- 06-Layer 2 - LAN Switching
- 01-EtherLike-MIB
- 02-HH3C-LAG-MIB
- 03-HH3C-LLDP-EXT-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-LswVLAN-MIB
- 08-HH3C-MAC-INFORMATION-MIB
- 09-HH3C-MLAG-MIB
- 10-HH3C-PROTOCOL-VLAN-MIB
- 11-HH3C-PVST-MIB
- 12-HH3C-SUBNET-VLAN-MIB
- 13-HH3C-VMAP-MIB
- 14-HH3C-VOICE-VLAN-MIB
- 15-IEEE8021-CFM-MIB
- 16-IEEE8021-CFM-V2-MIB
- 17-IEEE8023-LAG-MIB
- 18-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 19-LLDP-EXT-DOT1-MIB
- 20-LLDP-EXT-DOT1-V2-MIB
- 21-LLDP-EXT-DOT3-MIB
- 22-LLDP-EXT-DOT3-V2-MIB
- 23-LLDP-EXT-MED-MIB
- 24-LLDP-MIB
- 25-LLDP-V2-MIB
- 26-MAU-MIB
- 27-P-BRIDGE-MIB
- 28-Q-BRIDGE-MIB
26-MAU-MIB | 68.64 KB |
MAU-MIB
About this MIB
This MIB is defined in RFC 3636 and contains interface media attachment unit (MAU) information.
The document might not be updated in time. For the latest detailed informatin, see the offical document at https://www.iana.org/assignments/ianamau-mib/ianamau-mib.
MIB file name
rfc3636-mau.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).snmpDot3MauMgt(26)
Tabular objects
ifMauTable
About this table
Use this table to obtain the interface MAU state.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifMauIfIndex and ifMauIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauIfIndex (1.3.6.1.2.1.26.2.1.1.1) |
read-only |
InterfaceIndex |
Standard MIB values. |
Index of the interface in this entry. |
As per the MIB. |
ifMauIndex (1.3.6.1.2.1.26.2.1.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Interface MAU index. |
As per the MIB. |
ifMauType (1.3.6.1.2.1.26.2.1.1.3) |
read-only |
AutonomousType |
Interface MAU operation type. The value (1) indicates autonegotiation. The value (2) indicates autonegotiation is not enabled or applied on an interface. |
As per the MIB. |
ifMauStatus (1.3.6.1.2.1.26.2.1.1.4) |
read-write |
INTEGER |
other(1), unknown(2), operational(3), standby(4), shutdown(5), reset(6) |
Current state of the interface MAU. |
The object can only be read. |
ifMauMediaAvailable (1.3.6.1.2.1.26.2.1.1.5) |
read-only |
INTEGER |
other(1), unknown(2), available(3), notAvailable(4), remoteFault(5), invalidSignal(6), remoteJabber(7), remoteLinkLoss(8), remoteTest(9), offline(10), autoNegError(11), pmdLinkFault(12), wisFrameLoss(13), wisSignalLoss(14), pcsLinkFault(15), excessiveBER(16), dxsLinkFault(17), pxsLinkFault(18) |
Current availability state of the interface MAU. |
As per the MIB. |
ifMauMediaAvailableStateExits (1.3.6.1.2.1.26.2.1.1.6) |
read-only |
Counter32 |
Number of switchovers from state available(3) to another state on an interface MAU. |
As per the MIB. |
ifMauJabberState (1.3.6.1.2.1.26.2.1.1.7) |
read-only |
INTEGER |
other(1), unknown(2), noJabber(3), jabbering(4) |
Jabber state of an interface MAU. |
As per the MIB. |
ifMauJabberingStateEnters (1.3.6.1.2.1.26.2.1.1.8) |
read-only |
Counter32 |
Number of the jabber state switchovers to the jabbering(4) state on an interface MAU. |
As per the MIB. |
ifMauFalseCarriers (1.3.6.1.2.1.26.2.1.1.9) |
read-only |
Counter32 |
Number of false carrier events on an interface MAU. |
As per the MIB. |
ifMauTypeList (1.3.6.1.2.1.26.2.1.1.10) |
read-only |
Integer32 |
Interface MAU type list (as a best practice, do not use this object). |
As per the MIB. |
ifMauDefaultType (1.3.6.1.2.1.26.2.1.1.11) |
read-write |
AutonomousType |
Default interface MAU type. |
ifMauAutoNegSupported (1.3.6.1.2.1.26.2.1.1.12) |
read-only |
TruthValue |
true(1), false(2) |
Whether an interface MAU supports autonegotiation. |
As per the MIB. |
ifMauTypeListBits (1.3.6.1.2.1.26.2.1.1.13) |
read-only |
BITS |
bOther(0), bAUI(1), b10base5(2), bFoirl(3), b10base2(4), b10baseT(5), b10baseFP(6), b10baseFB(7), b10baseFL(8), b10broad36(9), b10baseTHD(10), b10baseTFD(11), b10baseFLHD(12), b10baseFLFD(13), b100baseT4(14), b100baseTXHD(15), b100baseTXFD(16), b100baseFXHD(17), b100baseFXFD(18), b100baseT2HD(19), b100baseT2FD(20), b1000baseXHD(21), b1000baseXFD(22), b1000baseLXHD(23), b1000baseLXFD(24), b1000baseSXHD(25), b1000baseSXFD(26), b1000baseCXHD(27), b1000baseCXFD(28), b1000baseTHD(29), b1000baseTFD(30), b10GbaseX(31), b10GbaseLX4(32), b10GbaseR(33), b10GbaseER(34), b10GbaseLR(35), b10GbaseSR(36), b10GbaseW(37), b10GbaseEW(38), b10GbaseLW(39), b10GbaseSW(40), -- new since RFC 3636 b10GbaseCX4(41), b2BaseTL(42), b10PassTS(43), b100BaseBX10D(44), b100BaseBX10U(45), b100BaseLX10(46), b1000BaseBX10D(47), b1000BaseBX10U(48), b1000BaseLX10(49), b1000BasePX10D(50), b1000BasePX10U(51), b1000BasePX20D(52), b1000BasePX20U(53), b10GbaseT(54), b10GbaseLRM(55), b1000baseKX(56), b10GbaseKX4(57), b10GbaseKR(58), b10G1GbasePRXD1(59), b10G1GbasePRXD2(60), b10G1GbasePRXD3(61), b10G1GbasePRXU1(62), b10G1GbasePRXU2(63), b10G1GbasePRXU3(64), b10GbasePRD1(65), b10GbasePRD2(66), b10GbasePRD3(67), b10GbasePRU1(68), b10GbasePRU3(69), b40GbaseKR4(70), b40GbaseCR4(71), b40GbaseSR4(72), b40GbaseFR(73), b40GbaseLR4(74), b100GbaseCR10(75), b100GbaseSR10(76), b100GbaseLR4(77), b100GbaseER4(78), b1000baseT1(79), b1000basePX30D(80), b1000basePX30U(81), b1000basePX40D(82), b1000basePX40U(83), b10G1GbasePRXD4(84), b10G1GbasePRXU4(85), b10GbasePRD4(86), b10GbasePRU4(87), b25GbaseCR(88), b25GbaseCRS(89), b25GbaseKR(90), b25GbaseKRS(91), b25GbaseR(92), b25GbaseSR(93), b25GbaseT(94), b40GbaseER4(95), b40GbaseR(96), b40GbaseT(97), b100GbaseCR4(98), b100GbaseKR4(99), b100GbaseKP4(100), b100GbaseR(101), b100GbaseSR4(102), b2p5GbaseT(103), b5GbaseT(104), b100baseT1(105), b1000baseRHA(106), b1000baseRHB(107), b1000baseRHC(108), b2p5GbaseKX(109), b2p5GbaseX(110), b5GbaseKR(111), b5GbaseR(112), b10GpassXR(113), b25GbaseLR(114), b25GbaseER(115), b50GbaseR(116), b50GbaseCR(117), b50GbaseKR(118), b50GbaseSR(119), b50GbaseFR(120), b50GbaseLR(121), b50GbaseER(122), b100GbaseCR2(123), b100GbaseKR2(124), b100GbaseSR2(125), b100GbaseDR(126), b200GbaseR(127), b200GbaseDR4(128), b200GbaseFR4(129), b200GbaseLR4(130), b200GbaseCR4(131), b200GbaseKR4(132), b200GbaseSR4(133), b200GbaseER4(134), b400GbaseR(135), b400GbaseSR16(136), b400GbaseDR4(137), b400GbaseFR8(138), b400GbaseLR8(139), b400GbaseER8(140), b10baseT1L(141), b10baseT1SHD(142), b10baseT1SMD(143), b10baseT1SFD(144), |
Set of possible IEEE 802.3 types that the MAU could be. |
As per the MIB. |
ifMauHCFalseCarriers (1.3.6.1.2.1.26.2.1.1.14) |
read-only |
Counter64 |
Number of false carrier events on an interface MAU. A 64-bit counter is used to avoid counter rollover. |
As per the MIB. |
ifJackTable
About this table
Use this table to obtain the external jack information of an interface MAU.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifMauIfIndex, ifMauIndex, and ifJackIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifJackIndex (1.3.6.1.2.1.26.2.2.1.1) |
not-accessible |
Integer32 |
Index of the external jack of an interface MAU. |
As per the MIB. |
ifJackType (1.3.6.1.2.1.26.2.2.1.2) |
read-only |
JackType |
Type of the external jack of an interface MAU. |
As per the MIB. |
ifMauAutoNegTable
About this table
Use this table to obtain the autonegotiation information of an interface MAU.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauAutoNegAdminStatus (1.3.6.1.2.1.26.5.1.1.1) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Autonegotiation enabling state of an interface MAU. |
ifMauAutoNegRemoteSignaling (1.3.6.1.2.1.26.5.1.1.2) |
read-only |
INTEGER |
detected(1), notdetected(2) |
Whether the remote end of the link is using autonegotiation signaling. |
As per the MIB. |
ifMauAutoNegConfig (1.3.6.1.2.1.26.5.1.1.4) |
read-only |
INTEGER |
other(1), configuring(2), complete(3), disabled(4), parallelDetectFail(5) |
Current autonegotiation state of an interface MAU. |
As per the MIB. |
ifMauAutoNegCapability (1.3.6.1.2.1.26.5.1.1.5) |
read-only |
Integer32 |
Autonegotiation type list of an interface MAU. |
As per the MIB. |
ifMauAutoNegCapAdvertised (1.3.6.1.2.1.26.5.1.1.6) |
read-write |
Integer32 |
Autonegotiation type list advertised by an interface MAU. |
ifMauAutoNegCapReceived (1.3.6.1.2.1.26.5.1.1.7) |
read-only |
Integer32 |
Received autonegotiation type list from a remote autonegotiation entity. |
As per the MIB. |
ifMauAutoNegRestart (1.3.6.1.2.1.26.5.1.1.8) |
read-write |
INTEGER |
restart(1), norestart(2) |
Whether autonegotiation will be restarted on an interface MAU. |
ifMauAutoNegCapabilityBits (1.3.6.1.2.1.26.5.1.1.9) |
read-only |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bfdxPause(8), bfdxAPause(9), bfdxSPause(10), bfdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15), b10GbaseT(16), b1000baseKX(17), b10GbaseKX4(18), b10GbaseKR(19), b40GbaseKR4(20), b40GbaseCR4(21), b100GbaseCR10(22), b1000baseT1(23), b25GbaseRS(24), b25GbaseR(25), bRSFEC25Greq(26), bBaseFEC25Greq(27), b25GbaseT(28), b40GbaseT(29), b100GbaseCR4(30), b100GbaseKR4(31), b100GbaseKP4(32), bForceMS(33), b2p5GbaseT(34), b5GBaseT(35), b2p5GbaseKX(36), b5GbaseKR(37), b50GbaseR(38), b100GbaseR2(39), b200GbaseR4(40), b10baseT1L(41), b10baseT1S(42), |
Set of capabilities of the local autonegotiation entity. |
As per the MIB. |
ifMauAutoNegCapAdvertisedBits (1.3.6.1.2.1.26.5.1.1.10) |
read-write |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bFdxPause(8), bFdxAPause(9), bFdxSPause(10), bFdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15), b10GbaseT(16), b1000baseKX(17), b10GbaseKX4(18), b10GbaseKR(19), b40GbaseKR4(20), b40GbaseCR4(21), b100GbaseCR10(22), b1000baseT1(23), b25GbaseRS(24), b25GbaseR(25), bRSFEC25Greq(26), bBaseFEC25Greq(27), b25GbaseT(28), b40GbaseT(29), b100GbaseCR4(30), b100GbaseKR4(31), b100GbaseKP4(32), bForceMS(33), b2p5GbaseT(34), b5GBaseT(35), b2p5GbaseKX(36), b5GbaseKR(37), b50GbaseR(38), b100GbaseR2(39), b200GbaseR4(40), b10baseT1L(41), b10baseT1S(42), |
Set of capabilities advertised by the local autonegotiation entity. |
ifMauAutoNegCapReceivedBits (1.3.6.1.2.1.26.5.1.1.11) |
read-only |
BITS |
Set of capabilities received from the remote autonegotiation entity. |
As per the MIB. |
ifMauAutoNegRemoteFaultAdvertised (1.3.6.1.2.1.26.5.1.1.12) |
read-write |
INTEGER |
noError(1), offline(2), linkFailure(3), autoNegError(4) |
Local fault indications that this MAU has detected and will advertise at the next autonegotiation interaction. |
ifMauAutoNegRemoteFaultReceived (1.3.6.1.2.1.26.5.1.1.13) |
read-only |
INTEGER |
Fault indications received by the local end from the far end. |
As per the MIB. |
