.6.1.4.1.25506.2.176.2.1.9
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
Recommended action
To resolve the issue, check settings on member ports of the peer aggregation group and the cable connection status.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.10
A peer M-LAG interface has selected member ports.
Informational
OFF
This notification is generated when member ports of a peer M-LAG interface become selected.
Status control
Objects
OID
Index
Value range
M-LAG group ID.
No
Integer32
Integer32 (1..1024)
Recommended action
hh3cMLagPeerLinkUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.11
The peer-link interface comes up.
Informational
OFF
 This notification is generated if DRCPDUs can be sent and received correctly between the M-LAG member devices.
Status control
Objects
OID
Index
Value range
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.12
The peer-link interface goes down.
Informational
OFF
 This notification is generated when the peer-link interface goes down.
Status control
Objects
OID
Index
Value range
6.1.4.1.2.1.2.2.1.1
(ifIndex)
Interface index
No
Integer32
6.1.4.1.2.1.2.2.1.2
(ifDescr)
Interface name
Yes
OCTET STRING
Recommended action
To resolve the issue: 1. Verify that the M-LAG system settings are configured and consistent, such as the M-LAG system MAC address, priority, number, authentication password, and sequence number check.
2. Check the state of Layer 2 aggregate interface configured as the peer-link interface.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.13
The keepalive link goes down.
Informational
OFF
 This notification is generated when the keepalive link goes down.
Status control
Objects
OID
Index
Value range
No
OCTET STRING
Recommended action
To resolve the issue: 1. Check the device role.
2. Verify that the source and destination IP addresses of keepalive packets are consistent between the M-LAG member devices.
3. Check the state of the Layer 3 link used for keepalive detection.
hh3cMLagKeepaliveUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.14
The keepalive link comes up.
Informational
OFF
This notification is generated if keepalive packets can be sent and received correctly between the M-LAG member devices.
Status control
Objects
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.15
The device is placed in M-LAG MAD DOWN state.
Informational
OFF
 This notification is generated when service interfaces are shut down by M-LAG MAD.
Status control
Objects
OID
Index
Value range
No
OCTET STRING
Recommended action
To resolve the issue, check settings on both ends of the peer link.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.16
The device brings up service interfaces that are placed in M-LAG MAD DOWN state.
Informational
OFF
 This notification is generated when the device brings up service interfaces that are placed in M-LAG MAD DOWN state.
Status control
Objects
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.176.2.0.17
The M-LAG member device role is changed.
Informational
OFF
This notification is generated when the M-LAG member device role is changed.
Status control
Objects
OID
Index
Value range
hh3cMLagOldRole
No
INTEGER
none(0),
primary(1),
secondary(2)
hh3cMLagNewRole
No
INTEGER
none(0),
primary(1),
secondary(2)
Reason for the device role change.
No
OCTET STRING
Recommended action
